Staro 02.10.2012., 22:01   #1
krolovača
Datum registracije: Sep 2011
Postovi: 18
Komp se ruši za vrijeme Google Street Viewa, uploadanja slika na Facebook,...
Dakle, komp se profinjeno ugasi za vrijeme (do sad je bilo tako) gledanja google eartha na netu, za vrijeme uploadanja slika na facebook, za vrijeme spremanja wav filea u Fruity Loopsu itd. Nekad se samo ugasi, i onda ga mogu normalno upalit, a nekad se ugasi te se sljedeći put kad se digne pojavi blue screen nakon cca 10 sekundi (tako nekoliko paljenja i onda radi normalno). Probao s antivirusom, nije pomoglo.
WhoChrashed report:
On Tue 2.10.2012. 19:09:23 GMT your computer crashed
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: Unknown (0xFFFFFFFF82C1DACD)
Bugcheck code: 0x124 (0x0, 0xFFFFFFFF85874024, 0xFFFFFFFFF6204000, 0x135)
Error: WHEA_UNCORRECTABLE_ERROR
Bug check description: This bug check indicates that a fatal hardware error has occurred. This bug check uses the error data that is provided by the Windows Hardware Error Architecture (WHEA).
This is likely to be caused by a hardware problem problem. This problem might be caused by a thermal issue.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: Unknown .
Google query: Unknown WHEA_UNCORRECTABLE_ERROR
On Thu 27.9.2012. 17:50:42 GMT your computer crashed
crash dump file: C:\Windows\Minidump\092712-11750-01.dmp
This was probably caused by the following module: hal.sys (hal+0xEFCD)
Bugcheck code: 0x124 (0x0, 0xFFFFFFFF857E5024, 0xFFFFFFFFB6404000, 0x135)
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: hal.sys .
Google query: hal.sys WHEA_UNCORRECTABLE_ERROR
krolovača je offline   Reply With Quote
