Staro 03.11.2009., 15:13   #1081
trouble
našikan pravim haos
Lokacija: u zabrani
Postovi: 2,707
Autor sinisa1989 Pregled postova
Vjerojatno s tom serijom misle konkurirat nvdijinom GT300 čipu, jer trenutna 5xxx serija nije dovoljna.
Bez uvrede,al ovakakv komentar više priliči nekom 12 godišnjem slinavcu s BUG foruma nego nekome na PC-E.....
nVidia je sa svojim čipom trenutno na rekla-kazala....samo je pitanje dal će isporučit performanse proporcionalno realne večoj cijeni. Ako će bit 10%-20% veće performanse za 40% veću cijenu mogu si slobodno stavit metak v čelo. A kako iskustvo govori,ako i činjenice o proizvodnom procesu....tak bu i bilo(nadam se bez metka )
Staro 03.11.2009., 15:28   #1082
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
HD 5800 series still facing availability issues;
http://www.fudzilla.com/content/view/16255/34/
Zadnje izmijenjeno od: Matth€w. 03.11.2009. u 23:07.
Matth€w je offline   Reply With Quote
Staro 03.11.2009., 15:36   #1083
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
40nm yield issues cause Nvidia and AMD delays
O ovom se radi:
TSMC are unfortunately running into more problems with their 40nm process technology which is causing issues for AMD and Nvidia in regards to GPU production.
Both graphics cards giants are expected to face shipment delays of their most current orders from TSMC due to these issues with 40nm yields. TSMC chairman Morris Chang spoke to Heaven Media earlier today and reported that 40nm yields recently dropped to just over 40% at the beginning of October and that they are working as hard as they can to resolve these issues before the end of the year.
For those of you who don't know TSMC are a vital link in the production chain for both graphics card manufacturers and given the poor state of the current 40nm market with the release of the excellent HD5000 series from AMD it is tough for AIB partners to get the necessary samples to meet demand. With Nvidia's Fermi just around the corner this situation is only going to get worse especially in the run up to Christmas holiday season.
TSMC have been having issues for quite some time with this complex process and have actually improved their yield rates from 20 percent during the Q2 phase - unfortunately it is still not reaching the required levels to deliver the goods to both Nvidia and AMD.
These are delicate times and if the situation continues then many people will be unable to get their new HD5000 or upcoming Fermi graphics cards. We have a source close to this so we will keep you informed when and if the situation changes.
Staro 03.11.2009., 15:50   #1084
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
Kakve to točno probleme imaju s proizvodnjom 40nm yieldsa?
Staro 03.11.2009., 15:52   #1085
Jelc
Super Moderators
Postovi: 17,485
Autor Matth€w Pregled postova
Puno škarta?
Staro 03.11.2009., 15:54   #1086
generic
generic's Avatar
Postovi: 1,079
Autor trouble Pregled postova
Zašto? Ionako je 80% topica o GT300 i 20% ovog topica (dio prije nego su kartice izašle) čisto nagađanje. ATI je s 5800 serijom napravio ono što nvidia radi s GT300, a to je udvostručivanje broja SP-a. Tom logikom se razlika koja je između 4870 i GTX280 održava i dalje. Momak samo ide tom logikom, znači čista sirova snaga.
Ako se u obzir uzme cijena, dobavljivost, potrošnja,..., onda je to MOŽDA sasvim drukčija priča. 'Možda' je s capsom jer je i Sinisa1989 napisao 'vjerojatno' u svom postu. Danas ništa nije sigurno, što se vidi i iz TSMC-ovih problema.
Da se osvrnem i na te probleme s proizvodnjom, drago mi je da se malo situacija okrenula i da je ATI prodisao skoro punim plućima i da će sad uhvatit financijski zalet. Nvidijin čip mi se čini malo preglomazan i teško da će u početku imati odgovarajući (čitaj: profitabilan) yield.
generic je online   Reply With Quote
Staro 03.11.2009., 15:56   #1087
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
Autor Jelc Pregled postova
Puno škarta?
Hehe
Mislim da im nije dobro da im industrija trenutno radi na principu trial_and_error.
Staro 03.11.2009., 16:02   #1088
Postovi: 34,066
Hehe
Bit će prije app sistem - ako prođe, prođe
Staro 03.11.2009., 16:20   #1089
Mad_Duke
Autor generic Pregled postova
-cut-
Možeš ti nagađati kaj god ali u ovim uvjetima nvidia ne može napraviti profitabilniji (čitaj za manju cijenu) chip od ATi-a. Mogu samo povećati jaz koji je bio prisutan i kod prošle serije.
Može štekati taj proizvodni proces, ali atijeve grafe svejedno idu dalje i štancaju se i okupiraju polagano sve tržišne segmente, a situacija je svakim "tjednom" sve gora za nvidiju, a sve bolja za ATi zbog toga.
Staro 03.11.2009., 17:34   #1090
generic
generic's Avatar
Postovi: 1,079
Mogao si onda umjesto -cut- quotat dio na koji se odnosi jer sve što si ti sad u tom postu napisao sam i ja rekao u svom zadnjem paragrafu (uz presutnu činjenicu da su jezgre GTX-ova znatno veće od radeona serije 4800).
Ali ipak mi nije jasno o kojem se to jazu govori. Tek postoji hipotetski ekonomski jaz zbog razlike u cijeni proizvodnje čipova (ali opet se može uzeti u obzir i to da iako nvidija ima manji profit po čipu drži veći dio tržišta). Potrošnja, zagrijavanje, buka, sve je to tu negdje.
Staro 03.11.2009., 18:56   #1091
sinisa1989
Bazinga
sinisa1989's Avatar
Lokacija: Križevci
Postovi: 3,933
Nisam se uvrijedio, prihvaćam sve kritike. Ali, vjerojatno se i ja krivo izrazio, a ti krivo shvatio. Ja sam samo izrazio mišljenje prema informacijama koje sam pročitao. Naravno to su samo naglabanja. Kad oba dvije serije izađu na tržište i prijeđu s riječi na djela onda ćemo vidjet koja je kartica isplativija. Jer kao što si i rekao sve se svodi na omjer cijena i kvaliteta, a poznato je da je ati jeftiniji u odnosu na konkurenciju.
sinisa1989 je online   Reply With Quote
Staro 03.11.2009., 22:45   #1092
anidra
anidra's Avatar
Lokacija: Švedska
Postovi: 57
Autor dh41400 Pregled postova
Neki bi rekli cak i brza od GTX-ice, pod malim gasom
Sve u svemu opasna kartulja ... kada bi ove nove bile barem upola dobri OC-eri kao ta stara garda :/
Pa nije ti to baš mali gas, pogledaj malo sliku na linku koji si dao pa vidi pod GPU-Z kako su rezultati pod CrossFire - znači tip je roknuo 2 takve grafe
Zadnje izmijenjeno od: anidra. 03.11.2009. u 23:17.
anidra je offline   Reply With Quote
Staro 03.11.2009., 23:13   #1093
Constantine
Constantine's Avatar
Postovi: 668
http://www.bit-tech.net/news/hardwar...5870-vapor-x/1
379 funta,pa koliko ce tek kostat kod nas :O
Constantine je offline   Reply With Quote
Staro 03.11.2009., 23:23   #1094
Mr.Ex.President
Torrent freek
Mr.Ex.President's Avatar
Postovi: 3,949
Autor anidra Pregled postova
Pa nije nitko propustio da su dvije, al rezultat je i dalje impresivan
MBO: MSI B450 Gaming Plus
PSU: Corsair RM550X 550W
Periferija
LCD: HP ZR24w
Mouse: Logitech G400
Sound: Genius SP-HF1201A
Printer: HP LaserJet 1020
Scanner: HP ScanJet 4300
Headphones: Philips SHC 2000
MBO: Gigabyte GA-F2A85XM-HD3
HDD: WD Green 2TB [WD20EZRX]
PSU: Antec SU380
TV: Samsung 43E450 @HDMI
LINK
Staro 03.11.2009., 23:36   #1095
Halos
muimerP
Halos's Avatar
Lokacija: VG
Postovi: 3,334
Ajme tek sam sad vidio
Skor je fkt respekt, skinut 30k sa 2900@cf skidam kapu. Modao ih je brutalno
Stvarno, ekipa sa 4870@cf jedva skida 30k, ali ovaj bez pardona dere. Volio bih da izvrti nekakav crysis ili bilokoju malo jaču igru, da se vidi kako diše, makar i sa spustenim klokom proca.
Staro 03.11.2009., 23:45   #1096
maX
maX's Avatar
Postovi: 7,326
Uskoro se kod mene sprema 2xHD2900XT CF, bit će veselo
Neće biti preko 30kn, ali preko 26k bi moralo biti
Staro 03.11.2009., 23:45   #1097
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
Autor Constantine Pregled postova
Imaš u temi niže "ATI Radeon HD 5870" o tome
Staro 03.11.2009., 23:49   #1098
Mr.Ex.President
Torrent freek
Postovi: 3,949
Autor Halos Pregled postova
Sad smo već debelo offtopic, al nije on sa stock karticama skinuo 30k, pogledaj taktove, pa onda zamisli šta je sve radio s njom Nakon takve "obrade" 4870CF bi išle i preko 40k vjerovatno
Periferija
LCD: HP ZR24w
PSU: Antec SU380
LINK
Staro 03.11.2009., 23:56   #1099
Halos
muimerP
Halos's Avatar
Lokacija: VG
Postovi: 3,334
sry mod na OT, ali ono nije moglo bez komentara
@Max e to bu bilo veselo, jer xt je jača od pro
@president - znam, citaj gore kaj sam napisal. Ali 2900 je kartica prije 2 generacije, ma kakav mod daje svejedno je respektabilno da ju dovede do takvih performansi. Ali me zanima potrošnja
Back to topic
neznam dali se tko vec javio sa modovima 5850/70?Ima kaj na netu?
Staro 04.11.2009., 04:18   #1100
dh41400
Señor Audiophile
dh41400's Avatar
Lokacija: Zabreg
Postovi: 3,280
Vidi vidi, ti imas 8800GTX ... zanimljivo
Autor maX Pregled postova
Znao sam! Cim sam vidio da je onom tipu vec na procjenama rezervirana grafa ... sve mi je bilo jasno
Izvadi im dusu
Sorry za OT nebum vise
The Secret ...
Staro 04.11.2009., 10:36   #1101
Jelc
Super Moderators
Postovi: 17,485
Dečki, ajde malo lakše sa spamarom
Staro 04.11.2009., 11:38   #1102
Jelc
Super Moderators
Postovi: 17,485
AMD HD 5800 series - demand exceeding availabilty
AMD's new range of video cards is assuredly one of their best ranges in the companies history, with class leading performance, cutting edge technology as well as reduced temperatures compared to the last generation with great overclocking capability.
The only issue is availability - and its a problem that shows no signs of miraculously disappearing either. We reported a while ago that TSMC has been having issues with their 40nm engineering process and this is having a knock on effect for the end user. In the last week I have received over 200 emails from Driverheaven readers asking for my help in locating a 5800 series video card.
A month has passed and it is still difficult to get hold of a HD 5870 and the situation is even worse if you are looking for a HD 5850, which offers substantially better value for money than its bigger brother. Searching on google we find only a handful of stores with either in stock and the prices in Europe are also sky high with a lowest price of around 390 euros for the HD 5870. The 5850 we found on 3 stores and the prices are even worse with over 300 euros being the best deal we could find.
The Juniper series is easier to get with the Hd 5750 being available in quite a few shops and my personal favourite the HD5770 is stocked on most stores with prices around the £130 mark. With my own testing the HD5770 is a MONSTER card in Crossfire, even capable of powering the most demanding engines at the native resolution of a 30 inch panel.
In the USA, it seems just as tricky finding any of the 5800 series with slightly better odds if you want a 5700 series card.
This is a huge issue for AMD because if you think about it, the demand for these cards is so high without any competition right now from their main competitor Nvidia. This is costing AMD a lot of potential money and with the recent stepping down of former CEO Ruiz, their shares are taking a beating - down 18% in recent weeks.
Unfortunately AMD's massive leap on releasing DX11 capable hardware before their competitors has been not as much of a success as it should have been.
Staro 04.11.2009., 16:09   #1103
branuschi
branuschi's Avatar
Lokacija: Sinj
Postovi: 397
Hd 5970
Moje trgovine: 1 ,2 , 3 , 4 , 5 , 6 , 7 , 8 , 9 , 10 , 11 , 12 , 13 , 14 , 15 , 16 , 17 , 18 , 19 , 20 , 21 , 22 , 23 , 24
branuschi je offline   Reply With Quote
Staro 04.11.2009., 16:37   #1104
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
Stranica prije
Staro 05.11.2009., 13:25   #1105
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
Powercolor release passively cooled HD5750; PowerColor.com
Staro 05.11.2009., 13:50   #1106
pingmachine
machine that goes ping!
Postovi: 478
to! to je moja buduća kartica! osim ako ima power connector, onda nije.
pingmachine je offline   Reply With Quote
Staro 05.11.2009., 14:04   #1107
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
Još da naprave takvu 5770. Što se tiče power conectora, "običan" HD 5750 ti ga ima, 6-pinski...
Staro 05.11.2009., 14:10   #1108
Postovi: 34,066
Mislim da neće ni biti verzije bez power konektora. 5750 u loadu troši 86W, a PCI-E može dati samo 75W.
http://www.pcekspert.com/articles/710-1.html
Staro 05.11.2009., 14:14   #1109
pingmachine
Postovi: 478
Staro 05.11.2009., 14:20   #1110
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
Ne razumijem zašto nisu stavili podršku i za 57xx modele za PCI-e 2.0, kaj nije da on daje 150W?
