Staro 09.06.2005., 16:16   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Catalyst 5.6
Vani su
www.ati.com
Staro 09.06.2005., 16:19   #2
Jelc
Super Moderators
Postovi: 17,485
Fixed in this driver:
MS Works 8.0: Running the application under a German edition of Windows XP no longer results in an error message being displayed when clicking on the calendar
MVP Baseball 2004: Playing the game under Windows XP with an ATI PCIe product installed no longer results in brief display corruption being noticed when there is a transition between certain frames
Shadow Vault: Setting the desktop resolution to 1280x1024 and the D3D slider to Optimal Quality in the ATI 3D tab no longer results in corruption being displayed in the opening cinematic and no longer results in the game failing to respond along with a VPU recover message
VirtualSkipper3: Launching a challenge in the game no longer results in the game failing to respond while the challenge is loading
Assigning a hotkey to increase the overlay gamma no longer results in the hotkey not functioning properly when playing an MPEG using the Windows Media Player
Installing the display driver and the Catalyst™ Control Center, no longer results in a runtime error and the system tray failing to start when attempting to create multiple user accounts and enabling fast user switching
The Catalyst™ Control Center installation now checks for the installation of the Microsoft .Net Framework before preceding with the install of the Catalyst™ Control Center. This resolves an error message that was displayed when attempting to launch the Catalyst™ Control Center
The Scale to Full Screen option found in the Theater Mode settings of the Catalyst™ Control Center is now available when using multiple display devices and enabling clone mode
The text that describes the preferred setting for the Plugged-in option found under the Powerplay™ settings of the Catalyst™ Control Center is no longer missing
Catalyst™ Control Center: The Apply and Discard button are no longer disabled when disabling Overdrive™
Moving the TV to desktop2 and selecting swap device or double up no longer results in the CRT being in panning mode and display corruption being seen on the TV
The Optimal Performance text string is no longer missing in the Standard settings of the 3D options found in the Catalyst™ Control Center
The Color option found under Smartshader is no longer missing when selecting the option No Preview for the Catalyst™ Control Center
Changing the regional option found in the control panel to Japan followed by installing the display driver no longer results in the TV format failing to change in accordance with the regional option
Selecting German as the language for the Catalyst™ Control Center no longer results in the heading for the Digital Panel Attributes page being cut-off
Creating a hotkey to adjust any video overlay option no longer results in the overlay option not changing when executing the hotkey
Black text boxes are no longer displayed in the Overdrive™ option of the Catalyst™ Control Center when selecting the Windows XP Silver Color Scheme
The language translation of Hide Toolbar Text in the Preferences tab of the Catalyst™ Control Center is now correct for the Korean language
Paragraph truncation is no longer noticed in the confirmation dialog box when using the Korean language option and making a change to the Graphic Settings in the Display Options of the Catalyst™ Control Center
Changes to the Overlay Display in Clone Mode option found in the Theater Mode settings of the Catalyst™ Control Center are now retained
The Scale to full screen option found in the Theater Mode Settings of the Catalyst™ Control Center is now working properly
The title for the ATI Setup Wizard failed dialog box is no longer missing when running the installation under Windows XP Korean version
Display corruption is no longer noticed when resuming from a full screen DOS session and attempting to run a 3D application under Windows XP in a system containing an ATI Radeon® Xpress 200 series product
Connecting an HDTV to an ATI Radeon® Xpress 200 series no longer results in the selection of D3 and D4 in the HDTV properties
Connecting both a DVI display device and an HDTV to an ATI Radeon® Xpress 200 series no longer results in the DVI monitor failing to enter power save mode
The back lighting is no longer disabled after the installing of the display driver in a system containing an ATI Radeon® Xpress 200 series
Setting the Anti-Aliasing option to 4x and running an application that supports non-standard modes such as 1360x1024 no longer results in the application being displayed incorrectly
LCD Response Time Composition is now enabled and automatically turns off if video playback is below a predefined threshold
Adding a secondary ATI display adapter to a system contain an ATI Radeon® Xpress 200 series on board no longer results in hesitation being noticed when using the hot-key function to switch between display devices
Having a TV connected as the only display device and clicking the OK button in the ATI displays tab found in the Advanced section of the Display Properties no longer results in a flash of the TV image being noticed
Having a TV and CRT connected and clicking on Preview Automatic adjustment in the Optimize Media Center no longer results in both display devices displaying a black screen
full release note:
http://www2.ati.com/drivers/Catalyst...ase_notes.html
Staro 09.06.2005., 16:32   #3
Veki-os
Veki-os's Avatar
Datum registracije: Jun 2004
Postovi: 3,996
To ima samo sa CCC-om ili ja ne mogu nači sa CP-om?
Staro 09.06.2005., 16:50   #4
Vedran
Vedran's Avatar
Lokacija: Kutina
Postovi: 1,208
Re: Catalyst 5.6
Originally posted by Jelc
Vani su
www.ati.com
šta ti visiš na ati-jevoj stranici non-stop? prije cca. pola sata ih nije bilo.
svaka čast jelc, trebali bi te plaćat u ati-ju. :clap:
Vedran je offline   Reply With Quote
Staro 09.06.2005., 16:55   #5
Jelc
Super Moderators
Postovi: 17,485
Re: Re: Catalyst 5.6
Neeee...došao doma, driverheaven ne učitava, odem na rage3d-štani...kliknem bez veze na ATI-evo novih drivera.
Već sam ih skinuo
Došao neki dan DSL pa se sad bahatim
Staro 09.06.2005., 16:56   #6
Jelc
Super Moderators
Postovi: 17,485
Ja sam skinuo sa CP-om.
Oko 25 megi.
http://www2.ati.com/drivers/5-6_xp-2..._wdm_23864.exe
Staro 09.06.2005., 17:09   #7
Veki-os
Veki-os's Avatar
Postovi: 3,996
Oko 25 megi.
Hvala
Staro 09.06.2005., 17:19   #8
pinsla
Caught Somewhere In Time
pinsla's Avatar
Datum registracije: Oct 2002
Lokacija: zg-vrbani, vž u srcu
Postovi: 1,860
nemrem skinut nigde bemti
atijev sajt je u klincu
daj jelc postaj ih tu
pinsla je offline   Reply With Quote
Staro 09.06.2005., 17:20   #9
Mailman
Mailman's Avatar
Postovi: 1,606
čekam softmodanu verziju...
Mailman je offline   Reply With Quote
Staro 09.06.2005., 17:33   #10
Jelc
Super Moderators
Postovi: 17,485
Imaš dime flat pa skidaj
bdw-nisam vidio da se hvale sa 50% za LOMAC, bit će da su se malo zajebali
Staro 09.06.2005., 18:01   #11
MRKONJA
M.U.P.
MRKONJA's Avatar
Datum registracije: Sep 2004
Postovi: 2,277
100 bodova više u 3d05 nego sa starom verzijom. Nešto su poboljšali ali izgleda da
nije baš revolucionarno kako su najavljivali.Bacam se na igrice pa ćemo vidjet.
Abit AX8 VIA k8t890//Venice 3000@2250//1x1gb PQI//POV 7600gs silent//Seagate 7200.10 250gb(16mb//sata)//Hitachi 7k160 120gb@mobile kučište//Seagate 7200.7 200gb
//Samsung SH-w163A//Seasonic S-12 380w//Sharkoon silvation
MRKONJA je offline   Reply With Quote
Staro 09.06.2005., 18:07   #12
MasterX
do you speak it?
Lokacija: ::1
Postovi: 1,631
stavio sam nove drivere radi reda... nezanima me ni 3d marko ni 3d djura... nego vidio sam WMV decode support, ali to izgleda radi samo u kombinaciji sa Media Player-om 10... koji NECU staviti na svoj komp...
jel ima mozda neko nekakav workaround za media player 9 i ATI drivere bez onog smdrljivog control centra (koji trazi .NET) nego da radi sa obicnim control panel-om
Drinking Rum before 10am makes you a Pirate, not an Alcoholic.
MasterX je offline   Reply With Quote
Staro 09.06.2005., 18:11   #13
pinsla
pinsla's Avatar
Postovi: 1,860
ja bih skidal ali nemam gde
daj ljink koji dela
Staro 09.06.2005., 18:16   #14
Jelc
Super Moderators
Postovi: 17,485
Pa skini verziju samo sa CP-om:confused:
Par postova gore sam stavio ljink.
Mislim da se može nekaj iskemijat i sa devetkom, treba par stvari promijenitu u registryu.
Budem pogledao pa javim.
Staro 09.06.2005., 18:19   #15
Jelc
Super Moderators
Postovi: 17,485
daj ljink koji dela
Ja sam skinuo sa ljinka koji sam stavio Vekiju.
Židof škrti-kakti sa posla ne smiješ skidat???
Staro 09.06.2005., 18:20   #16
MRKONJA
M.U.P.
MRKONJA's Avatar
Postovi: 2,277
Povlačim šta sam prije reko. Doom3 1024x768 2xAA High detalji ne pada ispod 25FPS-a .
Cod ista reza 50-60fps.
Staro 09.06.2005., 18:24   #17
Tr4f1ka
Tr4f1ka's Avatar
Datum registracije: Apr 2004
Postovi: 301
woohooo
dobio sam 70 bodova u 3dmarku03, i 4-5 fpsa u doomu3 ( timedemo )
nije bas 50% al je super!!!
HARDCORE 4 LIFE
athlon xp 2500+ @ 3200+ (11x200)
gigabyte ga7n400l ( n force2 )
gigabyte radeon9600pro (@ 510/700 )
2x256 Samsung ddr400
ŽENE SU KAO RAM, ŠTO VIŠE IMAŠ TO BOLJE
Tr4f1ka je offline   Reply With Quote
Staro 09.06.2005., 18:34   #18
Jelc
Super Moderators
Postovi: 17,485
Treba benchati svake drivere sa AA i ANISO, možda ćeš imati u funjavom Marku 2001/3/5 nešto manje (bez AA i ANISO) ali sa svakim driverima AA+ANISO daju bolje rezultate.
A to je važno
Mislim-jebeš ti par frameova više ako je iq lošiji.
Staro 09.06.2005., 19:12   #19
Tr4f1ka
Tr4f1ka's Avatar
Postovi: 301
a jelce lako tebi benchati iq sa x800xl, ja tu jedva vrtim d3 kak treba na 1024x768 bez aa i af na 30-40fpsa...
HARDCORE 4 LIFE
Staro 09.06.2005., 19:31   #20
pinsla
pinsla's Avatar
Postovi: 1,860
pa jebo ga tito taj ljink ne dela
nisam našel ni na jedan koji dela
uporno pokušavam
Staro 09.06.2005., 19:56   #21
Mailman
Mailman's Avatar
Postovi: 1,606
Staro 09.06.2005., 21:07   #22
Mailman
Mailman's Avatar
Postovi: 1,606
Originally posted by Mailman
Softmodani driveri gotovi....
http://www.techpowerup.com/softmod/downloads.php
softmod ne radi....: nono :
edit: fixali su softmod
Zadnje izmijenjeno od: Mailman. 10.06.2005. u 00:22.
Staro 10.06.2005., 01:46   #23
Jelc
Super Moderators
Postovi: 17,485
Malo sam ih isprobavao-sve radi brzo i stabilno
Staro 10.06.2005., 14:44   #24
Jelc
Super Moderators
Postovi: 17,485
E da, moj je savjet skidati jedno po jedno a ne u paketu.
Posebno dd, CP i WDM.
ATI-jev instalater prvo stavi drivere, pa CP pa WDM...pa ispadne kak ti bog da...
Bolje je i sigurnije instalirati jedno po jedno (mislm-ako je grafa VIVO prvo drivere, ne restartati, VDM, restart) i na kraju CP.
Staro 14.06.2005., 01:13   #25
Srecko_83
Srecko_83's Avatar
Lokacija: Beč
Postovi: 121
Test 5,5 protiv 5,6
http://www.ocklub.net/index.php?suba...aficke_Kartice
Pripazite na score u 3dmarku05
Bez reklama u sigu.
Srecko_83 je offline   Reply With Quote
