Staro 18.02.2005., 19:27   #1
SulE
SulE's Avatar
Lokacija: Opatija(pobri)
Postovi: 38
Exclamation VTM:Blodlines problem
Ajde pliz ljudi imam problem sa blodlinesom,na levelu society of leopold 3 kada trebam pobjeć van iz spilje sa gumenjakom igra mi se sruši,i tako svaki put.Sruši se kada se počne loadat idući level?i tako svaki jebeni put na istom mjestu i ja nemogu dalje igrat?
Igra nije oreginal.
Pliz help!!!!
"One bright morning when my work is over I will fly away home" Bob Marley
StreetSajla Forum
SulE je offline   Reply With Quote
Staro 18.02.2005., 19:32   #2
SulE
SulE's Avatar
Postovi: 38
Evo i eror report
Danas neću moć vidjet odgovore,ali ako još šta treba sutra ću dodat!
Hvala
* * * Vampire Crash Data Log, Generated From Exe Built On: Oct 6 2004 * * *
vampire caused an Access Violation (0xc0000005)
in module vampire.exe at 001b:00000001.
Read from location 00000001 caused an access violation.
Context:
EDI: 0x00000001 ESI: 0x00000000 EAX: 0x00000001
EBX: 0x00000000 ECX: 0x0012e9f8 EDX: 0x20b42dd8
EIP: 0x00000001 EBP: 0x2009acb6 SegCs: 0x0000001b
EFlags: 0x00010202 ESP: 0x0012e784 SegSs: 0x00000023
Bytes at CS:EIP:
-----[ SysInfo ]-----
Error occurred at 2/19/2004 10:40:12.
1 processor(s), type 586.
99% memory in use.
512 MBytes physical memory.
4 MBytes physical memory free.
931 MBytes paging file.
75 MBytes paging file free.
2048 MBytes user address space.
1106 MBytes user address space free.
-----[ StackTrace ]-----
0x20D5E078 : ?F@@YAXPAPAVIEngineAPI@@@Z in D:\vampire\bin\engine.dll
0xCE8B5501 : <unknown symbol> in <unknown module>
-----[ ScopeTrace ]-----
SCOPE_TRACE data, stack depth = 3
02. RunListenServer ()
01. CEngineAPI::Run ()
00. LauncherMain ()
-----[ ModuleList ]-----
Module 1
D:\vampire\vampire.exe
Image Base: 0x00400000 Image Size: 0x00017000
Checksum: 0x00000000 Time Stamp: 0x4164cd8f
File Size: 1298432 File Time: 12/6/2004 22:30:30
Module 2
D:\vampire\bin\vstdlib.dll
Image Base: 0x10000000 Image Size: 0x00018000
Checksum: 0x00000000 Time Stamp: 0x4164cbb9
File Size: 94268 File Time: 10/6/2004 22:11:44
Module 3
D:\vampire\bin\tier0.dll
Image Base: 0x10000000 Image Size: 0x00034000
Checksum: 0x00000000 Time Stamp: 0x4164cbb5
File Size: 180280 File Time: 10/6/2004 22:11:44
....ovo dole ide u nedogled
StreetSajla Forum
Staro 18.02.2005., 22:19   #3
E.T.
E.T.'s Avatar
Postovi: 2,458
Ima vise rjesenja ovog problema/bug-a kojima uzgrd receno ova igra nazalost obiluje:
-Prvi je manje zahtjevan i svodi se na instalaciju sluzbenog patcha ver1.2 s ovog linka
-Drugi je objasnjen na ovom forumu link
-Inace se rjesenje takvog i slicnih problema najlakse nade ovako link
googlajte ljudi goooglajte!
www.rabbits-clan.com
E.T. je offline   Reply With Quote
Staro 19.02.2005., 12:34   #4
SulE
SulE's Avatar
Postovi: 38
Hvala kompa
StreetSajla Forum
