Staro 07.04.2005., 22:21   #1
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Novi CATALYST 5.4
Evo taze drivera
Točno po voznom redu.
Issues Resolved in CATALYST™ Software Suite 5.4
The following section provides a summary of the issues that have been resolved in the latest version of CATALYST™. These include:
3DMark2001: A black screen is no longer displayed when launching 3DMark2001 after launching Aquamark3 when the CATALYST™ CONTROL CENTER is installed
Pacific Fighters: Playing the game after playing any track for a short period of time and having the landscape detail set to perfect no longer results in the clouds becoming blocking when flying
Sail Simulator 4: Attempting to play the game under Windows XP with an ATI RADEON™ 9800 XT installed no longer results in the operating system failing to respond and rebooting
SolidWorks 2004: Display corruption is no longer noticed when setting the AA to 6X and AF to 16X
Splinter Cell: Depth buffer corruption noticed on the ATI RADEON™ X800 PRO is now resolved
Star Wars Knights of the Old Republic: Loading the Dantooine level of the game under Windows XP no longer results in slow game performance
Using the ATI Problem Report Wizard under Windows XP SP2 with an ATI RADEON™ X850 XT installed no longer results in an error message appearing when clicking the Finish button for the problem report
CATALYST™ CONTROL CENTER: An option to select Yes or No to changes made in SMARTGART™ is now displayed when clicking the Apply button in SMARTGART™
CATALYST™ CONTROL CENTER: Playing a video clip in the background and entering the Overlay page found in the Video section no longer results in the default value for the Hue not being reapplied unless the CATALYST™ CONTROL™ CENTER is closed and re-launched
CATALYST™ CONTROL CENTER: Selecting Germany as the language no longer results in some of the text overlapping each other on the Unlock button
CATALYST™ CONTROL CENTER: Selecting Netherlands (Dutch) as the language no longer results in some of the text in the Hotkey manager being cut off
CATALYST™ CONTROL CENTER: The Bus setting information is now displayed in the Graphic Hardware section of the Information Center found
CATALYST™ CONTROL CENTER: The Display Manager Wizard no longer contains a Component Video single display setting message, when multi-display desktop mode is selected
CATALYST™ CONTROL CENTER: Custom modes can only be applied if the display device can support the mode selected
Attempting to apply a higher refresh rate to a non-DDC monitor no longer results in the refresh rate reverting to 60hz.
SXGA+ LCD panel flicker is no longer noticed when the frame buffer (UMA size) is set to 32MB or 64MB
Known Issues for CATALYST™ Software Suite 5.4
The following section provides a brief description of known issues associated with the latest version of CATALYST™. These include the following:
Act of War: Playing the game under Windows XP SP2 with Anti-Aliasing enabled results in display flashing being noticed. To workaround this issue, change the mouse cursor size in the game options to small. Topic number 737-18944
Call of Duty: Corruption is noticed when playing a saved game under Windows XP with an ATI RADEON™ 9100 PRO IGP series installed and having a variety of graphic options provided by the game set high. Topic number 737-674
Farcry: Playing the game under Windows XP SP2 with the display set to 1024x76832bpp along with AA disabled results in flashing textures being noticed when setting the game's video options to high detail. Topic number 737-10089
Half-Life 2: Having the display set to 1024x768 32bpp and setting the video options in the game set to 1600x1200 and all other options set to their maximum values results in sluggish performance and missing textures. Topic number 737-10086
Rainbow six3: Athena Sword: Playing the game under Windows 2000 with an ATI RADEON™ X700 installed results in the game failing to retain its resolution option of 1600x1200 if you Alt-tab out of the game and then Alt-tab back to the game. Topic number 737-535
Serious Sam: The Second Encounter: Playing the game for approximately 5 to 10 minutes under Windows XP with the game quality set at normal/default, results in display corruption being seen in the menu. Topic number 737-10090
Star Wars Knights of the Old Republic 2: Playing the game under Windows XP with an ATI RADEON™ 9800 series installed, results in display corruption being noticed when changing the in-game options from low to maximum Topic number 737-10091
Star Wars Knights of the Old Republic 2: Setting the graphic option in the CATALYST™ CONTROL CENTER to Optimal Quality, followed by launching the game and setting the resolution option to 1600x1200, results in a performance drop being noticed. Topic # 737-10093
Assigning a hotkey to increase the overlay gamma results in the hotkey not functioning properly when playing an MPEG using the Windows Media Player. Topic number 737-494
CATALYST™ CONTROL CENTER: The Apply button in the Custom settings of the Advanced mode found under the CATALYST™ CONTROL CENTER Video standard settings is grayed out when playing a media file. Topic number 737-497
CATALYST™ CONTROL CENTER: Installing the display driver and the CATALYST™ CONTROL CENTER, results in a runtime error and the system tray failing to start when attempting to create multiple user accounts and enabling fast user switching. Topic number 737-10084
CATALYST™ CONTROL CENTER: Setting the desktop display to 800x600 or 1600x1200 16/32bpp results in the incorrect display resolution information being provided when checking the video control panel in the CATALYST™ CONTROL CENTER. Topic number 737-10087
CATALYST™ CONTROL CENTER: Changing the DPI setting found in the General tab of the display properties to Large size (120 DPI) results in the change not taking effect when launching the CATALYST™ CONTROL CENTER. Topic number 737-18885
Hot-plugging both a CRT and DVI display device results in clone mode failing to be applied. Topic number 737-18915
www.ati.com
Staro 08.04.2005., 09:04   #2
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,964
Da, a koliko vidim WDM driver je ostao isti, mater im....
Staro 08.04.2005., 14:27   #3
pinsla
Caught Somewhere In Time
pinsla's Avatar
Datum registracije: Oct 2002
Lokacija: zg-vrbani, vž u srcu
Postovi: 1,860
ne znam zakaj bi netko išao instalirat ove drajvere
kolko vidim po known issues ništ ne radi kak spada
pinsla je offline   Reply With Quote
Staro 08.04.2005., 14:47   #4
Jelc
Super Moderators
Postovi: 17,485
Vele oni vako:
The ATI WDM driver is a series of drivers used to enable the capture and TV tuner features on VIVO boards, and the ALL-IN-WONDER™ series of cards produced by ATI Technologies Inc.
The ATI WDM Driver Install bundle contains both the ATI WDM Driver 5.01 (6300) and 4.07 (6246). The setup program automatically detects the graphic adapter installed in your system and installs the appropriate ATI WDM components for the graphic adapter. The WDM version 5.01 (6.14.10.6300) will only install on:
ALL-IN-WONDER™ 9600 Series
ALL-IN-WONDER™ 9800 Series
ALL-IN-WONDER™ 9700 Series
ALL-IN-WONDER™ X600 Series
ALL-IN-WONDER™ X800 Series
The WDM version 4.07 is installed on the following: ATI products:
RADEON™ 9200 series or earlier ALL-IN-WONDER™ products.
ATI VIVO products
E jebiga, mi bi onda trebali koristiti 4.07 (6246)....
Staro 08.04.2005., 16:13   #5
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,964
Ma, nab... ih i njih i WDM...
Staro 08.04.2005., 16:20   #6
Jelc
Super Moderators
Postovi: 17,485
Issss...prika se iskeširo za regu pa je besan ko ovca
Pravi hardware-aš uvijek ima u pričuvi dobri stari Pinnacle
Staro 08.04.2005., 18:37   #7
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,964
Je ili 9200VIVO u drugom kopmu
Staro 08.04.2005., 22:44   #8
Jelc
Super Moderators
Postovi: 17,485
Hoćeš reći POS kasi
Staro 12.04.2005., 01:27   #9
BmwMPower
Lokacija: VG
Postovi: 1,128
2 puta puknuo te "NOVE" drivere ( u dva pokušaja nakon formatiranja i novih win) i svaki put mi se rušila grafa.... Dobri stari 4.8 :clap:
BmwMPower je offline   Reply With Quote
Staro 12.04.2005., 12:19   #10
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,007
Meni zadnji kojima mogu uopće bootati stroj - 5.1
Sad mi M$ update nudi neke 9800 PRO drivere, oko 5.5mb veliki. Jel probao to netko?
Staro 12.04.2005., 13:34   #11
RAK
Feldwebel
RAK's Avatar
Datum registracije: Feb 2002
Lokacija: bolnica
Postovi: 3,739
Meni rade odlično. Baš sam ih jučer instalirao. Jedino sam po putu izgubio AGP8x. To se nikako ne bi trebalo pripisati vriverima jer je komp preko vikenda "upoznao" 6 različitih grafičkih kartica.
Tih kao mačka
Brz kao gepard
Jak kao lav
Elegantan kao leopard
Nisam to ja, to je moj komp.
Staro 12.04.2005., 15:58   #12
Jelc
Super Moderators
Postovi: 17,485
Ma razlika od 4X i 8X je najviše 3-5%, i to samo u nekim slučajevima.
A da ne pričamo o tome da koji put pri uključivanju AGP 8X driveri znaju "zaboraviti" AGP write...
Meni je na KT 400 generalno brže radilo sa 4X
Staro 12.04.2005., 18:50   #13
soad
...Rage against...
soad's Avatar
Postovi: 49
evo bas sam stavio nove drivere i imam dosta losiji rezultat na 3dmarku...:confused:
ABIT AG8 uGURU 915INTEL LGA775
Intel Pentium 4HT 3,2GHz @ 2,8GHz
Jebes Intel kad mi hladnjak cvili i probija usi kad upalim wmp...
2 x DDR KingMax Hardcore Series 512mb
ASUS ATi X800xt 256MB GDDR3 @ 535/1120MHz (6100+ 3dMarks 05)
2x120gb raid0 maxtor
Nec dvd rw dual layer +/-
Channell Well 550W
Kuciste ThermalTake xaser3
Logitech Media Desktop Bluetooth
Sony LCD 12ms 19"
soad je offline   Reply With Quote
Staro 12.04.2005., 19:00   #14
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,964
Pa ak ti je bitan rezultat u 3d peri vrati stare...
Staro 15.04.2005., 20:16   #15
soad
...Rage against...
soad's Avatar
Postovi: 49
nije bitan,nego cisto govorim zbog toga sto svakim novim poboljsam rezultat a ovaj put bas i nije tako,3dmark nije nikakvo mjerilo...
Channell Well 550W
Sony LCD 12ms 19"
