Staro 19.02.2009., 23:27   #1
mante
Datum registracije: May 2005
Postovi: 176
Recovery konzola, copy e:\i386\ntldr c:\ problem ??
Brat mi je ugradio još jedan HD u comp i od tada svaki puta u toku podizanja wondowsa (xp) dolazi poruka: "NTDLR is missing, please insert CD restart itd...." te nakon toga moram uči u Bios i odabrati HD kao first boot device.i nakon toga windowsi se normalno podignu.
Googlao sam i našao ove upute:
Insert the Windows XP bootable CD into the computer.
When prompted to press any key to boot from the CD, press any key.
Once in the Windows XP setup menu press the "R" key to repair Windows.
Log into your Windows installation by pressing the "1" key and pressing enter.
You will then be prompted for your administrator password, enter that password.
Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
copy e:\i386\ntdetect.com c:\
Sve sam radio prema uputama i nakon upisivanja copy e:\i386\ntldr c:\ ispiše mi poruku: "access is denied".
Zna li ko u čemu je problem.
mante je offline   Reply With Quote
Staro 19.02.2009., 23:40   #2
Milentije
Adrenaline junkie
Milentije's Avatar
Lokacija: Doboj - Banja Luka
Postovi: 3,598
Jesi li siguran da ti CD-ROM ima oznaku E:?
Lenovo Legion Pro 5 - AMD Ryzen 7 7745HX, 32GB RAM, 1TB SSD, nVidia RTX4060 8GB, 16" 2560x1600 IPS
Staro 19.02.2009., 23:47   #3
mante
Postovi: 176
Autor Milentije Pregled postova
Sto posto, provjereno je E:
Staro 20.02.2009., 00:01   #4
thopok
Lokacija: Splity
Postovi: 3,003
Valjda nije (dobro) podešen prioritet diskova…?
Tu valjda "krivi" disk ima prioritet.
našao ove upute
To u ovom slučaju, čini se, nije potrebno.
Staro 20.02.2009., 08:29   #5
mante
Postovi: 176
Ok ali šta mi savjetuješ da uradim sad.
Staro 20.02.2009., 08:32   #6
Matt
Matt's Avatar
Lokacija: Zabok
Postovi: 1,622
Pa da provjeriš koji HD ti je prioritetni disk. Ukoliko je to disk na kojem nemaš instaliran XP, promjeni prioritet na HD na kojem je instaliran XP.
Svi elektronički uređaji rade na bijeli dim!
Kad dim izađe uređaj više ne radi!!!
Matt je offline   Reply With Quote
Staro 20.02.2009., 22:18   #7
zippo
herr Flick
zippo's Avatar
Postovi: 2,085
Koji HD, IDE ili SATA ?
Pomoglo bi kad bis upisao nesto pod Moj komp
Ako je IDE provjeri jumpere
.:S:T:A:L:K:E:R:.. :2 u ocekivanju
nema vise zippacha ......
zippo je offline   Reply With Quote
