Staro 18.07.2004., 23:57   #1
ljekra
ljekra's Avatar
Datum registracije: Dec 2003
Postovi: 391
Arrow CLUB3D 9800SE i 9800PRO RAZLIKA
Gotovo nikakva, ako trazite neku vga za malo para a zelite postic je... performanse, 9800se@pro, jednostavno i lako!
P.S. samo staviti pasivce na memoriju, jer je razlika u memi (links, bakreni 45kn)
A RAZLIKU MOZETE SAMI VIDJETI: www.club-3d.com ili
9800PRO
Brand:_ATI
Chip:_R350
Form_Factor:_AGP 4/8X
GPU_Mhz:_380
Memory_MHz:_340
Video_memory:_128 Mb
Memory_Bandwith:_256 bit
Memory_Type:_BGA DDR
DVI:_Yes
TV/OUT:_Yes
Features:_RADEON™ 9800 series is the ultimate accelerator of the most demanding next-generation 3D titles, scenes and environments Featuring highly programmable cinematic shader engines and support for the latest Microsoft® DirectX® 9.0 and OpenGL® feature sets Experience unparalleled 3D visual realism with the advanced engineering of ATI technology RADEON™ 9800 series beats with the heart of a champion, backed by the latest CATALYST™ software suite
Order_Code:_CGA-P988TVD
9800SE
Brand:_ATI
Chip:_R350
Form_Factor:_AGP 2X/4X/8X
GPU_Mhz:_380
Memory_MHz:_340
Memory_Type:_DDR
DVI:_Yes
TV/OUT:_Yes
Order_Code:_CGA-S988TVD
Toshiba U400 - 1.86GHz, 3Gb, 250Gb, 13.3''
HP NX7300 - 1.66GHz, 2Gb, 80Gb, 15.4''
Intel Server Board, XEON 2.0GHz, 1Gb ECC, 2x18.1Gb 10000rpm raid, 3x250Gb. 2x320Gb, 1x120Gb
ljekra je offline   Reply With Quote
Staro 19.07.2004., 00:30   #2
LorD ClockaN
od LemilicE
LorD ClockaN's Avatar
Lokacija: Veli Lošinj
Postovi: 4,712
Re: CLUB3D 9800SE i 9800PRO RAZLIKA
Dobro jutro!!!
Ja je imam već više od 6 mjeseci.
Jest da mi u sigu ne piše da je Club3D, ali bio je to topic prije na ATI forumu
Nemam više lema!!!
Staro 19.07.2004., 00:48   #3
ljekra
ljekra's Avatar
Postovi: 391
Re: Re: CLUB3D 9800SE i 9800PRO RAZLIKA
Originally posted by LorD ClockaN
Dobro jutro!!!
e da i jos nesto ide i na frekvu XT i vise(naravno origigi oma 256Mb rama), ali treba je.....acko hladenje, ako nista drugo vodeno, probo, jako brzo se mema zagrije!
Staro 19.07.2004., 02:32   #4
hrca
...(=_o)...
hrca's Avatar
Lokacija: Osijek/Đakovo
Postovi: 401
Jel dovoljno stavit pasivce na memoriju ili treba još nešto drugo ?De nek mi netko malo pojasni kako to ide
hrca je offline   Reply With Quote
Staro 19.07.2004., 09:28   #5
LorD ClockaN
od LemilicE
Postovi: 4,712
Moja ne ide na XT freqve.
Najviše bez artefakata sa Artic-Silencerom i pasivcima je 390/370
Vodeno na grafu dolazi ubrzo
Nemam više lema!!!
Staro 19.07.2004., 10:21   #6
ljekra
ljekra's Avatar
Postovi: 391
Pa ako se samo mod-a iz SE u pro, dovovljni su ti pasivci na memi, proc se malo jace grije, al on ima osigurano zracno hladenje, dok zbog meme ako joj ne stavis barem pasivce, imas na ekranu pri pokretanju 3d igre ili sl. hrpu artefekatata, pucanje slike i mjesanje boja i dr.!
E da bi jos sa PRO modo na XT, za to treba odlicno hladenje jer se grije u PM. (pro clock je 380/340, a treba dignut iznad 415/370), (mislim da zalman ima odlican zracni cooler od bakra, ugraduje se sa obje strane vga-e). Uskoro cu ga kupiti, pa probat, javim na forum.
Staro 19.07.2004., 12:51   #7
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
XT takt ti je 412/365
U pravilu skoro svaki GPU hoće ići toliko, memorija zna zezati.
Nije ni meni išlo preko 400 dok nisam promjenio BIOS.
Sad bez beda dela na 412
Staro 19.07.2004., 14:13   #8
LorD ClockaN
od LemilicE
Postovi: 4,712
Meni je kartica radila normalno modana u PRO sa original coolerom bez pasivaca. Bez artefakata
Nemam više lema!!!
Staro 19.07.2004., 14:54   #9
ljekra
ljekra's Avatar
Postovi: 391
MOzes mi dat link za update bios-a? Ili sendaj na forum
Hvala!
Staro 19.07.2004., 15:11   #10
Jelc
Super Moderators
Postovi: 17,485
Hvala!
Za moddane XT ti je tu:
http://my.tbaytel.net/panthor/files/
Hrpetina svih živih tu:
Staro 20.07.2004., 13:22   #11
LorD ClockaN
od LemilicE
Postovi: 4,712
Koja je razlika u linkovima između ova 2?
Club3d 9800SE ima Hynixovu memoriju, a oni biosi su svi sa Samsung memorijom.
Našao sam bios od Club3D 9800XT 128MB Hynix, ali kad ga učitam u Rabit, on mi napiše R360, pa me strah flashat da ne bi opet sjebo grafičku.
Kad bi bio takav bio sa R350...
Nemam više lema!!!
Staro 20.07.2004., 16:47   #12
Jelc
Super Moderators
Postovi: 17,485
Ne znam kak ide sa Hynix-om, nisam baš pratio...ali ja sam svoju NP flashao sa XT i nemam problema.
Dakle R350 sam flashao sa moddanim R360 BIOS-om.
Imam artifakte u par testova iz 2003 Marka ali u igrama i u 2D-u ne.
Ne možeš tek tak zajebati grafu sa BIOS-om
Samo sejvaj stari, ako ne dela kak treba vrati i nikom ništa...
Dobro je imati neku jeftinu PCI grafu pri flashu, ako ne dobro zapamti proceduru i re-flashaj "na sljepo" ako nekaj zezneš.
Staro 20.07.2004., 17:15   #13
ljekra
ljekra's Avatar
Postovi: 391
e ajd stavi flash na forum ili mi daj link da ga skinem, ja cu probat pa ti javim
thx
Staro 20.07.2004., 17:40   #14
Jelc
Super Moderators
Postovi: 17,485
thx
Ja sam vidio neki Sapphire 9800XT 128 MB na http://www.rojakpot.com/
Staro 20.07.2004., 17:45   #15
Jelc
Super Moderators
Postovi: 17,485
Aukrasnikurac
Htio sam staviti http://www.ocfaq.com/softmod/bios.php pa mi se prst omakao
Vidio sam kod http://www.rojakpot.com/ neki Sapphireov, Hynix 2.8ns 412/365 128 MB.
Ne znam da li je to vama paše...
Staro 20.07.2004., 18:52   #16
ljekra
ljekra's Avatar
Postovi: 391
Aukrasnikurac
meni treba za club3d
Staro 20.07.2004., 23:51   #17
LorD ClockaN
od LemilicE
Postovi: 4,712
Znači ja bi na moju R350 sa Hynix memorijom mogao flashat bios za R360 i Samsung memorijom???
Imam PCI S3 32/64V+ u ladici
Nemam više lema!!!
Staro 21.07.2004., 00:38   #18
ljekra
ljekra's Avatar
Postovi: 391
Brijem da ne, posto meni nije prosao niti jedan flash sa biosom od samsungove memorije, ustvari nije mi prosao nikakav, neznam kakav kur.... bios treba da to proradi!
Staro 21.07.2004., 01:03   #19
LorD ClockaN
od LemilicE
Postovi: 4,712
Upravo sam probao flashat XT bios od Club3D XT kartice sa 128MB Hynix memorije. Sa Rabitom sam biosu smanjio latencije da radio kao PRO (tako meni radi) i smanjio sam joj fekvencije GPUa i memorije.
Nakon flasha ekran mi je bio scrambled, pa sam opet morao napamet flashat nazad original bios.
Možda nisam smio micat latencije memorije, ali probao sam na mom original biosu stavit latencije XTa i ekran mi je također bio scrambled, ali puno manje nego kad sam flashao cijeli XT bios (sa PRO latencijama).
Mislim da nam nema nade, osim da probam još malo zategnut latencije memorije
Nemam više lema!!!
Staro 21.07.2004., 02:15   #20
Jelc
Super Moderators
Postovi: 17,485
Ja sam svoju Herc NP flashao sa modanim XT (isto Herc) i dela.
Kaj se tiče Hynix memorije-jedino sam je vidio na rojakpotu, ak naletim na još koju javim...
Staro 21.07.2004., 02:35   #21
Jelc
Super Moderators
Postovi: 17,485
Ovak-veli škvadra da kad su probali flashati sa Hynix baziranim da nije išlo, ali da im dela sa Samsungovim
Jedan je flashao sa Powercolor.9800XT.128MB.Samsung.E-Die i veli da dela fino.
Taj PowerColor je navodno jedan od bržih.
Ajde Lorde na posao
E da-ja sam isto flashao sa PRO frekvama a ne sa XT.
Pa kad ti se hoće lako clockneš ili si prek RadLinkera napraviš profil za igru sa višljim frekvama...
Staro 21.07.2004., 09:26   #22
LorD ClockaN
od LemilicE
Postovi: 4,712
Uspješno sam flashao sa Powercolor 9800XT Samsung (bez Die-E) 128MB biosom, nije bilo artefakata, ali ima jedan drugi problem.
Kad reinstaliravam driver kaže mi da ne postoji driver za moju karticu.
Da li trebam editirat još nešto?
Imam 2 različita PowerColor biosa, za oba 2 mi u Rabitu pod DeviceID kaže 4E4A (to je XT), ali kad flasham u RivaTuneru kaže mi da imam 414A, provjerio sam u instal.inf datoteci Catalysta i taj broj ne postoji.
Riješenje?
Jel ima još koj bios editor??
Nemam više lema!!!
Staro 21.07.2004., 09:41   #23
LorD ClockaN
od LemilicE
Postovi: 4,712
Sad sa probao flashat, ali bez da forsam flash i lijepo piše da je bios koji pokušavam flashat 4e4a (XT), znači nije u tome problem.
Da li moram napravit Hard-Mod u PRO, da bi mogao flashat u XT i normalno instalirat drivere?
Nemam više lema!!!
Staro 21.07.2004., 09:59   #24
ljekra
ljekra's Avatar
Postovi: 391
Riješenje?
Kad si flash-ao sigurno si zaboravio staviti 0 za no video adapter ili 1 za neki bla bla, uglavnom, pise ti sve u helpu od flashrom-a
Staro 21.07.2004., 10:04   #25
LorD ClockaN
od LemilicE
Postovi: 4,712
Nije mi prvi put da flasham.
Uspijem ja flashat, sve prođe kako spada, ali ne mogu instalirat drivere.
Kao što sam napisao u zadnjem postu, time sam samo htio provjerit točan DeviceID biosa
Nemam više lema!!!
Staro 21.07.2004., 10:11   #26
ljekra
ljekra's Avatar
Postovi: 391
ajd bas cu ja probat danas, ak neuspije se e-die biosom probat cu sa normalnim, jer pise na site-u da je e-die; first release of this bios!!
Staro 21.07.2004., 10:39   #27
LorD ClockaN
od LemilicE
Postovi: 4,712
Malo sam zategnuo latencije memorije po uzoru na XT bios koji ima latencije najsličnije mojima i uspio natuć 6406 Marka (399/375), na tim freqvama ima nešto artefakata, ali su mi sva testiranja na toj freqvi i sve slike koje imam, pa ne mijenjam.
Reci na kojim freqvama ti testiraš, pa da probam i ja, pa ćemo usporedit. Da li se isplati zajebavat sa tim latencijama.
Nemam više lema!!!
Staro 21.07.2004., 13:16   #28
Jelc
Super Moderators
Postovi: 17,485
Ja sam neke stvari mjenjao sa BiosEdit 2.5 verzijom.
Sa njim mjenjaš i id i SubSys itd...
Imam sa 432/368 oko 6618
http://service.futuremark.com/servle...jectId=2761671
S tim da sam mjenjao ploču i nisam radio re-instal OS-a
Sa čistim OS-om i procom na 2500 kak ga inače držim bilo bi nekaj više...
Sve razmišljam da konačno skinem onu tvorničku žvaku ili kaj je već gore, stavim Dr.Thermala pa da vidim do koliko ide GPU...
Staro 21.07.2004., 13:44   #29
LorD ClockaN
od LemilicE
Postovi: 4,712
E kad bi barem meni radio na 400 bez artefakata i to još sa Artic-Sinencerom.
Kad sam kupovao SE, nisam znao da se i NP može modat u PRO, a kamoli u XT.
Drugi put neću kupovat ćim izađe
Nemam više lema!!!
Staro 21.07.2004., 14:00   #30
Jelc
Super Moderators
Postovi: 17,485
Pa probaj sa onim orginalnim Powercolor.9800XT.128MB.Samsung.E-Die, nemoj ništa dirati latencije, samo ga sflashaj.
Eventualno mu promijeni takt na Pro frekve.
Probaj sa onim BiosEditom 2.5 ili novijim ili sa RadEdit-om.
Dobro je prije flasha pobrisati drivere i očistiti smeće od starih.
