#333 |
3.14zda ®
Lokacija: Orahovica
Postovi: 8,320
Zadnje izmijenjeno od: Dizel. 15.12.2009. u 17:06. |
#335 |
Postovi: 3,794
#336 |
3.14zda ®
Lokacija: Orahovica
Postovi: 8,320
Trenutno je ovakva situacija i sve radi veselo i rock stable. Za mene totalni overkill ![]() Procesor nariktan na 1.4V, a memorija na 1.8V. Ostale pizdarje mi se nije dalo dirati. Code:
Field Value CPU Properties CPU Type DualCore Intel Core 2 Duo E6850 CPU Alias Conroe CPU Stepping G0 Engineering Sample No CPUID CPU Name Intel(R) Core(TM)2 Duo CPU E6850 @ 3.00GHz CPUID Revision 000006FBh CPU VID 1.3500 V CPU Speed CPU Clock 3601.0 MHz (original: 3000 MHz, overclock: 20%) CPU Multiplier 9x CPU FSB 400.1 MHz (original: 333 MHz, overclock: 20%) Memory Bus 480.1 MHz DRAM:FSB Ratio 12:10 CPU Cache L1 Code Cache 32 KB per core L1 Data Cache 32 KB per core L2 Cache 4 MB (On-Die, ECC, ASC, Full-Speed) Motherboard Properties Motherboard ID 01/10/2008-iX38-W627DHG-6A79PA1BC-12 Motherboard Name Abit IX38 QuadGT (2 PCI, 1 PCI-E x1, 3 PCI-E x16, 4 DDR2 DIMM, Audio, Gigabit LAN, IEEE-1394) Chipset Properties Motherboard Chipset Intel Beachwood X38 Memory Timings 5-5-5-15 (CL-RCD-RP-RAS) Command Rate (CR) 2T DIMM1: G Skill F2-8500CL5-2GBPI-B 2 GB DDR2-800 DDR2 SDRAM (5-5-5-15 @ 400 MHz) (4-4-4-10 @ 266 MHz) DIMM3: G Skill F2-8500CL5-2GBPI-B 2 GB DDR2-800 DDR2 SDRAM (5-5-5-15 @ 400 MHz) (4-4-4-10 @ 266 MHz) BIOS Properties System BIOS Date 01/10/08 Video BIOS Date 01/12/09 Award BIOS Type Phoenix - AwardBIOS v6.00PG Award BIOS Message DMI BIOS Version 6.00 PG Graphics Processor Properties Video Adapter nVIDIA GeForce 9800 GT GPU Code Name G92GT (PCI Express 1.0 x16 10DE / 0614, Rev A2) GPU Clock (Geometric Domain) 702 MHz (original: 700 MHz) GPU Clock (Shader Domain) 1728 MHz (original: 1715 MHz) Memory Clock 900 MHz (original: 900 MHz) |
#337 |
Postovi: 11,642
Jel si ju probao dobiti na CL4? |
#338 |
3.14zda ®
Lokacija: Orahovica
Postovi: 8,320
Razmisljao sam o tome jer sam Tracere bez pol frke vozio na CL4 na istoj frekvenciji oko 960MHz na 2.1V...ali onda bih vjerovatno morao staviti napon preko 2V. A brat bratu, razlike nisam skuzio izmedju CL4 i CL5 dok sam imao Balistike. |
#339 |
Premuim
Postovi: 1,748
#340 | |
3.14zda ®
Lokacija: Orahovica
Postovi: 8,320
![]() Ako je memorija deklarirana da radi na 4-4-4-12, onda ima da i radi na toj latenciji da ga jebe babo Olimpijski. A Balistike su se nasiroko i nadaleko reklamirale kao 4-4-4-12 i zato sam ju guzio tako. To sto bude vrlo cesto rika mladih jelena - nisu reklamirali, naravno. Ovaj G.Skill pise da je 5-5-5-15, ako moze nize pri 2.1V - dobro, ako ne - nikome nista. |
#341 |
Postovi: 11,642
Evo da okačim i ja jedan rez, malo preko 20k... ![]() |
#343 |
3.14zda ®
Lokacija: Orahovica
Postovi: 8,320
#345 |
gadget freak
Lokacija: Jasenovac
Postovi: 2,224
#349 |
Jack of all, master of none
Lokacija: Matulji - Rijeka
Postovi: 6,214
Samo ti jedna jezgra radi na 22x množitelju, optereti proc i množitelj će pasti natrag na 21x. Btw. na kojoj je to voltaži? 1.2v? ![]()
#352 |
Postovi: 438
ddr3 čmark
zanimljivo da je ovo na 18x210 MHz dok je ddr na 2100MHz a 18x215 mema na 2150 neće dok npr. ako smanjim omjer na 2:8 pa je mema na 1720Mhz dobijem samo 17978 MB/s read Drugi naj rezultat sam dobio kod 19x210 odnosno mema na 2100MHz što je dalo 20367 Na 20x200 odnosno nazivnih 2000MHz memorije dobijem 18865 GB/s Ovo je sve na tvorničkih 9-9-9-27 @1,6V Da li imate prijedlog ili link na tutorial kako probati sa bržim postavkama na CL8 možda? fala Mod: slike preko 50kb u thumbnail!
Zadnje izmijenjeno od: Razer. 11.01.2010. u 23:23. |
#353 |
3.14zda ®
Lokacija: Orahovica
Postovi: 8,320
#355 |
Lokacija: Jug
Postovi: 506
