Staro 26.06.2009., 13:00   #31
e1ectra_one
Creepshow
e1ectra_one's Avatar
Postovi: 417
evo sad baš čitam na www.links.hr za napajanje komentar korisnika
Vrlo solidno napajanje dobre cijene i lijepog izgleda. Ima 2x 12V raila svaki 26A, sto nije dovoljno za GTX 260 koja treba 36A na jednom od railova
Sad jel istina neznam, al 4890 garant treba više od 260
sad gledam za Corsair HX750W
Single +12V rail design providing up to 62A
e1ectra_one je online   Reply With Quote
Staro 26.06.2009., 13:04   #32
pimpinjon
pimpinjon's Avatar
Postovi: 306
to sam baš htio pitat. kak ti railovi funkcioniraju?
pimpinjon je offline   Reply With Quote
Staro 26.06.2009., 13:08   #33
e1ectra_one
Creepshow
Postovi: 417
8. ARE MULTIPLE 12-VOLT RAILS BETTER THAN A SINGLE 12-VOLT RAIL?
With all the hype about multiple 12-volt rails (ads claim that two rails is better than one, five is better than four, etc.), you'd think it was a better design. Unfortunately, it's not!
Here are the facts: A large, single 12-volt rail (without a 240VA limit) can transfer 100% of the 12-volt output from the PSU to the computer, while a multi-rail 12-volt design has distribution losses of up to 30% of the power supply's rating. Those losses occur because power literally gets "trapped" on under-utilized rails. For example, if the 12-volt rail that powers the CPU is rated for 17 amps and the CPU only uses 7A, the remaining 10A is unusable, since it is isolated from the rest of the system.
Since the maximum current from any one 12-volt rail of a multiple-rail PSU is limited to 20 amps (240VA / 12 volts = 20 amps), PCs with high-performance components that draw over 20 amps from the same rail are subject to over-current shutdowns. With power requirements for multiple processors and graphics cards continuing to grow, the multiple-rail design, with its 240VA limit per rail, is basically obsolete.
PC Power and Cooling is once again leading the industry. All of our power supplies now feature a large, single 12-volt rail. The design is favored by major processor and graphics companies, complies with EPS12V specs (the 240VA limit is not a requirement) and is approved by all major safety agencies such as UL and TUV.3
Kažu ameri...
Kolko sam ja shavtio da su reilovi dijeljenje snage, raspodjela na dva ili više djelova
Staro 26.06.2009., 13:12   #34
pimpinjon
pimpinjon's Avatar
Postovi: 306
znam da je to to, ali dali može onda on na jednom railu isporučit svu snagu a da na ostalima ništa ne isporučuje? sad bi bilo dobro da netko iskusniji potvrdi ovo?
edit: evo isprobo upravo sad. test je bio loading od simsa 3. tu sam prvi put prepozno problem. taj loading očito ima neki bug jer grafa radi bez razloga u full loadu, a neradi ništ. kak znam da neradi ništ? zato jer kad minimiziram simse, grafa se prebaci u idle, a loading se obavi jednakom brzinom. ugl. sa riva tuneerom sam očito da grafa u tom trenutku vuče 60A, što sad na corsairu vx450w, koji je trenutno u kompu ide bez problema (ima single rail), a na thermaltakeu thoughpower 700w (80plus) koji ima 4 raila, komp se ugasi. mislim da sam našo izvor problema. ?
Staro 26.06.2009., 13:16   #35
e1ectra_one
Creepshow
Postovi: 417
Wolfy hajde u pomoć
Autor pimpinjon Pregled postova
očito je i tako nesta kod mene, ipak rolla GTA4 na high @ 1680x1050
Zadnje izmijenjeno od: domy_os. 27.06.2009. u 00:52.
Staro 26.06.2009., 13:26   #36
Campeonato
Premuim
Campeonato's Avatar
Postovi: 1,748
Pa jesi probao prestekavati kablove? Ak se snaga dijeli na railove po 26 A, mozda si ti ukopcao 2 kabla na kojima je max 26 A za grafu... Al opet to bi trebalo biti vise nego dovoljno za grafu, tako da railovi ne bi trebali bii problem, al opet ak su sve komponente na jednom railu, onda mozda i je, al cisto sumnjam...
Probaj na nekom drugom napajnaju probat svoj komp... Ili svoju grafu negdje drugdje...
Riva laze, po tome znaci da ti komp povuce u loadu 60* 12= 720W, jea rajt...
Campeonato je offline   Reply With Quote
Staro 26.06.2009., 13:27   #37
~Kaiser_Chief~
~Kaiser_Chief~'s Avatar
Lokacija: Zabok
Postovi: 1,189
dobronamjeran savjet... iako su ti to vec momci rekli, vjerojatno je u napajanju problem... reci nekom frendu ak si u mogucnosti da ti posudi neki psu pa da sprobate...
jer ocito bi ono bilo problem... posto si plocu mjenjao....
GL!
~Kaiser_Chief~ je offline   Reply With Quote
Staro 26.06.2009., 13:32   #38
pimpinjon
pimpinjon's Avatar
Postovi: 306
Autor Campeonato Pregled postova
znam da laže, neg htio sam usporedit s drugim igrama, a zaboravio napisat da u najvećem loadu u nekoj drugoj igrici ne napiše više od 50A. želio sam reći da taj loading vuče maks struje što grafa valjd može. i tad je vjerojatno prešlo granicu snage jednog raila i napajanje je popustilo.
sad sam baš razmišljo i skužio da su na tt-u vjerojatno oba pci-e kabla stavili na jedan rail što je malo blesavo. trebo bi uštekat jedan pci-e i neki molex s nekog drugog raila konvertat s onim kablom u pci-e i uštekat u grafu.
Staro 26.06.2009., 13:41   #39
e1ectra_one
Creepshow
Postovi: 417
možda i nelaže, formula je dobra P=U*I aj nevuće grafa 12V, pogledaj volzaže u gpu-z pa ceš vidit sve ispod 1.5v
Staro 26.06.2009., 13:43   #40
pimpinjon
pimpinjon's Avatar
Postovi: 306
čuj ako se u njoj smanjuje napon s 12 na 1,5, onda se struja povećava. vjerojatno to piše kolika je u njoj struja, a ne koliko vuće iz napajanja.
Staro 26.06.2009., 13:43   #41
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Za tvoju informaciju i ostalim samozvanim doktorima elektronike i napajanja ovdje, samo PWM regulacija procesorskog socketa na maticnoj ploci cucla oko 35-40A u 100% loadu dualcore procesora. I dosta vise trkeljanja o tim istosmjernim rajlama, ako nemate pojma sto to znaci.
Staro 26.06.2009., 13:46   #42
pimpinjon
pimpinjon's Avatar
Postovi: 306
pa dobro kad si se već ti uključio u raspravu, ti bi trebo znat šta to znači. jel je onda problem u tome što jedan rail nedaje dovoljno struje grafi?
Staro 26.06.2009., 14:01   #43
kill
Datum registracije: Jun 2003
Postovi: 533
http://www1.sapphiretech.com/us/prod...gpid=298&grp=3
System Requirements
* 500 Watt or greater power supply with two 75W 6-pin PCI Express® power connectors
da staviš neki vent da pirka po kartici? si polijepio ježeve na VRMove ?
kill je offline   Reply With Quote
Staro 26.06.2009., 14:29   #44
Wolverine
Wolverine's Avatar
Postovi: 12,428
Autor e1ectra_one Pregled postova
Jel ja vama moram crtat stvari ili?
Napajanje tjera uredno HD4870x2 (dakle dve HD4870) i klokirani Kentsfield
posustaje tek kada spojim dve HD4870x2 (dakle četiri HD4870 čipa) kada se gasi pod 3D-om
Onaj komentar je napisao netko tko niti ne zna čitat jer GTX260 ne treba 36A na +12V nego je to preporuka za cijeli komp
tip baljezga gluposti
imam negdje doma grafove od tog napajanja kako se ponašalo na testu pa ću ih postat
radio sam usporedni test napajanja 600-900W i govorim iz iskustva da to napajanje ako je ispravno tjera dve tvoje konfe....
nemojte bit gotovani i koristite tražilicu
evo pa čitajte
http://forum.pcekspert.com/showthread.php?t=48485
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 26.06.2009., 14:32   #45
e1ectra_one
Creepshow
Postovi: 417
Autor kill Pregled postova
System Requirements
ma hladni su vrm-ovi (dovoljno) ja ježevima je bilo preko 100, sa red plateom je ispod 80.
Staro 26.06.2009., 14:48   #46
pimpinjon
pimpinjon's Avatar
Postovi: 306
@ wolverine
ali NIKAD neće jedan imati više od 16A jer je tako izreguliran.
znači pošto moj tt ima 18A po railu, znači šta god bilo, on nemože dat više na tom railu pa makar i trebalo?
Staro 26.06.2009., 14:49   #47
dh41400
Señor Audiophile
dh41400's Avatar
Lokacija: Zabreg
Postovi: 3,280
Vrlo zanimljivo, kako su ljudi sigurni u ono sto vjerojatno prvi put cuju u zivotu
Ajmo po redu:
  • LC POWER PROPHECY 750W je built by Andyson (ne CWT) i to vrlo kvalitetno odradjuje (bavi se izradom vrlo solidnih napajanja).
  • Bez obzira koliko je navedeno railova na toj naljepnici s boka PSU-a, proizvodjaci cesto (ne uvijek) dijele 12V rail cisto iz razloga sto prema medjunarodnim standardima nije dozvoljeno veliku struju isporucivati preko 1 kabela (sto neki "snalazljivi" proizvodjaci nazivaju "rail", mozes si mislit )
  • Ta grafa nema sanse da vuce vise od 150W na 12V (bilo to preko PCI-E no.1, no.2 ili PCIe slota), a samim time ispada da je to napajanje sasvim dovoljno (580W @ 12V, ali ajmo reci da daje samo dio toga, npr. 400W).
  • Sto se tice struje koju grafa vuce, pa naravno da je moguca nazivno velika cifra 50+A jer je i napon na jezgri debelo manji od pocetnih 12V
  • Vec vam je Wolv par puta rekao da je tjerao 4870x2 na tom napajanju, okanite se tih kalkulacija s railovima (a i matematika vam je ... ).
  • Sto se tice testova gotovo identicnih platformi (cak i manje snage by Andyson): hardwarecanucks.com
  • Evo par eye candy-a za nevjerne:
S lijeva na desno Andyson 600W, Lc 8750, Andyson 700W
P.S. malo kasnim
The Secret ...
Staro 26.06.2009., 15:01   #48
e1ectra_one
Creepshow
Postovi: 417
Ma badave sve ovo, al meni se stroj i dalje gasi. Proc nije, mema nije, grafa hladna dovoljno, probani i drugi driveri. Negdje puca po šavovima, rekoh na X38 + 2x HD3870 mi se znalo dešavat isto u ugrama, ko i na P45 sa 4890, jedino mi je napajanje ostalo.
Staro 26.06.2009., 15:16   #49
dh41400
Señor Audiophile
dh41400's Avatar
Lokacija: Zabreg
Postovi: 3,280
Bilo bi najbolje da slozis konfu na stolu (izvan case-a), pa ako se opet srusi (sve na stocku ofkors) posudi drugo napajanje ili uzmi novo
The Secret ...
Staro 26.06.2009., 15:19   #50
pimpinjon
pimpinjon's Avatar
Postovi: 306
evo meni s corsom vx450 sve radi. bar zasad.
Staro 27.06.2009., 11:56   #51
Wolverine
Wolverine's Avatar
Postovi: 12,428
Autor dh41400 Pregled postova
Ajmo po redu:
[*]LC POWER PROPHECY 750W je built by Andyson (ne CWT) i to vrlo kvalitetno odradjuje (bavi se izradom vrlo solidnih napajanja).
Hvala na ispravci
ne znam zašto sam zabrijao da je CWT (možda zbog 850W Arkangel modela koji bi trebao biti sličan TT Toughpower 850)
Gle možda je napajanje neispravno...
Probaj od nekoga posudit neko ispravno napajanje pa provjeri
dakle radi se o ovom napajanju
ono sa svojih 580W na +12V mora tjerat tvoju konfu
Daddy-ev Seasonic S12 500W sa svojih 396W na +12V bez problema je upogonio Q6600 + hrpa diskova + HD4890 Toxic
Što se tiće odvojenih railova mnogi proizvođači ne odvajaju railove nego to samo naljepe na deklaraciju
Evo za primjer jedan Seasonic iz M12 serije nema 4 odvojena raila kako je deklarirano
tj nema OCP pa stoga nema ograničenej na 18A/railu kako je deklarirano...i samu vidite da je izvukao 35A sa jednog raila (gotovo dvostruku vrijednost)
Now on the previous page, you saw that Seasonic advertises this PSU as having four 12V rails. You'll notice in these load tests that I only specify a load on 12V1 and 12V2. This is because I could not find any proof that this PSU had more than two 12V rails; at the most three. And I found that even if there were three 12V rails, there is no OCP (over-current protection) or any circuitry in place that disrupts continuity between the multiple "rails." We'll discuss this further during the autopsy.
http://www.jonnyguru.com/modules.php...=Story2&reid=3
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 27.06.2009., 13:04   #52
e1ectra_one
Creepshow
Postovi: 417
Thx Wolverine
Evo konfa je na golo spojena, i naravno opet gasi, budem prodo sad sa drugim biosom, ako open onda cu probat sa E6600
EDIT:
I sa E6600 ista stvar.
Zadnje izmijenjeno od: e1ectra_one. 27.06.2009. u 14:58.
Staro 27.06.2009., 17:06   #53
dh41400
Señor Audiophile
dh41400's Avatar
Lokacija: Zabreg
Postovi: 3,280
Koliko vidim uzeo si tog LC-a prije 6 mjeseci ... pretpostavljam da je vazeca garancija (24 mjeseca IIRC).
Barem bi to trebalo biti jednostavno
The Secret ...
Staro 28.06.2009., 21:00   #54
e1ectra_one
Creepshow
Postovi: 417
Evo sa Corsair VX750 radi, budemo vidjeli do kad.
Staro 29.06.2009., 11:07   #55
Wolverine
Wolverine's Avatar
Postovi: 12,428
Valjda TX750
Ako je tako onda fino nosi LC-a na reklamaciju
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 29.06.2009., 18:06   #56
e1ectra_one
Creepshow
Postovi: 417
Valjda TX750
Ah sorry greškica, nisam ga ni gledo samo ubo i vrti Crysis Warhead
A za garu će mi reć da je napajanje ispravno jel kod frenda radi sve 5 na Q6600, HD4870
EDIT: riješeno, napajanje slabo i točka sta god vi rekli.
Zadnje izmijenjeno od: e1ectra_one. 01.07.2009. u 13:52.
Staro 02.07.2009., 23:48   #57
Sorter
Lokacija: Cakovec
Postovi: 6
Bok.
Ja imam slican problema ali sa drugom grafickom.
Radi se Sapphire 4850 Toxic. Napajanje mi je Chieftek 550W.
Radi ti onda sad sve sa tim corsairom?
Tnx.
Sorter je offline   Reply With Quote
Staro 03.07.2009., 10:34   #58
Wolverine
Wolverine's Avatar
Postovi: 12,428
Autor Sorter Pregled postova
Bok.
Tnx.
još kad bi reko koja je konfa
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 03.07.2009., 18:14   #59
Sorter
Lokacija: Cakovec
Postovi: 6
Da, sry.
CPU: CPU AMD Athlon X2 7750 BE BOX, 2.7GHz, SckAM2+
HLADNJAK: Thermaltake CL-P0257, Blue Orb II AlCu Cooler
MBO: MB Gigabyte MA770-UD3
MEMORIJA: DDR2 4GB (2x2GB kit) PC8000 (1000MHz) OCZ, Platinum XTC, DC kit
HDD: Seagate ST3250410AS, 250 GB 16MB, S-ATA300, NCQ3, 7200
GRAF: Sapphire Radeon HD4850 512MB Toxic
ZVUCNA: Sound CL X-FI Xtreme Gamer
NAPAJANJE: Chieftec power supply 550W
Staro 03.07.2009., 18:28   #60
Wolverine
Wolverine's Avatar
Postovi: 12,428
koju si grafu imao ranije?
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
