Staro 11.03.2009., 12:44   #8161
thedream
thedream's Avatar
Lokacija: Zagreb ( Šibenik )
Postovi: 5,458
Styx - Boat on the river (live 1982)
Staro 11.03.2009., 12:55   #8162
Hamm
Pod naletima kopita zla
Hamm's Avatar
Lokacija: SMB / ZGB
Postovi: 7,736
Soulfly - Limited Edition - 1998 i Soulfly-Conquer-2008
pripreme za koncert
Staro 11.03.2009., 13:51   #8163
Postovi: 7,568
Christina Milian - Perfect
Staro 11.03.2009., 13:54   #8164
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,760
Nine Inch Nails-Ghosts I-IV
Staro 11.03.2009., 13:57   #8165
naram-sin
The Last Akkadian
naram-sin's Avatar
Datum registracije: Apr 2008
Postovi: 194
naram-sin je offline   Reply With Quote
Staro 11.03.2009., 13:59   #8166
Mephsto
Mephsto's Avatar
Postovi: 199
let 3 - kurcem u čelo
Mephsto je offline   Reply With Quote
Staro 11.03.2009., 14:04   #8167
T0mB1ll
420
T0mB1ll's Avatar
Lokacija: Le Molve
Postovi: 1,577
aka Carl - Promo Mix March 2009
T0mB1ll je offline   Reply With Quote
Staro 11.03.2009., 22:10   #8168
Visage
8-bit Gen.
Visage's Avatar
Lokacija: Giethoorn - ZG
Postovi: 3,164
Staro 11.03.2009., 23:10   #8169
agm7007
noise freak
agm7007's Avatar
Postovi: 323
agm7007 je offline   Reply With Quote
Staro 11.03.2009., 23:49   #8170
Ladybug
Ladybug's Avatar
Lokacija: n/a
Postovi: 900
Ladybug je offline   Reply With Quote
Staro 12.03.2009., 00:16   #8171
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,508
Depeche Mode - Enjoy The Silence (live)
vidimo se u Zagrebu na koncertu...
Staro 12.03.2009., 01:34   #8172
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,744
It just works. Except when it doesn't.
CPU: AMD Ryzen9 7950X3D @ stock + AC Liquid Freezer II 360
MBO: Asus ProArt X670E-Creator WiFi
RAM: 4x32GB DDR5 G.Skill Trident Z5 Neo 6000
GPU1: NVIDIA GeForce RTX 4090 MSI Suprim Liquid X
GPU2: NVIDIA RTX A4000 custom cooled
SSD1: Samsung 990 PRO 2TB m.2 NVMe
SSD2: Samsung 970 EVO 4TB
PSU: Seasonic Prime GX-1300
CASE: Fractal Design Meshify 2 XL
Display: Asus Proart PA329CRV + 2x Dell 2715h
Audio: Asus Xonar U7 MK2 + Logitech X-530 5.1
Input: Ducky One 3 Classic RGB + Logitech MX Master 3
OS: Windows 11 Pro x64
HP Zbook 17 G6
CPU: i7-9850H @ 2.60GHz
RAM: 4x16GB DDR4 2400
GPU: NVIDIA Quadro RTX 4000
SSD: 512GB NVME SSD
Audio: Fiio Q1 DAC + AudioTechnica M50x
OS: Windows 10 Pro x64
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
MBO: Gigabyte X399 Aorus Pro
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
GPU: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: LG IPS231P
Audio: OnBoard + display speakers
Input: Microsoft Natural Keyboard + Logitech G602
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
GPU: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
GPU: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3, nVidia GTX970, Windows 10 x64
2016: FX-8320E, Asus M5A97 PRO, nVidia GTX970, Windows 10 x64
2015: i7 6700k, Asus Z170-A, nVidia 750Ti 4GB, Windows 7 x64
2014: FX-8350, ASRock 990FX Extreme3, nVidia GTX660, Windows 8.1 x64
2012: i7 3610QM, Asus N76VZ, nVidia GT650M, Windows 7 x64
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3, nVidia 9600GS, Windows 7 x64
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3, nVidia GTX260, Windows 7 x64
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4, nVidia 8800GTS Ultra 320bit, Windows 7 x64
2009: Intel C2Q Q6600, GIGABYTE EP31, nVidia 8600GS, Windows 7 x64
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x, nVidia 8600GS, Windows Vista x64
2008: Intel Core2Duo T7200, Toshiba A100-847, nVidia 7600 Go, Windows Vista x64
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe, nVidia 7600GT, Windows Vista x64
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe, ATI Radeon X700 PRO, Windows XP x64
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C, Matrox G450, Windows XP
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110, ATI RAGE LT Pro, Windows 2000
2002: AMD Duron 1200, Matsonic MS8127C, Matrox G450, Windows XP
2001: AMD Duron 750, Matsonic MS8127C, Matrox G400 DH, SB PCI 128, Windows98,
1998: Intel Pentium II 300 Klamath, Matrox G200, SB AWE64, Windows98
1996: Intel Pentium 120, Matrox Millenium, SB AWE32, Windows95
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
estugarda je offline   Reply With Quote
Staro 12.03.2009., 10:27   #8173
Baja 001
Baja 001's Avatar
Postovi: 7,504
Louis Amstrong - All Time Greatest Hits
Staro 12.03.2009., 10:32   #8174
BladeRunner
Type R
BladeRunner's Avatar
Postovi: 1,485
Thunder
by The Prodigy
David linčujem Davida Finčera
BladeRunner je offline   Reply With Quote
Staro 12.03.2009., 10:55   #8175
Router
Hejter
Postovi: 6,521
Mike Oldfield - Shadow on the wall
Router je online   Reply With Quote
Staro 12.03.2009., 13:03   #8176
BSA<AK-47>
Napokon dočekao DNF :)
BSA<AK-47>'s Avatar
Postovi: 1,460
eto malo nešto nekonvencijalno :
max payne 1&2 theme music
je tužaljkavo ,al odlično
I dont know you. I dont know what you want. If you leave, that will be the end. I wont look for you, I wont pursue you. But if you dont, I will look for you, I will find you and I will ignore you.
BSA<AK-47> je offline   Reply With Quote
Staro 12.03.2009., 13:29   #8177
John Creasy
Vocna iglica u mudante
John Creasy's Avatar
Lokacija: Beograd
Postovi: 2,837
Prodigy - Warriors dance
Staro 12.03.2009., 14:09   #8178
nick praskaton
Asshole
nick praskaton's Avatar
Lokacija: RH
Postovi: 2,361
Staro 12.03.2009., 20:56   #8179
bluefluid
bluefluid's Avatar
Lokacija: VG
Postovi: 1,760
Carcass - Symphonies of Sickness (1989)
Staro 13.03.2009., 16:53   #8180
Pizz
Registered Abuser
Pizz's Avatar
Lokacija: Velika Gorica \ ZG
Postovi: 747
danas na tapeti doorsi . . .
sutra je u otv-u Tribute to doors...
momci iz austrije kojih bi se i sam Jimbo posramio,
to idem svake godine, odličan koncert
Pizz je offline   Reply With Quote
Staro 13.03.2009., 20:04   #8181
mrga
all you need is freeware
mrga's Avatar
Lokacija: Stolica
Postovi: 897
Novi Prodigy. Dobre su mi Black Smoke, Wild west, Fighter Beat, World's On Fire i The Big Gundown.
Ostatak albuma je SMEĆE i prežvakavanje starih stvari
Neka zvijer krepa, kad nisu u stanju napraviti pošten album.
Trenutno me najviše oduševljava ovo. Jest da kopiraju Chemical Brotherse, al brate mili što to hebeno zvuči
Ovo je potpis.
Zadnje izmijenjeno od: mrga. 13.03.2009. u 20:18.
mrga je offline   Reply With Quote
Staro 13.03.2009., 21:30   #8182
Majo
Lokacija: Zagreb,Dubrava
Postovi: 2,281
Wintersun-Starchild
Majo je offline   Reply With Quote
Staro 14.03.2009., 20:31   #8183
Halos
muimerP
Halos's Avatar
Lokacija: VG
Postovi: 3,334
Staro 14.03.2009., 21:00   #8184
Željac
sto da napisem ?!
Željac's Avatar
Postovi: 880
Dethklok -Briefcase Full of Guts
Staro 15.03.2009., 23:27   #8185
Halos
muimerP
Halos's Avatar
Lokacija: VG
Postovi: 3,334
Staro 15.03.2009., 23:44   #8186
Postovi: 7,568
Heaven Shall Burn - What Ever it May Take
Staro 15.03.2009., 23:48   #8187
Tomtam
Magnum P.I.
Tomtam's Avatar
Lokacija: Belišće
Postovi: 764
Phil Collins - Against All Odds
Tomtam je offline   Reply With Quote
Staro 15.03.2009., 23:48   #8188
Majo
Postovi: 2,281
Cepa se Machine Head,ono kaj mi prvo dode od njih pod ruku
Staro 16.03.2009., 11:20   #8189
thedream
thedream's Avatar
Postovi: 5,458
Danas samo najbolje,prvi panterini albumi cijeli dan na repeatu,kao - malo za promjenu .
Metal magic - 1983
Projects in the Jungle - 1984
I am the Night - 1985
Power Metal - 1988
Staro 16.03.2009., 11:57   #8190
Hei$$e
Hei$$e's Avatar
Lokacija: Našice
Postovi: 444
Prljavo Kazalište - Ruža Hrvatska
Hei$$e je offline   Reply With Quote
