Staro 25.04.2008., 15:08   #1
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
Prime95
Nova verzija Prime95 ne donosi nista novo naspram 25.5 verzije no ipak su ispravljeni neki bugovi...
Changelog:
  • Bug in SSE2 trial factoring above 2^64 fixed.
  • Client-server getting out-of-sync in exchanging program options fixed.
  • Endless communication loop on Error 40 fixed.
Windows 32-bit - Download
Linux - Download
Linux 64-bit - Download
Windows 64-bit - Download
Mac OS X - Download
Staro 24.11.2008., 16:08   #2
stasio
stasio's Avatar
Lokacija: Malaysia
Postovi: 96
Prime95v.25.8
Prime95v.25.8 build 1 (32-bit)
1) Bug fixed in smart affinity on hyperthreaded CPUs.
2) Bug fixed in setting a thread priority other than 1.
3) Off-by-one-bit bug fixed in the benchmarking of trial factoring.
Need a Gigabyte latest BIOS?
GA-P67A-UD7 (B3-F3h), Core i7-2600K @ 5.1 GHz
G.Skill F3-17600CL8D-4GBPS @ 2133 (8-9-8-24-CR2)
G.Skill F3-17000CL8D-4GBXMD @ 2133 (7-9-7-20-CR1)
Evga GTS 450SC,WD Caviar Black SATA3 1TB HDD,
Corsair Hydro-H50 (MX-2)
Gigabyte Superb 720W,Windows 7 SP1
stasio je offline   Reply With Quote
Staro 14.12.2008., 12:48   #3
stasio
stasio's Avatar
Lokacija: Malaysia
Postovi: 96
Prime95v.25.8 build 3 (32bit)
Prime95v.25.8 build 3 (64bit)
4) In rare case an infinite loop could occur when the computer ID
in the spool file did not match the current computer ID.
5) The "days between checkin" value now has a range of 1 to 7 days.
In version 24, the range was 1 to 60 days with a default of 28 days.
6) Fixed bug where switching users on a Windows machine caused computer
GUIDs to be erroneously regenerated. You may need to suffer through
one more regenerated GUID before the fix takes effect.
7) A bug where some low memory situations on a multi-core machine resulted
in one or more worker threads sat idle has been fixed.
8) A crash bug doing 61 and 62 bit trial factoring on P
Staro 23.12.2008., 05:38   #4
stasio
stasio's Avatar
Lokacija: Malaysia
Postovi: 96
Staro 15.01.2009., 15:29   #5
stasio
stasio's Avatar
Lokacija: Malaysia
Postovi: 96
Staro 23.02.2009., 18:17   #6
stasio
stasio's Avatar
Lokacija: Malaysia
Postovi: 96
Staro 06.07.2009., 08:02   #7
stasio
stasio's Avatar
Lokacija: Malaysia
Postovi: 96
Staro 14.07.2009., 03:25   #8
stasio
stasio's Avatar
Lokacija: Malaysia
Postovi: 96
Staro 18.04.2010., 17:08   #9
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,531
Prime95
Ovak, stavio sam prime95 da provjerim stabilnost novog kompa, i odmah na početku torture testa (blend test) dobim slijedeće za worker 1,2,3
http://slike.hr/slike/p/prime95_cbcde.jpg
zanima me sad, pošto sam prvi puta pokretao prime95 i neznam ubiti što znači ovo ''worker stopped'' pa ako mi netko stručniji može reći dal je sve u redu, ili nije
konfiguracija sastrane
Staro 18.04.2010., 17:48   #10
dejanbinladen
konjpjukter
Postovi: 934
nije
dejanbinladen je offline   Reply With Quote
Staro 18.04.2010., 17:54   #11
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,531
ok, u čemu je problem, nešto neispravno ili što?
edit: nakon restarta kompa, pokrenuo sam opet prime i sad već pola sata nije našao nikakav error ni na jednoj jezgri, ne kužim ali eto :S
ipak je na prvom našao
http://slike.hr/slike/p/prime95a_1e5c8.jpg
Zadnje izmijenjeno od: mamutarka. 18.04.2010. u 18:20.
Staro 18.04.2010., 23:20   #12
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,531
nakon 4 sata prime-a 2 jezgre javljaju error, dve su ok... sad moram reklamirat izgleda
Staro 19.04.2010., 09:44   #13
Codiac
bycod
Codiac's Avatar
Lokacija: Zagreb / Dubrava
Postovi: 6,699
a glle ako ti komp radi normalno u svakodnevnim aplikacijama onda zaboravi na prime. primjera radi dok sam imao amd-a (prije cca 5god) on nije prolazio prime duze od sat vremena nikad, ali se nikad nije srusio ili nesto takvog.
.i.
Razer Blade 15
Staro 19.04.2010., 09:54   #14
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Autor M4mut Pregled postova
Prime nije vjerodostojan "alat" s kojim se dokazuje ispravnost procesora, kao i Vlatka Pokos Mark za grafičke kartice.
Procesor može biti satima stabilan u prajmanju i onda ti rukne kod kodiranja audia u mpeg2 konverziji...imao isti slučaj sa jednim P4 prije dosta godina.
Staro 19.04.2010., 12:13   #15
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,531
hvala na odgovrima, sinoć prije spavanja stavio prime i nakon cca 7 sati nije javio nikakav error
čudno da nekad prođe, a nekad ne :S
Staro 19.04.2010., 21:05   #16
alengrosevic
alengrosevic's Avatar
Postovi: 3,791
meni da ne radi prime95 ok, tj da mi nalazi errore, ja bih se zabrinuo. jer platio sam proc koji mora biti 100% ispravan, a ne samo na svakodnevnim aplikacijama. sto ako cu htjet za mjesec dva pokrenut neku specificnu aplikaciju pa mi pocne smrzavati komp ili bacati bluescreen?!
@m4mut: provjeri napajanje, da nije ono krivo za takvo ponasanje...
Staro 19.04.2010., 21:08   #17
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,531
napisao sam iznad, otkad sam updejtao bios prime radi 7+ sati u komadu bez errora
Staro 24.06.2010., 14:23   #18
stasio
stasio's Avatar
Lokacija: Malaysia
Postovi: 96
Prime95v.26.1 build 1(32bit)
ftp://mersenne.org/gimps/test_v26_32.zip
Prime95v.26.1 build 1(64bit)
ftp://mersenne.org/gimps/test_v26_64.zip
Test version.
Staro 15.09.2010., 07:27   #19
stasio
stasio's Avatar
Lokacija: Malaysia
Postovi: 96
Prime95v.26.2 build 1(32bit)
ftp://mersenne.org/gimps/p95v262.zip
Prime95v.26.2 build 1(64bit)
ftp://mersenne.org/gimps/p64v262.zip
From the included whatsnew.txt file:
1) Faster FFTs for most SSE2-capable CPU architectures.
2) More FFT lengths supported.
3) Some of the new, faster FFTs don't let us do as much error checking on each iteration.
If you don't want to lose this error checking, choose "SUM(INPUTS) error checking" from
the Options menu. This will slow down your tests by about 2-5%.
4) When a possible hardware error occurs during a test, the error message would
likely scroll off the screen unnoticed. Now, all future progress updates to
the screen will be followed by a message containing a count of the errors that
have occurred during the test.
5) Worker Windows now stagger their starts. This improves timings for some
CPUs and operating systems. See undoc.txt to control this feature.
Staro 15.09.2010., 12:06   #20
sinisa1989
Bazinga
sinisa1989's Avatar
Lokacija: Križevci
Postovi: 3,933
Jel ima neko problema sa skidanjem 64-bitne verzije? Dođe mi do 45% i dalje neće.
sinisa1989 je online   Reply With Quote
Staro 15.09.2010., 12:08   #21
Viperus
Viperus's Avatar
Postovi: 729
Šta ljudi ovo još uvjek koriste lol? Intel burn test v2.3 i gotovo XD
Viperus je offline   Reply With Quote
Staro 15.09.2010., 12:44   #22
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
Šta fali Primeu? Još uvijek jedan od najpouzdanijih i najboljih burn programa uz LinX.
@sinisa1989
Nemam tih problema, skida normalno obje verzije.
Staro 24.01.2011., 12:09   #23
mack666
mack666's Avatar
Datum registracije: Jan 2011
Postovi: 18
Prime95 - prvi susret
Eto nakon što sam sastavil napokon komp, skinul sam sa neta prime95 i pokrenul test i asrock oc tuner da vidim temeprature. E sad pročital sam malo po netu i otprilike skužil kak to radi, ali eto molim malu pomoć da me upoznate sa time, kako to ide i sve ostalo.
evo jedna slika, dakle sve je stock, sad neznam dal su t oke temperature ili?
mack666 je offline   Reply With Quote
Staro 24.01.2011., 12:20   #24
pročital si malo po netu, ali nisi pročital po forumu u koju temu da to strpaš ?
ako to piše 45°C, onda je OK. nego, koji ti to test koristiš, nadam se da nije Blend.
Staro 24.01.2011., 12:24   #25
mack666
mack666's Avatar
Postovi: 18
da piše 45, ne nije blend nego je onaj prvi gore koji kao anjviše opterećuje procesor. i sad sam skinul CPU-Z i zanima me jedna stvar, tako je i u biosima, ram je G.Skill Ripyaws 1333mHz a ovdje mi piše da kuca na 667mHz
http://valid.canardpc.com/show_oc.php?id=1615395
isto i za grafičku da je core na 399mHz, je to oke, ili sam ja očito neš krivo napravil?
Staro 24.01.2011., 12:43   #26
Autor mack666 Pregled postova
sve je to OK, i više nego OK. 667 x 2 je ~ 1333 MHz, tako da taj broj koji ti izbaci CPU-Z, uvijek množi sa 2.
Staro 24.01.2011., 12:58   #27
mack666
mack666's Avatar
Postovi: 18
oke, zahvaljujem na informacija, sad me samo još zanima onaj OC tab koji je u biosima, tj. mogu clockati cpu i grafiku po postocima u koracima od 5%, dakle mogu svaki put za 5% dignuti i onda porenem prime95 na nekoliko sati da vidim jeli sve oke?
Staro 11.02.2011., 09:42   #28
stasio
stasio's Avatar
Lokacija: Malaysia
Postovi: 96
Prime95 v26.5 Build 2
ftp://mersenne.org/gimps/p95v265.zip
ftp://mersenne.org/gimps/p64v265.zip
1) Minor bug fixes.
2) Starting in build 2, P-1 work will display the chance of finding a factor.
The worktodo.txt line must include how_far_factored using the new syntax:
Pminus1=k,b,n,c,B1,B2[,how_far_factored][,B2_start][,"factors"]
Staro 19.02.2011., 04:06   #29
stasio
stasio's Avatar
Lokacija: Malaysia
Postovi: 96
Prime95 v26.5 Build 3
Starting with build 3, at startup the program tries to determine which
hyperthreaded logical CPUs comprise one physical CPU. If this isn't working
properly, see the AffinityScramble2 setting in undoc.txt. The previous
version's AffinityScramble setting is no longer supported!
