Staro 10.02.2009., 16:23   #1
Gustavo
Lokacija: Sisak
Postovi: 358
Kako dodati memoriju
Imam problem s dodavanjem memorije na matičnoj,na drugom slotu kad stavim karticu ne podiže mi računalo,ostaje crn ekran,na prvom slotu rade obje kartice,a na drugom nijedna,ploča je ASUS K8V-MX.
> Physical Memory : 256 MB
>> General Information
DIMM0 (RAS 0, RAS 1) : 256 (Single Bank)
DIMM1 : Empty
>> Information SPD EEPROM (DIMM0)
Manufacturer : Kingmax Semiconductor
Part Number : MPWB62D-38KT3-FHA
Serial Number : Unspecified
Type : DDR-SDRAM PC3200 (200 MHz) - [DDR-400]
Size : 256 MB (1 rows, 4 banks)
Module Buffered : No
Module Registered : No
Width : 64-bit
Error Correction Capability : No
Max. Burst Length : 8
Refresh : Reduced (.5x)7.8 µs, Self Refresh
Voltage : SSTL 2.5v
Manufacture : Week 0 of 2004
Supported Frequencies : 133 MHz, 200 MHz
CAS Latency (tCL) : 2 clocks @133 MHz, 2.5 clocks @200 MHz
RAS to CAS (tRCD) : 3 clocks @133 MHz, 4 clocks @200 MHz
RAS Precharge (tRP) : 3 clocks @133 MHz, 4 clocks @200 MHz
Cycle Time (tRAS) : 6 clocks @133 MHz, 8 clocks @200 MHz
>> Memory Controller Information
Memory Controller : SIMM, DIMM, SDRAM
Number of connectors : 2
Max. Module Size : 1024 MB
Max. Memory Size : 2048 MB
Supported Speed : 70ns, 60ns, 50ns
Supported Voltages : 2.9v
Error Detection Method : 64-bit ECC
Error Correction Capability : Unspecified
Current/Supported Interleave : 1-way/1-way
Zadnje izmijenjeno od: domy_os. 10.02.2009. u 22:32.
Gustavo je offline   Reply With Quote
Staro 10.02.2009., 17:54   #2
domis
Lokacija: Hrvatistan
Postovi: 4,165
mozda je jedan memorijski kanal odapel papke
Staro 10.02.2009., 18:55   #3
thopok
Lokacija: Splity
Postovi: 3,003
Staro 10.02.2009., 23:21   #4
Gustavo
Lokacija: Sisak
Postovi: 358
Autor thopok Pregled postova
Ništa tu ne vidim što bi mi pomoglo,čudi me da nijedna memorijska kartica ne radi na drugom slotu.
