Staro 22.04.2013., 17:26   #1
eXodus_1
Lokacija: split
Postovi: 46
(riješeno) Problem hdd ili windows.neznam ni sam:)
Ovakva je situacija. Prijatelj mi je dao svoj komp da vidim zasto mu ne moze bootat se. Problem je bio 'windows could not start because the following file is missing or corrupt :system32\drivers\pci.sys.
Win xp je bio
Pokusao sam nakon toga stavit windows 7 cd da formatiram hdd i instaliram novi windows ali nije islo...
Onda sam mislim gresku napravio,a to je da sam spojio njegov hdd na svoj komp i formatirao ga.
Nakon toga sam vratio ga u njegovu kutiuu i probao instalirat win7 al sad mi izbacuje bootmgr error,press ctrl alt delete...probqo par puta uvik isto...
Ima li sugestija sto da napravim? Da formatitam hdd na svom kompu ponovo?ima li neka posebna vrsta formatiranja hdd da na njega mogu stavit windows...svaka pomoc dobro dosla.
eXodus_1 je offline   Reply With Quote
Staro 22.04.2013., 17:53   #2
Postovi: 16,831
Stric kaže:
Fixes for BOOTMGR Errors
1. Restart the PC. The BOOTMGR error could be a fluke.
2. Check your optical drives, USB ports, and floppy drives for media. Often times, the "BOOTMGR is Missing" error will appear if your PC is trying to boot to a non-bootable disc, external drive, or floppy disk.
Note: If you find that this is the cause of your issue and it's happening regularly, you might want to consider changing the boot order in BIOS so the hard drive is listed as the first boot device.
3. Reseat all internal data and power cables. BOOTMGR error messages could be caused by unplugged, loose, or malfunctioning power or controller cables.
Try replacing the PATA or SATA cable if you suspect it might be faulty.
4. Perform a Startup Repair of Windows. This type of installation should replace any missing or corrupt files, including BOOTMGR.
Even though a Startup Repair is a common solution for BOOTMGR problems, don't worry if it doesn't fix your problem. Just continue troubleshooting - something will work.
5. Write a new partition boot sector to the Windows system partition to correct any possible corruption, configuration problem, or other damage.
The partition boot sector is an important piece in the boot process so if there's any issue with it, you'll see problems like "BOOTMGR is Missing" errors.
6. Rebuild the Boot Configuration Data (BCD). Similar to the partition boot sector, a corrupted or incorrectly configured BCD could cause BOOTMGR error messages.
Important: The following troubleshooting steps are much less likely to help fix your BOOTMGR problem. If you've skipped any of the above ideas then you may have overlooked a very likely solution to this problem!
7. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including BOOTMGR errors.
Note: There's usually an Auto setting in BIOS for hard disk and optical drive configurations which is usually a safe bet if you're not sure what to do.
8. Update your motherboard's BIOS. An outdated BIOS version can sometimes cause the "BOOTMGR is Missing" error.
9. Perform a clean installation of Windows. This type of installation will completely remove Windows from your PC and install it again from scratch. While this will almost certainly resolve any BOOTMGR errors, it's a time consuming process due to the fact that all of your data must be backed up and then later restored.
If you can't gain access to your files to back them up, please understand that you will lose them all if you continue with a clean installation of Windows!
10. Replace the hard drive and then install a new copy of Windows. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
Staro 22.04.2013., 18:06   #3
Brzi Picek
Brzi Picek's Avatar
Datum registracije: Nov 2011
Lokacija: Ri,De,Čk,Zg itd
Postovi: 500
napravi si cd ili usb bootabilni s odličnim Partition Wizard (Mini tool poznatije)
wajpaj cijeli i popravi MBR
probaj testirati surface pa instaliraj
ako neče onda zaboravi na njega
Brzi Picek je offline   Reply With Quote
Staro 22.04.2013., 19:03   #4
eXodus_1
Lokacija: split
Postovi: 46
Znaci spojit taj formatirani hdd(ntfs) na njegov komp, na svome napravit butabilni (mini tool)cd i stavit u njegov komp i dalje llsve ovo navedeno...probat cu pa javim ishod...
Staro 22.04.2013., 19:53   #5
Brzi Picek
Brzi Picek's Avatar
Postovi: 500
ma spoji ga na svojem , nije bitno
samo ga wajpaj
windows 7 ionako sam praticionira disk, netreba se raditi particije osim ako ne želiš neke posebne particije raditi
Staro 23.04.2013., 16:33   #6
OuttaControl
OuttaControl's Avatar
Lokacija: Dalmacija
Postovi: 5,832
najbolje ti je da skines hiren cd, on ima u sebi mnoštvo alata, pa za ubuduće da imaš, ima i za fix svakakvih errora odma na home screenu
btw nevaljal ram zna često radit čudne greške, neće tu bootmgr error, ali pri instalaciji zna izbacivat neobične greške(xp zna pisat da nemože pročitat file sa cda, 7. zna 0x0000008c ja mislim ili takve)
OuttaControl je online   Reply With Quote
Staro 23.04.2013., 20:27   #7
Forace
Lokacija: Petrinja
Postovi: 1,604
Kao što i OuttaControl kaže: prvo hiren, a onda sve ostalo. Znači hiren boot cd spržit i fino testirat HDD proizvođačevim alatom i memoriju memtestom.
Ovisno o memoriji i sumljivom ponašanju računala obično biram između ta 2 koji će se prvi vrtit, al na kraju testiram i memoriju i hdd :P.
I to obavezno kad mi dođe računalo koje odjednom počne čudno ponašat.
Tek nakon što potvrdim da su memorija i hdd u redu ite reinstalacija OS.a ili testiranje iz istog .
Forace je offline   Reply With Quote
Staro 23.04.2013., 22:21   #8
eXodus_1
Lokacija: split
Postovi: 46
Rijesija. Prvo sa. HDD low level format napravija, pa proba instalaciju XPa i izbaciva je error upravo koji se spominje dva posta prije...malo googla i nasa da ram jebe i na blef izvuka jedan ram i instalacija normalno prosla. Izmedu ostalog napravija sam hiren bootable cd za ubuduce. Hvala svima na savjetima i pomoci.
