Staro 21.06.2010., 01:18   #1
amilo1538
Datum registracije: Jun 2010
Lokacija: Solin
Postovi: 44
Bijeli ekran na laptopu???
Laptop: Fujitsu Siemens Amilo Pa 1538
Star 2,5 godine
Od toga upaljen sigurno 2 godine (skidanje, leechanje)
Dodao sam mu 1 gigu rama naknadno, znači ima 2 gige rama.
I sad, kada ga upalim, bude mi bjeli ekran. Pretpostavljam da je ošla grafička.
Ima li tko sličnih problema, ili zna rješenje?
Svaka pomoć dobrodošla!!!
TNX!
Specifikacije Laptopa:
General
Windows Vista Certification Windows Vista Premium Ready
System Type Notebook
Built-in Devices Stereo speakers, wireless LAN aerial
Width 35.7 cm
Depth 25.9 cm
Height 3.5 cm
Weight 2.7 kg
Processor
Processor AMD Turion 64 X2 mobile technology TL-50
Multi-Core Technology Dual-Core
64-bit Computing Yes
Features PowerNow! technology, HyperTransport technology, AMD64 technology, integrated memory controller, Enhanced Virus Protection
Cache Memory
Type L2 Cache
RAM
Installed Size 1 GB / 2 GB (max)
Technology DDR2 SDRAM
Storage Controller
Type Serial ATA
Serial ATA Interface Serial ATA-150
Storage
Hard Drive 120 GB - Serial ATA-150
Optical Storage
Type DVD±RW (+R double layer)
Read Speed 24x (CD) / 8x (DVD)
Write Speed 24x (CD) / 6x (DVD±R) / 2.4x (DVD+R DL)
CD / DVD Rewrite Speed 20x (CD) / 4x (DVD±RW)
Card Reader
Type 4 in 1 card reader
Supported Flash Memory Cards SD Memory Card, Memory Stick, Memory Stick PRO, MultiMediaCard
Display
Display Type 15.4" TFT
Max Resolution 1280 x 800 ( WXGA )
Widescreen Display Yes
Features Crystal View
Video
Graphics Processor / Vendor NVIDIA GeForce Go 7400 TurboCache supporting 512MB
Video Memory 128 MB
Audio
Audio Output Sound card
Features 7.1 SPDIF
Audio Input Microphone
Input Device(s)
Type Keyboard, touchpad
Telecom
Modem Fax / modem
Max Transfer Rate 56 Kbps
Protocols & Specifications ITU V.92
Networking
Networking Network adapter
Wireless LAN Supported Yes
Data Link Protocol Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g
Compliant Standards IEEE 802.11b, IEEE 802.11g
Expansion / Connectivity
Expansion Slots Total (Free) 2 ( 0 ) x memory
1 ( 1 ) x ExpressCard/54
Interfaces 1 x IEEE 1394 (FireWire)
4 x Hi-Speed USB - 4 PIN USB Type A
1 x display / video - S-video output
1 x modem - phone line - RJ-11
1 x network - Ethernet 10Base-T/100Base-TX - RJ-45
1 x display / video - VGA - 15 pin HD D-Sub (HD-15)
1 x microphone - input - mini-phone 3.5mm
1 x audio - line-In - mini-phone stereo 3.5 mm
1 x audio - SPDIF output/headphones
amilo1538 je offline   Reply With Quote
Staro 21.06.2010., 18:36   #2
Ivic@
Postovi: 88
Ako imaš probaj spojit neki monitor na VGA izlaz pa vidi dali ima slike, ako ima onda vjerojatno il ti je otišo LCD ili je negdje slab neki kontakt između LCD-a i matične, eh ako nema slike ni na njemu bojim se da je matična...
Ivic@ je offline   Reply With Quote
Staro 22.06.2010., 15:40   #3
Dawg
kernel panic
Dawg's Avatar
Lokacija: Kroejša
Postovi: 30
Prije bih reko da ti je matrica riknula na lcd-u, probaj vanjski monitor prištekat kao što Ivic@ kaže.
Dawg je offline   Reply With Quote
Staro 26.06.2010., 16:05   #4
mariposa_cro
mariposa_cro's Avatar
Postovi: 31
ili je lcd panel otisao ili ti se jednostavno otkačio ili sj.... kabel između ploče i panela
pod uvijetom da ima izlaza preko vga porta naravno
Zadnje izmijenjeno od: mariposa_cro. 26.06.2010. u 16:11.
mariposa_cro je offline   Reply With Quote
Staro 30.06.2010., 04:46   #5
amilo1538
Lokacija: Solin
Postovi: 44
Imam mali update.
Sada mi tek ništa nije jasno.
Laptop valja, vratio sam mu vistu ultimate x86, par puta ga upalio i ugasio, radi normalno na svom ekranu, ko da mu se ništa nije dogodilo?
wtf?
jel zna itko šta se događa?
Staro 30.06.2010., 12:22   #6
mariposa_cro
Postovi: 31
Nije ni meni, kako si mu uspio uopće vratiti vistu? Nisi nam rekao da li ima išta kad ga spojiš na vanjski monitor, da li si ga par puta možda zatvorio i otvorio, možda onda i je do lošeg kontakta
Staro 01.07.2010., 22:34   #7
BDD
Lokacija: Bjelovar
Postovi: 42
si probo lagano otvarat i zatvarat lcd u radu,da vidiš da ti ne prekida na kabelu sa matične ili čak sama matična.Probaj još sa hirenom VGA test..poz
BDD je offline   Reply With Quote
