Staro 25.08.2009., 15:43   #31
Ati freak
aka Striko
Ati freak's Avatar
Lokacija: Krapina - Zagreb
Postovi: 1,766
Autor xulos Pregled postova
According to a fresh report by Donanim Haber, AMD's next performance graphics accelerator, the Radeon HD 5870, codenamed "Cypress" is expected to be aggressively priced, at US $299. At that price, it intends to be highly competitive against GeForce GTX 285 from NVIDIA. The secret-sauce behind the price could be the 40 nm fab process on which the GPU is being built, which allows upping transistor counts while maintaining significantly smaller die-sizes compared to 55 nm.
There is a great deal of uncertainty surrounding the specifications of the GPU, including what level of performance with existing application could it end up offering. Some sources, such as ChipHell, which are one of the first to leak pictures of components related to various Evergreen family products claim the Cypress GPU to have an almost 100% increase in stream processor counts compared to RV770, while others remain conservative expecting it to be around 50%. With this kind of a pricing, Cypress could trigger market-wide changes in GPU pricing, if it ends up with a good price/performance ratio at $299.
Cypress is expected to be launched on 22 September, close to two weeks after the company unveils the Evergreen family of DirectX 11 compliant GPUs on September 10. Market availability is expected in October. In related news from the same report, the enthusiast-grade accelerator that uses two of these GPUs, codenamed "Hemlock", is expected to be out in November.
Preuzeto sa : http://techpowerup.com/102342/Radeon...ed_Report.html
Ma to je sve velika halabuka a nakon svega bude velika banana....
Misli se natjecati s GTX 285... wow..... Za to im je trebalo skoro godina dana da nekaj naprave, i to je pitanje kakav bude to na kraju "proizvod"....
Ili opet puno vode, malo casa..... ( puno se toga veli, malo toga ostane istinito )
btw. Nemoj misliti da ni na koji nacin diskreditiram ovu temu...
No previse sam se ATI-evih "cuda" nagledao.....
Al nek se decki trude
LP.
(Jesam ga namljeo ) :S
Staro 25.08.2009., 15:46   #32
Postovi: 7,568
Cijenom se misle pozicionirati u rang GTX 285 modela, a performansama su već (potvrđeno) bolji. Tak da si stvarno fino namljel.
Staro 25.08.2009., 15:51   #33
Ati freak
aka Striko
Ati freak's Avatar
Postovi: 1,766
Autor McG Pregled postova
Potvrđeno?
Daj link
Da se i u to uvjerim
Ili bude sve ostalo na papiru
Staro 25.08.2009., 15:57   #34
Postovi: 7,568
Imaš toga po netu kolko te volja, ovaj put ja ne budem taj koji daje sve na srebrnom pladnju.
Em kartice stižu 22.09.'09., em su već poznate sve specifikacije, em čak (između ostalog) imaš i 3DMark rezultate.
Kartice su tak i tak već predstavljene na QuakeConu, a stvarno ne znam na koju foru bi ovo trebalo biti slabije do GTX 285.
  • 750-900 MHz core clock speed
  • 1GB of GDDR5 running at 1100 MHz (effectively 4400 MHz)
  • 1200-1600 shader processors (compared with 800 on the current HD 4870)
  • 32 ROPS (compared with 16 on the HD 4870)
  • 60-80 TMUs (compared with 40 on the HD 4870)
  • 2.1 TFlops of effective computational potential
  • over 300 mm² DIE (~256 mm² RV770/790)
  • DirectX 11 Support
Samo treba Google upogoniti.
Zadnje izmijenjeno od: McG. 25.08.2009. u 16:14.
Staro 25.08.2009., 16:10   #35
D-I-A-B-L-O
Bannija :D
D-I-A-B-L-O's Avatar
Lokacija: Sisak
Postovi: 1,098
Ovo prvi puta citam, kad dodjem doma moram prosurfat da vidim kaj to je.
Sve u svemu, raduje me izlazak nove serije zato sto bi po nekakvoj logiki trebao oznaciti pad HD48xx serije.
Veselim se cf-u sa u mojoj konfi
D-I-A-B-L-O je offline   Reply With Quote
Staro 25.08.2009., 16:14   #36
Ati freak
aka Striko
Ati freak's Avatar
Postovi: 1,766
Treba
Nadao sam se da imas pri ruci linkove pa da turisticki razgledam
Ako je istina, ajde bar da nekaj naprave kak spada.
Našao neku sliku vidim da su fala Bogu malo cooler mjenjali
al bome i ima preko 30 cm duljine, pa to moram kucu kupiti za nju , a ne kuciste--
Staro 25.08.2009., 16:17   #37
Postovi: 7,568
Editiral sam post i ako se od QuakeCona po netu vuku te specifikacije, onda nije problem naći ni ostatak konkretnog materijala.
ATi je zayebal s R600 i HD 2900 serijom, nakon toga ni jedno lansiranje i predstavljanje im nije bilo "papirnato".
Teško da bude ovo, pogotovo kad već imaju spremne kartice.
Staro 25.08.2009., 16:19   #38
Gilbert5
Agent 0
Gilbert5's Avatar
Lokacija: Kutina - ZG
Postovi: 4,312
Mislim da ce biti 1600 shadera, slična igra je igrana sa ovom generacijom kada su najavili 640 shadera, pa se na dan izlaska promjenila informacija sa specifikacijama na 800.
Navodno da ce sabirnica biti 512 bitna...nije loše.
Staro 25.08.2009., 17:28   #39
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,760
bit ce boom perf-cijena kao i 48**, samo se ja opet pitam, dal i gdje ce mo mi moci iskoristiti svu tu snagu i moc il ce se vrtit folding home
Staro 25.08.2009., 18:31   #40
Mad_Duke
Autor bluefluid Pregled postova
Ma glavna da dodje, pa da jos srusi cijene danasnjih perjanica i svi sretni i zadovoljni. (i nevidija i aemde kupci).
A gdje ce se koristiti ta snaga. Meni pada na pamet Rage, a ako ID napravi isti ili bolji posao kao sa Doomom 3, onda ce to biti i Doom 4.
http://www.gametrailers.com/video/te...software/23179
Ali to su sve stvari koje se ticu sljedece godine. Tako da, sto prije dodju, to ce prije pasti cijene :P
Jedino ono sto me zanima je neki naslov koji ce koristiti DX11. Bas da vidim to čudo, jer ce ID Tech 5 engine koji sam spomenuo ranije je OpenGL i DirectX 9-based.
Staro 26.08.2009., 16:32   #41
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
Za kompeticiju GTX285 su napravili HD4870x2 , HD4850x2 , HD4890 Bleki.
Bit će HD5870 dobra za crysis 2!!! Šta ću se naigrat
Zen5 PCIvy bridge Notebook
CPU: AMD Ryzen 7 9700x, CO per Core, CS -20 (Mid, High, Max)
COOLER: Arctic Cooling Liquid Freezer III 420 A-RGB
MBO: MSI Tomahawk X870
RAM: Corsair Vengeance DDR5 32GB, 6000MHz CL28
GPU: MSI SuprimX Nvidia GeForce RTX 3070
NVM1: Samsung Evo 970 2TB
HDD1: WD Red 4TB, WD40EFRX
HDD2: WD Blue 6TB, WD60EZRZ
HDD3: WD Blue 6TB, WD60EZRZ
PSU: Corsair RMx 850W, ATX3.1
CASE: Fractal Meshify 2 XL
VENTS: 4x Arctic Cooling P14 PWM PST A-RGB
OS: Win 11 Pro, 64-bit
MONITOR: AOC Q3279VWFD8 - 32", IPS, 2560x1440
TV: LG 7450
MOUSE: Logitech MX Master 3
KEYBOARD: Logitech MX Keys
GAMEPAD: XBOX One
HEADPHONES: Sennheiser HD560s
DELL Inspiron 15R, 5520
CPU: Intel Core i7 3632QM, 2.20Ghz, turbo 3.20GHz
RAM: DDR3, 6GB (4GB + 2GB), 1600Mhz CL11
GPU: AMD Radeon 7670, Intel HD4000
SSD: Samsung EVO 850, 250GB
SCREEN: 15,6 inch LCD, 1366x768
OS: Ubuntu 24.04, 64-bit
DraŽ je offline   Reply With Quote
Staro 26.08.2009., 17:07   #42
jurbAs
jurbAs's Avatar
Postovi: 2,583
Imam osjecaj da ce se ponovo grijat ko lude i trosit ko male elektrane... i nadam se da nece ukenjat drivere eto... sve ostalo super treba vidjet kad izade koliko je to dobro i koliko ce se to isplatit...
Staro 26.08.2009., 17:19   #43
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
One slike su u biti slike hd 5600 serije, a ova slika je od hd5850 ?
Nadam se da će se moći musashi namontirat na hd5850/70.
TV: LG 7450
GAMEPAD: XBOX One
Staro 26.08.2009., 17:26   #44
jurbAs
jurbAs's Avatar
Postovi: 2,583
ponovo neka turbina na mlazni pogon po pitanju venta... i jakooo puno kondezatora.. uf...
Staro 26.08.2009., 17:28   #45
Matth€w
Matth€w's Avatar
Lokacija: NaN
Postovi: 3,438
Samo jedan 6pin za napajanje...? Bogte kolka je. :O
Matth€w je offline   Reply With Quote
Staro 26.08.2009., 18:04   #46
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
TV: LG 7450
GAMEPAD: XBOX One
Staro 26.08.2009., 18:17   #47
Postovi: 7,568
Photoshop i rendering. Pogledaj slike još jemput, to je FirePro serija.
Staro 26.08.2009., 18:48   #48
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,770
Sama grafa izgleda dobro, ali cooler mi bas nema smisla.. Ako je sudeci po ovom cip na istoj poziciji ko i "x" samo s druge strane, ispada da je cooler direktno na gpu-u.. Zasto pozicionirati sam cooler direktno iznad gpu-a, umisto sa strane ko na starijim modelima tako da blok bude na gpu-u.. Mozda photoshop, a mozda se i grafe nebudu vise tako grijale (nadam se) pa nije ni bitno
Sn4k3 je online   Reply With Quote
Staro 26.08.2009., 22:20   #49
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
A hebiga...
Bili živi i vidjeli desetog rujna.
TV: LG 7450
GAMEPAD: XBOX One
Staro 26.08.2009., 22:48   #50
thedream
thedream's Avatar
Lokacija: Zagreb ( Šibenik )
Postovi: 5,458
Napokon će i DDR5 dobiti adekvatnu sabirnicu hvala qrcu,kako Gile kaže,512bit.
Staro 26.08.2009., 22:58   #51
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
Kome treba tolika sabirnica + gddr5? Pa to je preko propusnost oko 300GB/s
384 bitna bi bila sasvim OK i cijena bi bila manja.
TV: LG 7450
GAMEPAD: XBOX One
Staro 26.08.2009., 23:11   #52
Minox
Minox's Avatar
Postovi: 565
kome treba
pa večim monitorima
Minox je offline   Reply With Quote
Staro 26.08.2009., 23:12   #53
Mad_Duke
Nadam se da ne za sve modele. Inace ce cijena biti prevelika!
Staro 26.08.2009., 23:43   #54
Bara_st
Datum registracije: Mar 2009
Postovi: 197
Koje sve grafe iz serije 5xxx možemo očekivati 10. rujna?
Bara_st je offline   Reply With Quote
Staro 27.08.2009., 00:39   #55
jurbAs
jurbAs's Avatar
Postovi: 2,583
5870 i 5850 kontam si da ce sa time krenut onda ce izbacit x2 i onda ce ici ovi jeftiniji modeli... tako je bilo sa 48xx karticama....
Staro 27.08.2009., 01:02   #56
Momir
Momir's Avatar
Postovi: 1,012
Vec znam da cu uzet jednu HD5850, cim budem mogao
Nego, svi ste se uhvatili te 512-bitne sabirnice. Moze li neki konkretan link, ili vi to onak nagadjate?? Prema slikama mi izgleda da nemoze biti 512, nego samo 256-bitna.
Kartice nebi smjele trositi/grijati/buciti vise od "stare" serije.
Ipak se koristi napredniji proces, koji nije toliko zelen, nego je isproban u nekim postojecim karticama i sasvim ok radi.
Kad se sjetim samo intelovog prelaza sa 130nm -> 90nm -> 65nm, e to je bilo sve nabrzaka i nije bas sljakalo kak je trebalo.
Momir je offline   Reply With Quote
Staro 27.08.2009., 02:32   #57
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,581
Autor DraŽ Pregled postova
propusnost je izmedju 150 i 160 GB
@ momir ja sam na par linkova nasao da je sabirnica 512bitna.
Staro 27.08.2009., 02:43   #58
zkljaja
Brat od Đon Vejna
zkljaja's Avatar
Lokacija: zg-vg
Postovi: 1,204
uuuuu, taman mi garancija na 3870 placenoj 1300kn istjece garancija..
Svidja mi se ddr5 i 512bit-a, jer sa 256 je u rangu propusnosti npr. ddr3 + 448bit kod nevidije.
Staro 27.08.2009., 02:43   #59
Gilbert5
Agent 0
Gilbert5's Avatar
Postovi: 4,312
Ne znam, ja sam na 1920*1200 i 9800GTX+ uredno gura ovu rezu. Ovo će prema najavama biti stvarno brza kartica, samo pohvale za crvene. Kada god naprave dobar posao sa karticama, zelenim karticama padaju cijene i to je samo dobro.
@Momir, google (na HD5870 upit) baca pregršt specifikacija, uključujući i 512 bitnu sabirnicu...istina ili ne - ne znam. npr
Zadnje izmijenjeno od: Gilbert5. 27.08.2009. u 09:06.
Staro 27.08.2009., 07:22   #60
Momir
Momir's Avatar
Postovi: 1,012
Pa ako je propusnost 150 do 160 GB, onda je nemoguce da je 512bitna, jer uz taj takt bi trebalo onda biti puno vise.
A i sama kartica izgleda prejednostavno i nekako mi mali broj mem cipova ima za 512 bita. (negledam one fotosopirane fireGL modele)
