Staro 17.09.2008., 21:19   #1
Sonic1984
Sonic1984's Avatar
Postovi: 542
Catalyst 8.9
Evo izasli novi driveri, nadam se samo da su bolji od proslih........
http://ati.amd.com/support/driver.HTML
Zadnje izmijenjeno od: Jelc. 17.09.2008. u 21:30.
Sonic1984 je offline   Reply With Quote
Staro 17.09.2008., 21:23   #2
boris87
boris87's Avatar
Lokacija: Žepče
Postovi: 407
ajd nek netko proba na x1950pro...pa se izjasni!
boris87 je offline   Reply With Quote
Staro 17.09.2008., 21:26   #3
Newbie Pro
Zule
Newbie Pro's Avatar
Postovi: 1,993
Autor boris87 Pregled postova
Ne kuzim. Ocito imas pristup netu i iz siga zakljucujem da imas x1950pro. Odvazi se i popij metak za nekog drugog, a ne obrnuto.
Newbie Pro je offline   Reply With Quote
Staro 17.09.2008., 21:27   #4
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
New Features :
Catalyst™ 8.9 introduces the following new features:
• Catalyst™ Control Center: New Display mode support
• OverDrive™ support for QUAD CrossFireX configurations
· OpenGL™ 3.0 extension support
This release of Catalyst™ introduces 1080p @ 50Hz custom mode support for HDTVs for the ATI Radeon HD 4000 Series, ATI Radeon HD 3000 Series, ATI Radeon HD 2000 Series, and ATI Radeon X1000 Series of products. Users can configure their own custom 1080p @ 50Hz modes to best fit their display.
This release of Catalyst™ introduces Overdrive support for QUAD CrossFireX configurations. Users can now over-clock each graphics accelerator’s engine or memory speed when running in QUAD CrossFire configurations using manual controls or the automated auto-tuning utility.
OpenGL™ 3.0 support - Phase 1
This release of Catalyst™ introduces OpenGL™ 3.0 extension support. In upcoming Catalyst™ releases AMD will continue to expand its support for OpenGL 3.0 extensions. The following is a list of supported extensions in Catalyst 8.9:
· ARB_half_float_pixel
· ARB_draw_instanced
· ARB_instanced_arrays
· EXT_texture_compression_3dc
· EXT_texture_compression_rgtc
· EXT_texture_compression_latc
· EXT_texture_shared_exponent
· EXT_depth_buffer_float
· EXT_gpu_shader4
· ARB_map_buffer_range
Resolved Issues for the Windows Vista Operating System :
This section provides information on resolved issues in this release of the ATI Catalyst™ Software Suite for Windows Vista. These include:
· Company of Heroes: Setting the in-game options to maximum levels no longer results in the game exiting to the desktop after the game has completed loading. Further details can be found in topic number 737-32600
· Quake 4: Corruption is no longer noticed during the new game introduction • Playing a Blu-ray DVD title may result in corruption being intermittently noticed when using certain display resolutions such as 1360x768, 1360x1024, or 1600x1200
· DiRT: Setting shadows to ultra quadCF no longer results in a performance drop being noticed. Further details can be found in topic number 737-37320
· Assassins Creed: Brightness and saturation distortion is no longer observed during game play with ForceAA enabled. Further details can be found in topic number 737-37327
· Grid: Enabling CrossFire and starting a new game no longer results in flickering bands being noticed across the display device. Further details can be found in topic number 737-37331
· Jericho: Corruption is no longer noticed when AA is enabled and the in-game option Advanced Smoothing is enabled. Further details can be found in topic number 737-37332
· Age of Conan: Playing the game for a short period of time no longer results in flickering corruption being noticed. Further details can be found in topic number 737-37333
· Enabling BOB de-interlacing no longer results in a green line being noticed on the bottom of the playback window when playing a 1080i clip. Further details can be found in topic number 737-35895
· Playing certain Blu-Ray DVD titles using the Cyberlink player no longer result in color corruption being noticed. This issue may be experienced under the Windows Vista (32 bit version) operating system when using an ATI Radeon™ HD 4870 X2 product
· The Blu-ray DVD movie image no longer fails to rotated when the player window is drag to an extend monitor which rotated 180 degree. Further details can be found in topic number 737-37329
· Switching from h.264 to MPEG2 video titles no longer results in the operating system failing to respond. Further details can be found in topic number 737-37322
· VC1 streams with Interlaced Frame and Slice features no longer results in picture corruption and flicker in VLD sites. Further details can be found in topic number 737-37324
· Playing a DVD title using the Windows Media Player no longer results in the user defined Avivo Video settings failing to be applied. Further details can be found in topic number 737-37317
· Playing a DVD title using the PowerDVD player no longer results in the PowerDVD player failing to respond when DXVA is disabled, closed captioning is enabled and the user is fast forwarding the DVD title anywhere from 4x to 32x. Further details can be found in topic number 737-37328
· Clicking on the seek slider when playing a DVD title using the PowerDVD player no longer results in corruption being noticed on the playback window. Further details can be found in topic number 737-37323
· Resuming from power saving mode on a system with an HDMI TV connected no longer results in the operating system failing to resume. Further details can be found in topic number 737-37318
· Using a hot-key command to switch between an HDMI display device and any other display device no longer fails. Further details can be found in topic number 737-37330
Resolved Issues for the Windows XP Operating System :
This section provides information on resolved issues in this release of the ATI Catalyst™ Software Suite for Windows XP. These include:
· Lord of the Rings: Return of the King: Flickering is no longer noticed when changing chapters
· Stranglehold: Setting the in-game options to 1024x768, and Decals off no longer results in the game failing to respond after a short period of game play
· World in Conflict (DX9): Enabling CrossFire no longer results in flashing corruption and the game intermittently failing to respond. Further details can be found in topic number 737-37341
· Oblivion: Setting the display option to 2048X1536 and AA to either 8x or 16x, while having the in-game options remain at their default values no longer results in the game failing to respond. Further details can be found in topic number 737-37342
· Hellgate London: Enabling AA to 8x, AF to 16x and setting Mipmap Detail Level to High Performance, along with AAA set to Performance no longer results in textures being missing when playing the game 8x. Further details can be found in topic number 737-37343
· Witcher: Game corruption is no longer noticed when setting all of the in-game options to their maximum values and having CrossFire enabled along with AA set to 16x and AF set to 8x. Further details can be found in topic number 737-37344
· Spore: Playing the game in a windowed mode on the secondary display device no longer results in poor performance being noticed when AA is set to 8x. Further details can be found in topic number 737-37345
· Company of Heroes: Opposing Fronts: Enabling CrossFire no longer results in the displays flashing corruption when setting the in game graphics options to off or their lowest settings. Further details can be found in topic number 737-35118
· Age of Conan: The inventory icons may show corruption when playing the game with CrossFire™ enabled. This issue may also be experienced under the Windows Vista operating system as well. Further details can be found in topic number 737-34825
· Catalyst Control Center->Theater Mode->Video Aspect Ratio: The default settings no longer fail to be restored when clicking on the Default button. Further details can be found in topic number 737-37337
· Setting the display mode to 1080p50 and rebooting the system no longer results in the display mode failing to be retained
· Cropped text is no longer noticed when changing the language option and DPI setting from their default values. Further details can be found in topic number 737-37334
· Setting the language option to Polish no longer results in the hot-key Ctrl+alt+C being active resolving issues with Polish keyboards. Further details can be found in topic number 737-37335
· Certain supported languages no longer display cropped text within the Display Options of the Catalyst Control Center. Further details can be found in topic number 737-37336
· Resuming from hibernation mode no longer results in the TV signal failing to be restored. Further details can be found in topic number 737-37338
· Closed captioning no longer fails under the Windows XP and Windows XP Professional x64 Edition operating systems. Further details can be found in topic number 737-37339
· The FM seek function under Windows MCE no longer fails to find radio stations. Further details can be found in topic number 737-37340
Resolved Issues for the Windows XP Professional x64 Edition Operating System
This section provides information on resolved issues in this release of the ATI Catalyst™ Software Suite for Windows XP Professional x64 Edition. These include:
· Momentary screen flicker may intermittently be noticed when launching or exiting a D3D or OpenGL application. This issue may be experienced on systems running the Windows XP Professional x64 Edition operating system and containing an ATI Radeon™ HD 4870 X2 product
Staro 17.09.2008., 21:28   #5
Lihto
The Dark Side of Moon
Lihto's Avatar
Postovi: 3,945
Onaj koji je otvorio temu mogao je lagano ubacit linkove i sve,ne otvori Jelc i ekipa bezveze pa sam jave došli driveri nego stave i linkove i šta rješavaju...
Macbook M1+ LG32UQ85R
iPad 5 White 32gb Wifi
iPhone XR 128gb
Lihto je offline   Reply With Quote
Staro 17.09.2008., 21:37   #6
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Meni svejedno, 8.7 mi rade kao sat i zasad konja koji pobjedjuje ne mijenjam
Staro 17.09.2008., 21:47   #7
Neo-ST
Buying Bitcoin
Neo-ST's Avatar
Postovi: 8,261
Autor Sonic1984 Pregled postova
Preduhitrio si Jelca, sad će bit ljut na tebe
Staro 17.09.2008., 21:55   #8
TemplarLord
TemplarLord's Avatar
Lokacija: Bjelovar
Postovi: 47
Još uvijek nije riješen problem sa X16xx i X19xx grafama sa uključenim DoF u Mass Effectu... Therefore, nema razloga da se mičem sa 8.7 drivera :P
TemplarLord je offline   Reply With Quote
Staro 17.09.2008., 22:16   #9
Neo-ST
Buying Bitcoin
Neo-ST's Avatar
Postovi: 8,261
Autor TemplarLord Pregled postova
Evo, pa poduzmite nešto:
http://ati.supportcenteronline.com/i...D=486&type=web
Staro 17.09.2008., 22:58   #10
joolka
music freak
joolka's Avatar
Lokacija: Sibenik
Postovi: 3,313
...mogli bi vrlo lako doci i 9.0 nakon ovih jer vidim da nepopravlju nista vezano za clear sky a ja imam problem kad ukljucim dx10 u obliku nekakvih crta po ekranu a i warhead je tu tako da ce i tu biti fixanja...uglavnom ne zurite s ovim ako nemorate
LENOVO LEGION 5 Pro Gaming Laptop (AMD Ryzen 7 7745HX,RTX 4060,32gb DDR5,2tb SSD)
Staro 18.09.2008., 08:41   #11
thedream
thedream's Avatar
Lokacija: Zagreb ( Šibenik )
Postovi: 5,458
Ja recimo,LMAO,ne mogu od stavljanja ovih 8.9 drivera više ući u display propertiese u Visti x64,toliko o update-anju drivera.A ništa,format C:
Staro 18.09.2008., 09:47   #12
Sonic1984
Sonic1984's Avatar
Postovi: 542
Autor Dizel Pregled postova
Imas i pravo, ja jos imam te i ne mjenjam ih bar dok nesto drasticno ne naprave bolje....
Staro 18.09.2008., 09:52   #13
sipe
sipe's Avatar
Postovi: 993
Fuck kaj da radim sad? Ti to ozbiljno ili?
sipe je offline   Reply With Quote
Staro 18.09.2008., 10:12   #14
Jelc
Super Moderators
Postovi: 17,485
Od 8.8 su bolji u svakom slučaju
Staro 18.09.2008., 10:29   #15
thedream
thedream's Avatar
Postovi: 5,458
Autor sipe Pregled postova
Meni da,tebi će možda super raditi..sad ne znam kako da to popravim,osim formatom i nova Vista.Ne da se kliknuti jednostavno,neće prihvatiti, tj. otvoriti.
Staro 18.09.2008., 10:31   #16
žile
žile's Avatar
Postovi: 3,074
Kod mene u redu,x64 vista.Počisti ih iz safe moda pa probaj ponovno.
žile je offline   Reply With Quote
Staro 18.09.2008., 11:35   #17
sipe
sipe's Avatar
Postovi: 993
Kod mene isto otvara sve bez problema
Staro 19.09.2008., 18:06   #18
Igorr
Flajing super šiiiip
Igorr's Avatar
Lokacija: Zd -- Zg
Postovi: 1,676
Meni nakon instaliranja 8.9 komp ne zeli uci u windows, pa sam ih morao micati iz safe moda i vratiti 8.7
Naravno prije toga sam uninstalirao 8.7 te sa najnovijim driver sweeperom obrisao ostatke iz safe moda.
3 puta sam probao 3 razlicita downloada (da mi slucajno nebi bilo da sam digao neki defektni primjer) i svako put isto.
Na kraju sam odustao
Ako netko ima neku ideju sto bi mogao biti problem neka vice
Inace komp je ovaj navedeni, a imam xp sa sp3.
5.1.4 setup:
Zvučnici - 2x Arendal 1723 S monitors, 1x 1723 S center, 4x 1961 height, 2x 1961 surround, XTZ 12.17 EDGE
Amps - Marantz Cinema 40 + ROTEL RMB-1585
Igorr je offline   Reply With Quote
Staro 19.09.2008., 18:48   #19
dejanbinladen
konjpjukter
Postovi: 934
vista x64 radi ko sisa
dejanbinladen je offline   Reply With Quote
Staro 19.09.2008., 19:14   #20
DraŽ
DraŽ's Avatar
Lokacija: Petrinja
Postovi: 904
Meni rade super u windows xpSP3 i dosad su mi svi radili 8.7, 8.8, 8.9beta, 8.9.
Jel zna tko gdje mogu skinut program za dekodiranje videa preko graficke (hd4870)?
DraŽ je offline   Reply With Quote
Staro 19.09.2008., 20:13   #21
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Autor žile Pregled postova
Ne zna on ako neki kurac ne zaflasha usput sa svojim super flopijem
Autor DraŽ Pregled postova
Vjerovatno prvo trazi na www.google.com
Autor Jelc Pregled postova
Tebi i verzija 6.0 radi dobro sa X1900AIW na XP SP2
Staro 19.09.2008., 21:10   #22
Jelc
Super Moderators
Postovi: 17,485
Zadnji PowerDVD
Staro 19.09.2008., 21:16   #23
Core2Duo22
Mucki provokator
Core2Duo22's Avatar
Postovi: 299
Radi dobro na x1950gt...napokon više nema BSODova na 32bit visti
Core2Duo22 je offline   Reply With Quote
Staro 19.09.2008., 22:15   #24
stopalo9
stopalo9's Avatar
Postovi: 763
Zadovoljniji sam sa 8.9 verzijom ako gledamo na 8.8 barem po stabilnosti
stopalo9 je offline   Reply With Quote
Staro 20.09.2008., 17:16   #25
Kimi
Kimi's Avatar
Postovi: 652
Opet sranje:cim maknem sadašnje driver,komp se prim pokretnju(znači izabreme account koji želim,sad se automatski pokreće xfire i sl) restarta,bez obrzira odem li ja na full micanje drivera ili samo displeay drivera.
Kimi je offline   Reply With Quote
Staro 20.09.2008., 18:10   #26
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Ne kuzim kako ja nikad nemam problema kod reinstalacije drivera, cak i sad kad imam aktivan CrossFire, uopce ne cistim drivercleanerom i ne brisem stare, nego samo "prelijepim" nove preko starih, a neki ovdje i na single kartici imaju probljemos, nevjerovatno. Koji vi kurac radite sa svojim sistemom kad vam i obicna reinstalacija VGA drivera pravi probleme?!
Staro 20.09.2008., 19:04   #27
Kimi
Kimi's Avatar
Postovi: 652
Ne razumijem tvoj post,zašto onda ne zatovriti cijelu SW/HW prolemi sekciju i napisat: nemojte si sjebat sistem
Sistem nije sjeban,jer da su sjebani ovi driveri nebih imao tako dobre performanse,samo pitam jel ima neka cakica,jer sam do sada ima 4Nvidia kartica,0 atica
Staro 20.09.2008., 20:05   #28
Igorr
Igorr's Avatar
Lokacija: Zd -- Zg
Postovi: 1,676
Ajde ne blebeci gluposti i ne deri se...
Osobno sam promijenio 6-7 nvidia kartica i nesto manje od toga ATI kartica i nikad do sad nisam imao problema pri instaliranju novih drivera.
Sad imam relativno novu instalaciju windowsa na kojoj nemam nikakvih problema i 8.9 mi nedaju da udem u windows sto god da radio...
Tako da ocito moze doci do nekih problema koje smo izazvali sa nekim sitnicama koje nebi smijele smetati ali ocito da smetaju, i tko bi sad shvatio koje su to sitnice...
5.1.4 setup:
Staro 20.09.2008., 21:00   #29
Dizel
3.14zda ®
Dizel's Avatar
Lokacija: Orahovica
Postovi: 8,320
Ma naravno, driveri su krivi
Staro 20.09.2008., 21:14   #30
Jelc
Super Moderators
Postovi: 17,485
Dizel, prestani spamat...
