Staro 18.02.2010., 05:02   #151
stasio
stasio's Avatar
Lokacija: Malaysia
Postovi: 96
CPU-Z 1.53.2 - updated
-fix CAS for Clarkdale
-released 15.02.2010
This is internal beta version and without validation.
Need a Gigabyte latest BIOS?
GA-P67A-UD7 (B3-F3h), Core i7-2600K @ 5.1 GHz
G.Skill F3-17600CL8D-4GBPS @ 2133 (8-9-8-24-CR2)
G.Skill F3-17000CL8D-4GBXMD @ 2133 (7-9-7-20-CR1)
Evga GTS 450SC,WD Caviar Black SATA3 1TB HDD,
Corsair Hydro-H50 (MX-2)
Gigabyte Superb 720W,Windows 7 SP1
stasio je offline   Reply With Quote
Staro 28.02.2010., 11:00   #152
stasio
stasio's Avatar
Lokacija: Malaysia
Postovi: 96
Staro 02.03.2010., 04:50   #153
stasio
stasio's Avatar
Lokacija: Malaysia
Postovi: 96
Staro 25.03.2010., 02:50   #154
stasio
stasio's Avatar
Lokacija: Malaysia
Postovi: 96
CPU-Z 1.54 -32bit
CPU-Z 1.54 -64bit
* Intel Core i7-880, Core i5-680, Core i3-550 processors.
* Intel Xeon 5600 line (32nm) processors.
* AMD Phenom II X6, Sempron II, Turion II, Turion II Ultra and Athlon II Mobile "Caspian" processors.
* NVIDIA GeForce 320M chipset.
* AMD 870/880G/890GX + SB800/SB850 chipset.
* Introduction of validation rooms.
Staro 31.05.2010., 03:05   #155
stasio
stasio's Avatar
Lokacija: Malaysia
Postovi: 96
Staro 13.06.2010., 05:57   #156
stasio
stasio's Avatar
Lokacija: Malaysia
Postovi: 96
Staro 10.07.2010., 02:06   #157
Voorhees
Datum registracije: Jul 2003
Postovi: 167
CPU-Z v1.55
* VIA VX900/VX900M and VN1000/VN1000M chipsets.
* Intel Core i5-760, Core i7-875K and Core i5-655K processors.
* Intel Core i7-940XM, 840QM, 740QM mobile processors.
* Intel Core i5-450M, 540UM, 430UM, Core i3-370M mobile processors.
* Intel Pentium P6000 processor.
* New parameter in cpuz.ini : UseDisplayAPI
x86 (zip)
x64 (zip)
x86/x64 (installer)
za Win98 (zip)
Voorhees je offline   Reply With Quote
Staro 28.10.2010., 12:13   #158
pci_e3x
Premium spammer
pci_e3x's Avatar
Datum registracije: Aug 2010
Lokacija: D.Zagora
Postovi: 776
v 1.56
-Intel Core i3/i5/i7 "2000" serie processors (Sandy Bridge) with new logos.
-Intel Core i7 970 "Gulftown".
-Intel P67 chipset.
-AMD Phenom II, Athlon II and Sempron II "Caspian" processors.
Setup
x64 Zip
x86 Zip
Staro 12.01.2011., 09:12   #159
stasio
stasio's Avatar
Lokacija: Malaysia
Postovi: 96
Staro 19.02.2011., 04:14   #160
stasio
stasio's Avatar
Lokacija: Malaysia
Postovi: 96
CPU-Z 1.57
ftp://ftp.cpuid.com/cpu-z/cpu-z_1.57-setup-en.exe
ftp://ftp.cpuid.com/cpu-z/cpu-z_1.57-32bits-en.zip
ftp://ftp.cpuid.com/cpu-z/cpu-z_1.57-64bits-en.zip
* Intel Xeon "Westmere-EX" support
* GPU frequency report on Intel Sandy Bridge processor
* AMD Zacate/Ontario processors support
* Report TDP on main page when available
* Cores clocks on floating menu
* P67/H67 stepping report
Staro 25.06.2011., 07:02   #161
Voorhees
Postovi: 167
CPU-Z v1.58
* AMD FX "Bulldozer" processors family (K15)
* AMD Llano processors family (K12)
* Intel Sandy Bridge-EP processors preliminary support
x86 (zip)
x64 (zip)
x86/x64 (installer)
Staro 02.07.2012., 22:06   #162
Voorhees
Postovi: 167
CPU-Z v1.61
* Intel CedarTrail platform.
* VIA VX11 chipset.
* Intel Xeon E5 processors.
* Fix wrong CPU clock speed under Win8.
x86 (zip)
x64 (zip)
x86/x64 (installer)
Staro 17.06.2014., 09:12   #163
alengrosevic
alengrosevic's Avatar
Postovi: 3,799
evo, izašla je i verzija 1.69.2
http://www.cpuid.com/softwares/cpu-z.html
Staro 19.09.2014., 14:54   #164
ukiy
ukiy's Avatar
Datum registracije: Apr 2008
Lokacija: ST
Postovi: 398
Ekipa, imam jedan problem sa CPU-Z...
Naime, komp se smrzne sekund nakon sto pokrenem validaciju i prisiljen sam napraviti restart...
Event Viewer ne pokaziva nikakav problem i svi ostali slicni programi (HWInfo, aida64) rade normalno... Validation link mi ipak stigne na mail, okacio sam ga u potpis...
E sad je baza u tome sto se ovo dogadja samo kad je instaliran Pentium G3258 na MSI B85-G43 ploci, ako je gore i5-4570 CPU-Z radi ko podmazan.
Ima li tko slicnih problema?
ukiy je online   Reply With Quote
Staro 19.09.2014., 16:02   #165
ShanTech
Datum registracije: Apr 2011
Postovi: 3,784
Vidiš da ti program piše bedastoće (core voltage 0.36V). Jesi probao s drugom verzijom programa? Isto tako, da li je na ploči najnoviji bios?
CPU je inače stabilan, testirano?
Staro 19.09.2014., 16:27   #166
ukiy
ukiy's Avatar
Lokacija: ST
Postovi: 398
Ma to je idle napon, dobro pise. Koristim zadnju verziju, nisam pokusava sa starijom, racunam novije-stabilnije, ali budem probao...
Na ploci je zadnja verzija BIOSa... Nisam pretjerano testirao stabilnost, sat vremena sa aida64 stres testom, 4.5GHz@1.250 temperature ne prelaze 60C...
Inace nema nikakve razlike proc bio OC-an ili ne, CPU-Z svejedno radi problem.
