I´m CREEPING DEATH !!!!
Postovi: 135
(riješeno) Smrzavanje kompa
Problem je sljedeći, kad god igram neki igricu nakon nekoliko minuta komp se smrzne, ponekad se dogodi da se smrzne i kad gledam youtube u fullscreenu, dvaput mi se smrznuo dok sam gledao film, isto fullscreen! Da li netko zna u čemu bi mogao biti problem? |
jedan i jedini :D
Lokacija: novi zagreb
Postovi: 5,249
probaj stavit druge drivere za vegu, mozda te to zeza. i pogledaj da temp od vege, da ti se slucajno ne pregrijava? makar bi onda vjerojatno dobio artfakte po ekranu |
N00B
Postovi: 3,886
Sto ti kaze event viewer -> system (kakvih errora imas tu)? |
Postovi: 135
Jedanput mi je samo ovo izbacilo kad sam restartao komp: Problem signature: Problem Event Name: BlueScreen OS Version: 6.1.7600.2.0.0.256.1 Locale ID: 1050 Additional information about the problem: BCCode: 116 BCP1: FFFFFA8004CC2010 BCP2: FFFFF8800579D220 BCP3: 0000000000000000 BCP4: 0000000000000002 OS Version: 6_1_7600 Service Pack: 0_0 Product: 256_1 Files that help describe the problem: C:\Windows\Minidump\110909-32838-01.dmp C:\Users\PERNATY\AppData\Local\Temp\WER-47783-0.sysdata.xml |
N00B
Postovi: 3,886
Instaliraj debugging tool http://www.microsoft.com/whdc/devtoo...tallx86.mspx#a pa sa njim ocitaj *.dmp u "C:\Windows\Minidump\" pa postaj tu na forum.. Iako bi rekao da neki driver zahebava. |
Datum registracije: Mar 2009
Lokacija: KT
Postovi: 2
Probaj ne gledat u full screenu. ![]()
"Kids, You Tried Your Best and You Failed Miserably. The Lesson Is, Never Try." |
Postovi: 135
Ovo mi je ispisalo kad sam napisao komandu !analyze -v !! ADDITIONAL_DEBUG_TEXT: Use '!findthebuild' command to search for the target build information. If the build information is available, run '!findthebuild -s ; .reload' to set symbol path and load symbols. FAULTING_MODULE: fffff80002c13000 nt DEBUG_FLR_IMAGE_TIMESTAMP: 4abfff56 FAULTING_IP: nvlddmkm+e7220 fffff880`0579d220 803d31c0960000 cmp byte ptr [nvlddmkm+0xa53258 (fffff880`06109258)],0 DEFAULT_BUCKET_ID: GRAPHICS_DRIVER_TDR_FAULT CUSTOMER_CRASH_COUNT: 1 BUGCHECK_STR: 0x116 CURRENT_IRQL: 0 STACK_TEXT: fffff880`03c669c8 fffff880`04938ef8 : 00000000`00000116 fffffa80`04cc2010 fffff880`0579d220 00000000`00000000 : nt+0x71f00 fffff880`03c669d0 00000000`00000116 : fffffa80`04cc2010 fffff880`0579d220 00000000`00000000 00000000`00000002 : dxgkrnl+0x5cef8 fffff880`03c669d8 fffffa80`04cc2010 : fffff880`0579d220 00000000`00000000 00000000`00000002 00000000`00000000 : 0x116 fffff880`03c669e0 fffff880`0579d220 : 00000000`00000000 00000000`00000002 00000000`00000000 00000000`00000000 : 0xfffffa80`04cc2010 fffff880`03c669e8 00000000`00000000 : 00000000`00000002 00000000`00000000 00000000`00000000 fffff880`04938c02 : nvlddmkm+0xe7220 STACK_COMMAND: kb FOLLOWUP_IP: nvlddmkm+e7220 fffff880`0579d220 803d31c0960000 cmp byte ptr [nvlddmkm+0xa53258 (fffff880`06109258)],0 SYMBOL_STACK_INDEX: 4 SYMBOL_NAME: nvlddmkm+e7220 FOLLOWUP_NAME: MachineOwner MODULE_NAME: nvlddmkm IMAGE_NAME: nvlddmkm.sys BUCKET_ID: WRONG_SYMBOLS Followup: MachineOwner Ovo je iz drugog dmp filea!! MODULE_NAME: nt FAULTING_MODULE: fffff80002c5d000 nt DEBUG_FLR_IMAGE_TIMESTAMP: 4a5bc600 DRVPOWERSTATE_SUBCODE: 3 IRP_ADDRESS: fffffa8004e72920 CUSTOMER_CRASH_COUNT: 1 DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT BUGCHECK_STR: 0x9F CURRENT_IRQL: 0 LAST_CONTROL_TRANSFER: from fffff80002d3de23 to fffff80002ccef00 STACK_TEXT: fffff800`00b9c4c8 fffff800`02d3de23 : 00000000`0000009f 00000000`00000003 fffffa80`06442060 fffff800`00b9c518 : nt+0x71f00 fffff800`00b9c4d0 00000000`0000009f : 00000000`00000003 fffffa80`06442060 fffff800`00b9c518 fffffa80`04e72920 : nt+0xe0e23 fffff800`00b9c4d8 00000000`00000003 : fffffa80`06442060 fffff800`00b9c518 fffffa80`04e72920 00000000`c00000bb : 0x9f fffff800`00b9c4e0 fffffa80`06442060 : fffff800`00b9c518 fffffa80`04e72920 00000000`c00000bb 00000000`00000000 : 0x3 fffff800`00b9c4e8 fffff800`00b9c518 : fffffa80`04e72920 00000000`c00000bb 00000000`00000000 fffff800`02e7d2e0 : 0xfffffa80`06442060 fffff800`00b9c4f0 fffffa80`04e72920 : 00000000`c00000bb 00000000`00000000 fffff800`02e7d2e0 fffffa80`00000002 : 0xfffff800`00b9c518 fffff800`00b9c4f8 00000000`c00000bb : 00000000`00000000 fffff800`02e7d2e0 fffffa80`00000002 00000000`00018000 : 0xfffffa80`04e72920 fffff800`00b9c500 00000000`00000000 : fffff800`02e7d2e0 fffffa80`00000002 00000000`00018000 fffff800`02e7d2d0 : 0xc00000bb STACK_COMMAND: kb FOLLOWUP_IP: nt+71f00 fffff800`02ccef00 48894c2408 mov qword ptr [rsp+8],rcx SYMBOL_STACK_INDEX: 0 SYMBOL_NAME: nt+71f00 FOLLOWUP_NAME: MachineOwner IMAGE_NAME: ntoskrnl.exe BUCKET_ID: WRONG_SYMBOLS Followup: MachineOwner |
N00B
Postovi: 3,886
Izgleda da te zeza drajver od grafe! Jesi probao unistall drajvera ciscenje svega u safe modeu sa driver cleaner, a zatim install novih drajvera? |
N00B
Postovi: 3,886
#19 |
Addicted to music.
Postovi: 1,782
Provjeri grafulju.Meni je tako smrzavalo,jer je grafička odapela. Moguće da ima neki problem,ne mora značiti nužno da umire. Probaj sa drajverima eksperimentirati,ako ništa,onda se baci na malo zahtjevnije postupke. |
#20 |
Postovi: 135
Događalo mi se na XP-u, VISTU uopće nisam koristio, i sada mi se događa na Win 7, čini se da najvjerovatnije neki problem u grafulji! Najvjerovatnije zagrijavanje, jer kad kod pogledan temp., uvijek je oko 80-90 stupnjeva, zavisi od igrice do igrice, al opet mi ne ide u glavu zašto se onda smrzava u YouTubeu, tu je temperatura oko 60 stupnjeva! Ostalo mi je još par stvari za provjeriti, pa ćemo vidjeti. Uglavnom, hvala svima koji su mi dali prijedloge, ako nešto otkrijem, javim! Problem je stvarno zanimljiv! |
#21 |
Addicted to music.
Postovi: 1,782
Zato ti i kažem.Identična mi se stvar događala,prvo sa igrama,zatim gledajući youtube videa,pa čak i film u fullscreen modu,ono. Tako da sam osobno uvjeren da je 90 % to do grafičke,pošto sam ja piknuo novu i ugradio,problem magično nestao. Ajde,pa javi što je bilo. ![]() |
#22 |
Postovi: 135
Riješio sam problem, stvar je bila u latenciji memorije i software-u, matična mi je dizala latenciju na 9-9-9-24, a trebala je biti na 7-7-7-20! A što se tiče softwarea, ja sam uporno skidao soft. za nVidiu a na za XFX, jer sam mislio da su to isti soft. Još jednom svima puno hvala! |
