Staro 19.12.2010., 18:27   #481
_saiko
system kaiser
Postovi: 194
Ma imam slozeno sve samo sam htio tog veterana iskoristiti...
Nis prodajem onda.. Ako netko kupuje za socket 775 i ekvivalentne amd sockete javite se
_saiko je offline   Reply With Quote
Staro 21.12.2010., 19:18   #482
Milentije
Adrenaline junkie
Milentije's Avatar
Lokacija: Doboj - Banja Luka
Postovi: 3,593
UD11(!?) u OMG-ATX izdanju.
The word in Gigabyte's office is that this big boy's whopping PCB has been given the internal moniker of 'OMG-ATX' to describe its dimensions.
There's no word on the official specs yet either, although we've heard rumblings about on-board SSDs striped together in RAID 0 configuration, as well as an army of solid state capacitors.
LINK
Staro 31.12.2010., 17:12   #483
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Intel Readies Pair of New X58 Extreme Series Desktop Boards
Intel's Desktop Board division is readying two new high-end socket LGA1366 motherboards under its Extreme Series line. The company's last high-end LGA1366 motherboard, the DX58SO "SmackOver", was released more than 25 months ago in November 2008, when the first Intel Core i7 processors came to be. The new motherboards are up to date in terms of features. They use the latest Rev. 13 X58 northbridge, all solid-state capacitors, support the latest LGA1366 processors out of the box, and feature USB 3.0 and SATA 6 Gb/s support. The two motherboards consist of DX58SO2 "SmackOver II", and its "lite" variant, the DX58OG.
The DX58SO2 uses digital PWM CPU power circuit, a sporty blue heatsink cluster over the northbridge, VRM area, and southbridge, with heat spread between the northbridge and VRM using a heat-pipe. It features six internal SATA 3 Gb/s, two internal SATA 6 Gb/s, and two eSATA 3 Gb/s ports, two USB 3.0 ports, 8-channel HD audio, and expansion slots that include three PCI-Express 2.0 x16 (x16/x16/NC or x16/x8/x8), two PCI-E x1, and one PCI.
The DX58OG uses the same exaxt PCB as the DX58SO, except that a lot of features are downscaled. The CPU VRM has fewer phases, although USB 3.0 and SATA 6 Gb/s ports are unaffected, there are no eSATA ports, and a 6-channel HD audio CODEC instead of 8-channel, and the third PCI-Express x16 slot is reduced to x1. Both boards feature certain new features that Intel is introducing with its latest Extreme Series boards, namely, BIOS Vault Technology that helps recover BIOS, a Back-to-BIOS button, and a more efficient inter-phase load balancing mechanism. Intel’s new Desktop Boards should be available anytime soon, probably from early January.
http://www.techpowerup.com/137422/In...op-Boards.html
C L O W N I N G A R O U N D
Staro 02.01.2011., 17:28   #484
ms825
ms825's Avatar
Datum registracije: Dec 2010
Lokacija: Vrbovec
Postovi: 81
bok svima, dal mi moze neko objasnit zasto je i7 940 skoro duplo skuplji od i7 950, jer ja gledam specifikacije na intelovoj stranici i nigdje ne vidim razlog za tolku razliku u cijeni (valjda sam corav).
hvala.
ms825 je offline   Reply With Quote
Staro 02.01.2011., 19:39   #485
Wolverine
Wolverine's Avatar
Postovi: 12,433
Zato kaj se ne proizvodi više pa ga nemaju na lageru i to što vidiš je stara cifra.
Mark Twain
Intel Core i7 2760QM
2x 8GB DDR3
Intel HD3000
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 06.01.2011., 14:19   #486
ms825
ms825's Avatar
Lokacija: Vrbovec
Postovi: 81
@ wolverine
Pa nie bas neki odgovor, jer i u svim ducanima i u hrv i u ger je takva razlika u cjeni, a razlog za takvu razliku cijeni samo zato kaj se vise ne proizvodi je bedasto.
Staro 06.01.2011., 14:44   #487
Milentije
Adrenaline junkie
Milentije's Avatar
Postovi: 3,593
Bilo bedasto ili ne tako je.
Staro 06.01.2011., 20:41   #488
Swarm dude
Premium moderator
Swarm dude's Avatar
Postovi: 4,600
Wolv ti je sve rekao, oni su taj proc nabavili po toj i toj cijeni (koja je bila viša od trenutne i7 950) nekoć prije i sad ga ne daju ispod cijene, već drže tu koja je.
MBO: MSI 760GM-E51 FX
VGA: Nvidia Quadro K600
SSD: Crucial BX500 1TB
Staro 09.01.2011., 01:27   #489
ms825
ms825's Avatar
Lokacija: Vrbovec
Postovi: 81
onda ok
Staro 13.01.2011., 11:32   #490
_DoKmA_
Datum registracije: Jan 2011
Postovi: 14
Intel® X58 Express Chipset Based-Eclipse plus
_DoKmA_ je offline   Reply With Quote
Staro 15.01.2011., 17:20   #491
ms825
ms825's Avatar
Lokacija: Vrbovec
Postovi: 81
http://www.gigabyte.com/products/pro...px?pid=3449#sp
zanima me sta znaci u specifikacijama memorije :
2. Dual/3 channel memory architecture (jel to znaci da mogu ici dual i triple moduli nutra)
Staro 19.01.2011., 16:04   #492
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,760
Autor ms825 Pregled postova
Ako stavis paran broj plocica (2, 4) radit ce ti u dual channelu, a ako stavis neparan br (3 ili 6) radit ce ti u triple channelu.
Sto znaci da mozes uzeti 3 kita od recimo 2x2GB i sve skupa ce radit u triple channelu
Inace, evo jedna novost iz asus-a:
ASUS ROG Rampage III Black Edition
The lads of Hexus posted a small picture of the upcoming ASUS ROG Rampage III Black Edition motherboard. It has a X58 chipset and the main novelty is ThunderBolt, a new expansion card from ASUS that integrates Xonar sound as well as BigFoot's Killer NPU. Pricing and availability is unknown.
Despite the launch of Intel's Sandy Bridge platform, the ultra-high end is still served by the venerable X58/LGA1366 platform, and it's that audience that the Black is targeted at. The spec-sheet for the board itself reads pretty much the same as last year's Rampage III Extreme, although there have been a few tweaks along the way, including redesigned heatsinks.
Basically, this means that the board sports a quartet of PCIe x16 slots capable of supporting three-way SLI or four-way CrossFireX, support for 24GB DDR3 at speeds of up to 2,200MHz and all the other high-end features you'd expect on a ROG board...
Izvor: guru3d
Staro 20.01.2011., 15:52   #493
ms825
ms825's Avatar
Lokacija: Vrbovec
Postovi: 81
Autor bluefluid Pregled postova
Hvala na odgovru.
Staro 07.02.2011., 21:22   #494
Doink the Clown
Postovi: 6,214
Sapphire PURE Black X58 Intel Motherboard
Staro 08.02.2011., 02:15   #495
Milentije
Adrenaline junkie
Milentije's Avatar
Postovi: 3,593
Ovu ploču sam nekidan vidio na Sapphireovom sajtu. Valjda će ovaj put bolje proći nego sa onom jesetrom ili kako se već zvala oan njihova ploča za AMD.
Staro 08.02.2011., 10:37   #496
cccp
cccp's Avatar
Datum registracije: Feb 2004
Postovi: 1,030
Veći dio ili cijeli tim EVGA zadužen za matične ploče je prešao u Sapphire, a oni valjda znaju što rade.
cccp je offline   Reply With Quote
Staro 29.03.2011., 16:58   #497
alengrosevic
alengrosevic's Avatar
Postovi: 3,793
asus Rampage II black edition, cini se predobra ploca....
http://www.asus.com/product.aspx?P_I...dtm&templete=2
Staro 29.03.2011., 17:07   #498
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,581
Mislis Rampage III Je, ploca je stvarno opremljena, ali s ozirom na novi 2011 socket i cijenu po kojoj ce se prodavati, mislim da nece bit pretjerano popularna
Staro 30.10.2011., 00:49   #499
neopro32
neopro32's Avatar
Postovi: 3
Autor Matth€w Pregled postova
Review
http://www.guru3d.com/article/msi-bi...xpower-review/
Meni mrak layout, odličan bundle, očito dobra cijena, solidne performanse, jedino kaj nema, kao i RIIIE, NF200 ICs, a i I/O backplate se nekako čini ispraznim, to pripisujem nedostatku audio konektora koji dolaze na posebnoj zvučnoj.
Još jedna opaska koja se sigurno neće mnogima svidjeti, a ni meni, touch kontrole na ploči za PWR, RST i etc.. Čemu im je to trebalo.
pitanje oko ove maticne ploce...vidim da ima vise slotova za graficke al zbog debljina grafickih nije moguce ikorisitit sve slotove...e sada me zanima da se popune svi slotovi kakve graficke trebaju ici?
neopro32 je offline   Reply With Quote
Staro 30.10.2011., 01:23   #500
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
Autor neopro32 Pregled postova
Single slot grafičke, no to nema smisla jer maksimalno ih možeš upariti 4 za CF/SLI, jedino kao trebaš jako puno monitora/video izlaza.
Matth€w je offline   Reply With Quote
Staro 21.11.2011., 00:40   #501
xtreme96
OC addict
xtreme96's Avatar
Datum registracije: Apr 2009
Lokacija: Gothenburg, Sweden
Postovi: 1,001
Jel moze i7 990X iskoristit dvije GTX590?
Pitam jer jedan moj prijatelj koji se "kupa" u parama ima 990X i 2x GTX590 + 24GB Corsair XMS3 + vodeno,obje grafe vodom hladjene i proc...Mislim prebolestan sistem i jede malu djecu doslovno,nema igre koju nevrti na max. postavkama na 30" monitoru. Al mi je malo zapelo za oko te dvije grafe i 990X.
xtreme96 je offline   Reply With Quote
Staro 21.11.2011., 15:47   #502
Elpresidente1
Datum registracije: May 2009
Postovi: 389
Ma može kolko hoće tj . kolko ima para, doduše bitnije pitanje skaliranja samog sli-a, drivera al to je danas rješeno dost dobro bar mislim (nisam gledo kak stoji u recenzijama) bolje to potraži neg da pitaš tu jer nezenam jel imao ko 2 još, bar nisam vidio da se hvalio.
Elpresidente1 je offline   Reply With Quote
Staro 01.02.2012., 17:06   #503
ludigljivar
Datum registracije: Feb 2012
Postovi: 1
Lijep pozdrav svima.
Imam pitanje u vezi ovog socketa i 990x procesora. S obzirom da se odustalo od razvoja ove platforme, da li taj procesor košta toliko puno iz razloga što je nabavljen po skupoj cijeni ili je taj procesor uistinu bolji od najboljeg s2011 procesora koji je duplo jeftiniji?
ludigljivar je offline   Reply With Quote
Staro 26.02.2013., 17:28   #504
RomperStomper
RomperStomper's Avatar
Lokacija: Sisak
Postovi: 20
trebao bih neki dobar hladnjak za 990x što tiše to boje i da nije neka kvrga
jel bi bio ovaj dobar?
http://www.newegg.com/Product/Produc...82E16835186049
RomperStomper je offline   Reply With Quote
Staro 02.03.2013., 00:21   #505
RomperStomper
Lokacija: Sisak
Postovi: 20
Baš nitko nema neku ideju? Slažem komp a ne mogu bez hladnjaka nastaviti!
Staro 28.05.2015., 19:32   #506
carnage88
carnage88's Avatar
Datum registracije: Oct 2014
Lokacija: cro
Postovi: 54
Intel i7 930
Zanima me dal je potrebno mijenjati procesor iz naslova, radi na 2.8 GHz, tocnije zanima me dal radi bottleneck na GTX 780ti / 970 / 980.
carnage88 je offline   Reply With Quote
Staro 28.05.2015., 20:18   #507
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,581
Posto su rijetki "bolji" procesori na tom socketu, ja bi na tvom mjestu radije kupio neki dobar kuler i kloknuo ga na jedno 4 - 4.2 ghz i onda nemas problema. Ipak je to quadcore sa HT, a ne pentium 4.
Staro 28.05.2015., 20:51   #508
bloodthorn
Crypto currency
bloodthorn's Avatar
Datum registracije: Aug 2008
Lokacija: Dubrovnik
Postovi: 525
Koliko se ja sječam, moj je bez problema radio na 4Ghz s TRUE hladnjakom. Tako da je hladnjak bolja investicija od mjenjana navedenog. (osim ako si naletio na nekakav six core za male novce)
bloodthorn je offline   Reply With Quote
Staro 29.05.2015., 08:48   #509
jed2i
jed2i's Avatar
Datum registracije: Jul 2004
Postovi: 1,771
Autor carnage88 Pregled postova
Isprobaj na stock kuleru koliko voltaže ti treba za 4.0 ghz
pokušaj stavit na 1.18V i opleti neki test da provjeriš stabilnost
Ja sam imao i7 920 na raijintek themisu, dakle ne themis evo, nego manji, themis i temperature su bile super
Nije to cookwell da mu treba kila bakra i nikla da ga ohladi, osim ako ga delidas
Staro 29.05.2015., 17:34   #510
Mislim glupo je naći odgovarajuću temu koja je 1 klik udaljena od ove pa je bolje otvoriti novu kad se ima nekaj za reći...
http://forum.pcekspert.com/showthread.php?t=189436
