Staro 17.02.2010., 20:58   #1
Liquid Snake
Liquid Snake's Avatar
Postovi: 166
Catalyst 10.2 Official
Liquid Snake je offline   Reply With Quote
Staro 17.02.2010., 22:46   #2
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
Stavio 10.2,za sad sve šljaka.
Alph4Dawg je offline   Reply With Quote
Staro 18.02.2010., 00:10   #3
Goranbm
Goranbm's Avatar
Postovi: 1,238
Known Issues Under the Windows Vista Operating System
The following section provides a summary of open issues that may be experienced under
the Windows Vista operating system in the latest version of Catalyst™. These include:
?? Drop frames may be visible when viewing interlaced Blu-ray content on some ASICs
?? Random seeking while watching Blu-ray content on PowerDVD 9 may cause a black
line to appear
?? WinDVD 10 may stop responding when moved to an extended display in a multimonitor
setup
?? Minor frame drops might periodically occur while viewing H.264 interlaced Blu-ray
content during fast moving scenes
?? "1776x1000" and "1152 x 648" HDTV resolutions might be missing from the
Desktop Area for Catalyst Control Center - Desktop Properties
?? With one of displays connected via the DisplayPort, PowerDVD may terminate
during Blu-ray content playback in Eyefinity mode
?? Black video may appear on one monitor when switching to clone mode during Bluray
playback on PowerDVD
ATI Catalyst™ Release Note Version 10.2 9
?? Blank screen might be observed while exiting "Heaven-OGL" or "GL View"
applications; display can be resumed by pressing ALT+CTRL+DEL and clicking on
task manager
?? Laser designator beam might not focus on target properly in "Call of Duty: Modern
Warefare 2" during Act II: Exodus mission
?? Intermittent grey screen or vertical line corruption may randomly appear on the
screen
Evo kako piše u službenom dokumentu, sive linije još se nalaze pod known issues ... znači još uvjek se mora čekati riješenje.....
Goranbm je offline   Reply With Quote
Staro 18.02.2010., 00:16   #4
denied
denied's Avatar
Postovi: 1,193
Važno da se neka igrica vrti s 3 fps-a brže
To što se mora par puta na dan restartat niije tako važno
denied je offline   Reply With Quote
Staro 18.02.2010., 10:24   #5
Dr. Beast
Postovi: 1,505
Ja sam deinstalirao 9.6, krenuo instalirati 10.2 i nakon što su se otpakirali, kliknuo na install, malo rondalo po HDD i ništa ne ide dalje, čekao 10-ak min, probao restart pa sve ispočetka, ali ista stvar. VGA je HD3850, a OS WinXP. Na kraju sam vratio 9.6 jer mi je i s 9.12 bila ista stvar kao i s 10.2.
Zadnje izmijenjeno od: Dr. Beast. 18.02.2010. u 14:11.
Dr. Beast je online   Reply With Quote
Staro 18.02.2010., 11:22   #6
Bartuc
The All Seeing Eye
Bartuc's Avatar
Postovi: 1,103
Baš sam sada išao pogledati kako izgledaju te sive crte i skužio sam da sam ja taj problem imao ČAK i na geForce 7900GS grafičkoj kartici u igri FEAR. Tako da ne vjerujem da je problem u ATI-u i njihovim driverima. Također sam imao probleme i na HD4850 u igri Mass Effect 1.
Znači igraš igru, na ekranu se pojave usko poredane vertikalne sive linije (svjetlija i tamnija nijansa) i komp totalno zablokira te jedino pomaže manualan restart (ctrl+alt+del, alt+F4 i sl. NE pomažu.) Jel to to? Ako je, onda definitivno nije do ATI-a pošto se sjećam tog problema na 7900GS kao da je bilo jučer (pošto bi popizdio kad god bi se to desilo )!!
Bartuc je offline   Reply With Quote
Staro 18.02.2010., 14:01   #7
Goranbm
Goranbm's Avatar
Postovi: 1,238
Problem je svakako do ATI-ja, jer oni njega navode u svojim Driverima pod poznate probleme.... To što se tebi do dešavalo na Nvidiji, neznači da nije do ATI-ja, nego samo znači da su na tadašnjim driverima za seriju koju si naveo i nvidijini driveri bili loši
Staro 18.02.2010., 14:37   #8
Bartuc
The All Seeing Eye
Bartuc's Avatar
Postovi: 1,103
Ma mislio sam da je možda do Windowsa pošto je isti efekt bio na ATI i na nVidia kartici. Prvo sam mislio da je do pregrijavanja, ali nije. Na kraju mi je na obje kartice pomoglo isključivanje AA (u 3D modu)...
Staro 18.02.2010., 15:19   #9
Goranbm
Goranbm's Avatar
Postovi: 1,238
Ma sve je to zakomlipicirano... i kod svakog je drugacije.. Citao sam dosta o tome, i uglavnom su u pitanju sve verzije windowsa i sve kartice iz serije 5XXX, s tid da neki su problem rijesili sa spustanjem taktova, neki sa voltažama, a nekima ništa ne pomaže... evo recimo ja sam jučer stavio ove nove 10.2 drivere, i eto sinoć i do sad niti jedno resetiranje nije bilo potrebno, a igram dosta igara novijih... Bio sam poslao i mail u XFX, i rekli su mi da nije potrebno vraćati karticu na reklamaciju, jer problem je sa driverima i da se radi sa ATI-jem (tj. AMD-om) na otklanjanju problema... AMD je vec najavio da ce potkraj mjeseca izaci driveri koji ce rijesiti problem, pa cemo vidjeti
Staro 19.02.2010., 00:42   #10
Bartuc
The All Seeing Eye
Bartuc's Avatar
Postovi: 1,103
Formatirao sam komp i ipak sam si stavio v10.2. Grizla bi me savjest da sam stavio 9.12 Budem se kockao, a i sumnjam da ću imati problema sa driverima. Sutra ostaje samo snimiti Stalker CoP, Mass Effect 2, Crysis i Warhead te optimizirati čitav sistem... Pre dugo nisam ništa igrao, vražji ispiti
Staro 19.02.2010., 19:35   #11
IGoR_2803
IGoR_2803's Avatar
Lokacija: N/A
Postovi: 768
pa ti imaš hd4850, ne? mislim da se samo ekipa sa 5xxx javlja s tim vertikalnim linijama... ja sam na 9.12, za hd3850 i onako nema neke razlike, ne da mi se svaki mjesec mjenjati...
Staro 19.02.2010., 21:52   #12
Bartuc
The All Seeing Eye
Bartuc's Avatar
Postovi: 1,103
Kockao sam se i zajebao. NEMOJTE snimati v10.2 drivere. Imam HD4850 i Mass Effect 2 svako malo izbacuje sive vertikalne crte i zablokira se sistem. Upravo sam ih uninstalirao i stavio nazad v9.12 drivere. Nadam se da će to riješiti problem, ako ne, idem sve do 9.10 drivera.
Upravo mi je ATI nevjerojatno pao u očima.
Staro 19.02.2010., 22:08   #13
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Ja na XP-u još vozim 9.12 hotfix, na sedmici onu betu 10.1
Staro 20.02.2010., 01:42   #14
IGoR_2803
IGoR_2803's Avatar
Lokacija: N/A
Postovi: 768
ništa, ja ostajem na 9.12... samo mi je žao ekipe koja je iskeširala masnu lovu za nove grafe pa sad ima takve probleme...
Staro 20.02.2010., 05:32   #15
Xenomorph
Arroyo settler
Xenomorph's Avatar
Lokacija: .::Zagreb::.
Postovi: 316
Evo meni radi ok za sad
Xenomorph je offline   Reply With Quote
Staro 20.02.2010., 05:52   #16
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,750
Takodjer, sve ok.. Novi stalker, mass effect 2, dirt, bioshock2... Jos samo cekam avp3
Staro 20.02.2010., 11:54   #17
ivand123
otišo po cigare i nesto
ivand123's Avatar
Lokacija: Zagreb (Maksimir)
Postovi: 373
Autor Bartuc Pregled postova
Meni na 4670 radi sve ok, ti si očito jedini s tim problemom na 4xxx karticama jer niđe nisam našo nikog da se žali.
ivand123 je offline   Reply With Quote
Staro 20.02.2010., 11:58   #18
Bartuc
The All Seeing Eye
Bartuc's Avatar
Postovi: 1,103
Zašto uvijek ja
Jučer sam bio vani pa nisam isprobao v9.12. Danas planiram maratonćeka nabaciti u ME2 i ozbiljno se nadam da neću svakih 10 minuta morati restartati komp.
Staro 20.02.2010., 15:40   #19
2 die 4
2 die 4's Avatar
Postovi: 2,258
Ja sam na 10.1 i sve štima, neću mjenjat za sada!
A igre, vrtim svaku na 1920x1080, i sve na full!
Trenutno igram BF 2 Bad Company (beta) i imam 90-55fps, avr. 70 fps ali to je dakako u igri, nikakav bench!
Btw @ Sn4k3 AvP3 je najveće razočaranje do sada, barem demo!
RedGreenBlue
Staro 20.02.2010., 16:03   #20
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,750
Hmm... Nadam se da mi se sviditi, barem neka ocekivanja nek ispuni i dobro.. Znam da nije ko dobri stari avp2 ali bar priblizno (nadam se..)
Staro 20.02.2010., 16:05   #21
Bartuc
The All Seeing Eye
Bartuc's Avatar
Postovi: 1,103
Da, da updateam situaciju. Na kraju nije do drivera. Pogledao sam troubleshoot stranicu od Mass Effecta i strašno puno ljudi ima problema s njom, a svi imaju različite konfe/grafe/drivere/sustave itd. Tako da nije do ATI-a pošto ima brdo ljudi i sa nVidia karticama koji imaju problema sa rušenjem te igre.
Staro 28.02.2010., 01:23   #22
microsoft66
microsoft66's Avatar
Datum registracije: Apr 2008
Lokacija: VK
Postovi: 1,265
neznam di da ovo stavim pa evo vamo:imam u laptopu ati hd 4570 sa 512 ,i zanima me sta ide sve od drivera?isao sam na ati stranicu,odabrao mobility radeon za win 7 64bit od nekih 90mb mislim i to pokrenio al nemam nikakav control panel niti ista slicno kao na nvidia karticama!jel moram jos nesto instalirati ili..?
Staro 28.02.2010., 05:23   #23
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,566
Skini sa driverheavena " mobility modder" i s njime prodji instalaciju, imas na stranici objasnjeno kako treba.Meni radi odlicno
Btw promjeni taj " moj komp" u nesto normalnije.
Staro 02.03.2010., 10:14   #24
Šef gradilišta
Šef gradilišta's Avatar
Datum registracije: Mar 2009
Lokacija: Zagreb 24/7
Postovi: 34
10.2 u kombinaciji s 5870 daje low fps u Dirt2, Crysis i GTA 4. Sve navedeno je puno bolje funkcioniralo sa 4890 + 9.12....
Generalno je fps iznad 40, no na trenutke naglo pada ispod 20, tak da je sve skupa neupotrebljivo... Vjerojatno postoje riješenja, no nema vremena kopat po webu...
Šef gradilišta je offline   Reply With Quote
Staro 05.04.2010., 21:21   #25
pinkskin
pinkskin's Avatar
Lokacija: Daruvar
Postovi: 1,744
Ja imam problem i mislim da je do drivera. Koristim te 10.2 i nekad mi ostanu frekvencije na 400 za gpu i 450 za memoriju, i u igrama i na desktopu. u 2D bi trebale biti 157/300 a u igrama 775/500. Znači nekad frekvencije ostanu 400/450 i nejdu ni gore ni dolje. Nakon restarta bude normalo, nekad mi se to desi.
Jel imao netko takav problem, HD5670 i Win 7 32bit.
