Staro 03.06.2010., 21:10   #1
Jerry
Jerry's Avatar
Postovi: 1,816
DFI Lanparty is no more
http://www.bit-tech.net/hardware/mot...over-for-dfi/2
Autor darkijas Pregled postova
Today, we finally got our answer: DFI told its LANParty team in 2009 there would be no more LANParty products. The division was losing money continually through 2009 and late in the year the sales team were told to clear their inventory before being moved to the far more profitable industrial division.
Bilo je lijepo druziti se s njima. Sada su se pridruzili Epoxu i Abitu. Imam LP nf2 Ultra B, LP nf4, LP ICFX3200, 8rda+, 8npa+ SLI te IC7G max i aw9d max.
Za mene nikakva ROG, FTW i slicna sranja to ne mogu zamijeniti.
Stupid is as stupid does
Jerry je offline   Reply With Quote
Staro 03.06.2010., 21:49   #2
alengrosevic
alengrosevic's Avatar
Postovi: 3,800
Lanparty RIP
definitivno najbolje ploce koje su bile na trzistu...
alengrosevic je online   Reply With Quote
Staro 03.06.2010., 21:50   #3
micek_kc
fanATIčni AMDovac
micek_kc's Avatar
Lokacija: KC-ZG
Postovi: 1,312
Ja sam također imao Nf2 Ultra b plocu i bila je najbolja ploca koju sam ikada imao
Vozio sam gore mobilca na skoro 3ghz i Corsu Bh5 na 550mhz
Sad imam njihovu 790gx jr,prije sam imao 790fx i lagano sam razocaran sa obje...
Sad cemo se trebati okretati Asus/MSI proizvodima(namjerno nisam spomenuo điđabajt jer mi se nikad nisu dopali)
AMD Phenom 9850be 2,5ghz@2,9ghz@OCZ Vendetta 2 700rpm
DFI Lan Party JR 790GX-M2RS
OCZ Blade 2x2Gb ddrII@1066mhz@1.8v
Gigabyte HD4850 1GB Multi Core @passive
Auzentech Meridian@Opamp LM4562NA
2xWestern Digital 6400aaks@RAID 1 + Seagate S-ATA 160gb@XXX
Tagan 480W Supersilent
Thermaltake V1000+ black with side window
Logitech MX500
DELL 2007FP
AMD Athlon 3000+(venice e3) stock
Abit AV8
Kingmax Superram 2x256ddr433 FHAS stock
Gainward 7600GT GS 256mb
Seagate Barracuda 80gb P-ata
Denon AVR-3805 black finish @DIY 3.5mm > 2RCA(Neutrik RCA plugs)
Focal Jmlab Chorus S 726s classic finish@VDH CS-122 HB
Focal Jmlab Chorus S CC700s classic finish@VDH CS-122 HB
Focal Jmlab Chorus S SW700 classic finish@Bandridge Profigold Subwoofer Cable
Review Chorus S serije
Review Denon AVR-3805
micek_kc je offline   Reply With Quote
Staro 03.06.2010., 22:09   #4
d4rk_ch1ld
d4rk_ch1ld's Avatar
Lokacija: Krapinske Toplice
Postovi: 695
Kutiju čuvam do kraja života R.I.P lan party.
d4rk_ch1ld je offline   Reply With Quote
Staro 04.06.2010., 00:58   #5
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,776
U mom kompu je nekad bila UT 590-SLI M2R/G i mogu reci da sam s njom ima i jako dobrih ali i losijih trenutaka (oc musice i sl.), ali dan-danas radi u frendovom kompu.. Sve u svemu vrhunske ploce. R.I.P Lp!
Ps: kutija ostaje kod mene na neodredjeno
Staro 04.06.2010., 21:04   #6
blue#13
Postovi: 516
u mom kompu je bila DFI P35 T2RS LP ,predobra mbo ,nisam ju trebo prodat
R.I.P. lp
blue#13 je offline   Reply With Quote
Staro 04.06.2010., 22:23   #7
joolka
music freak
joolka's Avatar
Lokacija: Sibenik
Postovi: 3,320
Autor blue#13 Pregled postova
R.I.P. lp
..he he ja sam se opskrbio s dvjema DFI UT P35 T2RS i jednom novom ICFX 3200 zapakiranom...najbolje ploce koje sam imao tj imam,inace sto se tice DFI-a mogu samo reci sad smo osudjeni na asusov i gigabytov kic,
RIP DFI
LENOVO LEGION 5 Pro Gaming Laptop (AMD Ryzen 7 7745HX,RTX 4060,32gb DDR5,2tb SSD)
Staro 04.06.2010., 22:23   #8
Halos
muimerP
Halos's Avatar
Lokacija: VG
Postovi: 3,334
R.I.P. lp
Imah ju...
Staro 04.06.2010., 23:21   #9
okarm
Postovi: 781
a ja eto, nazlost, imao samo losa iskustva sa LP...
pocevsi od nf2 na kojoj se kondezatori napuhali nakon mjesec dana, a nista nije bilo klokano.... dobio drugu u servisu i s njom je bilo sve ok.. dok nisam za godinu dana kupio jos rama i otkrio da jedan utor ne radi...
nisam naucio lekciju pa sam uzeo i jednu sa p35 chipsetom.. nakon pola godine crkla 2 sata porta... nakon toga vise nisam ima strpljenja pa sam se prebacio na drugi brand...
Staro 04.06.2010., 23:47   #10
MAGARAC
MAGARAC's Avatar
Postovi: 5,997
DFI P45 T2RS plus,jedina defijevka koju sam imao i bila je super. Nakon BFG u kratkom vremenu još jedno oc ime silazi s scene.
Staro 04.06.2010., 23:47   #11
Milentije
Adrenaline junkie
Milentije's Avatar
Lokacija: Doboj - Banja Luka
Postovi: 3,593
Imao sam ABIT BH7, pa sam se zajebao i prodao je po mizernoj cijeni. Ni dan danas ne mogu prežaliti tu ploču.
Sada imam DFI LP UT P35 T2R i nemam namjeru da je prodajem, ni za kakve pare.
DFI je polako poceo da smanjuje broj proizvoda u zadnjih godinu, ili malo vise. Bilo mi je to cudno, ali nikada mi nije palo na pamet da ce prestati sa proizvodnjom ploča.
I ABIT i EPoX i DFI su imali problema sa marketingom i silovanjem tržišta svojim imenom. ASUS se prodaje zbog silne reklame, GIGABYTE se isto prodaje zbog silne reklame, MSI se prodavao i kada im ploče nisu bile na dobrom glasu zato što su imali dobar marketing, EVGA isti slučaj. ABIT i DFI su imali vrhunske ploče ali očito je zakazao marketing sektor i na kraju su završili ovako. Šteta!
Milentije je online   Reply With Quote
Staro 04.06.2010., 23:52   #12
D-I-A-B-L-O
Bannija :D
D-I-A-B-L-O's Avatar
Lokacija: Sisak
Postovi: 1,098
Ne vidim čemu kukanje, isti su kao i ostali, top ploče su im bile ok, ove jeftinije su znale bit mušičave i bok.
Sad svi ko fol pljuju po asusu i gigabyte-u, a da se oni zgase onda bi svi vikali joj kak je giga bio dobar brand, prelijepe ploče i blablabla...
Ja imam rebrandiranu dfi ploču, od sapphire-a, toliko malo rebrandiranu da je čak i naziv lanparty ostao na njoj, ali da sam presretan pločom i nisam.
Nemam nikakvih kvarova ali neke memorije mi ne voli, među njima je i kingmax koji sam prvi kupio i stalno imao problema, sad imam supertalent i mushkin i s njome radi ali ono, jebeš ploču koja neće radit sa memorijom predviđenom za nju, tako da po meni taj lanparty i dfi i nije baš nešto extra posebno.
Šteta je jedino što se konkurencija smanjuje i to što je već stara firma, koja se udomaćila u našim krajevima a i cijelom svijetu, ali po kvaliteti ih uopće nebih izdvojio iznad asusa gigbytea i sličnih.
D-I-A-B-L-O je offline   Reply With Quote
Staro 05.06.2010., 05:12   #13
jurbAs
jurbAs's Avatar
Postovi: 2,583
imao sam 3 ploce u LGA775 rigu i 2 su krepale ali DFI i dan danas se nosi sa oc.anim b3 na 1.425v i na 3.3ghz ploca je neunistiva.... i sad kad se covijek pita sto da sad kupi od tih ploca sve su preskupe i precjenjene di su odlicne ploce do 2000kn za 1366 socket?!
