Datum registracije: Jun 2002
Lokacija: Tuh. Toplice
Postovi: 327
nForce2 cool patch
This patch will allow nForce2 chipset based motherboards with AMD cpus to use C2/C1 idle state (S2K bus disconnection and reduce idle/load temperatures by 1-10c degrees dnload: http://www.newgenerationorder.org/C2NGO.zip /edit evo meni pala sa 39 na 33-34, jel netko drugi isprobao mozda?
Sempron 2800+ @ 2400 MHz/Epox 8KDA3i/ST passive/GEIL 2x512 MB/Enlight 300 W/9800 Pro/SB Live!/Seagate 320 GB/Pioneer 110D Zadnje izmijenjeno od: Lifo. 19.09.2004. u 04:41. |
Datum registracije: Nov 2002
Postovi: 1,950
aha, i meni je opala tempa pa se nakon 5 min smrzo sistem |
Datum registracije: Sep 2002
Postovi: 2,722
nije se smrzo i pala za 5 stupnjeva. nije loše ![]() edit: eto kad sam brzoplet, prvo je pala za 1 stupanj, kanije za 5, pa za 7, sad za 9!!! Ili ovaj patch sjebe sondu ili je stvarno zakon. A ja sam bio prebrz i prerano pisao pad temperature, trebao se on ohladiti. |
#5 | |
Postovi: 327
Quote: 14 Processors with Half-Frequency Multipliers May Hang Upon Wake-up from Disconnect Products Affected: A4, A5, A6, A7, A9 Normal Specified Operation: The processor should reconnect to the system bus upon wake-up after a disconnect while in the C2 and C3 ACPI low-power states. Non-conformance:The processor uses a special circuit to wake up from a low-power state and reconnect to the system bus when the nominal operating frequency is generated with a half-frequency multiplier. This circuit is rarely observed to glitch when coming out of the C2 and C3 low-power states. Potential Effect on System: The system will hang. Suggested Workaround: Do not use the C2 or C3 ACPI states on processors that run at a nominal operating frequency generated with a half-frequency multiplier. This can be accomplished by having the BIOS not declare C2 or C3 support to the operating system in the Fixed ACPI Description Table (FADT). Resolution Status: Fix planned for a future revision. Also note that all Cx states only apply to the CPU, and no other part of the system. For Cx states to operate correctly, there **MUST** be BIOS support.
Sempron 2800+ @ 2400 MHz/Epox 8KDA3i/ST passive/GEIL 2x512 MB/Enlight 300 W/9800 Pro/SB Live!/Seagate 320 GB/Pioneer 110D |
#8 | |||||||
Datum registracije: Jun 2004
Lokacija: Kaštela<->Varaždin
Postovi: 178
E LIFO, Sta si to stavia na silent boost (w/ Panaflo FBL08A12M)?
Postovi: 327
Ma to je originalni vent od silent boosta, samo ovako puno bolje zvuci, zar ne? ![]()
hmhm...zzz svima...
Lokacija: 21000 Split
Postovi: 1,070
Izgleda da je to i meni bilo uključeno
moj zivot se mijenja... iz dana u dan ja kune neman pozzz svima koju me znaju, a i onima koj ne
hmhm...zzz svima...
Postovi: 1,070
Sorry laga san smanjila mi se temp od 4-5 stupnjeva odlična stvarčica thx![]()
Datum registracije: Jul 2004
Postovi: 756
Evo kod mene je pala za 10°C , i sve radi OK,ali mi nije jasno dali samo piše da je temp. pala za toliko ili ju je stvarno skinuo za tih 10°,i kod dizanja Windowsa mi pokazuje 36° i ako ju je doista skinuo za toliko skidam mu kapu ![]() |
#14 | |
Lokacija: Zagreb/Dubrava
Postovi: 2,869
Datum registracije: Sep 2004
Lokacija: Mars
Postovi: 64
I meni je skinulo 5-6 stupnjeva.
Athlon 64 3000+ -- Zalman 7000B-Cu -- DFI LanParty UT 250Gb -- 1*512 GEIL value DDR400 -- Sapphire 9800pro -- ZM80D-HP + vent-- Chieftec 360W -- Seagate 80GB -- ZamZung DVD-rom -- Chieftec MIDI Dragon -- Creative Megaworks 5.1-- 795DF -- MX510 -- DX9.0c -- XP pro SP1a -- |
#16 |
Postovi: 541
meni je skinuo 7-8 stupnjeva ![]() |
#17 |
Game Master
Postovi: 28
Ne radi ?
Evo meni npr. nije nista snizio temperaturu. Ploca je NF7-S, idle je bio 46 stupnjeva i ostao 46 stupnjeva a full load se takodjer nije promijenio 56 bio, 56 ostao.Pozdrav
Abit NF7-S V2.0 with ZM-NB47J AMD Athlon XP-M 2500+ @ 210*11 (2310 MHz-a) 1.65V Thermalright SLK900A + 92mm Enermax @ potenciometar 2 x 256Mb Kingmax SuperRam DDR433 (8-3-3-2) Sapphire Radeon 9700np @ 360/620 with Zalman ZM80C-HP Seagate 160Gb 7200rpm 8MB S-ATA Antec SLK3700AMB + Fortron 350W LogiTech MX500 & LogiTech UltraX Flat Desktop Hyundai Q995 |
#18 |
Junior Member
Datum registracije: May 2003
Postovi: 3,205
skino mi je skoro 10 stupnjeva. evo sad dok surfam npr. sto je zanemarivo opterecenje CPU-a. Normalno da pri full load-u ne moze skinuti nista. Evo dok surfam + svira winamp, cca 5stupnjeva manje.
__________________ |
#19 |
Lokacija: Sisak
Postovi: 1,127
Ma svaka čast tim utilityjima, al koju korist imam ak mi je temp.' na full opterećenju ista. Mislim, koja je svrha snižavanja temp u neopterećnemom stanju proca? |
#21 | |
Postovi: 2,722
#22 | |
Datum registracije: Jun 2003
Lokacija: Kuća
Postovi: 5,418
Re: Ne radi ?
#23 |
Postovi: 756
Vigor daj mi reci jer mi nije jasno kako je moguće da sa Thermalright SLK900A + 92mm Enermax @ 1918rpm imaš 46°C idle, pa kod mene Athlon 2200@2250MHZ sa nekim kusrać Glacialtechom ima manje u idle. Kod tebe definitivno nešto nije kako treba,Mislim Thermalright SLK900A + 92mm Enermax @ 1918rpm šta da ti pričam.....???? |
#24 |
hmhm...zzz svima...
Postovi: 1,070
tako i meni na bartonu 2500@2200 200*11 temperatura mi je ideal sa nekin sranjen od 80kn negdi ok 36-39 a u full loadu se popenje do 50
