Staro 04.06.2009., 22:09   #1
anonime
Lokacija: Porec
Postovi: 32
Problemi s LAN driverima
Imam Maticnu GA-8S661FXM-775 i na njoj integriran SiS 900 SiS900 Ethernet Adapter....
I kada zelim instalirati drivere uvijek mi javi:
Updata Driver for PnP Device Fail. Setup will wxit.
Sad neznam kak da to popravim???
anonime je offline   Reply With Quote
Staro 04.06.2009., 22:15   #2
Mr.Black
Mr.Black's Avatar
Postovi: 1,679
Ubaci cd s driverima, odi u device manager, na mrežnu desni klik - update driver i odredi mjesto sa cdea gdje ti je driver. Ovo te neke Plug and Play zeza..
Mr.Black je offline   Reply With Quote
Staro 04.06.2009., 22:16   #3
thopok
Lokacija: Splity
Postovi: 3,003
Staro 04.06.2009., 23:02   #4
Postovi: 23,507
Staro 05.06.2009., 00:16   #5
anonime
Lokacija: Porec
Postovi: 32
Sve to sto ste rekli sam probao.... i skinuti sa gigabytove stranice drivere i sa sis-ove stranice drivere.... no kada probam instalirati... error....
Staro 05.06.2009., 20:15   #6
thopok
Lokacija: Splity
Postovi: 3,003
Code:
            SiS PCI Fast Ethernet Adapter Installation
                     for Windows XP Driver
driver file:  .\sisnic.sys
INF file:     .\netoem.inf
Install The Driver
1.  Install the card in the PCI slot and connect the cable to the network;
    turn on the computer and start Windows XP.
2.  When Windows XP starts, a "Found New Hardware Wizard" dialog box appears
    identifying the card as a "Ethernet Controller";
    Select "Search for a suitable driver for your device [Recommended]".
    NOTE, if the "Found New Hardware Wizard" dialog box does not appear,
    Windows XP fails to detect your adapter. There may be problem with the
    adapter itself or with the system BIOS.
3.  Click Next then enable the "Specify a location" check box; specify the
    correct path in which SiS 900 PCI Fast Ethernet Adapter driver for
    Windows XP resides.
4.  Click Next then Windows ME identifies the card as
    "SiS 900 PCI Fast Ethernet Adapter"
5.  Click Next to let Windows XP finishes the driver installation.
Pa netko bi pomislio da se radi o sumnjivoj verziji OS-a koji nije ni naveden?
Ima li je uopće u device manager-u?
Evo, čak mi prolazi instalacija iako dotičnu ne posjedujem.
Code:
Install The Driver
    Windows XP resides.
Zadnje izmijenjeno od: thopok. 05.06.2009. u 20:31.
