#512 |
Xulos :)
Postovi: 7,580
Nije bit u tome da je bolja, nego je neisplativ prijelaz, al posto si ju dao burazu , to vec mjenja stvar .I prvo promjeni napajanje pa tek onda grafu ![]()
#519 | |
Jack of all, master of none
Lokacija: Matulji - Rijeka
Postovi: 6,214
Gigabyte Intros Rev. 2.0 of its GeForce GTX 560 Ti SuperOverclock Graphics Card
SOC je vani ![]() Citiraj:
http://www.techpowerup.com/148081/Gi...hics-Card.html
#521 |
Xulos :)
Postovi: 7,580
Club 3D B.V. brings another GeForce GTX 560 Ti CoolStream OC Edition card to market. This new Club 3D GeForce GTX 560 Ti CoolStream OC Edition features the award winning CoolStream thermal solution. Three pure copper, 6 mm diameter thick heatpipes, ensuring an efficient temperature dissipation. In addition to the high quality heatpipes, two big 92 mm temperature controlled fans, provide a dramatically improved airflow (54CFM) compared to the standard GTX 560 Ti design (35CFM). http://www.techpowerup.com/img/11-06-28/151a.jpg http://www.techpowerup.com/img/11-06-28/151b.jpg
#522 |
Datum registracije: Jun 2011
Postovi: 418
na koliko bi fps vrtila 1 gtx 560 ti bad company 2 ? |
#524 |
Postovi: 346
newyxx kaje tak tesko to lupit u gugl? evo prvi rez... http://www.tomshardware.com/reviews/...14,2845-9.html |
#525 |
Nema zakona jačeg od nas!
Datum registracije: Mar 2008
Postovi: 81
Evo par pitanja... Ponovo. Konfiguracija će biti sljedeća - X4 955 BE, AsRock 880G, 4GB RAM i Seasonic 430W. Dosada mi je prvi pick bila Gigabyte HD6850 (1300kn), ali MSI 560Ti ju ubija u svim kategorijama... Nažalost i u potrošnji - hoće li napajanje biti dovoljno? Samo što 560Ti košta 1550 do 1650kn - 300kn više od HD6850. Obična MSI560 je 1400kn, ali Ti su jače 15ak posto koliko sam shvatio. Drugi ali je činjenica da MSI ima najbolje hlađenje... Dakle troumim se oko sljedećih. MSI GTX 560 1024MB GDDR5 256 bit, N560GTX-M2D1GD5, Dual-Link DVI = 1400kn GAINWARD GTX 560 Ti 1GB GDDR5, GeForce GTX 560 Ti, 822MHz = 1550kn PointOfView GTX560 Ti 1024MB GDDR5 256 bit, DVI 2x, mini HDMI = 1575kn Isplati li se GTX 560 sa X4 procesorom, koja je razlika između GAINWARD i PointOfView modela i isplati li se dati 500kn više za MSI GTX 560 TwinFrozr II OC 1024MB GDDR5 256 bit? I opet, da li je napajanje dovoljno? Savjeti, prijedlozi, sve je dobrodošlo... Komp je za gaming, monitor 22'' (1920×1080).
Hvala ti Bože što sam R I J E Č A N I N Nothing is true, everything is permitted. |
#527 | |
woot!!!
Postovi: 2,501
#529 |
Postovi: 81
Ma nije što je OC, nisam zbog toga gledao... MSI je najkvalitetnija zbog najboljeg hlađenja, a ADM u ponudi nema MSI 560Ti model već samo "obični" 560. Da nude MSI 560Ti, kupio bi odmah...
#530 | |
Datum registracije: Apr 2011
Postovi: 1,430
http://www.adm.hr/product_info.php?c...oducts_id=9705 U glavnom naslovu ne piše, ali piše na šifri proizvoda i vidi se na slici, a ako se ode na link dolje - otvara stranicu proizvođača sa TI verzijom. ![]() |
#531 |
Postovi: 81
OK, čini se da nisam shvatio u potpunosti. Postoji li nešto između tj. MSI 560Ti bez TwinFrozr II OC? Pretpostavljam da bi trebalo postojati. MSI 560 obična (dakle 10ak% slabija od Ti) MSI 560Ti MSI 560 OC Ili se varam pa je 560Ti isto što i 560 OC Twin Frozr II? Čini se da je, barem po Nabavi.
#532 |
Datum registracije: Feb 2010
Postovi: 974
ovako, imaš 560 standardne koje su na 810mhz i njihove oc modele... s druge strane imaš 560ti kojima je stock clock 822mhz i njihove oc varijante.....kod nas u ponudi mislm da nema msi 560ti na stock clockovima...alternative bi u adm-u bile ona point of view ili gainward 560ti |
#533 |
Postovi: 1,430
twin frozr II je oznaka za poboljšano hlađanje twin frozr II/OC je oznaka za poboljšano hlađanje i tvornički overclock kartice i jedna i druga varijanta su moguće i za GTX 560 i za GTX 560 Ti evo ti sve moguće verzije: obična GTX 560 http://hr.msi.com/product/vga/N560GT...-Frozr-II.html http://hr.msi.com/product/vga/N560GT...ozr-II-OC.html GTX 560 Ti http://www.msi.com/product/vga/N560G...-Frozr-II.html http://www.msi.com/product/vga/N560G...ozr-II-OC.html http://www.msi.com/product/vga/N560G...n-Edition.html http://www.msi.com/product/vga/N560GTX-Ti-Hawk.html http://www.msi.com/product/vga/N560G...#?div=Overview |
#534 | |
Postovi: 8,241
Ima više verzija, s tim da OC model postoji i u običnoj 560 i u 560Ti verziji. Ja sam kratko imao MSI 560Ti OC TwinFrozr2, to bi trebao bit top model iz te serije. ![]()
Sent from AS/400. |
#535 |
Postovi: 81
OK, najbolja (koju si ti naveo) u ADM-u košta 1700kn. Najgora koju ću izabrati košta 1550kn. To je GAINWARD Ti model. Obična (dakle ne Ti) je 1400kn, to je backup doslovno, ako budem htio jeftiniju konfiguraciju. Hvala puno na razjašnjavanju situacije, sad je sve jasnije. ![]()
#537 | |
Postovi: 12,433
Koji dio nije jasan? ![]()
#540 |
Lokacija: KC (HR)
Postovi: 917
