Staro 08.04.2009., 21:07   #631
pingmachine
machine that goes ping!
Postovi: 478
@Mar - pa ako Black nisu PUNO glasniji onda uzimam njih.
http://www.silentpcreview.com/article904-page2.html
jest da su podaci za gigabajtnu verziju, ali...
pingmachine je offline   Reply With Quote
Staro 08.04.2009., 21:18   #632
Mar
Suit up!
Mar's Avatar
Postovi: 5,980
Terabajtna verizija ima 3 ploče i 6 glava dok 640GB ima dvije ploče i 4 glave.
- Barney Stinson
Staro 08.04.2009., 21:39   #633
pingmachine
Postovi: 478
"Seeking was particularly loud at 25 dBA, within spitting distance of the 10,000 RPM 150GB Raptor. Compared to our selection of newly re-tested reference drives, the WD Black fared poorly."
"It was more or less indistinguishable in this regard to the Caviar SE16 500GB — a two year old drive with 4 platters."
Staro 11.04.2009., 16:00   #634
LuxZg
Postovi: 512
Autor Jeote Pregled postova
Kaj nije u ADM-u najjeftiniji, 442 kn.. ???
Neznam, piše u ADM da je AAKS 475,85kn, a AALS (sa 60mj garancije) 509,33. Diskont24 ima AALS sa 60mj za 507,56kn. Nije neka razlika, al pored D24 i tak prolazim svaki dan, a ADM mi je 10-ak km dalje
Al nebitno, izgleda da bum i tak uzeo 2 diska "direkt" u Asbisu čim ih dobiju na lager.
Hvala svima na komentarima!
Intel Core 2 Duo E4400 @ 320x10 (3200MHz) w/ Scythe Ninja rev.B + 120mm fan | Gigabyte GA-P35-DS3R (Intel P35 + ICH9R) | 4x 1GB Kingmax MARS DDR2 800 CL5 | Sapphire ATi Radeon HD4890 | Seagate 7200.11 250GB+2x WD Black 640GB+Samsung F3 1TB; svi SATA/7200rpm | LG GH20NS15 SuperMulti, SATA | LG W2361V-PF 23", 1920x1080, DVI+HDMI | Aplus CS-188AF case w/ 250mm side fan | onboard 7.1, with Logitech X-540 5.1 speakers | Chieftec 450W /w 120mm fan | Windows 7 64bit Enterprise
LuxZg je offline   Reply With Quote
Staro 13.04.2009., 03:08   #635
ivanb
Lokacija: Sukošan
Postovi: 214
Pozdrav, imam dotični WD hard WD6400AAKS-00A7B2. I od kad sam ga kupio dosta puta mi se zaledi komp, instalirao sam ponovo windowse sigurno 5 puta i uvijek isti problem. uzeo sam sad ovaj HD tune i izvrtio neki test jer sumljam baš da nesto Hard disk nije u redu.
Probao sam write test ali nesto nije htjelo, pa sam samo read.
Evo slika http://www.max-save.org/images/661326untitled.JPG
ivanb je offline   Reply With Quote
Staro 13.04.2009., 17:03   #636
ivanb
Lokacija: Sukošan
Postovi: 214
Ajde recite neki dobar program da provjerim jeli sa Hardom sve u redu.
Staro 13.04.2009., 17:24   #637
dh41400
Señor Audiophile
dh41400's Avatar
Lokacija: Zabreg
Postovi: 3,280
The Secret ...
Staro 13.04.2009., 17:43   #638
ivanb
Lokacija: Sukošan
Postovi: 214
Moj problem nije u tome da on javi neku grešku prilikom kopiranja, nego mi se samo nekad zaledi PC, sad neznam do ćega, npr. prilikom instalacije igrice preko Alcohola skro se uvijek zaledi, tako da neznam u čemu je stvar.
Staro 13.04.2009., 17:46   #639
E-mil
Oppa Gangbang Style
E-mil's Avatar
Postovi: 1,764
Možda je problem u alkoholu
E-mil je offline   Reply With Quote
Staro 13.04.2009., 20:28   #640
ivanb
Lokacija: Sukošan
Postovi: 214
Nije u Alcoholu jer mi se taj problem javlja i u Power iso i daemon toolsu. A hard sam evo testirao od grešaka s HD Tune i nije našao grešku tako da neznam u čemu je problem.
Staro 13.04.2009., 21:13   #641
Rain Man
Lokacija: x
Postovi: 1,447
Problem je negdje u windowsima. A pogledaj i dal su kablovi dobro sjeli. Probaj mijenjat mjesta disku na konektorima na ploci.
Rain Man je offline   Reply With Quote
Staro 22.04.2009., 10:06   #642
aahz
Datum registracije: Apr 2009
Postovi: 1
Autor ivanb Pregled postova
Koju maticnu plocu imas? Ti diskovi znaju imati gadnih problema a Asusovom P5KPL-AM maticnom (G31 chipset). Inace imas na www.wdc.com Data Lifeguard Diagnostic alat za testiranje diska, a mozes i potraziti Bitpro, alat za stres test sustava. POgledaj da li ti je sata kontroler u biosu namjesten na aahci mod, ako je postavi ga na compatibile pa vidi kaj se desava.
aahz je offline   Reply With Quote
Staro 23.04.2009., 23:43   #643
daxdax
Postovi: 138
kod mene stanje sa wd6400aaks ovakvo:
tih ,brz i nakon 30 minuta iznenađujuće vruć (49c).
Išao brzo iz kućišta van kao vanjski hard u aluminijsko kučište.
daxdax je offline   Reply With Quote
Staro 24.04.2009., 00:24   #644
blackened
blackened's Avatar
Lokacija: Beli Manastir
Postovi: 1,281
i ja uzeo danas i mislim i da bi moj imao temperaturu oko 50c s obzirom da s otvorenom stranicom kućišta ima 43 stupnja...
Staro 24.04.2009., 00:49   #645
Rain Man
Lokacija: x
Postovi: 1,447
Nabavite vas dvojica neka bolja kucista, napravite neki protok zraka kroz kuciste i nece se diskovi toliko grijat. Moj je na 30c, drugi na 28c.
Staro 24.04.2009., 00:59   #646
blackened
blackened's Avatar
Postovi: 1,281
ne znam baš jel bi što koristilo pošto su ostali diskovi od 32-35 stupnjeva...
Staro 24.04.2009., 01:09   #647
danc00
Why so serious
danc00's Avatar
Postovi: 3,417
Autor blackened Pregled postova
Kakve veze imaju ti diskovi sa WD diskom...pa ne griju se svi isto! Očito da bi pala temp i ovima koji se manje griju, zar ne....
danc00 je offline   Reply With Quote
Staro 24.04.2009., 01:24   #648
blackened
blackened's Avatar
Postovi: 1,281
rekao sam to u smislu da se očigledno grije više od ostalih što mi malo čudno, svejedno bi ostala razlika u 10 stupnjeva između njega i ostalih...
Staro 24.04.2009., 02:57   #649
daxdax
Postovi: 138
Autor Rain Man Pregled postova
Čisto sumnjam u kučište kao krivca temperature.
U kučištu su mi 2x seagate 11 od 640gb sa pristojnim tempama oko 34c.
A da je WD šparet pokazuje i to da u externom usb kučištu (gdje na dodir osjetim razliku) najtopliji od svih mojih diskova.
F1 od 750GB je hladniji.
Vjerujem da ove nove serije nisu tako hladne ko tvoje.
Svakako treba vidjeti koje serije su ŠPARETI a koje nisu.
Moj krene sa 30c na dizanju sistema (nakon prospavane noći),a nakon 30-45minuta intenzive dosegne 49c s tim da uopće nije
sistemski disk,već se na njemu nalaze igre.
Čak sam našao i neke oficijalne testove gdje je radna temeperatura deklarirana na 46c... Kučište nema veze sa tom temperaturom.
Zadnje izmijenjeno od: daxdax. 24.04.2009. u 03:08.
Staro 24.04.2009., 18:18   #650
Rain Man
Lokacija: x
Postovi: 1,447
Moji su bez upaljenog prednjeg venta bili na 35, sad kad se ispred njih vrti 120mm na 600RPM su oko ili ispod 30 stupnjeva. Meni je vec dosta tih 640GB proslo kroz ruke i svi su uglavnom bili hladni. Sad ako se ovi novi vise griju (ili vise cuju), onda su stvarno nesto mijenjali u dizajnu. A ako jesu onda to nije isti disk.
Kuciste ima velike veze s temperaturom, no cinjenica je da ga 40 do 45 stupnjeva nece ubit. Svakome kome temp prelazi 50 u ljetu trebao bi razmislit o necem da puse po disku. Osim naravno ako je disk u nekom eksternom kucistu i ako se na toj temperaturi ne koristi 0/24.
Staro 24.04.2009., 18:53   #651
danc00
Why so serious
danc00's Avatar
Postovi: 3,417
Autor daxdax Pregled postova
Tolko o šparetu, neznam zake je tvoj tak vruči...pogle moju temp od WD-a !
Kučište je sa nula protoka zraka(120mm piri samo po graf i ćipsetu ne i po hardu), samo je otvoreno! A u sobi mi je oko 18-20°C !
Staro 24.04.2009., 18:56   #652
daxdax
Postovi: 138
Staro 24.04.2009., 19:00   #653
daxdax
Postovi: 138
Autor danc00 Pregled postova
ja navodim da je on najtopliji i u usb aluminijskom kučištu koje je izvan kante,tako da isključujem okolinu zatvorene kante.
Staro 24.04.2009., 19:18   #654
Dottore
Dottore's Avatar
Postovi: 7,726
sve zavisi kako disk stoji pokraj drugog..
one priče o eksternom disku zanemarite to. logično da eksterni nema što hladiti odnosno nema nikakav protok zraka još k tome u skučenom prostoru. niste svjesni da neznate razliku između mirovanja i loada. jasno pri opterečanju grije još više...
pošto imam stariji i novi disk ( oba 640gb). stariji aaks je kao storage a noviji ( uf zaboravio , mislim aals ) je sistematski. u pravili sistematski grije par 3-4stupnaj više nego storage ali pušu ventovi na 800rpm.
glede toga od kolega Rain Man imamo indetičnu temperaturu. tu se potpuno slažem
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 5
CPU: AMD Ryzen 7 PRO 8840u
RAM: 64GB DDR5
SSD: Kioxia XG8 1 TB NVMe M.2
Graphic: AMD Radeon 780M
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
RAM: 16GB soldered LPDDR4
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 24.04.2009., 19:33   #655
daxdax
Postovi: 138
Autor Dottore Pregled postova
Ma nema tu govora o tome gdje što stoji,jer je razlika u temperaturi ogromnih 10-15c između vaše serije i moje.
Taman da stoji u spužvi nesmije biti tolika razlika.
Ako hoćeš testirati nešto sve mora imati iste uvijete,odrediš koliko okoliš utiče a ostalo je prava temperatura.
Ako je F1 hladniji u istom aluminijskom kučištu i do 12c tada je jasno da se WD pregrijava.i da bi to shvatio ne moraš biti ajnštajn.
Staro 25.04.2009., 12:20   #656
Getriba
Postovi: 234
pitanje, neznam di bi ga stavio, a glupo mi je otvarat novu temu. utječe li popunjenost diska na brzinu istog? dakle, hoće li bit jednako brz bio on samo 5 % popunjen ili 85%? pretpostavka je da je u oba slučaja defragmentiran i nema ničeg ostalog kaj bi ga usporavalo
Getriba je offline   Reply With Quote
Staro 25.04.2009., 16:28   #657
dh41400
Señor Audiophile
dh41400's Avatar
Lokacija: Zabreg
Postovi: 3,280
Autor Getriba Pregled postova
... utječe li popunjenost diska na brzinu istog? dakle, hoće li bit jednako brz bio on samo 5 % popunjen ili 85%? pretpostavka je da je u oba slučaja defragmentiran i nema ničeg ostalog kaj bi ga usporavalo
Da, bit ce sporiji (znatno). Kada dodje do 90-95% popunjenosti prakticki postane spor kao puz.
Bilo bi preporucljivo ostavit na svakom disku barem 10-20% slobodnog kapaciteta, pogotovo ako je sistemski ili se cesto koristi.
Nadalje, novi disk ili eventualno privremeni backup na DVD/CD medije je preporucljiv.
The Secret ...
Staro 14.05.2009., 11:51   #658
daemon1
daemon1's Avatar
Lokacija: Tučepi
Postovi: 105
Molim pomoć, konf iz siga, kupio sam wd6400aaks,
oba harda su mi spojena na sata konektore, u biosu mi ga prepoznaje, kad idem na da dodam novi hardver kaže mi da je sve ok, ali u My Computer ga nema?
daemon1 je offline   Reply With Quote
Staro 14.05.2009., 12:12   #659
Roy
15/JG52
Roy's Avatar
Postovi: 774
Autor daemon1 Pregled postova
Formatiraj ga
Start--->control panel--->Administrative tools--->computer managment--->disk managment--->desni klik mišem na taj disk--->format i dalje slijedi uputstva. Kad dobije slovnu oznaku vidjeti ćeš ga u My Computer.
Roy je online   Reply With Quote
Staro 14.05.2009., 16:42   #660
mujica
črna jetra
mujica's Avatar
Postovi: 453
pomoc
eto radi se o istom hdd-u kao u naslovu topica, hdd je frendov i stalno baca eror ciclyc redundancy check. zapiknul sam ga kod sebe i ista stvar, pisanje na njega radi ok, al kod citanja/kopiranja opet isti error.
napravil sam onal wd-ov diagnostic test i dobil:
Test Result: FAIL Test Error Code: 06-Quick Test on drive 5 did not complete! Status code = 07 (Failed read test element), Failure Checkpoint = 97 (Unknown Test) SMART self-test did not complete on drive 5!
ima netko kakvu ideju il ide na servis?
Avoid hangovers: stay drunk.
mujica je offline   Reply With Quote
