Staro 21.08.2012., 23:55   #1
driftwood
driftwood's Avatar
Datum registracije: Jan 2010
Lokacija: .
Postovi: 685
(riješeno) HP 6715b crte po ekranu
Daklem, kad se upali sve neke crte, bijelo/crne boje...sumnjam na kabel(?)
Na eksternom monitoru radi.
Ako je kabel, jel ga ima netko?
Dazed and confused
Zadnje izmijenjeno od: driftwood. 22.08.2012. u 00:14. Razlog: evo slike
driftwood je offline   Reply With Quote
Staro 22.08.2012., 01:14   #2
_saiko
system kaiser
Postovi: 194
Gotovo sigurno kabel...
Ja sam jedan stariji laptop popravio tako da sam od kineza (ebay) naručio taj kablić..
No možda ti se netko sa polupanim ekranom smiluje i udijeli taj pregibni
<FLEET>
MBO: Gigabyte GA-X58A-UD7 (rev. 2.0)
CPU: Intel Core i7-950 @ 3.2 GHz
Chipset: Intel X58
RAM: 6 x 4 GB DDR3-1600 (PC3-12800)
VGA: HD4850
HDD(OS): OCZ Vertex3 120GB
HDD(local storage): WD WD2002FAEX 2TB, 2x Seagate 500GB (RAID0@IRST/ICH10R)
ODD: Optiarc (?)
PSU: Silverstone SST-ST60F-P Corsair VX450
Display: Samsung Syncmaster 930BF @ 1280 x 1024
Display2: Panasonic TC-P55VT60 @ 1920x1080
Other: eSata dock
OS: Windows 7 Ultimate x64
Input:
Logitech MX1000 + Logitech UltraX cordless
Model: HP Z420
CPU: Intel Xeon E5-1650 6x core @ 3.2 GHz
Chipset: Intel Sandy Bridge-E
RAM: 4 x 16 GB DDR3-1600 (PC3-12800)
VGA: Nvidia
HDD(OS): Seagate ST500DM002 500GB
HDD(local storage): 2x WD WD5000AAKX (RAID1@C600 SAS/SATA ctrl)
Display: 2x HP LA2205wg 22" @ 1680 x 1050
OS: Windows 7 Enterprise x64
Model: HP Elitebook 8570
CPU: Intel i5 3360M
Chipset: Intel Ivy Bridge
RAM: 2 x 8 GB DDR3-800 (PC3-12800)
VGA: Intel HD4000
HDD: Samsung SSD 850Pro 512GB
ODD: DVD+/-RW
Display: 15.4" (1366 x 768)
Other: Fingerprint reader
Input:
Logitech V500 cordless
MBO: GA-P35-DS3P (rev. 2.0)
CPU: Intel C2Q Q6600 @ 2.4 GHz
RAM: 4 x 2 GB DDR2-800 @ 533 MHz
VGA: ATI Rage 3D @ PCI
HDD(OS): Seagate ST380815AS 80GB / Seagate ST3500418AS 500GB
HDD(storage01): 2x WD RE WD4000FYYZ 4TB (RAID10,f2@mdadm)
HDD(storage02): WDC WD20EARX-00P 2TB
HDD(storage_cctv): Seagate ST3250824AS 250GB
ODD: NEC DVD-RW ND-4551A
PSU: Corsair GS800
Display: -
LAN: Intel 82571EB @2x1Gbps LACP
Controllers: RS232 Oxford Semiconductor Ltd OXuPCI952
OS: Linux x64 (Ubuntu 14.04 LTS)
MBO: HP ProLiant DL120 G7
CPU: Intel Xeon E3-1220 @ 4x 3.10GHz
Chipset: Intel i875P-ICH5
RAM: 4 x 4096 MB DDR3-667 (PC3-10600)
HDD1: 2x MB2000EBUCF HUA723020ALA640 2TB 7200RPM (RAID1@P410)
Display: -
LAN: 82574L @ 1000Mbps FD
OS: Linux x86_64 (Ubuntu 14.04 LTS)
MBO: ASRock 4Core1333-FullHD
CPU: Intel Core 2 Duo E84000 @ 3.0 GHz
Chipset: ATI RS600+SB600
RAM: 1 x 512 MB DDR2-800
VGA: -
HDD: Seagate 500GB
ODD: DVD-RW
PSU: Corsair VX450(?)
Display: Panasonic TH-50PY800
LAN: @1Gbps FD
OS: Windows 8.1 Pro x64
Input:
Logitech Cordless DiNovo Edge
MBO: Intel D201GLY2 (ITX)
CPU: Intel Celeron 220 @ 1.2GHz
Chipset: SiS662
RAM: 1 x 512 MB DDR2-533
VGA: Intel
HDD: Sandisk 1GB CF @ CF2IDE
ODD: -
PSU: miniITX type(?)
Display: -
LAN1-Uplink: @1000Mbps FD
LAN2: @100Mbps FD
OS: Mikrotik OS 6.28
Model: Mikrotik RB2011UAS-2HnD
</FLEET>
cat.7 - where crosstalk is not an issue anymore.
_saiko je offline   Reply With Quote
Staro 22.08.2012., 06:41   #3
MMI
MMI's Avatar
Postovi: 913
ekran-flat 96:04 %
puni oglasnici i jednog i drugog
MMI je offline   Reply With Quote
Staro 22.08.2012., 16:02   #4
driftwood
driftwood's Avatar
Lokacija: .
Postovi: 685
Ako se ekran pročačka i udara, zna to sve proraditi lijepo. (tako mi je frendica objasnila, čiji je laptop).
Ja isto sumnjam na kabel jer je u početku malo štekalo, pa onda sve više i više.
Zašto misliš da je ekran?
Dazed and confused
Staro 22.08.2012., 16:10   #5
_saiko
system kaiser
Postovi: 194
Ma flat kabel skoro sigurno... Kosta te 10ak $ narucivanjem ili i manje ako ti netko ovdje da.
<FLEET>
Chipset: Intel X58
VGA: HD4850
ODD: Optiarc (?)
Other: eSata dock
Input:
Model: HP Z420
VGA: Nvidia
CPU: Intel i5 3360M
VGA: Intel HD4000
ODD: DVD+/-RW
Input:
PSU: Corsair GS800
Display: -
Display: -
VGA: -
HDD: Seagate 500GB
ODD: DVD-RW
LAN: @1Gbps FD
Input:
Chipset: SiS662
VGA: Intel
ODD: -
Display: -
LAN2: @100Mbps FD
</FLEET>
Staro 22.08.2012., 18:57   #6
[GOW]Nec
[GOW]Nec's Avatar
Postovi: 1,215
Po slici, prije da je matrica prdnula na rosu.
Ako je flat, u većini slučajeva reagira na pomicanje ekrana, pa probaj.
[GOW]Nec je offline   Reply With Quote
Staro 31.08.2012., 16:38   #7
driftwood
driftwood's Avatar
Lokacija: .
Postovi: 685
Nije kabel
Znači ekran?
Dazed and confused
Staro 31.08.2012., 17:27   #8
[GOW]Nec
[GOW]Nec's Avatar
Postovi: 1,215
Koliko inča, koja reza? Možda imam baš što tražiš.
Staro 31.08.2012., 17:38   #9
driftwood
driftwood's Avatar
Lokacija: .
Postovi: 685
Nemam pojma. Kako da provjerim?
Čini mi se da je 15.4, rezoluciju ne znam.
Dazed and confused
Staro 31.08.2012., 17:42   #10
[GOW]Nec
[GOW]Nec's Avatar
Postovi: 1,215
Ovako?
http://www.cnet.com/laptops/hp-compa...-32470434.html
Nemam niti jedan s tom rezom. Imaš ih po 200 Kn više-manje posvuda.
Drugi način, ekran ima na poleđini oznaku. Izgooglaš ju. To ti je preciznije.
Staro 31.08.2012., 17:48   #11
driftwood
driftwood's Avatar
Lokacija: .
Postovi: 685
Manja je reza na ovom mom. Spojit ću laptop na vanjski monitor da provjerim rezoluciju(?)
Hvala ti na pomoći!
Dazed and confused
Staro 31.08.2012., 17:49   #12
[GOW]Nec
[GOW]Nec's Avatar
Postovi: 1,215
Ako ti paše 1280 x 800 matte, imam.
Ne mora biti da daje istu rezu na vanjski. Doduše, najveća ponuđena bi trebala biti najveća koju grafa može dati.
Nema na čemu.
Staro 07.09.2012., 18:58   #13
driftwood
driftwood's Avatar
Lokacija: .
Postovi: 685
Zamijenio ekran, sve šljaka.
Hvala @Alvin.
Dazed and confused
