Staro 28.07.2009., 15:42   #1
platine
Datum registracije: Jul 2009
Lokacija: Bistra
Postovi: 6
Keyboard Backlighting - ne radi
[IMG]file:///C:/DOCUME%7E1/Mario/LOCALS%7E1/Temp/moz-screenshot.png[/IMG]Imam dell studio 1555 , sve uredno instalirane drivere , no ne radi mi osvjetljenje tipkovnice iz neznam kojeg razloga .
platine je offline   Reply With Quote
Staro 28.07.2009., 16:09   #2
nino
nino's Avatar
Postovi: 12,613
1. Sliku uplodaj na http://www.imagesforme.com/
2.
The Dell Studio 1555 does have the option for a back-lit keyboard, however in order to have it, the system needs to be purchased that way. If the keyboard is back-lit you will have a symbol to adjust the keyboard's brightness settings on the F6 key. To change the settings you will need to press the Fn key and F6 key at the same time.
Dali tvoj ima?
Staro 29.07.2009., 22:28   #3
platine
Lokacija: Bistra
Postovi: 6
Navodno bi trebao imati backlighting te i mali subwofer od 3w , koji ja ne primjećujem .
moguće da je za naše tržište manje djelova ugrađeno ( Balkan )
Model je PP39L ( studio 1555 ). Iskreno neznam gdje da izlistam sve detalje o tom modelu .
LP
