Staro 03.07.2009., 02:43   #1
Atrax
Atrax's Avatar
Postovi: 553
Catalyst 9.7 BETA
Catalyst 9.7 (beta version at the time of writing) adds three new OpenGL extensions and continues to improve advanced features such as Geometry Shader (now a geometry shader can access to 16 textures samplers and 4096 uniforms!). Let’s see the new extensions:
* GL_EXT_pixel_buffer_object: This extension brings the support of PBO (Pixel Buffer Object) to Radeon video cards. This extension is useful because it allows asynchronous texture loading and thus improves texture loading… But Catalyst graphics drivers already support PBOs via the GL_ARB_pixel_buffer_object. So, actually, GL_EXT_pixel_buffer_object does not bring new feature.
* GL_EXT_provoking_vertex: This extension is used when flat shading is enabled (GL_FLAT). The provoking vertex of a primitive is the vertex that determines the constant primary and secondary colors when flat shading is enabled. This extension is supported in ForceWare since version 185.66.
* GL_EXT_vertex_array_bgra: allows to fetch a vertex component (mainly color componant) from a Direct3D color array where color is stored as BGRA. This extension avoids to perform the swizzling in the vertex shader. This extension is supported in ForceWare since version 181.00
Graphics driver information:
- Operating System: Windows XP 32-bit SP2
- Drivers Version: 8.630.0.0 – Catalyst 09.7 (6-10-2009)
- ATI Catalyst Version String: 09.7
- ATI Catalyst Release Version String: 8.63-090610a-082777E-ATI
Ovo je ukratko sažetak, evo link sa popisom OpenGL eksenzija i slično http://www.geeks3d.com/20090630/ati-...gl-extensions/
Za sada samo za XP, bar kolko ja vidim, ne daje mi google ništa za vistu.
Pa eto, ko ima XP i volju za probat http://www.megaupload.com/?d=KYXNVKC8
Kolko sam uspio pohvatat po postovima, u 9.7 control panel ima novi layout i neke nove postavke za podesit. Također, neki lik kaže da XP driveri na Visti daju nekih 30% bolje performanse, al u to se ne bih štel mešati.
Atrax je offline   Reply With Quote
Staro 07.07.2009., 15:52   #2
Tola
Lokacija: SGE
Postovi: 92
uu odlično jedva čekam finalnu verziju
Tola je offline   Reply With Quote
Staro 07.07.2009., 20:44   #3
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
Zašto svi tako žurno čekaju novu verziju CCC-a? Nisam još nikakvih loših iskustava imao zbog drivera, očito vi ostali jeste
Zen5 PCIvy bridge Notebook
CPU: AMD Ryzen 7 9700x, CO per Core, CS -20 (Mid, High, Max)
COOLER: Arctic Cooling Liquid Freezer III 420 A-RGB
MBO: MSI Tomahawk X870
RAM: Corsair Vengeance DDR5 32GB, 6000MHz CL28
GPU: MSI SuprimX Nvidia GeForce RTX 3070
NVM1: Samsung Evo 970 2TB
HDD1: WD Red 4TB, WD40EFRX
HDD2: WD Blue 6TB, WD60EZRZ
HDD3: WD Blue 6TB, WD60EZRZ
PSU: Corsair RMx 850W, ATX3.1
CASE: Fractal Meshify 2 XL
VENTS: 4x Arctic Cooling P14 PWM PST A-RGB
OS: Win 11 Pro, 64-bit
MONITOR: AOC Q3279VWFD8 - 32", IPS, 2560x1440
TV: LG 7450
MOUSE: Logitech MX Master 3
KEYBOARD: Logitech MX Keys
GAMEPAD: XBOX One
HEADPHONES: Sennheiser HD560s
DELL Inspiron 15R, 5520
CPU: Intel Core i7 3632QM, 2.20Ghz, turbo 3.20GHz
RAM: DDR3, 6GB (4GB + 2GB), 1600Mhz CL11
GPU: AMD Radeon 7670, Intel HD4000
SSD: Samsung EVO 850, 250GB
SCREEN: 15,6 inch LCD, 1366x768
OS: Ubuntu 24.04, 64-bit
DraŽ je offline   Reply With Quote
Staro 07.07.2009., 22:08   #4
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,763
Novo je uvik novo, pa makar i ne donosi nista novo, napeto je jer je novo
nadam se da me kuzite
Staro 07.07.2009., 22:27   #5
greg SE
greg SE's Avatar
Datum registracije: Oct 2001
Lokacija: Vinkovci
Postovi: 5,231
Autor DraŽ Pregled postova
ma ti ne bi primjetio da ti se boje u winsima tope samo dok ti framerate u krizi ne pada
Staro 07.07.2009., 22:54   #6
TomRi
Can You Hear Me? 142.8 dB
TomRi's Avatar
Lokacija: Zagreb, Kvatrić
Postovi: 2,073
još sam na 8.12
čekam release notes pa da vidim jel 9.7 nešto bolji, makar sumnjam
jer 9.6 ima pad performansi baš u onome što (jedino) koristim, ET;QW
http://www2.ati.com/relnotes/Catalys...ease_notes.pdf
page 6
A performance drop may be observed on Enemy Territory Quake Wars, Doom3 and
Quake4
valjda nabriju drivere za određene aplikacije, kada već ne mogu za sve,
a kako idu nove verzije drivera, nabrijavaju ih za novije aplikacije(igre) dok stare padaju u zaborav
i onda dolazi upravo do toga, pada performansi naspram STARIH drivera koji rade bolje (u toj nekoj igri npr)
tako da po meni, ako netko ne igra najnovije igre(za koje je rađen driver npr)
može i profitirati od starijih drivera, ne srljati bez razmišljanja odmah na download + install
(osim ako pročita u release notes da je došlo baš do nekog poboljšanja za tu određenu igru)
Danas je teško biti budala, prevelika je konkurencija...
Water cooled PC
Moj najveci MOD
Novi hobby: RC model + HD kamera
TomRi je offline   Reply With Quote
Staro 20.07.2009., 09:42   #7
Tola
Lokacija: SGE
Postovi: 92
Opet novi catalysti kasne.
Nema nikakvih naznaka da će uskoro stići.
Staro 20.07.2009., 13:59   #8
Matt
Matt's Avatar
Lokacija: Zabok
Postovi: 1,622
9.6 su mi puno stabilniji od prošlih verzija. Sa 9.5 sam imao česta zamrzavanja prilikom igranja COD4. Neznam zašto. Uglavnom sa 9.6 je sve ok, nadam se da na 9.7 nisu neš previše prčkali po optimiziranju starijih igara.
Svi elektronički uređaji rade na bijeli dim!
Kad dim izađe uređaj više ne radi!!!
Matt je offline   Reply With Quote
Staro 20.07.2009., 17:52   #9
Metamphetamine
Flaccitra
Metamphetamine's Avatar
Lokacija: Vinkovci
Postovi: 276
Autor Tola Pregled postova
Evo link za cat 9.7 WHQL, takvi će biti i na službenim stranicama
http://www.ngohq.com/graphic-cards/1...vista-7-a.html
Metamphetamine je offline   Reply With Quote
Staro 20.07.2009., 19:56   #10
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,763
Link na toj stranici za Vistu/Win7 ne radi, onaj za xp radi...
Edit: evo nasa sam link za nove catalyste, 9.7 (8.630) Vista/Win7 WHQL, x86 & x64:
http://www.pctreiber.net/filebase_redirect.php?fid=9507
Staro 21.07.2009., 00:26   #11
Apacer ft Bozja
Baja!
Apacer ft Bozja's Avatar
Lokacija: Sisak
Postovi: 761
Ispricavam se sto sam glup, ali do neki dan nisam nikada koristio ATI karticu, i sad imam zamjenski komp, koji ima radeon X550, ali ja se ne snalazim tu bas, pa da pitam jel zna tko da li ovi drajveri pasu na tu karticu Sada koristim 9.3.1, to sam skinuo sa njihove stranice, ali ja neznam da li je problem u drajverima ili sta, ali kad god pokrenem cabal online, slika mi se jednostavno smrzne, i nemogu nista nego resetirati komp. Pa ako netko mozda zna neke starije drajvere koji 100% rade sa ovom grafickom, bio bih vam jako zahvalan.
Hvala lijepa.
Apacer ft Bozja je offline   Reply With Quote
Staro 21.07.2009., 09:55   #12
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,007
Autor Apacer ft Bozja Pregled postova
Hvala lijepa.
Jel to AGP ili PCI-E kartica?
Staro 21.07.2009., 11:43   #13
Apacer ft Bozja
Baja!
Lokacija: Sisak
Postovi: 761
pci-e.
Meni su ti catalyst drajveri jedno 5 puta zbunjeniji od nvidijinih.
Staro 21.07.2009., 11:47   #14
Tola
Lokacija: SGE
Postovi: 92
Autor Sn4k3 Pregled postova
Jesi ih ti instalira???
Staro 21.07.2009., 13:40   #15
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,763
Jesam, jucer... Sve normalno radi, cak sam ih inst priko 9.6
Nije mi se dalo za**bavati s driver cleanerom..
Izgleda da su stvarno WHQL
Evo slika:
Staro 15.08.2009., 19:28   #16
Matt
Matt's Avatar
Lokacija: Zabok
Postovi: 1,622
Skinuo sam to sranje od drivera te mi je kao i svaka serija od 9.4 pa na dalje pregrijavala karticu koja je na default clocku i otišla mi memorija.
No dobro, nadam se da će sve dobro proći sa reklamacijom
