Staro 11.09.2009., 21:20   #1
Liquid Snake
Liquid Snake's Avatar
Postovi: 166
Catalyst 9.9 Official
Liquid Snake je offline   Reply With Quote
Staro 11.09.2009., 22:43   #2
sinisa1989
Bazinga
sinisa1989's Avatar
Lokacija: Križevci
Postovi: 3,933
Jel instalirao tko?
Staro 11.09.2009., 22:52   #3
stopalo9
stopalo9's Avatar
Postovi: 763
Autor sinisa1989 Pregled postova
Jel instalirao tko?
Evo ja
stopalo9 je offline   Reply With Quote
Staro 11.09.2009., 22:53   #4
LUXX
Vodenjak :)
LUXX's Avatar
Lokacija: Križevci
Postovi: 667
Ja upravo instaliro al nisam još probao igrat
LUXX je offline   Reply With Quote
Staro 11.09.2009., 22:55   #5
domis
Lokacija: Hrvatistan
Postovi: 4,165
baš sam probal i fakat su ubrzali alt+tab u igri
Staro 11.09.2009., 22:59   #6
sinisa1989
Bazinga
sinisa1989's Avatar
Lokacija: Križevci
Postovi: 3,933
Probat ću i ja sutra. Sad mi se neda klikat
Staro 11.09.2009., 23:46   #7
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
Pa tu nema još podrške za hd5800 seriju.
Zen5 PCIvy bridge Notebook
CPU: AMD Ryzen 7 9700x, CO per Core, CS -20 (Mid, High, Max)
COOLER: Arctic Cooling Liquid Freezer III 420 A-RGB
MBO: MSI Tomahawk X870
RAM: Corsair Vengeance DDR5 32GB, 6000MHz CL28
GPU: MSI SuprimX Nvidia GeForce RTX 3070
NVM1: Samsung Evo 970 2TB
HDD1: WD Red 4TB, WD40EFRX
HDD2: WD Blue 6TB, WD60EZRZ
HDD3: WD Blue 6TB, WD60EZRZ
PSU: Corsair RMx 850W, ATX3.1
CASE: Fractal Meshify 2 XL
VENTS: 4x Arctic Cooling P14 PWM PST A-RGB
OS: Win 11 Pro, 64-bit
MONITOR: AOC Q3279VWFD8 - 32", IPS, 2560x1440
TV: LG 7450
MOUSE: Logitech MX Master 3
KEYBOARD: Logitech MX Keys
GAMEPAD: XBOX One
HEADPHONES: Sennheiser HD560s
DELL Inspiron 15R, 5520
CPU: Intel Core i7 3632QM, 2.20Ghz, turbo 3.20GHz
RAM: DDR3, 6GB (4GB + 2GB), 1600Mhz CL11
GPU: AMD Radeon 7670, Intel HD4000
SSD: Samsung EVO 850, 250GB
SCREEN: 15,6 inch LCD, 1366x768
OS: Ubuntu 24.04, 64-bit
DraŽ je offline   Reply With Quote
Staro 12.09.2009., 02:05   #8
ZOKSY
ZOKSY's Avatar
Postovi: 278
9.8 su mi radili bez greške....sutra kemijam s novima.....
Draž- a zakaj bi bili kad serija 5xxxx nije još vani?
kaj ti posjeduješ dotičnu?
ZOKSY je offline   Reply With Quote
Staro 12.09.2009., 02:35   #9
ThePornstar
ThePornstar's Avatar
Postovi: 4,403
instalirani, isprobani, mogu reć da se vide neka poboljšanja šta se tiče vpu_recoverya kojeg više nema, također nema niti jednog bsod_a, što je kod zadnjih par verzija bilo prisutno
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
Battery: 57 Wh internal
ROM: Android 9
Staro 12.09.2009., 13:10   #10
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
Autor ZOKSY Pregled postova
Pa ako su demonstrirali kartice već onda trebaju i drivere, a imaju i neke špekulacije da ide u prodaju već ovog mjeseca 22.09, pa mi je to malo čudno.
Dali idu poslje ovih 9.10 ili 10.1?
TV: LG 7450
GAMEPAD: XBOX One
Staro 12.09.2009., 13:31   #11
Veki-os
Veki-os's Avatar
Datum registracije: Jun 2004
Postovi: 3,996
Autor DraŽ Pregled postova
Đisus,što tebe brine u životu...
Veki-os je online   Reply With Quote
Staro 12.09.2009., 13:43   #12
TomRi
Can You Hear Me? 142.8 dB
TomRi's Avatar
Lokacija: Zagreb, Kvatrić
Postovi: 2,073
ako te to već brine, samo se sjeti 8.12 iz 12. mjeseca 2008,
a evo ovi su 9.9 u 9.2009, pa dalje zaključi sam....
Danas je teško biti budala, prevelika je konkurencija...
Water cooled PC
Moj najveci MOD
Novi hobby: RC model + HD kamera
TomRi je offline   Reply With Quote
Staro 13.09.2009., 11:35   #13
Mario92
Omicron Alpha resident
Mario92's Avatar
Lokacija: Bistra
Postovi: 5,110
Stavio sam nove drivere, nisam skužio ništa novog.
Igre su i dalje na jednakom FPSu.
Staro 13.09.2009., 13:33   #14
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
Autor Mario92 Pregled postova
Pa jesi pročitao release notes? Samo bugfixevi.
TV: LG 7450
GAMEPAD: XBOX One
Staro 13.09.2009., 18:16   #15
E-mil
Oppa Gangbang Style
E-mil's Avatar
Postovi: 1,764
imao 9.5
stavio 9.9
"primjetio" u rivatuner-u nemam više Overclocking TAB (samo Fan)
vratio natrag 9.5
E-mil je offline   Reply With Quote
Staro 14.09.2009., 00:45   #16
Atrax
Atrax's Avatar
Postovi: 553
Zašto 10.1? 9.10 su sljedeći. 10.1 će bit u siječnju 2010-te, barem su do sada tako numerirali drivere, vjerojatno će i dalje tako.
I btw, red faction guerrilla mi sa 9.9 radi probleme. Nešto kao micro lag u FC2, svako malo preskoči frame, i to samo kad se vozikam, onfoot nisam primjetio to.
Ali je interesantno to što sada mogu stavit AA na 8x i ide puno glađe nego sa 9.8. Sad je to dilema, kvaliteta slike ili stabilan framerate, vratit se na 9.8 il ne.
I još jedna stvar sa RF:G, ambient occlusion opcija u gfx postavkama baca artefakte, i dio tekstura tla bude crn, tj kao da se sjene krivo projiciraju. Jel to kod mene samo ili?
Zadnje izmijenjeno od: Atrax. 14.09.2009. u 02:21.
Atrax je offline   Reply With Quote
Staro 14.09.2009., 02:44   #17
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,757
Autor Atrax Pregled postova
Zašto 10.1? 9.10 su sljedeći. 10.1 će bit u siječnju 2010-te, barem su do sada tako numerirali drivere, vjerojatno će i dalje tako...
Slazem se, IMO po datumu ce vjerojatno ici kao i dosad (10.mj. - v9.10, 11.mj. - 9.11 itd...)
Staro 14.09.2009., 03:10   #18
Jackson
Postovi: 648
Još nisu rješili problem crnih tekstura u Anno 1404, još uvijek je pod known issues
Jackson je offline   Reply With Quote
Staro 14.09.2009., 03:19   #19
Neo-ST
Neo-ST's Avatar
Postovi: 8,566
Meni Red Faction Guerrilla radi isto probleme sa 9.9
New game - prva misija, slika je negledljiva, sve treperi...
Escape - options - display - i bloka...
Staro 14.09.2009., 11:33   #20
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,007
Jedan on najmanje uzbudljivih catalysta ove godine, al eto instalirao reda radi
Staro 14.09.2009., 12:12   #21
win32
win32's Avatar
Datum registracije: Apr 2008
Postovi: 1,517
Instalirao i ja....
Glavno da rade......bar sa onim igrama koje igram.....
"In the beginning there was 0. And then there was 1. A mind-bending meditation on the transcendent power of digital computation."
Pošteni trgovac: 1, 2, 3, 4, 5...
win32 je offline   Reply With Quote
Staro 14.09.2009., 13:30   #22
Atrax
Atrax's Avatar
Postovi: 553
Autor Neo-ST Pregled postova
Upravo to. Evo danas malo dulje igrao, i počne se zamrzavat igra na 5-10 sec i onda opet krene. Jako nestabilno, i to sam probao kombinirat svakakve gfx postavke, nema razlike.
Mislio sam da je vpu recover, ali nije, grafa radi OK.
Ali provjeri da li ti je upaljen ambient occlusion. Ugasi ga pa vidi ima li kakve promjene na slici, meni je bacao artefakte i crne teksture.
Jedino velim, sa 9.9 mislim da dobivam više FPS, pogotovo sa AA na 8x, al imho, đaba mi ti FPS-i kad se zamrzavaju svako malo.
Vraćam se na 9.8 definitivno, inaće ne bih jer sve drugo radi bez problema, al baš sam se sad zagrijao za RF:G.
I btw, isprobavao sam malo TAB-at između igre i winsa, i stvarno ide sad puno brže, gotovo trenutno, u nekoliko igara sam probao.
Staro 14.09.2009., 15:33   #23
Neo-ST
Neo-ST's Avatar
Postovi: 8,566
Ma đaba ti je sve ako nemoš' igru igrat
Idem i ja na 9.8
Staro 14.09.2009., 16:10   #24
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,760
vracam se i ja na 9.8, nasao sam stabilni oc koji mi je na 9.9 sve samo ne stabilan...
Staro 14.09.2009., 16:29   #25
Atrax
Atrax's Avatar
Postovi: 553
Fail
Sva sreća pa sam si pobriso 9.8 s harda
Čačkam po guru3d al nemogu ništa nać, nisu li oni imali kao arhivu neku prije di se moglo skinut starih drivera?
I ati.com je imao nešto takvo, ali ne mogu ništa nać.
Help?
EDIT: pomiješao sam guru3d sa techpowerup, oni imaju arhivu. Riješeno.
Staro 14.09.2009., 16:32   #26
Neo-ST
Neo-ST's Avatar
Postovi: 8,566
http://www.mediafire.com/download.php?zyjmr4vgkvm
To su ti XG Catalysti, tweakani
Staro 14.09.2009., 17:10   #27
alen.s
alen.s's Avatar
Postovi: 1,441
složio bi se da nisu baš "najbolji do sada" ( xp 64 )
Staro 14.09.2009., 18:32   #28
Atrax
Atrax's Avatar
Postovi: 553
Stavio.
Ne budu li valjali...
RF:G sam isprobao, radi sada kak treba.
Staro 18.09.2009., 11:19   #29
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Hotfix for “No compatible hardware found” error when installing Catalyst drivers for ATI Radeon HD 4000, ATI Radeon HD 3000 and ATI Radeon HD 2000 Series AGP products
Symptoms:
"No compatible hardware not found" error message when attempting to install the ATI Catalyst Drivers directly from the AMD Download Home Page for the ATI Radeon™ HD 4000, ATI Radeon™ HD 3000 or ATI Radeon™ HD 2000 Series of AGP video cards.
All published AMD drivers have passed Microsoft's WHQL certification tests. A WHQL driver for ATI Radeon™ HD 4000, ATI Radeon™ HD 3000 or ATI Radeon™ HD 2000 Series of AGP products is not currently available.
Resolution:
This hotfix resolves the following issues:
Fix for problems with DirectX and ATI Radeon™ HD 4000, ATI Radeon™ HD 3000 or ATI Radeon™ HD 2000 Series of AGP Graphics cards.
Fix for "No compatible hardware not found" error message.
Graphics Cards:
ATI Radeon™ HD4000 series of AGP products
ATI Radeon™ HD3000 series of AGP products
ATI Radeon™ HD2000 series of AGP products
Operating System:
Windows Vista® 32-bit Edition
Windows Vista® 64-bit Edition
Windows® XP Professional
Windows® XP Home Edition
Windows® XP Media Center Edition
Windows® XP Professional x64 Edition
http://support.amd.com/us/kbarticles...AGPHotfix.aspx
Staro 25.09.2009., 16:50   #30
DomagojX
Lokacija: Zagreb/Sesvete
Postovi: 1,307
možda sam malo fulao topic ali mislimda je do ovih drivera...uglavnom imam 2 4870....i u riva tuneru za jednu grafu imam overklocking tab dok za drugu nigdje nema????
DomagojX je offline   Reply With Quote
