Staro 08.03.2007., 11:34   #151
Tetedeiench
Lokacija: Lille, France
Postovi: 44
Hey guys
1.1.1.b02 is out there
Core Temp support added !
http://www.ocbase.com/OpenBeta/OCCTPT1.1.1.b02.zip
Tetedeiench je offline   Reply With Quote
Staro 08.03.2007., 11:56   #152
Matijac
Matijac's Avatar
Postovi: 872
Tek sam sad videl ovaj thread, baš je super kaj je prevedeno na hrvatski.
Staro 06.10.2007., 17:50   #153
Tetedeiench
Postovi: 44
Hey guys
Been a while I've been really busy (new job + appartment + girlfriend... sigh), but i had enough time to cook something new for you
OCCT PT 1.1.1 official has been released
Among new features : Core temp support, Vista64 support (signed driver), much better everest support (display sensor names in list, much more stable...), new RAM mode, OCCT plays a sound when it detects an error, it's faster to stop a test...
Phew
I had only 2 new words to translate (Miscellaneous and sound) into croatian so i used a dictionnary... tell me if it is wrong, i'll correct it
You can get OCCT PT 1.1.1 over here, as usual : www.ocbase.com
Direct link :
www.ocbase.com/download.php?fileext=exe - EXE file
www.ocbase.com/download.php?fileext=zip - ZIP file
Thanks for your support guys !
Staro 06.10.2007., 19:41   #154
T0mB1ll
420
T0mB1ll's Avatar
Lokacija: Le Molve
Postovi: 1,577
nice work Tetedeiench..
Miscellaneous = "raznovrstan" or in your case it can be "Ostalo" but I think is't better "Ostalo"
sound = "zvuk"
T0mB1ll je offline   Reply With Quote
Staro 16.10.2007., 18:16   #155
domy_os
domy_os's Avatar
Postovi: 19,088
Yes, I agree, "Zvuk i ostalo" will be OK.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 14.03.2008., 16:59   #156
Tetedeiench
Postovi: 44
Hello guys !
It's been a while... but i haven't stopped working on OCCT
OCCT PT 2.0.0 as released today. It has alot of new features (as the "2.0.0" indicates), but among them, you'll notice :
* New tests (more effective !)
* Integrated monitoring : OCCT is now using the HWMonitor engine ! No need to install anything, OCCT has it built-in
* CPU-Z engine support
* Better graphs (scales are easier to read...)
And much more
As usual, go to http://www.ocbase.com/perestroika_en/ for the full changelog and the download link.
If you're lazy, just click here : http://www.ocbase.com/download.php?fileext=exe
And of course, most language files, including yours, were updated (thanks domi_os ! )
Staro 14.03.2008., 17:52   #157
nino
nino's Avatar
Postovi: 12,613
Thanks buddy, gj!
Staro 15.03.2008., 12:42   #158
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
Very good job Tetedeiench , Croatian language is perfectlly translated
new options are very good. best version of occt, of course
Bullet1 je online   Reply With Quote
Staro 15.03.2008., 13:13   #159
Vuco
Vuco's Avatar
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
Nice job
Staro 15.03.2008., 14:18   #160
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Hello... Wanted to leave a comment.
Just one thing... For the new Wolfdale processors (E8200, E8400, E8500) OCCT doesn't show good temperatures. It's often 10C higher...
Take a look:
Staro 15.03.2008., 14:46   #161
Vuco
Vuco's Avatar
Postovi: 9,505
To ti je jer koristiš Real Temp. On naprema drugima (Core Temp i ostali) daje ili 5/10°C manje temperature, ovisno, koliko sam skužio o Tjunction-u.
Staro 15.03.2008., 14:48   #162
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Autor Vuco Pregled postova
Al on ima jedini realne temperature oko Woldfalea...
Kolko sam čuo.
Staro 15.03.2008., 14:59   #163
Vuco
Vuco's Avatar
Postovi: 9,505
A napiši onda to čovjeku. Nek pogleda thread na XS-u za Real Temp, pa ako može da popravi onda očitavanja temperaturi. Vjerojatno ne znam za Real temp, jer program nije dugo vani.
Tetedeiench, look at this link below. It shows how temperatures for Intel processors can be wrong with CoreTemp, or similar programmes (which have, as he confirmed with a IR thermometer, wrong TJ max temperature set). On AMD CPUs, everything is OK.
Real temp - for Intel processors @ XS
Staro 15.03.2008., 16:14   #164
BladeRunner
Type R
BladeRunner's Avatar
Postovi: 1,485
Just wanted to say great job man; best version of OCCT, temp readings are ok, voltages too, except for 12V, but thats my MB sensor sucky.
Isprika na dva posta, al tek sam sad vidio. Inače gledam s Core Tempom i sad probam ovaj Real Temp i vidim da on pokazuje 5C manje.. Njemu je Tjunction 95, dok je kod Core Tempa 100C. I sad kome vjerovati?
David linčujem Davida Finčera
BladeRunner je offline   Reply With Quote
Staro 15.03.2008., 17:20   #165
Vuco
Vuco's Avatar
Postovi: 9,505
Navodno Real Temp jer taj Tjunction je max. temp, pri kojoj se procesor pregrije i ugasi (a s time i sve ostalo). Čovjek (tvorac Real Temp-a) je mjerio sa Infracrvenim termometrom i dobio da je na nekim procesorima Tjunction manji za 5°C, negdje 10°C.
Upitno je, način mjerenja temperature. Točnije, što je on mjerio sa IR termometrom (a što zapisao kao Tjunction). Gađao je IHS, a po nekim zakonima, jezgra koja predaje toplinu IHS-u, bi morala biti ipak toplija od njega samoga. Jel to 5°C ili 10°C, nitko nezna, no oboje je moguće.
Staro 16.03.2008., 17:15   #166
DeadMan+
LateralusX
DeadMan+'s Avatar
Postovi: 1,788
mali update:
OCCT Perestroïka 2.0.0a
MONITORING
* BugFixs : Now OCCT properly detect all 4 cores temperatures on some quad-cores CPU, and OCCT properly detects CPUs in Vista (some were problematic)
* OCCT now supports ACPI Sensors and HDD Sensors (SMART)
TRANSLATION
The "default.po" file used for translation is usable again - it was corrupted in the previous release
DeadMan+ je offline   Reply With Quote
Staro 20.03.2008., 09:37   #167
Tetedeiench
Postovi: 44
Yep, seems that Intel is messing up with TJunction these days.
For people complaining with the +15°C, seems that M0 are reported accuratly by OCCT, one of my beta tester tested it in a very simple way : he swapped a "non M0" with a "M0" stepping, with the very same cooling system. And it seems that only HWmonitor, and thus OCCT, didn't show an exact 15°C difference between the 2 CPU's...
Staro 20.03.2008., 09:53   #168
zippo
herr Flick
zippo's Avatar
Postovi: 2,085
Thanks buddy, nice job
@edit
naravno i nasim deckima koji su prevodili
.:S:T:A:L:K:E:R:.. :2 u ocekivanju
nema vise zippacha ......
Zadnje izmijenjeno od: zippo. 20.03.2008. u 10:42.
zippo je offline   Reply With Quote
Staro 20.03.2008., 10:19   #169
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Autor BladeRunner Pregled postova
Sve ti je objasnjeno na onoj temi...
Ukratko, oba su uglavnom malo nagađanje, ali ovaj tip je mjerio IC senzorom, pa... Uglavnom, teško mi je vjerovat da su temp 42C u idleu, baš kao E6300 naklokan...
Staro 02.04.2008., 15:07   #170
Neo-ST
Neo-ST's Avatar
Postovi: 8,828
Great application!
I especially like the part with graphs
But tell me, will those graphs be available if system freezes during the stress test?
Staro 28.04.2008., 12:06   #171
mskvorc1
mskvorc1's Avatar
Postovi: 288
Question OCCT 2.0.0a Problem
Kada pokrenem OCCT 2.0.0a javlja mi se sljedeća poruka:
Preveo sam sa francuskog na engleski i to znači:
operation float point invalid
I kada stisnem OK, pojavi mi se ovakav OCCT:
A verzija 1.1.1b radi bez problema. Pomognite ljudi. Komp mi normalno radi, nema nikada nikakvig grešaka ni slično, nakon 12h Dual Primea. Da li da pogledam ako u BIOS-u kakva opcija nije uključena ili isključena?
Mod: slike veće od 50kb, u thumbnail
Zadnje izmijenjeno od: Razer. 28.04.2008. u 13:15.
mskvorc1 je offline   Reply With Quote
Staro 09.07.2008., 00:06   #172
Mr.Ex.President
Torrent freek
Mr.Ex.President's Avatar
Postovi: 3,958
Meni radi 2.0.0 bez ikakvog problema, ali mi stalno isključuje testiranje u 3 sekundi (odma nakon one minute nadziranja) sa errorom procesor prevruć?
CPU - 43
CPU#1 - 51
CPU#2 -52
To su izmjerenetemperature, ako je to prevruće onda u k
Inače u opcija je uredno postavljena najviša temp od 70
I da, senzori su ok
MBO: MSI B450 Gaming Plus
PSU: Corsair RM550X 550W
Periferija
LCD: HP ZR24w
Mouse: Logitech G400
Sound: Genius SP-HF1201A
Printer: HP LaserJet 1020
Scanner: HP ScanJet 4300
Headphones: Philips SHC 2000
MBO: Gigabyte GA-F2A85XM-HD3
HDD: WD Green 2TB [WD20EZRX]
PSU: Antec SU380
TV: Samsung 43E450 @HDMI
LINK
Staro 13.09.2008., 01:34   #173
Vuco
Vuco's Avatar
Postovi: 9,505
New version OCCT adds GPU Stability Test
Upozorenje, to jest beta verzija. Neki napominju (kao i u linku niže) da je čak jači od, u zadnje razvikanog FurMarka. Neki vele da imaju iste temperature.
Uglavnom, ako želite probati - link na beta verziju. Neke slike sa usporedbom sa FurMarkom 1.4 možete naći na ovom linku (Madshrimps)
Staro 13.10.2008., 18:23   #174
DeadMan+
LateralusX
DeadMan+'s Avatar
Postovi: 1,788
OCCT Perestroïka 2.0.1 available
Code:
Changelog :
MONITORING
    * Core i7 support added
    * Some temps were displayed with a higher value than reality
GRAPHS
    * CPU frequency is now correct in the graphs
Download
Staro 23.11.2008., 19:51   #175
Vuco
Vuco's Avatar
Postovi: 9,505
Na XS-u je Tetedeiench objavio vijest da je verzija 3 u razvoju i trenutno je dostupna beta
Pa, tko želi probati -> XS news - OCCT Perestroika 3.0.0.b05 released
Slika kako će to izgledati u trojci:
Što je novo:
Code:
OCCT PT 3.0.0.beta !
What's new ?
5 Tests
    * CPU OCCT : The classical OCCT CPU tests. The modes "CPU, RAM, and Mix" have been renamed to match more closely their roles to "Low, Medium and Large data sets".
    * Linpack : The very same test that Intel Burn Test, based on an Intel library, that will make your CPU hotter than never before.
    * GPU 3D : OCCT GPU, a home-made 3d program that will make your GPU hotter than anything else (even furmark), and sports an error-checking mode just as ATITool.
    * GPU Memtest : A GPU memory memtest based on CUDA. Very useful as well, but in practice, it is better at detecting manufacturing errors, and not overclocking errors.
    * Power Supply : This test is actually Linpack combined with OCCT GPU. It aims at loading your power supply, and results shows that it uses 20% more power than Crysis and 25% than 3dmark BEWARE, THIS TEST IS REALLY HARD ON YOUR POWER SUPPLY, IT COULD MELT IT EASILY ! DO NOT USE IT IF YOU HAVE A "NO NAME" POWER SUPPLY !
GUI
    * Brand new GUI, with alot of options added
    * Help panel : just move your mouse
    * Modularity : you can hide/show the Monitoring/Sysinfo/Help parts
Graphs
    * Graphs have been revamped - they'll show the test configuration in the titles (Resolution for the GPU 3D test, etc...)
    * Another line has been added showing the CPU Usage on CPU tests and Power Supply, and the FPS on the 3d test !
Monitoring
    * Engine was updated, should support more cpus
    * Added GPU temperature monitoring and autodetection
    * The CPU Usage displayed is now instantaneous (just as the task manager) instead of the average since the starts of the test - more meaningful, especially since the graphs shows the CPU usage in time.
And many, many things i am probably forgetting.
KNOWN LIMITATIONS
    * The linpack test has a 64 bits mode, but no detection of a 64 bits CPU and OS is actually don. it'll be added later on.
    * The GPU MemTest test is supporting only one Graphic card
    * There's currently no way of launching the 3d test in fullscreen mode. I know this causes some issues on ATI and SLI systems. It'll be resolved later on
    * Translations aren't up to date at all !
Najnovija je 3.0.0.b05 koja ispravlja:
Code:
Features :
    * New Design ! (Thanks LOE)
    * The Linpack test (and thus the Power Supply test) should be compatible with AMD and Intel CPUs
    * You can now choose the 64 bits version of Linpack for the Power Supply test.
Known bugs :
    * Assigning a custom temperatures makes the voltage line disappear. Stop and restart OCCT to get around that
    * Sometimes OCCT detects a wrong # of CPUs. Again, restart OCCT and it should be fine.
Download link na betu:
Direct link
Zadnje izmijenjeno od: Vuco. 23.11.2008. u 20:27. Razlog: Sredio DL link
Staro 23.11.2008., 20:44   #176
Razer
Razer's Avatar
Postovi: 11,642
Vuco se baca u extremne vode Nabavlja i7, lurka po XS-u, dali je to nagovještaj nove konkurencije?
Staro 23.11.2008., 21:22   #177
Vuco
Vuco's Avatar
Postovi: 9,505
Autor Razer Pregled postova
Bez brige momci. S moje strane ne budete imali konkurenciju dok ne završim svoj davno započeti SS
Staro 23.11.2008., 21:48   #178
domy_os
domy_os's Avatar
Postovi: 19,088
Oho, OCCT postaje moćna igračka... Svaka čast Tetedeienchu, čovjek očito ne spava...
Staro 23.11.2008., 22:30   #179
Vuco
Vuco's Avatar
Postovi: 9,505
Znam da je beta, ali može li netko probati OCCT: GPU test ? Mislim, meni se niš ne dešava
Prvo idle-a minuti, onda piše starting i to je to. A brijem da bi mi se trebalo pojaviti onaj donut kao u Furmarku ili slično
Staro 23.11.2008., 22:34   #180
LUXX
Vodenjak :)
LUXX's Avatar
Lokacija: Križevci
Postovi: 667
i ja sam to probal jedno 3 minute i ništa se ne dešava.
Temperature ostaju iste.
Ništa jestivog i dlakavog se ne vrti
LUXX je offline   Reply With Quote
