Staro 13.08.2009., 22:18   #4831
sinisa1989
Bazinga
sinisa1989's Avatar
Lokacija: Križevci
Postovi: 3,933
Autor slavonac90 Pregled postova
jel tu riječ od piratskom ili oriđiđi online igranju?
Na ovim stranicam imaš i jednog i drugo, naravno malo više originala.Barem mislim.
Staro 17.08.2009., 19:16   #4832
Nybelung
Jel zna netko neki level 55 fix koji radi? - Popušio sam svoje levele a ne da mi se ponovo skupljati..
Probao sam ovoga:
1. Go to Start -> Run-> Type "regedit" -> Hit Enter.
2. Right click HKEY_LOCAL_MACHINE & click "Find..." type in "codkey" then click "Find Next"
3. Double-click "codkey" after it finds it
4. Copy the key already there onto a notepad/text document & save it
5. Replace the key with: DL2J8PY44Q22GE4888D2 backup:MJGQLGEWU8YGQ2TWA226
6. Press OK and close regedit.
7. Click my Computer > Hard drive Cor where ever call of duty 4 is installed) > Program Files > Activision > Call of Duty 4 - Modern Warfare > Players > Profiles then open the folder with your player user name(backup this folders content up before you continue)
8. After backup Remove All of the files in the folder, DO NOT REMOVE THE FOLDER ITSELF!
9. Place the "mpdata" file you have here in your user name folder
10. Open the Call of Duty 4 Multiplayer and check your rank. You should now be level 55 with all challenges, guns, and every camouflage unlocked!
11. Finally, in the game go to Options -> Multiplayer Options -> Key Code and type your original cd key you saved eariler in notepad or from your game manual then click ok to verify it
12. Go play online.
Al ne radi!
Staro 17.08.2009., 19:20   #4833
Apacer ft Bozja
Baja!
Apacer ft Bozja's Avatar
Lokacija: Sisak
Postovi: 761
Pa jel imas i "modificirani" mpdata?
Sjecam se da sam ja to tako bio napravio, ali to je bilo prije gotovo godinu i pol, a jako dugo nisam upalio te public servere, kao i sam cod u biti
Ako ne nadjes to sve skupa za 2-3 dana budem ti ja stavio to na rapidshare pa ti dam link. Bih ja i sada, ali hard mi je u kompu drugom, i nemogu do njega, a nemogu ga upaliti jer nemam proca
Apacer ft Bozja je offline   Reply With Quote
Staro 17.08.2009., 19:23   #4834
Nybelung
Sve sam uradio po uputama, imam i taj modificirani mpdata fajl.
Ne radi da ga je*, pokušao sam 5-6 puta..
Staro 17.08.2009., 19:25   #4835
Ecips Dlo
Ecips Dlo's Avatar
Datum registracije: May 2009
Lokacija: brlog
Postovi: 489
si probo sa EA..ako nisi klikni ovdje....
Ecips Dlo je offline   Reply With Quote
Staro 17.08.2009., 19:40   #4836
Nybelung
Autor akion Pregled postova
Hvala.
Staro 17.08.2009., 23:02   #4837
brodjo
Playmaker
brodjo's Avatar
Lokacija: Osijek/Wien
Postovi: 1,670
Ko još igra HC >_< EPIC FAIL !!!one1
brodjo je offline   Reply With Quote
Staro 17.08.2009., 23:07   #4838
sinisa1989
Bazinga
sinisa1989's Avatar
Lokacija: Križevci
Postovi: 3,933
Zaš ne bi igrao HC ak mi je dobar?
Staro 18.08.2009., 01:42   #4839
brodjo
Playmaker
brodjo's Avatar
Postovi: 1,670
Low je, nema veze sa skillom IMO, uzmes lmg i sprayay brate. Vječno prvi, također HC igrači ne da nemaju reflekse nego nemaju.
Staro 18.08.2009., 02:37   #4840
Nybelung
Igram samo HC.. Nema mi ništa gore od toga kad lika napuniš mecima, a on ostane živ. WTF? Pa nije Robocop..
Staro 18.08.2009., 14:12   #4841
A.J.
A.J.'s Avatar
Lokacija: Rijeka (Umag)
Postovi: 1,197
Autor brodjo Pregled postova
aj kad mi srede net naci cemo se na nekom HC serveru pa cemo istestirat reflekse
pod kojim nickom igras? ja pod Viper
A.J. je offline   Reply With Quote
Staro 18.08.2009., 17:10   #4842
Lucius
Postovi: 171
Autor Nybelung Pregled postova
haha potpis.
Ja takodjer samo hc, vise preferiram s&d i umjesto TDM-a uvijek radije odigram domination.
Lucius je offline   Reply With Quote
Staro 18.08.2009., 18:55   #4843
Nybelung
Autor Lucius Pregled postova
haha potpis.
S&D, TDM, DM.. Svejedno.. Samo nek je HC!
Nedavno sam krenuo igrati malo "obični" COD , izbušim lika sa kalašom, a on ipak pobježe sa 2kg olova u leđima?!
Odmah sam ugasio govno i prešao nazad na dobri stari HC.
Staro 18.08.2009., 20:38   #4844
hammer_of_thor
its slightly turbocharged
hammer_of_thor's Avatar
Postovi: 5,430
HAHA
Nisi očekivao valjda nešto drugačije?
Kao šlag na kraju lik se često vrati 2 kg teži i onda tebe ubije
Onaj poluproizvod od promoda nije ništa bolji, debelo pre-pristran mod prema nekim oružjima (npr, ono govno od malog kalaša sa kojim svi tobože pro igrači igraju)
blaa
hammer_of_thor je online   Reply With Quote
Staro 18.08.2009., 21:05   #4845
Overvide
Postovi: 541
Taj mali kalas je jos ubojitiji na serverima bez promoda.
Da ne govorim da je u mecevima ogranicenje na 2 mala kalasa.
Igrao na promodu ili ne, vak i onak cu igrat s 47, 74u ili scopom.
Overvide je offline   Reply With Quote
Staro 18.08.2009., 22:42   #4846
sinisa1989
Bazinga
sinisa1989's Avatar
Lokacija: Križevci
Postovi: 3,933
A pro mod je puno bolji?Da viđao sam ekipu da koriste velki i mali kalaš i pucaju metak po metak.Samo spray.
Pa nemoraš igrat sa lmg-om i sprayat. Uzmi si G3, M14, ili MP44 pa ću te onda vidjet kak ćeš biti prvi.
@ A.J.
Jel ti možda ovak pišeš svoj nick: ViPER?
Staro 18.08.2009., 22:46   #4847
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,347
G3 i HC -> 1 metak ubija, ma daj, iskopaj mi oko
žmnpp
Staro 18.08.2009., 23:24   #4848
Apacer ft Bozja
Baja!
Lokacija: Sisak
Postovi: 761
@hammer_of_thor
E sry, ali onda ti je aim u banani ako ti njega nemozes ubiti a da si u njega ispucao "2 kile olova". I glupost je to sto ti tako pricas "to boze pro igraci" ovo-ono. Taj mod je napravljen od igraca koji igraju natjecateljski, prema tome smatram da su oni itekako kompetentniji i strucniji po tom pitanju od tebe
@sinisa1989
Stani malo..tebi je cudno sto netko sa velikim kalasem ne "spreja", nego puca metak po metak kako ti velis, jer stvarno nisam skuzio jel se ti zajebavas ili ti je to cudno? :S
Staro 18.08.2009., 23:29   #4849
Atrax
Atrax's Avatar
Postovi: 553
Autor buljo Pregled postova
A kad čujem s leđa onaj njegov prigušeni "piju-piju" zvuk, odmah znam šta slijedi (killcam)
Od početka igram na HC serverima , jer ne mogu smislit pojavu da moram 20 metaka ispucat u lika da bi pao. I još kad si netko nakelji Jugger na sebe.....divotica
A što se refleksa tiće, mislim da ih je na HC serverima potrebno daleko više (u usporedbi sa klasičnim serverima, PRO mod nisam probao), jer u pravilu imaš samo jednu šansu, ako promašiš vjerojatno ćeš poginut (tu prije svega mislim na oružja tipa G3), to se u pravilu meni događa, ali valjda zato što sam naviko na HC.
Istina, spray&pray način igre je "isplativiji" u HC serverima, ali to su u pravilu njubovi koji ionak neznaju ciljat pa ih ubrzo naučiš lekciju, taj te spreja sa scorpionom i uspije promašit tako da....ne obazirem se na takve.
NHF
Atrax je offline   Reply With Quote
Staro 18.08.2009., 23:33   #4850
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,347
Di igrate vi? Na kojim HC serverima?
Morat ću ja se vratit malo na cod4 izgleda...
žmnpp
Staro 19.08.2009., 00:02   #4851
A.J.
A.J.'s Avatar
Postovi: 1,197
Autor sinisa1989 Pregled postova
@ A.J.
ne, kod mene je obicno Viper...
igram uglavnom na tate
Staro 19.08.2009., 00:19   #4852
xGAME
xGAME's Avatar
Lokacija: Chernobyl NPP
Postovi: 4,778
igram 75% matcheva s G3, i vecinom prvi, tako da barem meni nije problem biti s tim oružjem prvi, al ovisi od mape i koliko je ljudi na njoj i POGOTOVO koliko puta me bombe pokupe, jer s njima nisam u dobrim odnosima ...M14 I MP44, s tim ne igram, ispunio sam samo challenege za ta oružja
G3 i AK-47 FTW, s malim ne znam igrat xD
xGAME je offline   Reply With Quote
Staro 19.08.2009., 00:21   #4853
A.J.
A.J.'s Avatar
Postovi: 1,197
xgame dugo se nismo sreli....
aj kad mi srede net il se vratim u ljubljanu cemo se malo ispucat
Staro 19.08.2009., 10:13   #4854
sinisa1989
Bazinga
sinisa1989's Avatar
Lokacija: Križevci
Postovi: 3,933
Autor Apacer ft Bozja Pregled postova
@hammer_of_thor
@sinisa1989
Ja sam se zajebavao (vjerojatno sam se ja gore krivo izrazio).
Naravno da svi samo sprejaju. Ko puca metak po metak svaka čast.(osim naravno kad je potreban spray
@ xGame
Meni je isto G3 jedno od boljih oružja, pa zato i kažem nek proba s tim igrat kolega
Staro 19.08.2009., 10:40   #4855
xGAME
xGAME's Avatar
Postovi: 4,778
Autor A.J. Pregled postova
malo ću opet lovit tvoje bombe
Staro 19.08.2009., 10:47   #4856
V.I.P
Istrian Lifestyle
V.I.P's Avatar
Datum registracije: Jul 2009
Lokacija: Medulin
Postovi: 1,384
jel zna netko sta je sa nastavkom cod4? cuo sam nesto da bi trebao uskoro izaci?
V.I.P je offline   Reply With Quote
Staro 19.08.2009., 11:53   #4857
MisterM
1oo1 NooB
MisterM's Avatar
Postovi: 1,306
Autor Medulin Pregled postova
http://forum.pcekspert.com/showthread.php?t=143208
Malo treba pogledat po forumu..........
IT IS EASY TO KILL FIVE HUNDRED NOOBS. BUT THERE IS STILL FIVE HUNDRED AND ONE AND YOU ARE OUT OF AMMO!
1oo1
NOOB - POWER IN NUMBERS!
Good judgment comes from bad experience and a lot of that comes from bad judgment.
MisterM je offline   Reply With Quote
Staro 19.08.2009., 13:55   #4858
V.I.P
Istrian Lifestyle
V.I.P's Avatar
Lokacija: Medulin
Postovi: 1,384
ovo smece od google trazilice nista ne valja
hvala mister
Staro 19.08.2009., 20:55   #4859
sinisa1989
Bazinga
sinisa1989's Avatar
Lokacija: Križevci
Postovi: 3,933
A.J. jel tebi možda xf j3rk0?
Ak si to ti onda te iam među prijateljima.
Staro 19.08.2009., 21:06   #4860
A.J.
A.J.'s Avatar
Postovi: 1,197
taj sam
