Staro 26.07.2010., 13:43   #451
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,581
Da je neznam tko, nije imao srece jer je na takav banalan nacin uspio ubit takav proc
Staro 26.07.2010., 14:10   #452
DomagojX
Lokacija: Zagreb/Sesvete
Postovi: 1,307
a joj kaj je to njemu..to ko da je potrošio dnevni džeparac
DomagojX je offline   Reply With Quote
Staro 26.07.2010., 16:59   #453
MAGARAC
MAGARAC's Avatar
Postovi: 5,997
Autor xulos Pregled postova
Ma kontra. Ekipa je sretna je se može riješit loših proceva . Proguglaj malo pa buš videl.
Staro 09.08.2010., 09:47   #454
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,760
Autor bluefluid Pregled postova
ASUS SaberTooth X58 unveiled
ASUS officially introduced the TUF Series SaberTooth X58, a new motherboard that focuses on delivering the best stability, reliability, endurance, and value. SATA 6Gbps and USB 3.0 are included in the features list, but pricing and availability is unknown.
The board has high-quality chokes, solid state capacitors and MOSFETs and a CeraM!X Heatsink Coating on the more critical surfaces and components to enhance heat resistance and dissipation. As for actual specification, six DDR3 memory slots are present, as well as six SATA 3.0 Gbps connectors, a pair of SATA 6.0 Gbps ports and three PCI Express x16 slots that are more than apt for multi-GPU SLI or CrossFireX setups. Finally, the Sabertooth features an 8+2 phase power design, Gigabit Ethernet, two eSATA ports, 7.1 channel audio and FireWire.
The SaberTooth X58 also includes Gigabit Ethernet, two eSATA and two USB 3.0 ports, 7.1 channel audio and FireWire.
Izvor: guru3d
ASUS SABERTOOTH X58 Heavy Duty Motherboard Joins Durable TUF Series
The SABERTOOTH X58 from ASUS uses heavy duty materials and parts to ensure truly unmatched capabilities in terms of stability, reliability, endurance, and value.
The chokes, solid state capacitors and MOSFETs have all been tested under the most arduous of conditions and harsh environments based on military standards, providing users with a proven heavy duty solution.
TUF Series motherboards are ruggedized from the ground up, so they can handle more than just long-haul usage and heat. They are also tested to server-grade standards and can stand up to humidity and ambient temperatures to an exponentially larger extent than normal motherboards. As a consequence, they are long-life products users can install with complete confidence.
Being strong does not mean TUF Series motherboards compromise added features. The SABERTOOTH X58 ships with new data transfer standards USB 3.0 and SATA 6GB/s, so it offers some of the latest innovations in addition to superior strength. It is a complete package of guaranteed reliability and compatibility.
Izvor: techpowerup
Staro 16.08.2010., 18:21   #455
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Kakva je budućnost socketa 1366? Vidim sad da neš ima brzih procesora za 1156, da će izać 1155... Ne nalazim ništa za tzv. high-end 1366? Jedan chipset...
Staro 16.08.2010., 20:55   #456
Postovi: 7,568
Nema budućnosti i nema novih čipseta za LGA-1366. LGA-2011 je sljedeći novi high-end i stiže krajem godine skupa s Core i7-2000 modelima.
Zadnje izmijenjeno od: McG. 16.08.2010. u 21:12.
Staro 16.08.2010., 22:09   #457
blue#13
Postovi: 516
Graphics clock?
Kaj ce svaki procesor imati integriran GPU u sebi?
blue#13 je offline   Reply With Quote
Staro 16.08.2010., 22:23   #458
fran123456
Premija
fran123456's Avatar
Datum registracije: Mar 2009
Postovi: 1,634
Očito. Meni je najinteresantiji Quad sa TDPom od samo 45W
fran123456 je offline   Reply With Quote
Staro 16.08.2010., 22:36   #459
luks 88
luks 88's Avatar
Postovi: 477
a taj GPU integrirani će moći poslužiti za igranje ili ne ?
luks 88 je offline   Reply With Quote
Staro 16.08.2010., 22:51   #460
MAGARAC
MAGARAC's Avatar
Postovi: 5,997
Autor luks 88 Pregled postova
Ko i svi dosadašnji. Bude ali nebu ni blizu grafičkim karticama, male rezolucije i low detalji.
Zgodna je ova Asusova matična.
Staro 16.08.2010., 22:53   #461
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,772
Hmm, cisto sumnjam da ce integrirani GPU vrtiti novije igre - barem sto se tice zahtjevnijih igara (citaj: sve osim tetrisa, šaha, 2d igara i nekih nezahtjevnih 3d ). Salu na stranu, naravno da je moguce da ce GPU imati dovoljno "snage" da pokrene novije naslove, ali Imho to ce biti s ogranicenim detaljima i bez AA. AMD je vec demonstrira svoj novi CPU sa int. GPU-om koji "vrti" AvP3...
Sn4k3 je online   Reply With Quote
Staro 16.08.2010., 23:21   #462
RobCo PIP-Boy
Datum registracije: Aug 2010
Lokacija: Poluotok
Postovi: 42
mogu li dobiti link na tu AMD-ovu demonstraciju, Snejk?
RobCo PIP-Boy je offline   Reply With Quote
Staro 16.08.2010., 23:30   #463
Postovi: 7,568
Autor Sn4k3 Pregled postova
S tim da je u toj demonstraciji korišten dvojezgreni Ontario (AMD-ov odgovor na Intelov Atom) procesor namijenjen mobilnom tržištu. Prvi desktop Fusion, tj. Llano procesori budu dolazili s DX11 HD 5000 grafičkim karticama sa 480 stream procesora. Primjera radi, jedna HD 5670 ima 400 stream procesora i sasvim vredu vrti moderne igre. Jasna stvar da niko živ ne bude očekival gamerski stroj od novih procesora koji dolaze s integriranom grafičkom karticom, ali ipak budu višestruko bolji izbor od sadašnjih IGP rješenja. Kaj se tiče Intelove inetgrirane grafike - zasad se ama baš ništ konkretnog ne zna.
Možda budu skupa s procesorima ponudili IGP u rangu s AMD rješenjem, a možda budu integrirali samo malo bolju verziju od sadašnjih Intel HD IGP-a koje koriste Clarkdale procesori.
Autor RobCo PIP-Boy Pregled postova
Autor McG Pregled postova
AMD demonstrated its first Fusion APU (accelerated processing unit), which is a "fusion" between a processor and a graphics processor. The first such processor in the works is based on the 32 nm silicon fabrication technology, codenamed Llano, and fuses a quad-core processor with a DirectX 11 compliant GPU. AMD's Rick Bergman showed off a wafer of the Llano APUs, but it didn't stop there. Rick surprised the press when he went on to claim that the APU can power Aliens vs. Predator in DirectX 11 mode, with a reasonable level of detail, which was demonstrated.
Izvor: techPowerUp i TweakTown
Zadnje izmijenjeno od: McG. 16.08.2010. u 23:52.
Staro 16.08.2010., 23:33   #464
luks 88
luks 88's Avatar
Postovi: 477
kaj mislite dal se ide u smjeru da će za par godina "izumrjet" standardne grafičke i da će bit integrirane u CPU?
Staro 16.08.2010., 23:40   #465
Postovi: 7,568
Danas je skoro "sve" integrirano u nove procesore, ploče i čipsete, a opet se i dalje rade kojekakve zasebne kartice. Grafičke kartice ne idu nikud još dulji niz godina.
Staro 17.08.2010., 00:02   #466
RobCo PIP-Boy
Lokacija: Poluotok
Postovi: 42
hvala na linku...pretpostavljam da će izumrijeti kad riješe zagrijavanje.
Staro 17.08.2010., 00:09   #467
Postovi: 7,568
Bez obzira dal srede zagrijavanje, tržište (i marketing) diskretnih grafičkih kartica je preveliko i zarađuje prevelike novce, da bi samo tak pokleknulo pred modernim IGP rješenjima.
Neovisno o tome kolko dobre integrirane grafičke kartice postanu, tržište i potražnja za onim zasebnim ne bude iščeznula.
Staro 17.08.2010., 00:47   #468
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Odlično... Mijenjaju sockete ko čarape. Mogli su odmah pustit nekog od 10000 pinova pa da bude za buducnost.
Bezveze, izbacili su jedan čipset za neš što je trebo bit high-end i za kaj su trebali napravit neke nove procesore. Na kraju su bubnuli i7 od 920 do 960 i nedavno dali zadnji šestojezgreni koji košta ko suho zlato.
I da ne velim kakva glupost je kaj još uvijek neki i7 920 košta 2086 kn za kolko sam ga kupio malo poslije nego kaj je izašo, a da npr malo naklokaniji 940 koji nema smisla košta 3652 kn.
Staro 17.08.2010., 15:17   #469
Postovi: 7,568
Nema novci u takvim dugovječnim proizvodima. Nije im u interesu složiti platformu koja bude trajala jedno 5 do 10 godina, a oni bi za to vrijeme samo nudili nove procesore i proizvođačima slali upute za nove BIOS-e. Ovak svaku godinu predstave nekaj novo, nekaj kaj traži zamjenu većine dosadašnje platforme ili kupnju kompletno nove. Marketing radi svoje, proizvođači ploča predstavljaju nove modele i svi zarađuju. Osim toga, Intel je taj koji diktira u kojem smjeru bude se kretela većina današnje tehnike i tehnologije i živo ih zaboli, kad znaju da bude se sve kaj smisle - prodalo ko da se dijeli.
Staro 22.08.2010., 04:10   #470
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Imam osjećaj da je ovo palo iz vedra neba.
Staro 05.09.2010., 03:51   #471
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,760
ASUS Rampage III Formula Motherboard Review
Before moving on, I have to highlight that the Rampage III Formula will unfortunately not be making its way to Europe
The above table shows the main differences between the Rampage III Extreme and the new Formula. Despite the smaller and regular ATX form factor, there is very little that the Formula omits from its bigger brother. Instead of four PCIe x16 slots, the Formula only brandishes three. This isn't a great loss considering most users only use one or two GPUs and Quad SLI support isn't present even on the Extreme, hence demonstrating the welcoming compromise the board has reached. In terms of power circuitry and overclocking feature, the Formula only has a 2 phase VRM circuitry for the Northbridge and memory instead of 3 but it is still superior to the GENE's design. As previously mentioned, the RC Bluetooth module is also absent but ROG Connect serves the same functionality. The Formula does benefit from a few additional features over its bigger brother such as the onboard SupremeFX X-Fi2 chip , ASUS GameFirst and additional onboard USB ports to remain true to its gaming prowess.
Izvor:www.vortez.co.uk
Zadnje izmijenjeno od: bluefluid. 05.09.2010. u 03:59.
Staro 05.09.2010., 13:00   #472
Wolverine
Wolverine's Avatar
Postovi: 12,433
Ovi u Asusu mi nikako nisu jasni. Normalne ploče im imaj PLX a ove super-duper-ultra-mega nemaju.
Mark Twain
Intel Core i7 2760QM
2x 8GB DDR3
Intel HD3000
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 20.09.2010., 12:26   #473
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,760
ASUS TUF Sabertooth X58 review
Then the integrated passive ceramic-coating technology offers splendid of cooling performance as well. So while we can discuss and lift every theory and thesis on this motherboard, we like to keep it plain and simple. The ASUS TUF Sabertooth X58 is a good motherboard with decent feature set, nice performance, good tweakability and a stunning design, it's the Rambo amongst motherboards. If a 199 USD budget is your limit, then we can recommend this rugged looking sturdy piece of hardware very much.
Izvor: guru3d
Link na sluzb.stranice
Zadnje izmijenjeno od: bluefluid. 20.09.2010. u 13:44.
Staro 21.11.2010., 12:15   #474
Prcko Prcić
Datum registracije: Sep 2010
Lokacija: Lepoglava
Postovi: 178
da li netko zna da li sabertooth podrzava xeon E5502? Na asusovoj stranici ga niti ne spominju, ni da podrzava, ni da ne...
Prcko Prcić je offline   Reply With Quote
Staro 21.11.2010., 12:52   #475
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
Trebala bi. Ni za GB UD5 niti za Classified mi ne piše da podržava moj w3565 pa evo radi na objema
Bullet1 je online   Reply With Quote
Staro 21.11.2010., 13:22   #476
Prcko Prcić
Lokacija: Lepoglava
Postovi: 178
ok. Hvala Bullet
Staro 19.12.2010., 16:28   #477
_saiko
system kaiser
Postovi: 194
Socket 1156 vs 1366 rupe za cooler
Dakle zanima me da li su rupe za cooler na ploči istog razmaka za 1156 i 1366?
Stvar je u tome da imam stariji zalmanov (7700CU) cooler za kojeg se može nabaviti "stalak" za socket 1156, no ja imam 1366.
E sad da ne nabavljam bezveze prvo ću pitati.
Eto toliko, hvala.
_saiko je offline   Reply With Quote
Staro 19.12.2010., 16:29   #478
fran123456
Premija
fran123456's Avatar
Postovi: 1,634
Nisu istog razmaka. 1156 su manje za par mm.
Staro 19.12.2010., 16:39   #479
_saiko
system kaiser
Postovi: 194
Ziher? Ima negdje u dokumentaciji?
Steta onda :\
Staro 19.12.2010., 17:58   #480
vladosch
vladosch's Avatar
Lokacija: Garešnica
Postovi: 100
Najbolja opcija koju sam ja napravio je da upecaš neku od ASRock ploča, jer one imaju na socketu 1156 rupe i za hladnjake socket 775. Imam Thermaltake SonicTower rev 2 sa velikim hladnjakom i bilo mi je žao to mijenjati, a hlađenje je odlično. Matična mi je H55M PRO.
Eto staviš cooler od 775 na matičnu 1156 i riješeno.
vladosch je offline   Reply With Quote
