Zaključane teme
Staro 01.04.2010., 19:43   #1
fran123456
Premija
fran123456's Avatar
Datum registracije: Mar 2009
Postovi: 1,634
nVidia CUDA emulator for every pc
NVIDIA's CUDA GPU compute API could be making its way to practically every PC, with an NVIDIA GPU in place, or not. A chinese freelance developer has coded a means to get CUDA work as a middleware on OpenCL. This move lets CUDA work on ATI Radeon GPUs that support OpenCL, as well as x86 CPUs, since OpenCL specs allow the API to run on CPUs for development purposes. The implications of these are many:
  • Letting CUDA-accelerated software such as Badaboom make use of ATI GPUs
  • Letting PhysX run on ATI GPUs as PhysX middleware uses CUDA for GPU acceleration
  • Possibly better scaling of PhysX on multi-core CPUs (over OpenCL), as the regular PhysX CPU acceleration is infamous for bad multi-core scaling in performance
The software works as a translation layer, exchanging calls between CUDA and OpenCL or the CPU if OpenCL is not available. It comes in the form of a loader application that injects itself into the executing process. To get PhysX to run, one needs to install older versions of PhysX System Software (version 8.09.04 WHQL being the latest) from its standalone installer (installs PhysX libraries without looking for NVIDIA GPUs).
TechPowerUp!
DOWNLOAD: CUDA Emulator Loader
Zadnje izmijenjeno od: fran123456. 01.04.2010. u 22:02.
fran123456 je offline
Staro 01.04.2010., 23:54   #2
Overhaul
Overhaul's Avatar
Postovi: 517
Steta kaj je aprilili bio...volio bih da je ta "sala" istinita.
Sjecam se iste takve prije dvije godine, na onom cudnom ngohq siteu.
No zivimo u svijetu u kojem je ekonomski interes ipak bitniji od napretka
Overhaul je offline
Staro 02.04.2010., 00:09   #3
d4rk_ch1ld
d4rk_ch1ld's Avatar
Lokacija: Krapinske Toplice
Postovi: 695
@Fran Nisi skužio da je fake?
d4rk_ch1ld je offline
Staro 02.04.2010., 00:40   #4
ivoHuljev
Postovi: 306
to se gleda ovako: Da nije fake, bilo bi već 2000 postova
ivoHuljev je offline
Staro 02.04.2010., 08:04   #5
fran123456
Premija
fran123456's Avatar
Postovi: 1,634
Autor Overhaul Pregled postova
Misliš na ovo? Na kraju se tip zaposlio u nVidiji
Da, ovo je prvoaprilska šala, isto kao i Razer Venom.
Zaključane teme
