Staro 09.11.2008., 15:34   #1
domido
Lokacija: Krapina
Postovi: 6
SpeedTouch 780WL(i)
Dobio sam danas navedeni modem pa imam par problema. Ispricavam se unaprijed ako je te tema vec negdje otvorena. Zanima me kako da taj modem spojim s kompom? Putem usb-a ne radi. Sta treba uciniti da proradi. Jer na kompu nemam mreznu karticu.
domido je offline   Reply With Quote
Staro 09.11.2008., 16:31   #2
Codiac
bycod
Codiac's Avatar
Lokacija: Zagreb / Dubrava
Postovi: 6,699
kupi mreznu.
nabavi usb drajvere negdje iako ak se nevaram taj model nema usb prikljucak...
.i.
Razer Blade 15
Staro 09.11.2008., 16:55   #3
thopok
Lokacija: Splity
Postovi: 3,003
T-Com ne daje podršku za USB priključak.
Upute za samoinstalaciju Content Copying: Not Allowed
Zar takvi ne dođu na CD-u?
The first time you connect the Thomson Gateway to your computer through the USB port, you will be prompted for a USB driver as soon as you plug the USB cable into the computer.
You will find the required USB driver software on the Setup CD. The installation is Plug and Play, meaning
that installation requires almost no effort.
The Windows Found New Hardware Wizard may ask your authorization to connect to Windows Update to search for software. If this is the case, select No, not this time and click Next.
Make sure that the Setup CD is inserted, select Install the software automatically (Recommended), and
then click Next.
Zadnje izmijenjeno od: thopok. 09.11.2008. u 17:46.
Staro 09.11.2008., 19:23   #4
pinkskin
pinkskin's Avatar
Lokacija: Daruvar
Postovi: 1,744
imaš drivere na cd-u, ja probo se spojit i preko USB-a i radi
