Postovi: 1,606
Omega Drivers v2.5.97a (Cat 4.12)
What's New in Omega Drivers? Update v2.5.97a * Based on the Catalyst 4.12 Official drivers. * Fixed the version typo from previous release. * Forced some wide screen resolutions that didn't worked on previous set. * Could have fixed the FireGL OGL problems, need to test it thou. * Changed readme to html style instead of text. * Added a new section to readme to include RadLinker specific changes and fixes. What's new for RadLinker? v2.026 * Fixed installation problems with Windows 9x. * Fixed GUI problems with Windows 9x. * Added RadClock back to the package to help set the clock rate during bootup for people that have this problem. * Added option to remove context menu selection (thus removing ~90% of RadLinker's functionality) * Added fixed Polish language translation thanks to Adam "Poke" Grubba. http://www.omegadrivers.net/ |
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Sutra ih skidam, da li je već probao netko? |
Postovi: 1,606
Probao; kao i obično nikakvih problema nema ![]() |
Lika u mom srcu
Lokacija: Canada, Toronto
Postovi: 9,887
e pa meni neče uopće da prođe instalacija... pa sam skinuo oriđiđi ATI i softmodane da mogu clocknut sa ATItool-om, i super. ja sam do sada isprobavao i oriđiđi i Omega, ali razlike apsolutno nikakve.. s tim da u benchevima Omega daje malo slabije rezultate. U igrama sve je to ista kita... ![]() |
Lokacija: Ribarska 29, 52203 Medulin, Hrvatska
Postovi: 225
Sve OK
Skinuo odavno i već zaboravio Sve radi OK, igre, Benchovi itd, rezultati isti kao sa Omega 4.10 |
Super Moderators
Postovi: 17,485
Sve dela ok Čuo sam da nekima dela Radlinker problem pri instalaciji, neka instaliraju bez Radlinkera. Pa njega poslje restarta. |
Lokacija: Azeroth
Postovi: 106
skinuo sam doticne drivere ali mi svaki put nakon restarta windowsa radlinker vraca vrijednosti na default...help... |
#8 | |
Super Moderators
Postovi: 17,485
Ako lupiš samo Set-pri svakom restartu će se vratiti na staro. |
Lokacija: ZG - VŽ
Postovi: 375
evo da ne otvaram novi thread, trebam pomoc u vezi omega ( i ati drivera opcenito). radio sam prije par mjeseci reinstal winsa i stavio sam omegu 2.5.90 sve je ok radilo i nisam se previse igrao u zadnje vrijeme. Problemi dolaze kad sam instalirao NFSU2. Pri pokretanju igre ekran se zacrni i kreten pocne zajebavat, monitor skljoca kao pri promjeni refresha i reze i to tak ide jedno minutu da bi onda pokrenuo igru ali bez slike. onda mi je prekipilo i kresnem ja po restartu i pokusam ponovo. igra se podigne ali je donekle igriva tek u 800x600 sa svim na low. mislim si nije ovaj nastavak nista zahtjevniji od prvog a prvi je isao u toj rezi sve na full. odlucio ja se rijesit omege. deinstaliram ih u control panelu, restartam, pokrenem driver cleaner omega edition, restartam, deinstaliram setup od omega, restartam u safe mode i pocistim jos sa driver cleanerom. kad sam ga opet restarto pokrene mi se new hardware wizard i napise mi da je naso vga adapter, radeon 9600 series (omega 2.5.90). odlucim stavit catalyst 3.4 (to sam imo pri ruci, a i ti driveri su radili odlicno kad sam prvi put instaliro tu karticu). kad sam restarto sve radi super, igra leti sa 800x600 i sve na high. e sad idem ja sljedeci dan pokrenut igru a ona se ili pokrene odmah ili se ne pokrene uopce, ovisi o raspolozenju kompa. ta ista igra radi normalno kod frenda bilo s catalystima ili omegama. ako neko ima rijesenje molio bi da napise a ako ne neka napise koje da drivere stavim nakon sto kompu poklonim zakasnjeli bozicni poklon zvan Format C: ![]() |
Lokacija: Azeroth
Postovi: 106
hvala na tako brzom odgovoru... |
Lokacija: Ljubljana-Rijeka-Cres
Postovi: 154
da radlinker definitivno radi problem kod instalacije (imao sam prilike probati na kakava 3-4 PC). Probajte sa Driver Cleanerom ocistiti CAB fajlove i prijasnju instalaciju Omege i trebalo bi sve biti ok. Sto se tice samih drajvera sa svakom novom verzijom mi se smanjuje 3Dmar05 score: Catalyst 4.11..........1589 Omega 2.5.90.........1623 Omega 2.5.97.........1590 Omega 2.5.97a.......1581
HP NX9420 Core Duo T2400 1,83GHz 2GB RAM Seagate 100GB SATA ATI X1600PRO 256MB ram 17" LCD |
#12 | |
Super Moderators
Postovi: 17,485
Benchevi su mi sa novom verzijom sporiji kakvih 1%, ali zato HL2 ide dosta bolje. |
#13 | |
Super Moderators
Postovi: 17,485
Omega za 96xx seriju preporučuje da ako ima problema-FastWrite uključiš. |
Lokacija: Velika Gorica
Postovi: 624
znaci nisam samo ja imal takvih problema , prije par mjeseci i ja sam isto imal takvih problema ko Vodokotlic,istih takvih i nikak doc na zelenu granu sa NFSU2 sve sam pokusaval mjenjat drivere ma bas sve , ni jedan nacin nije bio toliko ucinkovit kao format C: sta se mora mora se |
Super Moderators
Postovi: 17,485
Pa, kad se drži osnovnih pravila pri promjeni drivera-takvih problema je manje. A i neke igre znaju zezati, najbolje je onda spremiti pozicije i lupiti re-instal igre. |
