#31 |
Postovi: 1,082
#33 |
Premija
Datum registracije: Mar 2009
Postovi: 1,634
Opa, pa ovo čudo bi moglo prestić Aresa po cijeni ![]()
K: 7950GX2, 8800 Ultra, GTX295 |
#35 | |
Datum registracije: Nov 2010
Postovi: 1,942
Očito će ta GTX 590 zvijerka biti brzo predstavljena jer su je naveli u 266.7x beta driverima. GeForce GTX 590 and GTX 550 Ti pops up in New Beta Driver Citiraj:
#36 |
Postovi: 5,997
Bas me zanima koja ce prva izac. Bilo je svakakovih informacija da nece uopce, da ce bit sporija od radeonke i sl. U svakom slucaju ce bit spektakularna grafa i strahovito me zanima TDP, odn na koju foru ce bit 300w. |
#41 |
Postovi: 5,997
Nije predvideno ali radi bez greske. Nije tx650 onda ni prilagoden za vise od 1 grafe a ja sam bez problema ganjal 3 kom sa njim. Bilo kako bilo ak mislis takvu zvijer ganjat, odn. imat neke koristi od nje bez 2560x1600 monitora ili 3 manja i i7 proca na 4.0ghz nema smisla. |
#42 |
Postovi: 2,523
To nema veze, jako malo graficki ga uopce zahtjeva, gledaj samo jacinu napajanja, pod to mislim na kolicinu ampera na 12v railu. Ni jedno napajanje nije "customizirano" za odreden tip kartica... Edit: Magarac me prestigo :-) |
#45 |
Premium spammer
Datum registracije: Aug 2010
Lokacija: D.Zagora
Postovi: 776
NVIDIA GeForce GTX 590 Launch Date is March 22 The dust seems to have settled down, after AMD's launch of the Radeon HD 6990, extending the red-team's performance lead previously held precariously by the Radeon HD 5970, to the GeForce GTX 580. It looks like NVIDIA will challenge the performance leadership with GeForce GTX 590, a dual-GPU graphics card that uses two GF110 GPUs (the ones on GTX 570 and GTX 580), for an SLI-on-a-stick solution. Rumors of NVIDIA working on this card became concrete as early as in November 2010, when NVIDIA's reference board became public for the first time. Latest reports suggest that NVIDIA has chosen March 22 as the launch day of GeForce GTX 590. Incidentally, that is also the launch date of EA/Crytek's much-hyped, initially DirectX 9 action/shooter game, Crysis 2. GeForce GTX 590 uses two GF110, though the shader configuration and clock speeds are not known. Since NVIDIA is chasing the top-spot, you can expect the most optimal configuration for the GF110s. A total of 3 GB (1536 MB per GPU system) on board, and NVIDIA's workhorse PCI-E bridge, nForce 200 will be the traffic cop and radio station between the two GPUs. The card will be able to do 3DVision Surround (NVIDIA's multi-display single head technology comparable to ATI Eyefinity) on its own, without needing a second card. ![]() http://www.techpowerup.com/141837/NV...-March-22.html |
#47 | |
Jack of all, master of none
Lokacija: Matulji - Rijeka
Postovi: 6,214
#49 |
Lokacija: NaN
Postovi: 3,438
#51 | ||
Postovi: 6,214
#52 |
Lokacija: NaN
Postovi: 3,438
Ma normalno da je dual slot, gdje bi stao taj treći aktivni DVI za mogućnost single card nVidia Surrounda kojeg su više puta najavili, a i sumnjam da ne bi još pored njih imala i HDMI/DP izlaz, jednostavno ne bi fizički stalo na single slot I/O backplate. Da ne pričam o količini topline (i vrlo vjerojatno većeg RPM-a/buke ventilatora) koje bi proizvodila ma koliko god da hladnjak bio dobar. |
#53 | |
Postovi: 6,214
#54 | |
Postovi: 6,214
GeForce GTX 590 Key Features Revealed
![]() http://www.techpowerup.com/142153/Ge...-Revealed.html
#55 |
prof.dr. gospodar svemira
Postovi: 432
http://www.fudzilla.com/graphics/ite...ks-the-gtx-590 600MHz mi se cini puno prenizak takt. Tako su vec "zaklali" GTX470 sa preniskim taktovima.
If you are not paranoid you don't have enough information |
#56 | |
Postovi: 1,082
#57 | |
Postovi: 6,214
NVIDIA GeForce GTX 590 Launch Delayed to March 24?
Odgoda od par dana izgleda... Citiraj:
#59 |
Postovi: 159
Objavljeni podaci: D13U-50 GF110/P1020 CUDA Cores 1024 Graphics Clock 612MHz Processor Clock 1224MHz Memory Clock 3420MHz Memory Interface Width 2 x 384-bit Memory Config 3GB GDDR5 Power Connector s Dual 8-pin Dimensions 11" x 4.5", Dual Slot Read more: http://vr-zone.com/articles/nvidia-g...#ixzz1H4PkVc10 |
#60 |
Premium spammer
Lokacija: D.Zagora
Postovi: 776
