Staro 07.05.2010., 12:59   #1
Razer
Razer's Avatar
Postovi: 11,642
Top10 3DMark 11 @ PCE
Single card rezultati
  1. elina08 - P13640 | HD 7950 @ 1328/1606 MHz, zrak | i7 3770K @ 4.9 GHz, zrak | ASRock Z77 Extreme 6 |
  2. njuskalo1983 - P13047 | HD 6990 @ 1007/1454 MHz | i7 2600k @ 5.0 GHz, zrak | Asus Maximus IV Gene-Z |
  3. sodom - P7683, ORB | HD 5970 @ 920/1201 MHz, zrak | i5 760 @ 4.0 GHz, zrak | Gigabyte P55-UD5 |
  4. Srecko_83 - P7584 | GTX 580 @ 928/1149/1856 MHz, zrak | i7 2600K @ 5.0 GHz, voda | Gigabyte Z68X-UD7-B3 |
  5. Rush xxx - P6679, ORB | HD 6950 @ 1000/1449 MHz, zrak | i7 920 @ 4.3 GHz, zrak | Gigabyte EX58-UD5 |
  6. Wolverine - P6388, ORB | GTX 580 @ 825/1005/1650 MHz, zrak | i7 940 @ 3.8 GHz, zrak | Gigabyte X58-UD4P |
  7. HCS - P6027 | HD 6950 @ 1010/1500 MHz, zrak | Phenom X6 1090T @ 4.0 GHz, zrak | ASRock 890GX Extreme3 |
  8. Razer - P5988 | Gigabyte GTX 560 Ti SOC @ 1070/1200 MHz, zrak | i7 3960X @ 5.15 GHz, zrak | Asus Ramapage IV Extreme |
  9. DraŽ - P5925 | GTX 570 @ 880/1050 MHz, zrak | Phenom X6 1075T @ 4.2 GHz, zrak | Asus M4A89GTD PRO |
  10. d4rk_ch1ld - P5817 | HD 5870 @ 1035/1325 MHz, zrak | i5 750 @ 4.55 GHz, voda | ASUS P7P55D EVO |
Multi card rezultati
  1. zagy1984 - P14881 | Dual MSI GTX 670 Power Edition OC @ 1098/1502 MHz, zrak | i7 3770K @ 3.9 GHz | Asus P8Z68 Deluxe/Gen3 |
  2. Blue_Fatal1ty - P11589, ORB | Dual GTX 660 @ 1046/1502/1111 MHz, zrak | i5 3570K @ 4423 MHz, zrak | ASUS P8Z-77-V |
  3. elina08 - P11333 | Dual HD 6950 @ 970/1350MHz, zrak | i7 950 @ 4011MHz, zrak | Gigabyte X58A-UD3R |
  4. xyan - P11224 | Dual GTX 480 @ 900/1050MHz, zrak | i7 950 @ 4418MHz, zrak | Asus Rampage II Extreme |
  5. St-M - P9018 | Dual GTX 560 Ti @ 950/1005MHz, zrak | i7 860 @ 4.0GHz, voda | Gigabyte P55-UD5 |
  6. Sam Fischer- P7908, ORB | Dual HD 5850 @ 920/1170 MHz, stock zrak, | Phenom X6 @3,87 GHz, zrak, | Asrock 880G Extreme 3 |
  7. NJUNJO_HR - P7519, ORB | Dual GTX 460 @ 920/4100MHz, zrak | i5 760 @ 4.4GHz, voda | Asrock P55 Extreme |
  8. Offshore - 4741 | Dual GTX 550 Ti @ 940/MHz/MHz, zrak | Phenom X4 960T @ 3.8GHz, zrak | Gigabyte GA-990XA-UD3 |
Pravila
  1. Za testiranje se koristi Futuremark 3DMark 11
  2. Na screenshotu se mora vidjeti rezolucija na kojoj se pokreće test, te CPU-Z i GPU-Z gdje se vidi koji su procesor i grafička kartica korišteni.
  3. Za bilo kakvo komentiranje rezultata i slično imate temu 3D Mark 11 rezulati i komentari
  4. Rezultati koji ne slijede template, neće se naći na listi
  5. Za testiranje se koriste default postavke; ili Performance Preset.
Svi rezultati moraju biti postani prema ovoj shemi:
Code:
nick - rezultat (linkan na SS) | poželjan ORB valid |  grafička kartica @ radni taktovi (MHz), hlađenje | procesor @ brzina (GHz), hlađenje | matična ploča |
Zadnje izmijenjeno od: Razer. 08.05.2013. u 01:57.
Staro 08.12.2010., 18:28   #2
Wolverine
Wolverine's Avatar
Postovi: 12,433
Wolverine - P6388, ORB | nVidia GTX580 @825/1005/1650, stock zrak, | Core i7 940 @3,8 GHz, zrak, | Gigabyte X58-UD4P
Mark Twain
Intel Core i7 2760QM
2x 8GB DDR3
Intel HD3000
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 09.12.2010., 03:01   #3
Verbum
Postovi: 684
Verbum - P4451, ORB | MSI GTX460 Hawk Talon Attack @ 970/1940/1100 MHz, zrak | i5 750 @ 4.20GHz, zrak | ASUS P7P55D |
Zadnje izmijenjeno od: Verbum. 25.12.2011. u 11:45.
Verbum je offline   Reply With Quote
Staro 09.12.2010., 04:15   #4
Prcko Prcić
Datum registracije: Sep 2010
Lokacija: Lepoglava
Postovi: 178
Prcko Prcić - 2850, ORB | Palit GTX 460 192 bit @ 800/1600/950, stock | Athlon II X2 245 @ 3.6 GHz, tvorničko | Asrock N68-GS3 UCC |
Prcko Prcić je offline   Reply With Quote
Staro 09.12.2010., 05:04   #5
Tyrant
Tyrant's Avatar
Datum registracije: May 2009
Postovi: 54
Tyrant - P4601, ORB | ATI HD5850 @ 925/1175 MHz, stock zrak | Core i7 950 @ 4,2 GHz, Corsair H50 | Asus Rampage II Extreme
Tyrant je offline   Reply With Quote
Staro 09.12.2010., 13:47   #6
sodom
sodom's Avatar
Postovi: 593
sodom - P7683, ORB | ATI HD 5970 @ 920/1201, AC Accelero Xtreme, | Core i5 760 @ 4,0 GHz, zrak, | Gigabyte p55-ud5
sodom je offline   Reply With Quote
Staro 23.01.2011., 13:23   #7
elina08
Seven
elina08's Avatar
Datum registracije: Jul 2009
Postovi: 97
elina08 - 5311 | HD 6870@1025/1200MHz , Zrak | i7 950@4.4GHz , Zrak | Gigabyte X58A-UD3R |
Zadnje izmijenjeno od: elina08. 23.01.2011. u 18:24.
elina08 je offline   Reply With Quote
Staro 23.01.2011., 14:48   #8
asibulj
Misanthrope
asibulj's Avatar
Lokacija: Neumünster
Postovi: 571
asibulj - 3724, ORB |GTX460 HAWK@ 870/1740/1960 zrak| X4 B20@ 3,0 Hyper 212+ ZRAK | Asus M4N72-E|
x230
asibulj je offline   Reply With Quote
Staro 23.01.2011., 15:47   #9
jopis
gadget freak
jopis's Avatar
Lokacija: Jasenovac
Postovi: 2,224
jopis - 4982 |HD 6950 @840/1325MHz, zrak | Q6600 @3,2GHz, zrak | Gigabyte X38-DS5
Staro 24.01.2011., 17:44   #10
HCS
Premijum
HCS's Avatar
Postovi: 1,360
HCS - P6027| HD 6950@1010/1500MHz, Zrak | 1090T@4000MHz, Zrak | ASRock 890GX Extreme3
Staro 24.01.2011., 22:07   #11
BojanZD
BojanZD's Avatar
Postovi: 1,398
BojanZD - P4158 / GTX 470@800-1674 /Q6600 3,4GHZ Zrak/ Asus P5Q-E
http://3dmark.com/3dm11/501614;jsess...N6BReVmhdP4wbv
edit:
Autor BojanZD Pregled postova
200MHZ gore i 100 bodova bolje http://3dmark.com/3dm11/521313;jsess...rPtUJMjBPaWbhd
Zadnje izmijenjeno od: Razer. 28.04.2011. u 13:12.
BojanZD je offline   Reply With Quote
Staro 26.01.2011., 18:53   #12
Rush xxx
Postovi: 41
Rush xxx-6679 ORB |HD 6950@1000/1449zrak|i7 920@4,3zrak|Gigabyte x58-UD5
Rush xxx je offline   Reply With Quote
Staro 30.01.2011., 16:59   #13
d4rk_ch1ld
d4rk_ch1ld's Avatar
Lokacija: Krapinske Toplice
Postovi: 695
d4rk_ch1ld - P5817 | VTX HD5870 @ 1035/1325 MHz, zrak | i5 750 @ 4.55GHz, voda | ASUS P7P55D EVO |
d4rk_ch1ld je offline   Reply With Quote
Staro 05.02.2011., 18:50   #14
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
DraŽ - P5925 | Palit GTX570 @ 880/1050MHz, zrak | x6 1075T @ 4,2GHz, zrak | ASUS M4A89GTD PRO
Može update rezultata? I molim da se razmotri nepriznavanje rezultata sa radeonkama kod kojih je korišten slider za teselaciju kad već nije PissX priznat kod vantage-a.
Zen5 PCIvy bridge Notebook
CPU: AMD Ryzen 7 9700x, CO per Core, CS -20 (Mid, High, Max)
COOLER: Arctic Cooling Liquid Freezer III 420 A-RGB
MBO: MSI Tomahawk X870
RAM: Corsair Vengeance DDR5 32GB, 6000MHz CL28
GPU: MSI SuprimX Nvidia GeForce RTX 3070
NVM1: Samsung Evo 970 2TB
HDD1: WD Red 4TB, WD40EFRX
HDD2: WD Blue 6TB, WD60EZRZ
HDD3: WD Blue 6TB, WD60EZRZ
PSU: Corsair RMx 850W, ATX3.1
CASE: Fractal Meshify 2 XL
VENTS: 4x Arctic Cooling P14 PWM PST A-RGB
OS: Win 11 Pro, 64-bit
MONITOR: AOC Q3279VWFD8 - 32", IPS, 2560x1440
TV: LG 7450
MOUSE: Logitech MX Master 3
KEYBOARD: Logitech MX Keys
GAMEPAD: XBOX One
HEADPHONES: Sennheiser HD560s
DELL Inspiron 15R, 5520
CPU: Intel Core i7 3632QM, 2.20Ghz, turbo 3.20GHz
RAM: DDR3, 6GB (4GB + 2GB), 1600Mhz CL11
GPU: AMD Radeon 7670, Intel HD4000
SSD: Samsung EVO 850, 250GB
SCREEN: 15,6 inch LCD, 1366x768
OS: Ubuntu 24.04, 64-bit
Zadnje izmijenjeno od: DraŽ. 20.02.2011. u 20:39.
DraŽ je offline   Reply With Quote
Staro 18.02.2011., 00:12   #15
NJUNJO_HR
NJUNJO_HR's Avatar
Lokacija: Zagreb (Trešnjevka, kod placa)
Postovi: 674
NJUNJO_HR - P7220, ORB | MSI GTX 460 Hawk Talon & Point of View GTX 460 1024 @ 920 / 4100 | i5 760 @ 3,52GHz Turbo on (160*22) | Asrock P55 Extreme
EDIT: evo proc na 4,4GHz
NJUNJO_HR - P7519, ORB | MSI GTX 460 Hawk Talon & Point of View GTX 460 1024 @ 920 / 4100 | i5 760 @ 4,4GHz Turbo off (210*21) | Asrock P55 Extreme
PCE 100+kg demolition squad
LCD 19'' Philips 190P6 | Coolermaster Stacker ATX/BTX (STC-T01) Black | Corsair HX520
ASRock P55 Extreme | Intel i5 760 | G.Skill F3-12800CL7D-4GBECO 2x2GB | XFX 7950 GT 512MB DDR3
Benq DW1670 & Plextor PX-755A | WD Black 1TB (WD1002FAEX), WD Green 2TB (WD20EARS)
Creative SB Audigy Player SB0090 | TP-Link TL-WN651G
Microsoft Wireless Optical Desktop for Bluetooth (Miš i Tipkovnica) | Razer Copperhead (Green) | Genious KB-16e Black
___ <<< Enchantress >>> ___
Parts of watercooling:
Laing DDC-1 water pump
3x Magicool Extreme radiators
EK-Supreme-Acetal for CPU
EK-NF4 rev1.1 for chipset
EK-FC79 for GPU
EK-Multioption reservoir 400 + EK-Multioption RES Bottom Rev.2
& green tubes.
Loop:
rezervoar / pumpa / GPU / rad1 / NB / rad2 / CPU / rad3 / rezervoar
Par slikica iz galerije
H2O galerija
___ <<< ex Morgoth >>> ___
Parts of ex aircooling:
Celeron 420 | ASRock 4CoreDual-SATA2 | XFX 7900 GS 600M
Thermalright Ultra-120 Extreme for CPU lapped
Thermalright HR-05 IFX for chipset lapped
Thermalright HR-03 PLUS for GPU
Lapping galerija
Zadnje izmijenjeno od: NJUNJO_HR. 18.02.2011. u 20:28.
NJUNJO_HR je offline   Reply With Quote
Staro 20.02.2011., 19:11   #16
elina08
Seven
elina08's Avatar
Postovi: 97
elina08 - P6509 | Asus HD6950@978/1375MHz , Zrak | i7 950@4011MHz , Zrak | Gigabyte x58a-ud3r
Staro 23.02.2011., 20:34   #17
xyan
xyan's Avatar
Datum registracije: Feb 2011
Lokacija: Vž-Zg
Postovi: 6
xyan - P11224 | Point of View GTX480 TGT Charged & Gainward GTX480 @900/1050 SLI , Zrak | i7 950@4418MHz , Zrak | Asus Rampage II Extreme
novi rekord
xyan je offline   Reply With Quote
Staro 24.02.2011., 06:00   #18
elina08
Seven
elina08's Avatar
Postovi: 97
Popravljen rezultat.
elina08 - 6741 | Asus HD6950@1025/1401MHz,zrak | i7 950@4393MHz
Staro 16.04.2011., 03:22   #19
NJUNJO_HR
NJUNJO_HR's Avatar
Postovi: 674
NJUNJO_HR - P5123, ORB | Gainward GTX 560 GS 1045/2250, voda | i5 760 @ 4,2GHz, voda, | ASRock P55 Extreme
EK-FC79 for GPU
& green tubes.
Loop:
H2O galerija
Lapping galerija
Staro 20.04.2011., 14:48   #20
Astral
Postovi: 2,523
Astral - P3639, ORB| Gigabyte GTX460 SOC @950/1063/1900, stock zrak, | C2D e7500 @4,0 GHz, zrak, | Asus P5Q3
Zadnje izmijenjeno od: Astral. 20.04.2011. u 14:57.
Astral je offline   Reply With Quote
Staro 02.06.2011., 01:41   #21
Srecko_83
Srecko_83's Avatar
Lokacija: Beč
Postovi: 121
Srecko_83 - 7584 | GTX 580@ 928/1149/1856 , zrak |Core I7-2600K @ 5GHz , Corsair H70
Stigla nova grafa ASUS GeForce GTX 580 Direct CU II
Operating system
64-bit Windows 7 (6.1.7600)
Motherboard
Gigabyte Technology Co., Ltd. Z68X-UD7-B3
CPU cooled by Corsair H70
Intel Core i7-2600K Processor @ 5GHz
Memory
16384 MB
Graphics Card
NVIDIA GeForce GTX 580 @ 928/1149/1856
7584 3DMarks
http://3dmark.com/3dm11/1304662
Bez reklama u sigu.
Srecko_83 je offline   Reply With Quote
Staro 14.06.2011., 20:18   #22
elina08
Seven
elina08's Avatar
Postovi: 97
elina08 - 11333 | 2xHD6950@970/1350MHz ,zrak | i7 950@4011MHz ,zrak
Staro 20.10.2011., 22:10   #23
Vendetta
Vendetta's Avatar
Postovi: 919
St-M - P9018 | SLI Gigabyte GTX560 Ti OC @950/1005 MHz, Zrak | i7 860@4GHz, H2O | Gigabyte P55-UD5
Vendetta je offline   Reply With Quote
Staro 05.02.2012., 17:39   #24
njuskalo1983
njuskalo1983's Avatar
Datum registracije: Feb 2012
Postovi: 8
njuskalo1983 - 13047 | Ati 6990 @ 1007/1454 | i7 2600k @ 5.0Ghz
http://imageshack.us/photo/my-images/263/3dmark11j.png/
njuskalo1983 je offline   Reply With Quote
Staro 06.02.2012., 22:49   #25
Offshore
Offshore's Avatar
Datum registracije: Dec 2011
Lokacija: Kastela
Postovi: 105
Offshore - 4741 | 2xGTX550Ti @ 940MHz,zrak | Phenom II 960T BE @ 3.8 GHz,zrak | Gigabyte GA-990XA-UD3
Force 12
Zadnje izmijenjeno od: Offshore. 07.02.2012. u 02:10.
Offshore je offline   Reply With Quote
Staro 29.10.2012., 23:40   #26
elina08
Seven
elina08's Avatar
Postovi: 97
elina08 - 13640 | HD7950@1328/1606 ,zrak | i7 3770k@4900MHz ,zrak | ASRock Z77 Extreme 6
Staro 06.11.2012., 21:54   #27
ZeljaOs
Postovi: 189
ZeljaOs - 4552 - HD 5850 @ 850/1200 - i5 2500K@4200MHz zrak - Asrock z68 pro3gen3
Zadnje izmijenjeno od: ZeljaOs. 06.11.2012. u 22:06.
ZeljaOs je offline   Reply With Quote
Staro 23.02.2013., 12:01   #28
zagy1984
zagy1984's Avatar
Datum registracije: Jan 2012
Postovi: 105
zagy1984 - 14881 , gtx 670 power edition oc SLI 1098/1502(stock) zrak, i7 3770k@3900mhz (stock) ,asus p8z68delux/gen3
http://www.zaslike.com/viewer.php?fi...hhl2eegq80.png
zagy1984 je offline   Reply With Quote
Staro 20.03.2013., 13:43   #29
Sam Fischer
Džabe si krečio!
Sam Fischer's Avatar
Postovi: 5,191
Sam Fischer- P7908, ORB | 2xHD5850 @ 920/1170, stock zrak, | Phenom X6 @3,87 GHz, zrak, | Asrock 880G Extreme 3
Staro 27.04.2013., 13:59   #30
Blue_Fatal1ty
Blue_Fatal1ty's Avatar
Lokacija: Čazma
Postovi: 1,728
Blue_Fatal1ty - P11589, ORB | SLI GTX660 @ 1046/1502/1111 MHz, zrak | i5 3570K @ 4423 MHz, zrak | ASUS P8Z-77-V |
