Staro 16.07.2004., 10:05   #1
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,964
Exclamation Divix 5.2
DivX 5.2
Support for three new languages
DivX 5.2 is available in English, French, German, and Japanese.
DivX User Guide
Full 120 Page illustrated User Guide, updated for DivX 5.2, including Quick-Start Guide. Localized versions (French, German, Japanese) will follow shortly - stay tuned!
How-to Guides
Learn how to encode DivX video using a variety of software products, including VirtualDub, Adobe Premiere, Pinnacle Studio, and Ulead Video Studio. More to follow...
Encoder: New Fast mode
A new Fast mode has been added to the encoder that lays around half-way between Fastest and Standard mode in terms of performance, but virtually matches Standard mode in terms of quality and compression. It is now possible to encode live capture directly to DivX without huge file sizes! Click here to read how Performance/Quality mappings have changed.
Encoder: Fix for Fastest mode
Fastest mode now better respects the encoder rate control, so files more closely match the average bitrate you specify. This also means that Fastest mode now produced DivX Certified-conformant video. Note that Fastest mode requires a very high bitrate to achieve good quality. To obtain the DivX 5.1 behavior for this mode, disable DivX Certified Profiles and select 1-Pass, Quality-based mode with Quantizer=3
Encoder: Bitrate Calculator
You can now calculate the bitrate you need to hit a target file size directly within the encoder configuration dialogue. Simply enter your target file size, the length of your video, and the audio bitrate. The bitrate calculator will enter the correct bitrate for you!
Encoder: Intel SSE3 (Prescott) Optimizations
The DivX 5.2 encoder features optimizations for Intel Prescott CPU's, improving performance by up to 15%.
Decoder: Generic MPEG-4
The DivX 5.1 encoder included a Generic MPEG-4 decoding option. In this release we have improved our generic MPEG-4 support so that your favorite decoder can play more of your favorite movies.
Decoder: Blocking fix (Oops!)
The 5.2 decoder corrects a small issue that can cause blocks to be displayed along high-contrast edges in the picture, mainly affecting anime content. Watch Pokémon as it was meant to be viewed once again!
Handheld Profile update
The handheld profile has been updated to better reflect the capabilities of DivX Certified devices already present in the consumer marketplace. By encoding with the new Handheld profile you can create higher quality video for your Handheld Certified device.
Staro 18.07.2004., 12:04   #2
miato
(°_°)
miato's Avatar
Postovi: 3,249
vec ga skidam
Staro 18.07.2004., 12:31   #3
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,964
Već ga isprobavam Bumo vidjeli, ali za sada obečava. Popravili su brzinu dodali neke fore iz Xvida i tak.
Staro 18.07.2004., 14:03   #4
BrunoZG
Junior Member
BrunoZG's Avatar
Datum registracije: May 2003
Postovi: 3,205
Aj probajte al sumnjam da se to moze mjerit i sa najstarijim xvid-om
AMD 3800+x2@2500, 1,375V
MB-ASROCK DUAL SATA(bios 2.2) 2+ENERMAX485W
2x512 Supertalent CL2
HDD-Hitachi 160GB, WD 800JB
ELSA 7600GT
Leadtek-2000XP expert
DVDROM-LITEON-167T ,DVDRW BENQ 1650,DVDRW NEC ND2500A@2510_fw205C
Monitor: Samsung 997MB (19')
Terratec Sky 5.1,EPSON-C42
BrunoZG je offline   Reply With Quote
