Staro 20.04.2009., 22:36   #1
V.I.P.
Datum registracije: Apr 2009
Postovi: 1
Windows XP home edition pitanje (za mene hitno)
Evo ovako, kupio sam nove legalne windowse i dobio kutiju sa 2 cd-a.
Jedan je windows xp home edition, a drugi paket s jezičnim sučeljem za windows xp home edition na hrvatsko jeziku i naravno certifikat. E sad mene zanima posto imam kompjuter i laptop dali ja na svoje racunalo i laptop mogu instalirati te windowse i obadvoje ih prijaviti kao legalne i registrirati se na microsoft?? Molio bih sto hitniji odgovor posto mi je ovo hica...
p.s. Sorry ako ovo vec ima negdje postano nisam imao vremena za pretrazivanje moram raditi...
V.I.P. je offline   Reply With Quote
Staro 20.04.2009., 22:37   #2
Facelessone
Facelessone's Avatar
Postovi: 4,205
ne! Jedni windowsi jedan komp.
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 20.04.2009., 22:55   #3
thopok
Lokacija: Splity
Postovi: 3,003
Tako jednostavno ipak nije…
You may install, use, access, display and run one copy of the Software on a single computer, such as a workstation, terminal or other device ("Workstation Computer"). The Software may not be used by more than one processor at any one time on any single Workstation Computer.
Instalacija Windows-a XP - Za Početnike
