Lokacija: pula
Postovi: 637
(riješeno) Slika se zamrzava dok igram COD4
Pozz. Imam problem zamrzavanja slike dok igram COD4. Dakle slika se zamrzne i zvuk isto, počne tulit loop trrrrrrrr. Samo fizički restart mi ostane da stisnem na drugo ne reagira. Mislio sam da je do overclocka ali nije, jer mi je sad sve na stock pa još uvijek to radi. Niti u jednoj drugoj igri mi se ne smrzava niti ovako u svakodnevnom radu. Driveri grafičke su updejtani više puta, različite verzije, kao i audio driveri.. ne znam više koje verzije sam sve koristio. Komp je u profilu. Os je Win7 home premium hvala na sugestijama i pomoći ![]() |
hustla
Postovi: 930
pregrijavanje?
I don't need to "Get a life". I'm a gamer. I have lots of lives. |
Lokacija: pula
Postovi: 637
sve temp su normalne. dakle samo u cod4 se dogadja. ostale igre f1 2010, shift2, sims3 nema greške. isto tako zamrzavanje ide na random, nekad zna proć sat vremena i ništa a nekad mi se nakon 5min zamrzne. evo error iz event viewer: Log Name: System Source: Microsoft-Windows-Kernel-Power Date: 7.10.2011. 17:35:51 Event ID: 41 Task Category: (63) Level: Critical Keywords: (2) User: SYSTEM Computer: CC6 Description: The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly. Event Xml: <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event"> <System> <Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331C3B3A-2005-44C2-AC5E-77220C37D6B4}" /> <EventID>41</EventID> <Version>2</Version> <Level>1</Level> <Task>63</Task> <Opcode>0</Opcode> <Keywords>0x8000000000000002</Keywords> <TimeCreated SystemTime="2011-10-07T15:35:51.706830300Z" /> <EventRecordID>222502</EventRecordID> <Correlation /> <Execution ProcessID="4" ThreadID="8" /> <Channel>System</Channel> <Computer>CC6</Computer> <Security UserID="S-1-5-18" /> </System> <EventData> <Data Name="BugcheckCode">0</Data> <Data Name="BugcheckParameter1">0x0</Data> <Data Name="BugcheckParameter2">0x0</Data> <Data Name="BugcheckParameter3">0x0</Data> <Data Name="BugcheckParameter4">0x0</Data> <Data Name="SleepInProgress">false</Data> <Data Name="PowerButtonTimestamp">0</Data> </EventData> </Event> |
Postovi: 4,403
Ajde skini ovaj programčić, pa opali SS i stavi ga tu.
#8 | |
Lokacija: pula
Postovi: 637
Taj program broji bsod evente vidim nema error od jučer, prekjučer kad mi se zamrznulo. ![]() Vidio sam da mi se taj problem počeo događat negdje u 5 mjesecu, pa sam pokušao otkrit šta je tada bilo instalirano ili mijenjano preko system restora ali nemam mogućnost toliko unazad gledati. Postoji li neka druga opcija da to vidim? googlao sam taj error 41, imala je ekipa nekih problema s zvučnom i sl. ali meni to nije uspjelo. |
Postovi: 4,403
Ne mora se svaki put pokazat plavi ekran kod takvih situacija, a ni restartat komp. Poprilično sam siguran da tebe muči nestabilan overclock, koji pak uopće ne mora imat veze s pregrijavanjem, kojeg kažeš, kod tebe ni nema. ntoskrnl.exe sa BCC-om 124 ukazuje na to. Za početak probaj i procesor i memoriju vratit na default postavke, a za svaki slučaj izvrti neki HDD test i obavezno pogledaj što kaže S.M.A.R.T. EDIT: ćorav sam malo danas ![]() Ali savjet za HDD test i dalje stoji.
Zadnje izmijenjeno od: ThePornstar. 08.10.2011. u 18:27. |
#10 | |
Datum registracije: Apr 2011
Postovi: 3,784
Je, al veli da i na defaultu ima problem, ja mislim ako je testirao kak se spada i problem mu je samo u COD4, onda valjda igra zeza? ![]() @dekky Što si od komponenata testirao i kako (kojim programima)? EDIT: Citiraj:
![]() Zadnje izmijenjeno od: ShanTech. 09.10.2011. u 19:46. |
Lokacija: pula
Postovi: 637
ma sve sam testirao, više se ne sjećam s čim i šta...bilo je lošeg overclocka i pada sustava ali sad je sve na difoltu. hard disk sam nedavno testirao i nije bilo greške. nego zaboravio sam reći da kad igram sa slušalicama(usb) sa svojim zvukom onda nema zamrzavanja, dok kad igram na integriranoj zvučnoj onda freez ![]() sad sam stavio 2.24 drivere realtek i opet frezza...ne znam više šta sam probao šta ne... koja zbunjola...lol hvala ![]() |
hustla
Postovi: 930
dok igras disejblaj zvucnu i bok, ili probaj googlat o tom problemu jer znam da su se neki driveri klali s codom i dolazilo je do poroblema (iz iskustva s p31 gigabyte plocom sam imo istu stvar)
Lokacija: pula
Postovi: 637
problem rijesen. nasao neku staru pci zvucnu, metnuo je unutra i fala bogu vise se ne smrzava. hvala, ![]() |
