Staro 02.05.2008., 12:48   #1
guests
Lokacija: croatia
Postovi: 3
vista problem,molm pomoć
nakon instaacije viste sve radi savršeno osim kad je restartam onda mi se pojave sljedeče poruke.....
Zadnje izmijenjeno od: guests. 02.05.2008. u 13:36.
guests je offline   Reply With Quote
Staro 02.05.2008., 12:51   #2
Postovi: 7,568
86KB + 89KB + 85KB u slikama, a samo 50KB je dozvoljeno.
Staro 02.05.2008., 12:51   #3
guests
Lokacija: croatia
Postovi: 3
skuil sam i da mi fali jedan driver kojeg nmrem nigdje pronači pa neznam
ima li to moda veze sa ovim porukama.....
Staro 02.05.2008., 13:00   #4
flajpan
flajpan's Avatar
Lokacija: Zagreb, Centar
Postovi: 1,797
Stavi slike u prvom postu u thumbnail - ovdje ih možeš re-uploadati:
http://img.w3dizajn.net/
Što se tiče problema - google čini čuda. Evo kako je ovaj čovjek riješio problem:
http://www.duxcw.com/yabbse/index.ph...threadid=18960
flajpan je online   Reply With Quote
Staro 02.05.2008., 13:38   #5
guests
Lokacija: croatia
Postovi: 3
hvala flajpan ali nemrem se pohvaliti da sam baš preveč skužil....
malo me engleski baš ne služi tak dobro....
Staro 02.05.2008., 13:46   #6
flajpan
flajpan's Avatar
Postovi: 1,797
Login as administrator (important) and you'll notice you don't get the error. (If you still get the error, the program was probably installed with a user that had limited rights and only that user can run it. This could have happenned in production and it was just never properly tested. In this case, the application will have to be re-installed with the administrator account, unless you know how to manipulate permissions for applications)
Goto start > Right click on MY Computer > Manage
Click plus next to Local users and groups
Click groups
Double click administrators on the right pane
Add the user you are logging in as to the administrators group
Log out and log back in as your user
When you log in as your user, you should now have full rights to read/execute anything on that machine unless something specifically denies it. The application should launch seamlessly and you should no longer get the error.
I also noticed that when changing the account from "Restricted" to "Priviledged" the problem disappeared.
Trebaš tom useru dati administratorske ovlasti - ovo podebljano je postupak.
Staro 02.05.2008., 14:33   #7
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Jedan od najlakših načina za dobiti trajni ban je otvaranje još jednog acc-a nakon bana...a ostalo ti je bilo samo tri dana do prestanka prvog bananka...
