Staro 17.09.2009., 12:08   #1
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Celeron D341 256kB 2.93GHz pjeva i dalje...
Neki mozda znaju, a neki i ne pricu o tom cudnom svatu...
http://forum.pcekspert.com/showthread.php?t=154848
Staro 17.09.2009., 12:19   #2
Doink the Clown
Jack of all, master of none
Doink the Clown's Avatar
Lokacija: Matulji - Rijeka
Postovi: 6,214
Joj, kad se tog epic poteza sjetim odmah u smijeh odvalim Što je bilo na kraju? Jesi ga kloknuo do 4.5?
C L O W N I N G A R O U N D
Staro 17.09.2009., 12:31   #3
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Evo danas mi se digao zivac i kao iz p**** ga odvalim na 170MHz FSB na P31-DS3L (multi je 22x sto dovodi do efektivne frekvencije od 3.74GHz) Stock napon, ofskroz.
Rezultat? OCCT govno se ne rusi oko 45 minuta, temperatura pod CF800 ne prlazi 50°C, ja zadovoljan i masem repom, zasad
Code:
Field	Value
CPU Properties
CPU Type	Intel Celeron D 341
CPU Alias	Prescott-256
CPU Stepping	E0
Engineering Sample	No
CPUID CPU Name	Intel(R) Celeron(R) CPU 2.93GHz
CPUID Revision	00000F41h
CPU Speed
CPU Clock	3740.0 MHz  (original: 2933 MHz, overclock: 28%)
CPU Multiplier	22x
CPU FSB	170.0 MHz  (original: 133 MHz, overclock: 28%)
Memory Bus	340.0 MHz
DRAM:FSB Ratio	8:4
CPU Cache
L1 Trace Cache	12K Instructions
L1 Data Cache	16 KB
L2 Cache	256 KB  (On-Die, ECC, ATC, Full-Speed)
Motherboard Properties
Motherboard ID	07/19/2007-P31-ICH7-6A79OG0WC-00
Motherboard Name	Gigabyte GA-P31-DS3L  (3 PCI, 3 PCI-E x1, 1 PCI-E x16, 4 DDR2 DIMM, Audio, Gigabit LAN)
Chipset Properties
Motherboard Chipset	Intel Bearlake P31
Memory Timings	5-4-4-10  (CL-RCD-RP-RAS)
Command Rate (CR)	2T
DIMM2: OCZ Gold XTC OCZ2G8001G	1 GB DDR2-800 DDR2 SDRAM  (5-5-5-15 @ 400 MHz)  (4-5-5-13 @ 333 MHz)  (3-4-4-10 @ 266 MHz)
DIMM4: OCZ Gold XTC OCZ2G8001G	1 GB DDR2-800 DDR2 SDRAM  (5-5-5-15 @ 400 MHz)  (4-5-5-13 @ 333 MHz)  (3-4-4-10 @ 266 MHz)
BIOS Properties
System BIOS Date	07/19/07
Video BIOS Date	05/02/08
Award BIOS Type	Award Modular BIOS v6.00PG
Award BIOS Message	Intel P31 BIOS for P31-DS3L F1
DMI BIOS Version	F1
Graphics Processor Properties
Video Adapter	nVIDIA GeForce 9600 GSO
GPU Code Name	G92GSO  (PCI Express 1.0 x16 10DE / 0610, Rev A2)
GPU Clock (Geometric Domain)	555 MHz  (original: 600 MHz)
GPU Clock (Shader Domain)	1350 MHz  (original: 1500 MHz)
Memory Clock	499 MHz  (original: 800 MHz)
Staro 17.09.2009., 12:36   #4
Doink the Clown
Postovi: 6,214
Autor Dizel Pregled postova
Nakon 45 min se komp sruši ili si jednostavno prekinuo test? Ajmo ajmo malo voltažicu gore pa iznad magične granice od 4Ghz Ako bude nekakav incredible rez šalji mail Intelu sa opisom svega što si napravio jadnom procu, tko zna možda si jedinstveni slučaj pa nagrade taj tvoj sadizam
Staro 17.09.2009., 12:38   #5
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Ma koje rusenje, dopizdilo mi gledati u taj stupidni program koji mi ionako jednu jadnu jezgru nakuri na 100%...rock stable masina
Staro 17.09.2009., 14:10   #6
Crash009
Crash009's Avatar
Lokacija: Orahovica
Postovi: 7,363
Stavi ga na Abiticu pa mu mast izvadi
Staro 17.09.2009., 16:28   #7
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Najvise mi muka skidati Nirvanu dolje i vaditi plocu van iz kucista jer ima ona 4 brezona usarafljena u plocicu ispod...blah. Mada i CF800 ima isti sistem montaze, lakse je pristupljiv jer nije tower hladnjak.
Uglavnom, ja sam odusevljen OC ogucnostima na stock naponu za jedan Prescott based procesor. 800MHz kao iz sale, dobar malac. Sad jel to zbog moje "rucne modifikacije" ili ne, ne znam
Staro 17.09.2009., 17:15   #8
Crash009
Crash009's Avatar
Lokacija: Orahovica
Postovi: 7,363
Opizdi još koji pa ce ići bar na 4GHz
Staro 17.09.2009., 20:31   #9
maX
maX's Avatar
Postovi: 7,326
A zašto nebi radio?
Ajde ajde, ne srami se, baci ga na Abiticu da ti se ne razleti regulacija na jadnoj P31-DS3L
Staro 17.09.2009., 21:53   #10
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Autor maX Pregled postova
A zašto nebi radio?
Sva sreca pa ova plocica nema senzore temperature na MOSFETima pa ne znam kako grije
