Povratak   PC Ekspert Forum > Računala > Periferija > Ostalo
Staro 14.06.2011., 14:36   #91
metalacos
metalacos's Avatar
Postovi: 69
Autor Veki-os Pregled postova
Za G500 uzmi ovu podlugu http://www.links.hr/index.php?naziv=...kl=101.800.134
Imam je i predobra je,koliko sam pročitao na netu napravljena je baš za senzor koji je u G500 i u nekom SS mišu.
Goliathus Control i slične "krpene" podloge ne uzimaj ni slučajno,prije ove podloge je miš bio na Goliathus Control podlozi i ona mu nikako ne odgovara,ni senzoru ni "klizačima".
Evo ove sekunde mogu potvrditi ovo, imam g500 i slicnu steelseries podlogu i iznimno sam zadovoljan! Perem u masini sve sljaka stara nekoliko god
metalacos je offline   Reply With Quote
Staro 28.06.2011., 22:15   #92
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
EVGA Intros Trio of Gaming Mousepads
Op op, čim je metal coated onda je poželjna na mom stolu i to ovaj dizajn u sredini
EVGA solidified its gamer-centric image by rolling out a trio of gaming mousepads. All three are essentially of the same size and specs, but differ with the graphic on the surface. The three are "XL" sized (14" x 10.25" or 35.5 cm x 26 cm). All three have the same rigid/metal-coated surface that provides low friction, meaning that it's is a speed-centric surface. A non-slip rubberized base provides traction with whatever is below. As for the designs, the first one is dedicated to the EVGA Gaming Community (EGC), and shows a shield surrounded by all sorts of gun barrels; next is a plain EVGA Gaming logo with a pattern in the background; the third design is of a tactical shooter background with "Pwnage" in the foreground. All three are priced at US $14.99 at the company's online store.
C L O W N I N G A R O U N D
Staro 28.06.2011., 23:18   #93
alengrosevic
alengrosevic's Avatar
Postovi: 3,801
ja se s ovim ne bih slozio nikako. Imao sam Razer eXactmat i razer destructor podloge i obje su bile dobre ali su "jele" teflonske nozice. Jednostavno sam vidio na podlozi da je nkakav fini prah ostajao gore dok nisam skuzio da su to "nozice" misa. Njih sam zamjenio za Goliathus podlogu (rpa) i preporodio sam se. Gore radim trenutno sa G700 ali je tu bio i G500, G5 rev.2, Razer Lachesis, Deathadder i jos nekoliko miseva. Svi su fantasticno reagirali na podlogu te sam se odlicno naigrao na njoj (FPS-ovi, COD4, Crysis, Farcry itd..). Sto je najbolje ona je polirala te "nozice" te mis klizi po podlozi, fantasticno je raditi na njoj. Moja preporuka je da ide na tu "krpenu" podlogu. K tome je osjetno jeftinija...
Staro 29.06.2011., 08:44   #94
Sinac
...samo te gledam...
Sinac's Avatar
Postovi: 2,838
I ja bih potvrdio da su krpene podloge meni i mojim mišonjama uvijek bolje od plastike/aluminija/kerefeka. Logitech G5, G5 rev2, G500, MS Habu, sve radi super na Gigabyte Ghost podlozi. Probao i druge podloge ali mi miš najbolje klizi po krpenoj podlozi. Izmjenjao sam i druge, njih 3-4 sa različitim površinama, miš je zahvalan na krpenoj podlozi jer se teflonske nožice nikad ne zaprljaju i ne troše se, na podlozi se ne skuplja prašina i lako se očisti mokrom krpom ili pranjem.
Staro 29.06.2011., 11:27   #95
chief_wolfinjo
Staro 06.07.2011., 14:35   #96
veve
woot!!!
veve's Avatar
Postovi: 2,502
The XFX WarPad™ isn't rough around the edges. This unique breakthrough in gaming technology is a mousepad designed to eliminate friction and discomfort during long or intensive gaming and working sessions.
The XFX WarPad™ creates an edge so comfortable and supportive that your competition might just tire out before you do.
Effortlessly clamping onto any desk edge up to 2" thick and only requiring a 2" deep desktop lip to clamp onto, the XFX WarPad™ is easy to roll up and take anywhere you go.
With it's unique clamping feature, you never have to worry about this mousepad sliding around.
This revolutionary mouse pad comes in at 16.97 inches x 13.98 inches. It's generous size helps to accommodate multi display gaming and projects.
For gamers, by gamers, the XFX WarPad™ was meticulously developed by XFX's product developers to meet every intensive users’ needs.
The XFX WarPad™ has been tested and appraised by casual gamers, professionals, students and champions of the gaming scene to make sure that it has perfect ergonomics for any user.
If you want an edge in your gaming, but not the pain of feeling the edge of your gaming surface, the XFX WarPad™ is just what you've been wishing for.
XFX WarPad
Zadnje izmijenjeno od: veve. 06.07.2011. u 14:46.
veve je offline   Reply With Quote
Staro 27.07.2011., 17:28   #97
fooK
Powaaa user
fooK's Avatar
Lokacija: Hrvatska, Zagreb
Postovi: 160
Netko je pitao za ove stvarno velike podloge -> http://www.xtracpads.com/products.ph...id=5&section=1
Ne znam gdje se moze nabaviti, al vjerujem da ima neki webshop koji shipa za HR ili mozda neki ducan u HR. Nije mi se dalo toliko guglat, ali za ovu sam znao, pa eto da podijelim
Imao sam Razer Goliathus Control, bila ok sa MX518, sa G500 mi nije bila nesto. Sad imam SS QCK heavy XXL i odlicna je, ali me zanima PureTrak Talent.
http://www.puretrak.com/products/item/6 Jel netko to probao?
Fun starts @ 2000 rpm with 465nM
Pošteni trgovac: 1
fooK je offline   Reply With Quote
Staro 18.08.2011., 16:57   #98
Goc 101
Goc 101's Avatar
Datum registracije: Aug 2011
Lokacija: Sesvete
Postovi: 129
preporuka za g400
Nedavno sam si uzeo novog mišonju G400, ali mi sada ova 5 godina stara podloga od 30 kn sa naslonom za ruku koji je uvijek okrenut u stranu da ne smeta, nikako ne odgovara. Pa me zanima jel ima tko kakvih iskustava i preporuka u vezi podloga konkretno za G400?
Edit: uzeo Sharkoon Rush Outplay i prezadovoljan. Ne znam kakva je u usporedbi s drugima ali ako još nekog zanima ima u Linksu za 89 kn.
Evo i jedna recenzija: http://www.bug.hr/vijesti/izdrzljivi...ay/100804.aspx
Zadnje izmijenjeno od: Goc 101. 03.09.2011. u 15:22. Razlog: kupio podlogu
Goc 101 je offline   Reply With Quote
Staro 14.05.2012., 16:55   #99
RS_BuRnOuT
RS_BuRnOuT's Avatar
Lokacija: Kž\Vž
Postovi: 459
Autor veve Pregled postova
XFXWarPad
XFX WarPad
Trenutno sam na Sharkoon 1337 XL, ok je podloga al vec istrosena nakon par godina koristenja.
Dvoumim se izmedu SteelSeries QCK Heavy i gore navedene XFX WarPad.
Miš je Roccat Kone
Igram CoD4 i BF3.
RS_BuRnOuT je offline   Reply With Quote
Staro 14.05.2012., 17:21   #100
QuidZz
QuidZz's Avatar
Lokacija: Sinj
Postovi: 3,538
Ja sam imao jako puno podloga i najbolje su mi Qck podloge, imao sam tu Heavy i radila je savrseno sa G9X
Staro 14.05.2012., 17:26   #101
veve
woot!!!
veve's Avatar
Postovi: 2,502
Podjednake su, jedino je Qck Heavy malo veca od ove i nema ovaj drzac za stol kaj je po meni cisto nebitno.
Moj glas za Qck Heavy, jer sam ju imao prilike koristiti neko vrijeme i super je bila.
Staro 21.05.2012., 12:38   #102
tbogovi1
tbogovi1's Avatar
Datum registracije: Mar 2011
Lokacija: Sl.Brod
Postovi: 250
kupi razora i miran si 100 godina. zakon su
tbogovi1 je offline   Reply With Quote
Staro 24.10.2012., 16:33   #103
zuiko
Postovi: 456
zuiko je offline   Reply With Quote
Staro 24.10.2012., 17:32   #104
QuidZz
QuidZz's Avatar
Lokacija: Sinj
Postovi: 3,538
Steelseries qck
Staro 24.10.2012., 17:32   #105
Sinac
Sinac's Avatar
Postovi: 2,838
Samo za info, ja sam prije nekih 2-3 godine kupio Gigabyteovu podlogu (guma cca 5 mm i gore tekstil), veličine otprilike A3 formata, za 75 kn i još dan danas je kao nova i to nakon dobrog "glancanja" u TeamFortressu 2, BFBC2 i BF3. Miševi klize po njoj kao po loju a nikad ništa prljavo ili da bi zapinjalo. Perem ju tu i tamo mlakom vodom.
Staro 24.10.2012., 17:44   #106
chare
Happy hippo
chare's Avatar
Lokacija: Cakovec
Postovi: 562
Uzmi Steelseries Qck+. ZNaci ne qck vec qck+. Razlika u cijeni je mala a u velicini ogromna.
chare je offline   Reply With Quote
Staro 24.10.2012., 19:16   #107
Crypto
Crypto's Avatar
Postovi: 107
Ja bi uzeo CM Storm, prvenstveno jer sam se naviknuo na udobnost podloge debljine 5 mm (imam CM Storm Tactics) i više ne kupujem ove milimetarske podloge.
Što se tiče dimenzija, ta Medium verzija je po meni taman...
Crypto je offline   Reply With Quote
Staro 24.10.2012., 19:17   #108
zuiko
Postovi: 456
Meni paše malo veća od a4 formata.
Kad već ima oprečnih mišljenja, između koje dvije da biram?
Hvala na savjetima!
Staro 24.10.2012., 20:47   #109
chare
Happy hippo
chare's Avatar
Lokacija: Cakovec
Postovi: 562
Najbolje ti je da odes do ducana i pogleas obje i odlucis. Ja ti mogu tvrdit da je jedna bolja a neko drugi da nije a tebi ce pak najbolja biti neka treca. Imas sada izbor za dvije super podloge al ti moras sam vidjet koja ti vise pase
Staro 24.10.2012., 21:04   #110
zuiko
Postovi: 456
Ak su te dvije bolje od druge dvije onda ću tako.
Hvala!
Staro 25.10.2012., 00:11   #111
ThePornstar
ThePornstar's Avatar
Postovi: 4,403
Koju god da uzmeš nećeš pogriješit. Moja preporuka ide za SHARKOON 1337 Gaming Mat Black koja me služi već 3 godine, uz pranje svakih par mjeseci.
Dost je tanja od QCK i meni nekak ugodnija od navedene QCK.
Staro 25.10.2012., 08:42   #112
zuiko
Postovi: 456
Budući da neki preporučuju deblju, a neki tanju, vjerojatno ću uzet srednju
Staro 28.10.2012., 09:27   #113
zuiko
Postovi: 456
Kupio sam steelseries i razočaran sam.
Podloga nije bila dobro zarolana u kutiji pa ima "uši (dva prilično velika) i blage nabore. Ostavio sam je na stolu pod hrpom knjiga od petka popodne do nedjelje ujutro i ništa se nije izravnalo. Da pokušam peglom?
Staro 28.10.2012., 10:15   #114
Sinac
Sinac's Avatar
Postovi: 2,838
Autor zuiko Pregled postova
Ne vjerujem da će pomoći, pegla će samo pogoršati. Nosi to na zamjenu, čudi me da nisi u subotu odmah jurio zamjeniti.
Staro 28.10.2012., 11:23   #115
zuiko
Postovi: 456
Bio sam na putu pa je ostalo dan i pol (nadao sam se da će to bit dovoljno dugo). U međuvremenu je žena bacila kutiju pa mi vjerojatno ne bi priznali reklamaciju. Probao sam peglom i nakon pola sata peglanja preko krpe podloga je iskoristiva. Postoje još dvije vrlo plitke brazde gdje je bila najjače savijena ali to ne smeta mišu. Vidjet ćemo kako će se pokazati.
Staro 28.10.2012., 14:21   #116
DiRT
► Play ▌▌ Pause ■ Stop
DiRT's Avatar
Datum registracije: Jan 2010
Postovi: 1,180
Pa čekaj, meni se tek izravnala za mjesec, dva. I sada je super, uopće se ne troši podloga kao ni nožice od G400. A nožice od G400 bez podloge u prva 2 tjedna na stolu su mi se potrošile, tj izgrebale, a sad je stanje nepromijenjeno već pola godine i više. Podlogu sam brisao, prao...I ko nova je, Qck mini. Ne treba mi bolja.
PC:
CPU:
Intel Core i7-7700
COOLER:
SCYTHE Mugen 3 rev. B
MBO:
MSI B250 GAMING M3
GPU:
ASUS Dual Radeon RX 6650 XT OC Edition 8GB GDDR6
RAM:
Kingston HyperX Fury (2x8GB) 2133MHz@2400MHz CL16 DDR4
SSD:
Samsung 870 EVO (500GB)
Samsung 970 EVO Plus (2TB)
HDD:
WD1003FZEX (1TB)
WD20EZRZ (2TB)
EXTERNI HDD/SSD:
Seagate Basic Portable Drive (1TB)
WD My Passport (1TB)
WD My Passport (2TB)
WD Elements (2TB)
Verbatim Vx500 (240GB)
Silicon Power PC60 (240GB)
Kingston XS1000 (1TB)
PSU:
Corsair 650W RM650, 2019, 80 PLUS Gold
MONITOR (TV):
Dell G2724D + Dell U2414H
Samsung UE55NU8002TXXH
Samsung QE43Q60AAUXXH
Philips 43PUS8506/12
KUĆIŠTE:
Antec 300, 2xSCYTHE Slip Stream 120mm (500rpm, 7.5 dB)
OS:
Windows 10 Pro 64-bit
TIPKOVNICA:
Logitech K800 Illuminated
MIŠ:
Logitech G502 Proteus Spectrum RGB + SteelSeries QcK Edge - Medium
Logitech MX Master 3 Black
Logitech MX Master 2S Bluetooth Edition Graphite
Logitech M590 Silent
ZVUČNICI:
Logitech Z-5500 (S/PDIF) + Logitech Bluetooth Audio Receiver
MAGNAT Monitor Supreme 202 Black 2-way bass reflex bookshelf speakers
MAGNAT Monitor Supreme Center 252 Mocca
SLUŠALICE:
Logitech Zone Vibe 100
Samsung Galaxy Buds3 Pro
Xiaomi Redmi Buds 5 Pro
Xiaomi Buds 3 Star Wars Edition
Mi True Wireless Earbuds Basic 2
Sennheiser CX 3.00
AKG Samsung Galaxy Earbuds
AKG Y500 Wireless
MOB:
Samsung Galaxy S7 Black, 4/32GB +
Samsung microSDXC 64GB EVO+
Samsung Galaxy S10e Black, 6/128GB +
Samsung microSDXC 256GB EVO+
Huawei P50 Pro Golden Black, 8/256GB
Samsung Galaxy A55 5G Awesome Navy, 8/256GB
Samsung Galaxy S24+ Onyx Black, 12/256GB
Samsung Galaxy S25+ Blue Black, 12/256GB
LAPTOP:
(Lenovo ThinkPad E560)
CPU: Intel Core i3-6100U
MBO: -
GPU: Intel HD Graphics 520
RAM: 2x4GB DDR3L 1600MHz
SSD: Kingston A400 480GB
OSTALO: 15.6-inch HD TN
OS: Windows 11 Pro 64-bit
PC POSAO:
(HP Z2 Tower G9 Workstation)
CPU: Intel Core i7-14700K
MBO: HP 895C
GPU: Nvidia RTX A2000 12GB
RAM: 1x16GB DDR5
SSD: Samsung 512GB
HDD: WD 2TB
MONITORI: 2 komada HP Z27 27-inch 4K UHD
PERIFERIJA: Logitech K750 Solar, Logitech MX Master 3 Graphite + Logitech MX Master 2S Bluetooth Edition Graphite
LAPTOP POSAO:
(Apple MacBook Air 13.6-inch M2 8/256GB MLXY3CR/A Silver)
(HP EliteBook x360 1040 G11 2-in-1, 14-inch WUXGA Touchscreen, Intel Core Ultra 7 155H, 16GB LPDDR5x, Samsung 1TB PCIe Gen4 NVMe TLC M.2 SSD, Backlit Keyboard, Windows 11 Pro 64-bit)
(HP ProBook 450 G7, 15.6-inch FHD, Intel Core i5-10210U, 8GB DDR4, Samsung 512GB NVMe M.2 SSD, MX250 Graphics, Backlit Keyboard, Windows 11 Pro 64-bit)
DiRT je offline   Reply With Quote
Staro 28.10.2012., 14:47   #117
zuiko
Postovi: 456
Bolje da ne napišem što bih rekao o proizvodu kojem treba par tjedana da postigao uvjete/karakteristike za optimalan rad. Pogotovo kad je to podloga za miš. Al bit će ok. Pegla je poslužila
Staro 30.10.2012., 23:06   #118
nex
nex's Avatar
Lokacija: .
Postovi: 526
S tankim Qck podlogama nikada nisam imao problema, izravnale su se odmah nakon vadjenja iz kutije.
Ali zato debele... Jedna Qck Heavy se nikada nije izravnala iako sam je par mjeseci (!!!) ostavio ispod utega od nekoliko kg.
nex je offline   Reply With Quote
Staro 31.10.2012., 10:05   #119
zuiko
Postovi: 456
Onda je bolje ne preporučit takve podloge.
Kod tanjih (bar ove moje) pegla pomaže ali ipak nije 100% ravno.
Kakve su druge što se toga tiče. Da znam za iduću
Dal bi se ova velika XFX mogla rezat bez da to prouzroči odljeplivanje ili neki drugi problem?
Mogla bi mi stati na stol samo ako joj odrežem ugao s nazivom
Staro 31.10.2012., 10:26   #120
nex
nex's Avatar
Lokacija: .
Postovi: 526
A ono... nemoguce je reci da su sve takve i prestati ih preporucivati. Znam dosta ljudi koji igraju na SS Qck Heavy i njima je savrseno ravna. A znam i one koji je kao i ja nikako nisu mogli izravnati. Na kraju ispada da je to lutrija.
