Staro 09.05.2009., 22:38   #1
SnakePriest
Lokacija: Zagreb,Rudeš
Postovi: 197
Athlon 7750+ BE club ("unlocked" ones inside :) )
bilo bi dobro da svatko napise nesto o svom iskustvu sa AMD 7750+ Black Edition procom...da podijelite sa nama koji su tek sad kupili proc
screenshotovi,cpu-z validacije...sve je dobrodoslo
SnakePriest je offline   Reply With Quote
Staro 10.05.2009., 01:19   #2
vacs
vacs's Avatar
Lokacija: RH
Postovi: 1,736
evo da probijem led...slika govori vise od 1000 rijeci pa nek onda prica
inace je ovakva situacija bila
boots stable:
cpu clock: 3300mhz
multi: 16.5x
fsb: 200 (stock)
ht link: 1800 (stock)
ram: 1066mhz (stock)
ram timings: 5-5-5-15
cpu v: 1.4v
ram v: 2.1v (stock)
NB v: 1.2v (stock)
HT v: 1.2v (stock)
pci-e clock: locked 100mhz
won't boot:
cpu clock: 3400mhz
multi: 17x
fsb: 200 (stock)
cpu v: 1.45v (same thing with 1.5v)
ram v: 2.1v (stock)
NB v: 1.2v (stock)
HT v: 1.2v (stock)
won't boot:
cpu clock: 3432mhz
multi: 16.5x
fsb: 208mhz (boots bios but won't windows)
ht link: 1800mhz (same thing with 1600mhz)
ram: 1066mhz (same thing with 800 and 667)
ram timings: 5-5-5-15 (with 667mhz i left it on auto)
ram v: 2.1v (stock)
NB v: 1.2v (same thing with 1.3v)
HT v: 1.2v (same thing with 1.3v)
nakon toga sam jos proba sa 1.6v i uspio uci u win al se rusilo na prime-u pa sam odusta
dojmovi: totalno razocaranje
vacs je online   Reply With Quote
Staro 11.05.2009., 13:04   #3
Thorax
Doomster
Thorax's Avatar
Datum registracije: Mar 2008
Lokacija: Kraj Donji
Postovi: 400
Najveći (nestabilni) clock 3630 MHz - validacija
Najveći stabilni clock 3520 MHz - nemam validaciju, al evo slika Wprime1024
Za 24/7 je držan na 3.3 GHz uz 1.45 V na ASRock 790GX 128M.
Neko vrijeme je bio na DFI 790FXB-MRSH i tamo mu je za 3.3 bilo dovoljno 1.4 V.
CPU: AMD Athlon 640 under TX3
MBO: Asrock 870 Extreme3
RAM: 8 GB DDR3 Mushkin @ 1333, CL8
VGA: XFX HD4830
HDD: WD 6400AAKS
Monitor: Samsung 2470H
PSU: Fortron PNF 400W
OS: Win 7 Enterprise x64 SP1
Net: 12 Mbit/1,25 Mbit
Sound: Logitech X-530
CPU: Intel Celeron T3100
MBO: HP 1526
RAM: 2 GB DDR3
VGA: GMA 4500MHD
HDD: WD3200BEVT
Monitor: 15,6“ LCD
PSU: HP 65 W
OS: Win 7 Enterprise x86 SP1
Sound: Arctic Sound P281
CPU: AMD Athlon M320 undervolt @ 0.975 V
MBO: AMD 785
RAM: 2 GB DDR2 800
VGA: Integrated HD4200
HDD: Hitachi 250 GB
Monitor: LCD 15,6“
PSU: Delta Electronics 65 W
OS: Win 7 Ultimate x86
Net: 8 Mbit/768 kbit
Sound: integrated
Thorax je offline   Reply With Quote
Staro 11.05.2009., 18:08   #4
SnakePriest
Postovi: 197
uh,nije lose,evo cekajte do sredine tjedna da si nabavim Corsaira VX550 pa cu i ja pocet clockati jer sa ovim mojim 400W Fortonom nemogu drzati ni 3.0 ghz jer se stalno rusi 2. jezgra nakon 3 sekunde jer napajanje ne daje stabilne struje....
Staro 16.05.2009., 12:48   #5
SnakePriest
Postovi: 197
ja nemogu overclockati iznad 3000 mhz stabilno da ga je....
Staro 16.05.2009., 13:02   #6
Thorax
Doomster
Thorax's Avatar
Postovi: 400
To je nemoguće, kakav god da je primjerak. Mora ići preko 3 GHz.
Koje su ti postavke i naponi u BIOS-u?
VGA: XFX HD4830
HDD: WD 6400AAKS
MBO: HP 1526
RAM: 2 GB DDR3
VGA: GMA 4500MHD
HDD: WD3200BEVT
Monitor: 15,6“ LCD
PSU: HP 65 W
MBO: AMD 785
RAM: 2 GB DDR2 800
HDD: Hitachi 250 GB
Monitor: LCD 15,6“
Sound: integrated
Staro 16.05.2009., 13:22   #7
SnakePriest
Postovi: 197
http://img32.imageshack.us/img32/5620/30561547.jpg
evo printscreen...vrtim orthosa 2 sata i zasada je stabilno sve na 3 ghz
Staro 16.05.2009., 17:48   #8
vacs
vacs's Avatar
Lokacija: RH
Postovi: 1,736
jes proba sa ovim mojim postavkama?
Staro 16.05.2009., 19:06   #9
DomagojX
Lokacija: Zagreb/Sesvete
Postovi: 1,307
Autor SnakePriest Pregled postova
digni još malo multi od memorije
DomagojX je offline   Reply With Quote
Staro 16.05.2009., 19:50   #10
SnakePriest
Postovi: 197
mislis na ovo FSB: DRAM 1:2???
Staro 16.05.2009., 20:06   #11
vacs
vacs's Avatar
Lokacija: RH
Postovi: 1,736
da mislio je na to samo sto to ne mozes mjenjati nego samo odma odabrati 1066mhz ako imas rame sa tom brzinom,a koliko vidim nemas...
uglavnom probaj ovak:
cpu clock: 3300mhz
multi: 16.5x
fsb: 200
ht link: 1800
ram: 800mhz
cpu v: 1.4v
ram v: 2.1v
NB v: 1.2v
HT v: 1.2v
pci-e clock: 100mhz
Staro 16.05.2009., 20:11   #12
SnakePriest
Postovi: 197
ajd budem kada poslusam malo trancea al mi stavrno ne ide sa ovim overclockanjem....
ma jok,ne ide na 3300,cak sam stavio +0.150 i nece mi uopce uci u win....
Zadnje izmijenjeno od: Razer. 16.05.2009. u 20:41. Razlog: Bez duplih postova!
Staro 16.05.2009., 23:56   #13
Cele303
Cele303's Avatar
Postovi: 337
To je matična od vacsa ali drugi 7750 ili isto i proc od vacsa? Čudno da neće preko 3.0, jel ima ta ploča ACC? Probaj se s njim poigrat, ili isključit ako je uključen ili ga uključit sa Auto na All Cores...
Evo da i ja prebacim SS sa one teme gdje smo pričali o 7750...
http://valid.canardpc.com/show_oc.php?id=504877
Cele303 je offline   Reply With Quote
Staro 17.05.2009., 00:04   #14
SnakePriest
Postovi: 197
moj proc je kupljen u Diskontu a ova maticna je kupljena od vacsa,evo guram proc na 3.1 ghz stabilno 3 i pol sata pod Orthosom
Staro 17.05.2009., 11:28   #15
SnakePriest
Postovi: 197
ljudi evo dokaza da se taj AMD 7750+ BE moze pretvoriti u cetverojezgrenog....ja se jutros probudio i naisao na ovo
http://img43.imageshack.us/img43/5337/31320856.jpg
fakat mi nije bilo jasno....upalim Prime i komp mi se zablokira nakon minutu i resetira se i opet mi pise da imam dvojezgrenog Athlona...
Staro 17.05.2009., 12:30   #16
DomagojX
Postovi: 1,307
cool....možda everest laže....kad ti se to pojavi aj upali cpuz da vidimo...
Staro 17.05.2009., 12:39   #17
SnakePriest
Postovi: 197
komp se resetirao i opet je dvojezgreni...ali pogledaj Windows Task manager...sumnjam da bi on lagao a i na my computeru pise Engineering Sample
Staro 17.05.2009., 14:17   #18
SnakePriest
Postovi: 197
u ACC kad stavim PER CORE vidim 4 jezgre....a kad ulazim u win onda je normalno dvojezgreni...
Staro 17.05.2009., 17:26   #19
Thorax
Doomster
Thorax's Avatar
Postovi: 400
Kad staviš per core uvijek se pokažu 4 jezgre, to nije ništa čudno.
VGA: XFX HD4830
HDD: WD 6400AAKS
MBO: HP 1526
RAM: 2 GB DDR3
VGA: GMA 4500MHD
HDD: WD3200BEVT
Monitor: 15,6“ LCD
PSU: HP 65 W
MBO: AMD 785
RAM: 2 GB DDR2 800
HDD: Hitachi 250 GB
Monitor: LCD 15,6“
Sound: integrated
Staro 17.05.2009., 20:07   #20
SnakePriest
Postovi: 197
ne kuzim zasto nemogu povecat FSB od maticne ploce....
Staro 17.05.2009., 23:03   #21
maX
maX's Avatar
Postovi: 7,326
zato jer kod AMD-a nema FSB-a nakon socketa A...
btw, zbog cega ovaj procesor zavrijedjuje poseban thread? kako bi bilo da sad svi pocnu otvarat za svaki model procesora poseban "club" thread?
Staro 17.05.2009., 23:06   #22
SnakePriest
Postovi: 197
ma mislim na HTT ili kako god se vec zove...stiscem enter na to ko budala ali uopce nemogu mijenjati....niti mogu otvoriti opciju da mijenjam...
Staro 17.05.2009., 23:09   #23
maX
maX's Avatar
Postovi: 7,326
mozda trebas negdje nesto sa Auto na Manual prebaciti
Staro 18.05.2009., 00:46   #24
vacs
vacs's Avatar
Lokacija: RH
Postovi: 1,736
sa + se mjenja,no dabe ti jer cpu ne podnosi preko 208 fsb (bar moj nije)
Staro 18.05.2009., 00:50   #25
SnakePriest
Postovi: 197
erm,ja sam cak stavio na automatic overclock v8 i on je sam overclockao na 230x13.5 na 1.4 volt 3.1 ghz i radio je stabilno
Staro 18.05.2009., 09:26   #26
Thorax
Doomster
Thorax's Avatar
Postovi: 400
Autor vacs Pregled postova
To je zbilja čudno, svaki Phenom je išao bar do 220-230.
Moj 7750 je išao do 240 bez problema, nije stvar samo u procesoru, dobar dio je i ploča odgovorna.
VGA: XFX HD4830
HDD: WD 6400AAKS
MBO: HP 1526
RAM: 2 GB DDR3
VGA: GMA 4500MHD
HDD: WD3200BEVT
Monitor: 15,6“ LCD
PSU: HP 65 W
MBO: AMD 785
RAM: 2 GB DDR2 800
HDD: Hitachi 250 GB
Monitor: LCD 15,6“
Sound: integrated
Staro 18.05.2009., 10:15   #27
SnakePriest
Postovi: 197
evo ja njemu utrpao 230 i boota normalno,samo nemogu ici bas preko 1.4 jer u loadu mi temp raste do 70 stupnjeva sa Freezerom.a dok mi je na 1.31 idle temp 31-32 stupnja na 3 ghz....
Staro 18.05.2009., 14:09   #28
Shinobi
Shinobi's Avatar
Datum registracije: Mar 2009
Postovi: 75
mogu vam samo nesto rec.. 7750 BE i GA M57 SLI S4 kombinacija 0 bodova.. sa tvornickih 2.7 dignem na 2.8 i nece se upalit komp..
Shinobi je offline   Reply With Quote
Staro 18.05.2009., 19:04   #29
SnakePriest
Postovi: 197
SnakePriest otkljucao još 2 jezgre na AMD 7750+Black Editionu
mislim da nije Korejanac jedini koji je uspio unlockat jos 2 jezgre kod Kume^^
evo galerije sa printscreenovima
http://img40.imageshack.us/gal.php?g...raniphenom.jpg
Staro 18.05.2009., 19:13   #30
Tomo
Re-Registered User
Tomo's Avatar
Postovi: 627
Nemoj se slucajno raspisat kak si dosao do tog itd ...
Ajde i mene zanima quad core proc od 450kn
Tomo je offline   Reply With Quote
