Staro 25.08.2011., 23:06   #8401
doky
doky's Avatar
Datum registracije: Nov 2010
Postovi: 1,942
Pa možda je žica i pukla što bi bilo dosta logičnije no nije prikazano. Što se tiče odsjaja možda je neki lik iz zajebancije stavio nekakav flashlight attachment u sred bijela dana.
doky je offline   Reply With Quote
Staro 26.08.2011., 01:41   #8402
panda505
panda505's Avatar
Lokacija: Beertopia
Postovi: 2,013
Sound efekti @ 9:40
54' / 74' / 90' / 2014
Staro 26.08.2011., 14:34   #8403
DeadMan+
LateralusX
DeadMan+'s Avatar
Postovi: 1,788
za one koji imaju MSI Afterburner instaliran, nova vezija 2.2. Beta 6:
Added new compatibility option allowing disabling low-level access to hardware. New option replaces more complex RTCore.cfg renaming related workaround for BFBC2 Punkbuster's bug
DeadMan+ je offline   Reply With Quote
Staro 26.08.2011., 15:25   #8404
PointDexter
PointDexter's Avatar
Lokacija: Éire
Postovi: 1,812
No shit... the PATCH is here
http://forums.electronicarts.co.uk/b...-795745-a.html
Dobro pročitajte upute jer koliko sam shvatio ako instaliraš patch nema igranja na regularnim serverima.... ali nisam sve još proučio pa možda i griješim!!
alien-smilies-0046.gif von smiliesuche.de
PointDexter je offline   Reply With Quote
Staro 26.08.2011., 15:29   #8405
Neo-ST
Neo-ST's Avatar
Postovi: 8,596
dobar, ali isto ću počekati official verziju...
i da, u pravu si:
The Beta client can only play against a couple of special Beta game servers.
Staro 26.08.2011., 15:32   #8406
PointDexter
Lokacija: Éire
Postovi: 1,812
Autor Neo-ST Pregled postova
i da, u pravu si:
Ima mogućnost da probaš i BETU bez da shebeš normalnu verziju
Code:
Make a copy of that directory. Name that copy "BFBC2 - R10".
This is your backup, in case you want to play the non-Beta version of BFBC2;
if so, launch BFBC2Game.exe inside of that directory.
I Kalms kaže:
Code:
BC2 will not be moved to a newer backend.
Znači rješavaju se bugovite/neadekvate "Plasme" kao centralnog servera za BC2
Staro 26.08.2011., 16:37   #8407
vm@
vm@'s Avatar
Datum registracije: May 2009
Lokacija: donji lapac
Postovi: 547
koje bi mi drivere za grafu preporučili (moj komp) koristim 10.6 što je došlo sa grafom, ali dobivam neke čudne anomalije, recimo oko glava je zelena prozirna kocka ili su lica crna i dijelivi mape ili ružičasto, uspijem to riješiti tako da prebacujem postavke sa low na mediu, high i obrnuto a nekad pomogne i promjena frekvencije osvježavanja ekrana i je li netko imao ovakvih problema
vm@ je offline   Reply With Quote
Staro 26.08.2011., 16:45   #8408
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,760
instaliraj zadnje, a prije toga pobrisi trenutne sa driver sweeperom
Staro 26.08.2011., 16:48   #8409
vm@
vm@'s Avatar
Postovi: 547
sa ccc ili bez?
Staro 26.08.2011., 16:57   #8410
Ati freak
aka Striko
Ati freak's Avatar
Lokacija: Krapina - Zagreb
Postovi: 1,756
Autor vm@ Pregled postova
sa ccc ili bez?
kaj ce ti CCC ?
Ati freak je online   Reply With Quote
Staro 26.08.2011., 17:16   #8411
PointDexter
Lokacija: Éire
Postovi: 1,812
sa ccc ili bez?
Sa
Staro 26.08.2011., 17:30   #8412
DeadMan+
LateralusX
DeadMan+'s Avatar
Postovi: 1,788
Autor PointDexter Pregled postova
ovo stvarno nisam ocekivao do iza Bozica
ni ja nisam sigiran za servere, ali lista poboljsanja je odlicna:
  • Removed some memory leaks
  • Fixed crashes when the game attempted to render lots of content (high detail, high FOV or multiple-monitor modes)
  • Chat window no longer causes lag spikes
  • Chat window reworked opacity & visibility-time is controllable through settings in settings.ini
  • Clantag is remembered when using auto-login
  • Banner URLs can be up to 252 characters in length
  • SecuROM wrapper removed from non-Steam version
  • Minor performance improvements
  • Reduced rubberbanding on >24player servers
Staro 26.08.2011., 17:34   #8413
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
Bekapiraš BFBC2 direktorij i ako hoćeš igrati 'normalnu' verziju, pokreneš igru iz bekapiranog foldera, a BETU pokrećeš iz updateanog.
Nakon što stavite beta patch u server browseru ćete vidjeti samo servere sa beta r11 patchem, a ne i ove 'normalne', tako da nema razloga za brigu.
All you have is your fire and the place you need to reach.
Don't you ever tame your demons, always keep them on a leash.
Alph4Dawg je offline   Reply With Quote
Staro 26.08.2011., 18:52   #8414
vm@
vm@'s Avatar
Postovi: 547
instalirao sam zadne sa ccc i nešto se popravilo ali još postoji pogotovo kad stavim na minimum
Staro 27.08.2011., 00:13   #8415
panda505
panda505's Avatar
Lokacija: Beertopia
Postovi: 2,013
Predobra runda na Arica Conquest, neki 24slotni server sa hight ticket rateom
uglavnom došao sam na odprilike 300 - 600 za RU
na kraju smo zgubili samo s 84 razlike
Staro 27.08.2011., 21:30   #8416
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,580
Bzvz updejtao igru, jer za 2,4 gb i naustrb toga da sad moram imat 2 instalacije, nije vrijedno uopce, chat lag mi ne smeta a hitreg je ionako u kurcu..
Staro 27.08.2011., 22:09   #8417
PointDexter
Lokacija: Éire
Postovi: 1,812
Autor xulos Pregled postova
chatlag ti neće smetati jedino ako stojiš nepokretan i ne mičeš pušku ...kemperčino...
Hitreg je IMO bolji, možda baš zato jer nema stutteringa i drugih zastajkivanja
Staro 27.08.2011., 22:16   #8418
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,580
Rodjeni kemper ti mi kazes, kempercino koja imas 3ipo tisuce kilova s ovim govnetom iznad Ma igrao sam nekih 45 min s ump-45 bas na onom r11 serveru i pricao s ekipom , 25 metaka iz umpa direkt i 2 iz rex-a u lika i kita.I onda je valjd bio neki lik bas sa sluzbenog foruma i rekao da nisu popravili/popravljali hit reg nego da zato treba "patchirati" servere i jos kojekakve pozdarije.Tako da , 2.4 gb gluposti.
Staro 28.08.2011., 11:15   #8419
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
Kmete slavonski, imati par tisuća killova sa SV-98 ne znači kempati u grmlju.
Neki ljudi rushaju sa snajperima, Marko.
Uglavnom, vidi se ogroman napredak što se performansi tiče.Hitreg jest malo bolji, ali i dalje je loš.Chat ne uzrokuje stuttering i lag.
Staro 28.08.2011., 12:12   #8420
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,760
A cuj, radije bih i kmet bio danas, dajes 1/10 feudalcu koji te drzi i sve super. Nema drzave koja ti se napija krvi i uzme pol place koju zaradis...
Staro 28.08.2011., 12:23   #8421
Neo-ST
Neo-ST's Avatar
Postovi: 8,596
Zaboravljate da je to bilo na par beta servera sa 1% sveukupnih igrača, čekajte da to postane službeni patch pa ćemo vidit kad navre bagra
Staro 28.08.2011., 12:36   #8422
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
Gle, community je zapravo smeće.Umjesto da svi (uključujući vas nekolicinu ovdje) stave beta patch, da svi zajedno istestiramo igru i bacimo kvalitetni feedback (kao što to DICE i želi), zapravo nas 20 % je stavilo patch i testira, a BETA serveri zjape prazni.
Patch neće postati službeni bez feedbacka.
Bitno da svi stalno plaču i jauču da hoće promijeniti ovo i ono, da treba novi patch.Sada kada nam je DICE dao priliku da istestiramo patch i damo im feedback (da znaju kako nastaviti dalje, što mjenjati da naprave kvalitetan službeni patch) igrači opet samo whineaju i prave se pametni, a nisu ni probali patch.
Staro 28.08.2011., 12:42   #8423
PointDexter
Lokacija: Éire
Postovi: 1,812
Autor Mansky Hunt Pregled postova
Točno to... baci samo oko na službeni forum. To je hrpa vajnera kojim je "patch došao pre kasno"... pa zar svi misle da kad dođe BF3 da neće nikad više zaigrat BC2?!?
I svima sad odjednom taj chat lag i stuttering ne smeta... i performanse su svima zadovoljavajuće
Gejmeri su hrpa glupih/ljenih/informatični nepismenih džabalebaroša
...naravno iznimka su PcE-ovci...
EDIT: I što se tiče SV98... od tih 3.6k killova sigurno je 2000 napravljeno na manje od 30m
Staro 29.08.2011., 09:52   #8424
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,580
Sarcasm on , pls .Zajebavao sam se
Staro 29.08.2011., 17:41   #8425
viper
super user
viper's Avatar
Lokacija: Houston, TX
Postovi: 1,805
Meni se cini da su s ovim patchom popravili noz jer me je poprilicno dobro islo usprkos pingu 200
viper je offline   Reply With Quote
Staro 29.08.2011., 17:45   #8426
PointDexter
Lokacija: Éire
Postovi: 1,812
Autor viper Pregled postova
Išlo bi i bolje da nije bilo retardiranih Rusa
Staro 31.08.2011., 22:33   #8427
Stratofortress
Stratofortress's Avatar
Lokacija: 52,000 feet
Postovi: 81
Bojim se da je sve teže nać server bez imbecilne dječice koja uništava samo po svojim bazama.
Za sve je kriv Steam sa 75%OFF!
Stratofortress je offline   Reply With Quote
Staro 02.09.2011., 10:54   #8428
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
@ Triumph2407 - Pogledaj accuracy kmete.
Ako ne vjeruješ pogledaj mi i u statsima. Moraš se još malo potruditi. :P
Ali dajem ti kredite jer imaš više headshota, iako sam ja SV98 koristio za rush only i close combat, pa nisam zadao previše headshota već više pogodaka u tijelo.
Staro 02.09.2011., 12:30   #8429
PointDexter
Lokacija: Éire
Postovi: 1,812
Svejedno te 1vs1 spwnam
...peasant...
Staro 02.09.2011., 12:50   #8430
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
...peasant...
You wish, sada imamo isti mish.
Hahahha.
