Staro 10.02.2010., 01:41   #1351
MadBoY
MadModerator
MadBoY's Avatar
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
Prije se u biti moglo birati izmedju 3 kartice, a sad ih ima 300.
5970, 5870, 5850, 5770, 5750, 5670, 5650, 5570, 5450...
Pa se snadji ko, sta, gdje, koliko
Staro 10.02.2010., 12:33   #1352
Zvone2772
interferometar
Zvone2772's Avatar
Postovi: 768
Evo danas najavljena još i 5550
Jedina razlika od sestre s brojem xx70 je sporija memorija (GDDR2) i -80 SP-a (320)
LiNk
A i 5830 je "iza ugla".
Zvone2772 je offline   Reply With Quote
Staro 10.02.2010., 21:22   #1353
Momir
Momir's Avatar
Postovi: 1,011
Malo gledam na gigabyteovim stranicama graficke
I vidim da su 58xx i 57xx serija PCI-E 2.0 x16,
a 54xx, 55xx, 56xx i 59xx serija PCI-E 2.1 x16
Vidim da su brzine jedne i druge sabirnice iste, ali sigurno ima neka caka, pa ako se da kome pojasniti malo ili me uputit ako je vec bilo rijeci o tome.
Pretpostavljam da za mene, obicnog smrtnika, razlike nisu bitne, ali zanimaju me.
Momir je offline   Reply With Quote
Staro 10.02.2010., 21:49   #1354
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Evo kaj veli 0.02 sec serčanja
PCI Express 2.1
PCI Express 2.1 supports a large proportion of the management, support, and troubleshooting systems planned to be fully implemented in PCI Express 3.0. But, the speed is the same as PCI Express 2.0.
Staro 10.02.2010., 23:25   #1355
danc00
Why so serious
danc00's Avatar
Postovi: 3,415
Autor Jelc Pregled postova
A kaj će biti novog u PCIe 3.0. Kad već srčaš.
danc00 je offline   Reply With Quote
Staro 11.02.2010., 01:50   #1356
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,758
Custom ASUS Radeon5850 DirectCU and 5870 TOP
Asus will soon release a customized version of the Radeon HD 5850 graphics card with the DirectCU cooler, this cooling solution promises 20 percent lower temperatures than the stock cooler, while cutting noise production by 35 percent as well. The DirectCU cooler utilizes two 8mm heatpipes that make direct contact with the GPU, you can expect this card by the end of the month.
Another new card is the Radeon HD 5870 TOP edition, this model will features slightly higher clockspeeds than the reference model. Availability is expected by early March 2010.
Izvor:guru3d
Staro 11.02.2010., 06:12   #1357
Momir
Momir's Avatar
Postovi: 1,011
Dobro, taj dio sam i sam nasao
Ocekivao sam neko drugacije pojasnjenje na naskem jesiku, al ako je to to onda nista, svejedno na trudu.
Staro 12.02.2010., 21:29   #1358
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,758
Radeon HD 5830 Specifications out
We've already been saying more or less that you can expect a Radeon HD 5830 card soon. The card is supposed positioned in the 200~230 USD range making it widespread available and affordable for a lot of people. Personally I look forward to this product very much.
The Radeon HD 5830 performance should be inbetween the 5850 and the 5770, and as it seems it's base off the Cypress LE core. The card reportedly will come with 1280 shaders processors and a core speed of 750MHz for the GPU. Featured with 1GB of GDDR5 memory, clocked at 1000MHz, the difference between the 5830 and the 5850 shouldn't be that significant, in terms of performance. When you put the two side by side, the 5850 is featured with 1440 shaders and 72 texture units, while the GPU is set at 725MHz.
It is very likely that the PCB and cooler will be similar to the HD 5850 model.
___________________________________________________________________________
ASUS ROG 5870 Matrix 2GB Photo's
Over at a Chinese website they obtained some cool photo's of the ASUS ROG 5870 Matrix, the card comes with a 2GB framebuffer. Apparantly it operates at 900 MHz on the core clock and memory at 4900 MHz. The card will come with voltage checkpoints to monitor the juice flowing through the card.
Apparantly it can cram 1.5v through it's pipes allowing a clock frequency of 1080 MHz.
Izvor: guru3d
Staro 13.02.2010., 17:16   #1359
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,758
Sapphire Readies HD 5850 Toxic Graphics Card
Sapphire is making an addition to its Toxic series graphics card that feature non-reference design with out of the box higher clock speeds, based on the ATI Radeon HD 5850 GPU. The Toxic HD 5850. It features what appears to be a non-reference blue PCB by Sapphire, a non-reference cooler with a dash of racy blue graphics, and higher clock speeds. Its GPU is clocked at 765 MHz and memory at 1125 MHz (4500 MHz effective), against reference clock speeds of 725 MHz and 1000 (4000 eff.) MHz, respectively. The Radeon HD 5850 GPU is DirectX 11 compliant, has 1440 stream processors, and a 256-bit GDDR5 memory interface. There's 1 GB of memory on board. It is expected to be released on or before 15th Feb. Online store Overclockers UK has listed this card before its announcement at £269.99 including applicable tax, though we expect the price to come down after release.
Staro 14.02.2010., 22:20   #1360
Postovi: 7,568
The RV870 Story: AMD Showing up to the Fight
When I wrote The RV770 Story I was convinced that ATi had embraced a new, refocused approach to GPU design, only to learn that they nearly threw out all of the learnings with the RV870. The Northern Islands GPUs, due out later this year, were surely designed before anyone knew how RV870 would play out. Much less whether or not Fermi/GF100 would be this late.
The past three product generations have been executed extremely well. Regardless of whether you're an AMD, Intel or nVidia fan, you must give credit where it's due. The past couple of years have shown us a dramatic turn around from the graphics group at AMD. To go from the shakiness of the R500 and R600 GPUs to solidly executing on the RV670, 770 and 870 year after year is praiseworthy.
I almost wonder if AMD’s CPU team could learn from the graphics group's execution. I do hope that along with the ATi acquisition came the open mindedness to learn from one another.
Zanimljivo štivo, lišeno fanatizma kakav se non-stop viđa diljem ovog i sličnih foruma.
Čista tehnička strana priče koja bi se bez problema mogla primijeniti nakon predstavljanja svake CPU i GPU generacije.
Staro 15.02.2010., 11:33   #1361
timmy
timmy's Avatar
Lokacija: N/A
Postovi: 1,242
Evo jedan zanimljiv link, ako nekome treba.
Voltmodovi za 5750, 5770, 5870; sve na jednom mjestu + sav potreban softver.
timmy je offline   Reply With Quote
Staro 17.02.2010., 17:15   #1362
Skorn
Skorn's Avatar
Postovi: 604
pls erase this post
~ Reductio ad Absurdum ~
igre za PS ONE / PS2 koje me zanimaju
Zadnje izmijenjeno od: Skorn. 19.02.2010. u 16:58.
Skorn je offline   Reply With Quote
Staro 23.02.2010., 08:41   #1363
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
Thumbs up Hd 5830
Detaljnije specifikacije HD 5830, koja btw. izlazi ovaj tjedan.
http://www.tcmagazine.com/comments.php?id=32829&catid=2
Matth€w je offline   Reply With Quote
Staro 23.02.2010., 09:13   #1364
Blue_Fatal1ty
Blue_Fatal1ty's Avatar
Lokacija: Čazma
Postovi: 1,728
Autor Matth€w Pregled postova
više troši od 5850????
Staro 23.02.2010., 10:09   #1365
Postovi: 34,003
Malo mi se čini prevelika na onoj slici. Još ima 2 venta na cooleru. Previše sumnjivo.
Staro 23.02.2010., 10:51   #1366
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
Autor Blue_Fatal1ty Pregled postova
Ima dosta veći radni takt GPU-a, ali opet s druge strane ima dosta manje stream procesora, ROPsa i texture unitsa, tako da je i meni to ispalo malo čudno. Možda ne utječe na potrošnju.
Autor coconut Pregled postova
Da, meni je isto sumnjiva slika i kutija. Previše Ultra Durable fora na kutiji od jedne grafičke kartica...? Hm
http://www.techpowerup.com/115908/AT...s_Surface.html
http://vr-zone.com/articles/ati-rade...aked/8475.html
Zadnje izmijenjeno od: Matth€w. 23.02.2010. u 11:20.
Staro 23.02.2010., 14:02   #1367
Mad_Duke
Pa sve četri su "jedna te ista kartica.". Sad, kako su izašle iz tvornice, tako su "clockane". Za jedne lošije modele mi je skroz logično da oderu recimo jaču frekvu, a da disable-aju više jedinice.
Staro 23.02.2010., 14:56   #1368
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
Staro 23.02.2010., 15:08   #1369
Momir
Momir's Avatar
Postovi: 1,011
na zadnjoj slikici (slajdu) u zadnjem redu piše "6*2560*1600" kako spojiti 6 monitora ili necega?
nije li 3 maximum, osim one cudne zvjerke koju nisam vidio da se igdje prodaje (ona sa 6 mini DP portova i 2GB rama...)
Staro 24.02.2010., 13:38   #1370
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
Malo informacija o rezultatima HD 5830
http://vr-zone.com/articles/ati-rade...arks/8483.html
Staro 25.02.2010., 13:03   #1371
MAGARAC
MAGARAC's Avatar
Postovi: 5,991
ATI Radeon HD 5830
Od danas HD 5830 službeno u prodaji
http://www.hexus.net/content/item.php?item=22569
Staro 25.02.2010., 13:34   #1372
Postovi: 34,003
Nažalost, kao i većina 5xxx serije, precijenjena je. Razlika u performansama između slabije 5770 i nje nije velika koliko razlika u cijeni. Po meni, fail.
Staro 25.02.2010., 13:55   #1373
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,758
Radeon HD 5830 review
Overall the performance is still very nice though, the Radeon positions itself in-between the Radeon HD 5770 and Radeon HD 5850, but when we tally our results up, the Radeon HD 5830 is often closer to the 5770 than it is to the Radeon HD 5850.
Looking up some prices here in the Netherlands and in our USA Pricegrabber database tells us the following, and you guys can already feel where this conclusion is heading, if we take the 1024MB models then:
* Radeon HD 5770 1024MB can be found for roughly 140 EUR / 169 USD.
* Radeon HD 5850 1024MB can can be found for roughly 260 EUR / 319 USD.
And here's my dilemma, the Radeon HD 5830 will cost cost you give or take 230 EUR / 259 USD at launch.
Now if you compare the 5830 to the 5770 then you are looking at ten, maybe fifteen percent performance difference tops, and as such I find it a tad hard to recommend the Radeon HD 5830. Personally I'd say save yourself the money and go with the excellent HD 5770, that or drop a few tenners more and go for the sweet Radeon HD 5850, which makes a little more sense. The 5830 however comes with 256-bit memory whereas the 5770 does its magic on a 128-bit bus.
Now we like the Radeon HD 5830, it really is a fun product, but we do feel that its price positioning somehow doesn't match up properly. This product should be hovering at a sub 200 EUR / 239 USD level IMHO -- well, wishful thinking perhaps?
Izvor: guru3d
Zadnje izmijenjeno od: bluefluid. 25.02.2010. u 15:23.
Staro 25.02.2010., 14:01   #1374
MAGARAC
MAGARAC's Avatar
Postovi: 5,991
Grafa je bliža 5770 nego 5850 po performansama a cijena je trenutno bliža 5850. Mislim da če jako brzo i cijena pasti i da če grafa bit dobra kupovina.
Šteta kaj su baš toliko skresali 5850, 16 ROPova i 2 sahder clustera. Zbog toga je grafa na 800mhz,zbog čega više troši i više se grije od 5850. Sapphireova nema mogučnost softverske regulacije voltaže.
evo još jedan reveiw: http://www.guru3d.com/article/radeon-5830-review/1
Staro 25.02.2010., 16:26   #1375
Mad_Duke
S obzirom koliko je ljudi tu kod nas već prešlo na 5xxx seriju. Ne bi se složio.
Neka samo pumpaju različite modele.
Staro 25.02.2010., 18:05   #1376
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Eto još jedan review HD5830 s Tomičinog hardvera
ATI Radeon HD 5830: Bridging The 5700- And 5800- Price Gap
C L O W N I N G A R O U N D
Staro 25.02.2010., 18:54   #1377
thedream
thedream's Avatar
Lokacija: Zagreb ( Šibenik )
Postovi: 5,458
Klasična zamjena za 4890.Nuf said. Mogla bi biti dobra kupnja ekipi koja prelazi sa serije 2 i 3,a 5770 im je preslaba,uvjetno rečeno.
Staro 25.02.2010., 18:56   #1378
zackoj
zackoj's Avatar
Postovi: 888
Sve ovisi koja ce cijena bit u nas. Sumnjam da ce biti ispod 1500kn
jedan je GAZDA F1. Michael never give up, never surrender !!!
zackoj je offline   Reply With Quote
Staro 25.02.2010., 23:29   #1379
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
Autor MAGARAC Pregled postova
Šteta kaj su baš toliko skresali 5850, 16 ROPova i 2 sahder clustera. Zbog toga je grafa na 800mhz,zbog čega više troši i više se grije od 5850. Sapphireova nema mogučnost softverske regulacije voltaže.Evo još jedan reveiw: http://www.guru3d.com/article/radeon-5830-review/1
Pa hd5850 ima jednako rop-ova kao i hd5870 tj. 32, a hd5830 te 5750/70 imaju po 16. 5850 uopće nije jako skresana(160 sp-a,8 tmu-a i manji clockovi), ali hd5830 je stvarno previše. Mogla je biti hit,ali su je uvalili kao i hd4730 isti vrag.
Zen5 PCIvy bridge Notebook
CPU: AMD Ryzen 7 9700x, CO per Core, CS -20 (Mid, High, Max)
COOLER: Arctic Cooling Liquid Freezer III 420 A-RGB
MBO: MSI Tomahawk X870
RAM: Corsair Vengeance DDR5 32GB, 6000MHz CL28
GPU: MSI SuprimX Nvidia GeForce RTX 3070
NVM1: Samsung Evo 970 2TB
HDD1: WD Red 4TB, WD40EFRX
HDD2: WD Blue 6TB, WD60EZRZ
HDD3: WD Blue 6TB, WD60EZRZ
PSU: Corsair RMx 850W, ATX3.1
CASE: Fractal Meshify 2 XL
VENTS: 4x Arctic Cooling P14 PWM PST A-RGB
OS: Win 11 Pro, 64-bit
MONITOR: AOC Q3279VWFD8 - 32", IPS, 2560x1440
TV: LG 7450
MOUSE: Logitech MX Master 3
KEYBOARD: Logitech MX Keys
GAMEPAD: XBOX One
HEADPHONES: Sennheiser HD560s
DELL Inspiron 15R, 5520
CPU: Intel Core i7 3632QM, 2.20Ghz, turbo 3.20GHz
RAM: DDR3, 6GB (4GB + 2GB), 1600Mhz CL11
GPU: AMD Radeon 7670, Intel HD4000
SSD: Samsung EVO 850, 250GB
SCREEN: 15,6 inch LCD, 1366x768
OS: Ubuntu 24.04, 64-bit
DraŽ je offline   Reply With Quote
Staro 26.02.2010., 00:20   #1380
MAGARAC
MAGARAC's Avatar
Postovi: 5,991
Autor DraŽ Pregled postova
ma htio sam napisati kakva je 5830 u odnosu na 5850,odnosno koliko je skresana 5850 da bi se dobila 5830,16Rops i 2 shader clustera manje.
inače je 5850 sresana samo za 1 shader cluster u odnosu na 5870 i 3fazna regulacija . Mogli su slobodno ostavit 1 cluster spa više na grafi i postavit niže klokove(5830)
