Staro 10.11.2009., 07:41   #541
dart_tom
dart_tom's Avatar
Lokacija: osijek
Postovi: 454
Autor cleary_555 Pregled postova
Imam msi R4890. U catalystu bez podizanja memory clocka stavim gpu na 1 Ghz i pise kad kliknem test custom clocks passed. Malo mi je cudno jer kazu da ostale idu najvise do cca. 955 Mhz. Grafa je OC edition.
probaj samo staviti 3dmark ili neku igru pa ćeš vidjeti dali će raditi na 1gh!
dart_tom je offline   Reply With Quote
Staro 13.11.2009., 21:28   #542
Jalovski
Jalovski's Avatar
Postovi: 28
Pozdrav,
evo kupio sam novu xfx hd 4890 i imam jedan problem koji malo ide na zivce.
Trazio sam po interentu neko rijesenje i jedino na sto sam naisao je isti problem kod jednog reviewa od hd 4770 kartice.(opis na dnu posta)
evo opis problema koji je identican mom, venitilator grafičke u windowsima dok surfam ili dok je potpunom idleu mijenja brzinu vrtnje svake dvije ili tri sekunde.
Sad neznam da li da karticu vratim ili da probam updejtat bios?
Hvala
"One thing we do need to mention: the first Radeon HD 4770 that arrived had an early BIOS with a slightly “off” cooling ramp. It’d heat up, spin to full duty cycle for two seconds, then drop back down to idle. This was fixed by a second card sent out by ATI, along with a note stating all of the boards appearing at retail starting April 28th would include the fixed BIOS. We were also able to fix the issue by manually keying in the fan speed."
Jalovski je offline   Reply With Quote
Staro 13.11.2009., 21:46   #543
zgmmax
zgmmax's Avatar
Postovi: 1,673
pogledas ovaj post
Code:
http://forum.pcekspert.com/showpost.php?p=1126081&postcount=2
rjesenje br. 2 i to je to
zgmmax je online   Reply With Quote
Staro 13.11.2009., 23:30   #544
Jalovski
Jalovski's Avatar
Postovi: 28
Radi, hvala puno
pozz
Staro 15.11.2009., 22:25   #545
herr_martin
Datum registracije: Jul 2009
Lokacija: Varazdin
Postovi: 63
sapphire radeon 4890 1 gb, problem
imam problem s doticnom karticom, naime kad god pokrenem igru cuje se pistanje neko, bas nesto u grafickoj kartici, 100% nije ventilator nego nesto drugo.. e sad problem je recimo cod2 ili warcraft 3 mogu igrati kolko ocu nista nece biti sve super, a ostale igre tipa crysis ili mw2 i ostale igram svega minutu dvije i samo mi zasteka komp, na ekranu mi dodje obicno samo smedje crte i nemogu napravit nista osim restartat komp, i kad mi se tako smrzne igra onda prestane to pistanje... i kako se u igri kreces misem, tako se i pistanje onak drugacije cuje.. ovisi uvijek... u ovim igrama di se smrzne tu se uvijek cuje to pistanje jace, dok se u warcraftu ili cod2 cuje malo slabije.. sad ja mislim da je to hardwareski problem i da bi bilo najbolje promijenit na garanciju karticu, al ako mozda ko moze bolje objasnit ako zna sto je, neka slobodno kaze. mogu prilozit i video di se cuje kako pisti kartica... stvarno bi vas molio za neke savjete jer kartica je stara ni 2 mjeseca, i od pocetka mi je recimo u codu4 nakon par min tak zastekala igra i ekran postao smedji, ali sad mi skoro u svakoj igri se to dogodi nemogu nista normalno igrati, znaci da ponovim, sve igre rade besprijekorno, nist ne steka i to nego samo u jednom casu BUM, i ode slika, pojavi se smedje i gotovo, mogu samo restartat komp..
herr_martin je offline   Reply With Quote
Staro 15.11.2009., 22:39   #546
Halos
muimerP
Halos's Avatar
Lokacija: VG
Postovi: 3,334
Bok
Sad, ja cu od onoga sto se meni desavalo...
Znaci šištanje cujem i sada u nekim trenutcima i to je normalno za skoro sve nove( i stare ofc) grafe oko toga se nemoraš zamarat, a to sa micanjem miša sam nekada na staroj konfi znao čut i dolazilo je iz napajanja.
Problem sa rušenjem grafe u igrama moze biti od drivera, pregrijavanja,(slabijeg)napajanja pa sve do neispravne grafe.
Mislim da bi ti za pocetak trebao fino počistiti sve drivere u safe modu sa driver cleanerom maknutu sve, bubnuti najnovije drivere odmah, u međuvremenu propuhati graficku(mada mislim da nije potrebno u 2 mjeseca...nije mogla toliko prasine pojest, ali nikad se nezna ), a tek onda skinutu GPU-z i pratiti kako se temperature razvijaju u igrama.
Naravno moraš ispunit Moj Komp opciju da znamo sa kakvim napajanjem raspolažeš i tako to.
Staro 15.11.2009., 22:41   #547
herr_martin
Lokacija: Varazdin
Postovi: 63
ok hvala ti, evo sad cu napisati moj komp i to i probati ovo sto kazes, al ja mislim da je neispravna graficka..
Staro 15.11.2009., 23:03   #548
herr_martin
Lokacija: Varazdin
Postovi: 63
evo updejto sam moj komp pa pogledaj... al ne mislim da je radi ostalih komponenata...
Staro 15.11.2009., 23:06   #549
blue#13
Postovi: 516
hmm,sigurno je napajanje, to napajanje nema niti 300realnih watta
blue#13 je offline   Reply With Quote
Staro 15.11.2009., 23:08   #550
Halos
muimerP
Halos's Avatar
Lokacija: VG
Postovi: 3,334
Cuj, konfa ti definitivno nije slaba, a sad taj 750W...neznam, to bi Wolv ili Gilbert mogli odgovoriti, dali je napajanje ili nije...
Ali, ipak ti za pocetak napravi ono gore, pa javi dali se ponavlja. Ako da, onda smo barem eliminirali jedan dio
Staro 15.11.2009., 23:16   #551
herr_martin
Lokacija: Varazdin
Postovi: 63
Autor blue#13 Pregled postova
hmmm, al da je napajanje nebi onda bilo da bi se komp resetirao sam od sebe ili ugasio? a moj problem je da mi igra zasteka i postane slika smedja s crtama i to je to.. znam citao sam o tom napajanju dosta, al ne vjerujem stvarno da je do napajanja...
e a kak s driver cleanerom izbrisem drivere? samo idem tamo start ili treba neka procedura biti?
Zadnje izmijenjeno od: herr_martin. 16.11.2009. u 00:09.
Staro 16.11.2009., 00:40   #552
e1ectra_one
Creepshow
e1ectra_one's Avatar
Postovi: 417
Imao sam ja sličan problem sa identičnom grafom, GTA4 rušilo, ugasi i upali komp samo na LCpower-u 750W za 750kn.
Probaj OCCT Power Supply Test
e1ectra_one je offline   Reply With Quote
Staro 16.11.2009., 00:52   #553
herr_martin
Lokacija: Varazdin
Postovi: 63
e electa a sad sa ovom trenutnom 4890, koju vidim da imas, nemas nikakve probleme? znaci nista ti ne pisti iz nje ili da ti se dogadja ovo sto se dogadja meni u igrama?
Staro 16.11.2009., 02:01   #554
e1ectra_one
Creepshow
Postovi: 417
Malo zuji u loadu, VRM najvjerovatnije, na 3 4890 sam to isto primjetio. To se inaće nečuje to stock-a.
Staro 16.11.2009., 03:11   #555
dart_tom
dart_tom's Avatar
Lokacija: osijek
Postovi: 454
Sto se pistanja tiče nemam nikakvih problema ali ovo sto ti u nekim igrama zasteka i pojave se crte smedje mi smrdi na riku grafulje jer sam ima sličan slučaj,s tim da isto neke manje zahtijevne igre tipa ice age3 i nekih starijih strategija su radile ali čim bi pokrenuo neku pucacinu dobio bi smedje crte ili snjig i pomago je samo reset,uglavnom artefakte tak da mislim da ćeš morat reklamirat ali kao sto su ti drugi rekli prvo probaj rijesit driverima da budeš 100%
Staro 16.11.2009., 10:41   #556
herr_martin
Lokacija: Varazdin
Postovi: 63
renstalirao sam drivere, opet ne radi, igram mozda pola minute i pojavi se, ovaj put ekran s crno sivim crtama.. i ja isto sumnjam da je nesto u grafickoj otislo, tj da je tvornicka greska neka jer tako je od pocetka od kad sam kupio racunalo, samo sto sam prije mogao igrati neke igre tipa crysis i nije se rusio, a evo jucer ga idem probati malo i onda mi se i on srusi...i tako.. ma nista, ako nema neko jos kakav prijedlog, idem zvat i poslat im to na garanciju, samo se nadam da nebudem izgubio zivaca i zivaca kod te garancije jer svi znamo kako je to kad su garancije u pitanju i muljanje oko nje..
da dodam, temperature graficke su ok, ne pregrijava se ni nista...
Staro 16.11.2009., 11:13   #557
Postovi: 33,998
Probaj je na nekom drugom kompu prije nego je reklamiraš tek toliko da eleminiraš i tu mogućnost.
Staro 16.11.2009., 15:36   #558
herr_martin
Lokacija: Varazdin
Postovi: 63
ma evo odnio sam na reklamaciju, zvali su me za 1 sat, rekli da su potvrdili moje sumnje da je graficka kriva, dakle testirali su je, zakljucili da pod opterecenjem zasteka i dobit cu vjerojatno novu kroz tjedan dana jer su je poslali na reklamaciju i tako mi rekli. sad imam 9500gt zamjensku koju su mi stavili tek tolko da mogu imati funkcionalan komp i to je to.. glavno da me nisu mucili oko te reklamacije kako to zna biti nego su posteni bili i rekli da je graficka pokvarena. eto tolko za sad
Staro 04.12.2009., 14:50   #559
zgmmax
zgmmax's Avatar
Postovi: 1,673
da malo dignemo temu
Jucer stavio acellero S1 rev 2 na svoju karticu i zadovoljan sam temp gpu 45C u idlu, dok je sa stock kulerom bila na 58.
Jedino nisam zadovoljan sa temp. memorije koja je 71C, posto nisam imao onu termo traku sam zaljepio hladnjake sam sa termovodljivom pastom i oni se drze ne padaju. Po njima puse Scythe slip stream @5V, jedino da sam stavio predebelo te paste, al nisam siguran u to kada pastu nanosim sa kisticem
Zadnje izmijenjeno od: zgmmax. 04.12.2009. u 15:41.
Staro 04.12.2009., 14:53   #560
Cuky
jedan i jedini :D
Cuky's Avatar
Lokacija: novi zagreb
Postovi: 5,250
jel imas redplate za karticu? ako imas stavi njega pa onda na nj accelero
Staro 04.12.2009., 15:09   #561
zgmmax
zgmmax's Avatar
Postovi: 1,673
Nemam
Imam od VTX a mislim da oni nemaju referentni dizaj, jer sam kupio i za MOSFET onaj hladnjak kaj radi zalman i ne pasu mi rupe.
Budem kupio ljepilo pa cu ga kapnut u jedan cosak i tak zalijepit hladnjak
Staro 04.12.2009., 15:11   #562
Cuky
jedan i jedini :D
Cuky's Avatar
Postovi: 5,250
hmmm. poslikaj vegu pa cemo vidjet sto se moze izvest
ja imam iskustva, vec sam jednu skurio
Staro 04.12.2009., 15:41   #563
zgmmax
zgmmax's Avatar
Postovi: 1,673
kada dodjem doma sa posla
bome mi onda ne treba tvoje iskustvo
nadam se sam da si zapamtio kak si uspio skurit grafu i da je proslo pod garanciju
Staro 04.12.2009., 15:43   #564
Cuky
jedan i jedini :D
Cuky's Avatar
Postovi: 5,250
ma rijesena je reklamacija u roku keks. fora je bila u tome da nisam smio stavljat one plasticne distancere za cooler, jer kad njih stavis onda baza coolera ne legne na gpu kak treba i ode u k sve.
a to ne pise u uputama, itd.
Staro 05.12.2009., 15:35   #565
zgmmax
zgmmax's Avatar
Postovi: 1,673
rijesio sam problem
vent sam stavio da mi puse po MOSFETu i nije pokrivo sve cipove od memorije. Sada puse na nekih 1000rpm i temp su mi 50c gpu, a 60c mema
Staro 05.12.2009., 19:40   #566
toMoo
Datum registracije: Aug 2008
Lokacija: croatia
Postovi: 20
Xfx hd4890 1gb ddr5
pozdrav,
zanima me ova garficka..zanima me samo jel joj njezin serijski hladanjak ok il se mora stavljat drugi?
imam 4870 i na nju sam moro stavljat zalman-a
hvala
toMoo je offline   Reply With Quote
Staro 05.12.2009., 19:41   #567
fran123456
Premija
fran123456's Avatar
Datum registracije: Mar 2009
Postovi: 1,634
Ne bih trebao ako ti ne smeta buka. Inače je ovaj sasvim ok.
fran123456 je offline   Reply With Quote
Staro 05.12.2009., 19:46   #568
toMoo
Lokacija: croatia
Postovi: 20
ma kakva buka glavno da mi hladi i da se ne rusi
Staro 05.12.2009., 19:49   #569
fran123456
Premija
fran123456's Avatar
Postovi: 1,634
Stavi vent na 100% i nema rušenja Btw koji je to cooler bio na hd4870, a da se rušila? Ja sam ih imao par komada, nikakvo rušenje ni na jednoj.
Staro 05.12.2009., 19:51   #570
toMoo
Lokacija: croatia
Postovi: 20
serijski kuler je bio a sad kak imam zalman 50c pod full opterecenjem
