Staro 02.09.2009., 20:04   #1
jjd37
jjd37's Avatar
Postovi: 245
Kako spojiti crossfire bridge?
Dakle problem je u tome da imam 2 crosfire mostica od svake kartice po jedan i 2 mjesta za njihovo spajanje pa sam u dvojbi dali su oba dva doista i potrebna .Naime uputstva su blago receno manjkava i pokazuju spajanje samo 1-im mosticem a ni na stranici proizvodaca nije nista bolji support (Sapphire ). Dali moze stetiti ako se spoje oba? Ako netko ima iskustva molio bi za pomoc.
| MSI Z97 MPOWER (MS-7915) | Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz - Noctua NH-D14 | Coolermaster Stacker | 4x G.Skill F3-10666CL7-2GBRH | OCT Vector 180 240GB, Hitachi HDS721010CLA332,ST3250410AS,ST3250410AS | GAINWARD GeForce GTX 980Ti Phoenix GS | Corsair HX 850W | LG L1919S |UPS CyberPower 2200VA |
| ASRock EX58 Extreme | CPU Intel i7 920 | Corsair 3x2GB | WDC WD5001AALS,WDC WD6400AAKS,SAMSUNG HD322HJ,ST3160813AS,,ST3300622AS,WDC WD800JB-00JJC0 | CrossFire Sapphire ATI Radeon HD4890 Vapor-X | Corsair HX850W | CIBOX 22" | UPS Trust PW4105 |
| Spectrum 48K | Comodore 128 | PC 386 |
| Dell Latitude D820 |
jjd37 je offline   Reply With Quote
Staro 02.09.2009., 20:07   #2
MAXx
Čupavac
MAXx's Avatar
Postovi: 261
Spoji obadva. Nećeš imati nikakvih problema. LINK
Science cannot be stopped. Man will gather knowledge no matter what the consequences – and we cannot predict what they will be. - Linus Pauling
MAXx je offline   Reply With Quote
Staro 03.09.2009., 05:31   #3
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
| DFI LanParty CFX3200-DR | AMD64 X2 4600 skt939 - Freezer 64 Pro | Chieftec BA02BBBOP | 4x1GB Kit Corsair PC4000 | Hitachi HDS721680PLA,ST330062 2AS,WDC WD800JB-00JJC0 | CrossFire Sapphire ATI Radeon HD4890 Vapor-X | Corsair HX850W | CIBOX 22" | UPS Trust PW4105 |
Daj samo reci da se salis da ti je ovo konfiguracija...Boze, baci peglu i budi precizan
Staro 03.09.2009., 08:04   #4
Postovi: 33,952
X2 4600 nije dovoljan 4890 ni da se zagrije kako treba, a za CF je totalno neprimjeren. Nema šanse da primjetiš razliku u performansama između jedne ili dvije 4890.
Staro 03.09.2009., 09:16   #5
dh41400
Señor Audiophile
dh41400's Avatar
Lokacija: Zabreg
Postovi: 3,280
Ma kakvu peglu ... ovo je dovoljno
The Secret ...
Staro 03.09.2009., 13:04   #6
jjd37
jjd37's Avatar
Postovi: 245
Autor Dizel Pregled postova
Autor coconut Pregled postova
Autor dh41400 Pregled postova
Polako nisam ja "Zlatna Zagrebacka mladez" pa da odjednom dam 10000 kunica za sve sto mi treba. Znam i ja sve gore navedeno ali trenutno je ovo nadogradnja stare masine.
Staro 03.09.2009., 13:18   #7
Postovi: 33,952
Ali, tom nadogradnjom ne dobijaš baš ništa jer proc ne može nahraniti podacima obe grafe. Zapravo, ne može ni jednu, a kamoli obe. Kupi bolju ploču i proc pa će CF ti doći do izražaja iako je i to upitno jer performanse ne rastu proporcionalno (2 grafe NIJE jednako duplo više fps).
Staro 03.09.2009., 13:50   #8
jjd37
jjd37's Avatar
Postovi: 245
Za sada je dosta i ovo me lupilo posteno po depu. Trenutno nemam za jos 2-3t kuna ulaganja u komp ipak se mora od neceg i zivit.
Staro 04.09.2009., 20:29   #9
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Bolje da si ulozio to u dobru plocu, procesor i jednu takvu 4890...i ostatak si mogao zapit komotno
