Postovi: 166
Catalyst 10.3 Official
Na serveru su i službeni 10.3 driveri, skinite putem download managera tipa FlashGet. Release Notes: http://www2.ati.com/relnotes/Catalys...ease_notes.pdf Code:
https://a248.e.akamai.net/f/674/9206/0/www2.ati.com/drivers/10-3_vista64_win7_64_dd_ccc_wdm_enu.exe https://a248.e.akamai.net/f/674/9206/0/www2.ati.com/drivers/10-3_vista32_win7_32_dd_ccc_wdm_enu.exe https://a248.e.akamai.net/f/674/9206/0/www2.ati.com/drivers/10-3_xp64_dd_ccc_enu.exe https://a248.e.akamai.net/f/674/9206/0/www2.ati.com/drivers/10-3_xp32_dd_ccc_wdm_enu.exe Code:
Driver Packaging Version 8.712-100302b-096979C-ATI Catalyst™ Version 10.3 Provider ATI Technologies Inc. 2D Driver Version 8.01.01.1010 Direct3D Version 8.14.10.0735 OpenGL Version 6.14.10.9704 Catalyst™ Control Center Version 2010.0302.2233.40412 Zadnje izmijenjeno od: Liquid Snake. 24.03.2010. u 14:16. Razlog: Release Notes |
Postovi: 323
Na stranici od atia ih jos nema... |
Postovi: 548
Lokacija: Duga Resa
Postovi: 513
Ma ne za tu grafu, nego je sestra uzela lap sa 5650 grafom, a do sada nije bio nikakav mobility driver za seriju 5xxx. No, ima i za moju 3430 ![]() The following notebook graphics products are supported in this release:
Arroyo settler
Lokacija: .::Zagreb::.
Postovi: 316
Imam mali problem dakle,imao sam instalirani Ati catalyst 10.2 i sad sam htio staviti ovaj novi catalyst.S novim catalystom sam maknuo ovaj stari i počeo instaliravati novi,kad pojavi mi se error kod instalacije samo drivera.Driver Install:the INF file not found .Do sada nikada nisam imao problema s driverima.Hvala![]()
#12 | ||
super user
Lokacija: Houston, TX
Postovi: 1,805
Arroyo settler
Postovi: 316
#16 |
Arroyo settler
Postovi: 316
#19 |
Postovi: 2,327
uninstalliraj drivere u control panelu pomocu one aplikacije remove programs.resetiraj komp u safe mod.pokreni driver sweeper i zbrisi sve od ati-a ali tako da kliknes par puta sve dok ne ispraznis listu(svaki put kad zbrises pitat ce te dal oces restartat reci ne i samo klikci clean).kad si to napravio odi u device manager i zbrisi od tamo rucno sve drivere od grafe.Nakon toga restart i ponovo driver sweeper da provjeris jer ostalo kaj i ak je clean,a ak nije trebao bi ti instalirat drivere bez problema(osim ak ti nije grafa pa pa bok). LP
#20 |
Lokacija: Zagreb ( Šibenik )
Postovi: 5,458
Ja bi se vratio svakako na drivere sa tvorničkog CD-a,da ti ih windowsi sami povuku. Onda lako lupiš 10.3 gore preko njih. Prije tvorničkih sve dobro očisti kako su kolege sugerirale,prvo ručno u control panelu pa onda pomoću driver sweepera,restartaj komp ali sa umetnutim Sapphire CD-om i trebalo bi pomoći. Ne znam jesi clockao ti svoju,ali evo otkad sam ja uzeo svoju,koliko ima,2mj? skoro tu negdje,da kucnem u drvo ništa joj nije. Samo lupam drivere od onda jedne preko drugih kako koji dolaze,i sve radi savršeno, temperature si vidio,38 idle,load sumnjam da je ikad bio preko 70. Naravno,nije niti pola mhz clockana,nikad. Proc da,ali clockam samo nvidje ![]() ![]() . Nisam dugo neku ATi baš naclockao,još od 3870 tamo prvih, Club3D sam frljio. |
#22 |
Why so serious
Postovi: 3,415
Jebo vas led, pa nije niš kartici, nisam ju klokal čak ju nisam ni ružno pogledal! Jednostavno sam zbrisal drivere(10.2) neznam koji mi je Bog bil da sam brisal, moglel sam ljepo ko inače prek njih lupit, i od restarta je sve u k. preko DM-a instalira drivere al nemam CCC, ni niš ostalo. A u S.MOD mi neče, neznam zašto, napravi sve do ulaska u S.M i onda se restarta...a baš danas kad trebam riješit seminar u MathCAD-u....(samo mi nemojte reći da reinstaliram windowse.... ) Idem opet sve ispočetka brisat... |
#25 | |
Postovi: 166
Probaj ovo: Citiraj:
#27 | |
Postovi: 166
Tu možes naći kompatibilne sa catalyst installer-om: http://code.msdn.microsoft.com/KB961...ReleaseId=2067 Možes to probati, pa da opet instaliraš drivere na stari način umjesto preko konzole. |
#28 |
Addicted to music.
Postovi: 1,782
Stavio i za sada sve šljaka.Doduše,nisam imao problema ni sa 10.2.
All you have is your fire and the place you need to reach. Don't you ever tame your demons, always keep them on a leash. |
#29 |
Why so serious
Postovi: 3,415
Ne valja mi nekaj, možda su inst driveri al koda ih nema...imam spojeno prek HDMI kabla i sad mi je slika na monitoru 2cm od rubova....nije dobro....nenam koji je to vrag, možda nije inst drivere za HDMI? P.S-probal sam inst drivere i opet ništa, sad ću skinut to kaj si mi poslal pa ću probat! P.S.2. ---sve radi ko i prije nakon kaj sam inst Visual C++, nemam pojma kak mi je to isparilo iz kompa, jer prije nisam imal problema oko toga! Valjda se je samo pobrisalo.... ![]() Još jedno zahvaljujem...sad radi ko blesavo |
#30 |
Lokacija: NaN
Postovi: 3,438
