#151 |
Lokacija: Lille, France
Postovi: 44
Hey guys ![]() 1.1.1.b02 is out there ![]() Core Temp support added ! http://www.ocbase.com/OpenBeta/OCCTPT1.1.1.b02.zip |
#153 |
Postovi: 44
Hey guys ![]() Been a while ![]() ![]() OCCT PT 1.1.1 official has been released ![]() Among new features : Core temp support, Vista64 support (signed driver), much better everest support (display sensor names in list, much more stable...), new RAM mode, OCCT plays a sound when it detects an error, it's faster to stop a test... Phew ![]() I had only 2 new words to translate (Miscellaneous and sound) into croatian so i used a dictionnary... tell me if it is wrong, i'll correct it ![]() You can get OCCT PT 1.1.1 over here, as usual : www.ocbase.com Direct link : www.ocbase.com/download.php?fileext=exe - EXE file www.ocbase.com/download.php?fileext=zip - ZIP file Thanks for your support guys ! |
#155 |
Postovi: 18,872
Yes, I agree, "Zvuk i ostalo" will be OK. ![]()
#156 |
Postovi: 44
Hello guys ! It's been a while... but i haven't stopped working on OCCT ![]() OCCT PT 2.0.0 as released today. It has alot of new features (as the "2.0.0" indicates), but among them, you'll notice : * New tests (more effective !) * Integrated monitoring : OCCT is now using the HWMonitor engine ! No need to install anything, OCCT has it built-in * CPU-Z engine support * Better graphs (scales are easier to read...) And much more ![]() As usual, go to http://www.ocbase.com/perestroika_en/ for the full changelog and the download link. If you're lazy, just click here : http://www.ocbase.com/download.php?fileext=exe ![]() And of course, most language files, including yours, were updated (thanks domi_os ! ) |
#157 |
Postovi: 12,613
Thanks buddy, gj! ![]()
#161 |
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
To ti je jer koristiš Real Temp. On naprema drugima (Core Temp i ostali) daje ili 5/10°C manje temperature, ovisno, koliko sam skužio o Tjunction-u.
#162 |
Postovi: 4,707
#163 |
Postovi: 9,505
A napiši onda to čovjeku. Nek pogleda thread na XS-u za Real Temp, pa ako može da popravi onda očitavanja temperaturi. Vjerojatno ne znam za Real temp, jer program nije dugo vani. Tetedeiench, look at this link below. It shows how temperatures for Intel processors can be wrong with CoreTemp, or similar programmes (which have, as he confirmed with a IR thermometer, wrong TJ max temperature set). On AMD CPUs, everything is OK. Real temp - for Intel processors @ XS
#164 | |
Type R
Postovi: 1,485
Just wanted to say great job man; best version of OCCT, temp readings are ok, voltages too, except for 12V, but thats my MB sensor sucky. Citiraj:
David linčujem Davida Finčera |
#165 |
Postovi: 9,505
Navodno Real Temp jer taj Tjunction je max. temp, pri kojoj se procesor pregrije i ugasi (a s time i sve ostalo). Čovjek (tvorac Real Temp-a) je mjerio sa Infracrvenim termometrom i dobio da je na nekim procesorima Tjunction manji za 5°C, negdje 10°C. Upitno je, način mjerenja temperature. Točnije, što je on mjerio sa IR termometrom (a što zapisao kao Tjunction). Gađao je IHS, a po nekim zakonima, jezgra koja predaje toplinu IHS-u, bi morala biti ipak toplija od njega samoga. Jel to 5°C ili 10°C, nitko nezna, no oboje je moguće.
#166 |
LateralusX
Postovi: 1,788
mali update: OCCT Perestroïka 2.0.0a MONITORING * BugFixs : Now OCCT properly detect all 4 cores temperatures on some quad-cores CPU, and OCCT properly detects CPUs in Vista (some were problematic) * OCCT now supports ACPI Sensors and HDD Sensors (SMART) TRANSLATION The "default.po" file used for translation is usable again - it was corrupted in the previous release |
#167 | |
Postovi: 44
For people complaining with the +15°C, seems that M0 are reported accuratly by OCCT, one of my beta tester tested it in a very simple way : he swapped a "non M0" with a "M0" stepping, with the very same cooling system. And it seems that only HWmonitor, and thus OCCT, didn't show an exact 15°C difference between the 2 CPU's... |
#168 |
herr Flick
Postovi: 2,085
Thanks buddy, nice job ![]() @edit naravno i nasim deckima koji su prevodili ![]()
.:S:T:A:L:K:E:R:. ![]() ![]() nema vise zippacha ![]() Zadnje izmijenjeno od: zippo. 20.03.2008. u 09:42. |
#169 | |
Postovi: 4,707
Ukratko, oba su uglavnom malo nagađanje, ali ovaj tip je mjerio IC senzorom, pa... Uglavnom, teško mi je vjerovat da su temp 42C u idleu, baš kao E6300 naklokan... |
#171 |
Postovi: 288
![]() Kada pokrenem OCCT 2.0.0a javlja mi se sljedeća poruka: Preveo sam sa francuskog na engleski i to znači: operation float point invalid I kada stisnem OK, pojavi mi se ovakav OCCT: ![]() A verzija 1.1.1b radi bez problema. Pomognite ljudi. Komp mi normalno radi, nema nikada nikakvig grešaka ni slično, nakon 12h Dual Primea. Da li da pogledam ako u BIOS-u kakva opcija nije uključena ili isključena? Mod: slike veće od 50kb, u thumbnail Zadnje izmijenjeno od: Razer. 28.04.2008. u 12:15. |
#172 | |
Torrent freek
Postovi: 3,947
Meni radi 2.0.0 bez ikakvog problema, ali mi stalno isključuje testiranje u 3 sekundi (odma nakon one minute nadziranja) sa errorom procesor prevruć? Citiraj:
![]() Inače u opcija je uredno postavljena najviša temp od 70 ![]() I da, senzori su ok ![]()
#173 |
Postovi: 9,505
New version OCCT adds GPU Stability Test Upozorenje, to jest beta verzija. Neki napominju (kao i u linku niže) da je čak jači od, u zadnje razvikanog FurMarka. Neki vele da imaju iste temperature. Uglavnom, ako želite probati - link na beta verziju. Neke slike sa usporedbom sa FurMarkom 1.4 možete naći na ovom linku (Madshrimps)
#174 |
LateralusX
Postovi: 1,788
OCCT Perestroïka 2.0.1 available Code:
Changelog : MONITORING * Core i7 support added * Some temps were displayed with a higher value than reality GRAPHS * CPU frequency is now correct in the graphs |
#175 |
Postovi: 9,505
Na XS-u je Tetedeiench objavio vijest da je verzija 3 u razvoju i trenutno je dostupna beta ![]() Pa, tko želi probati -> XS news - OCCT Perestroika 3.0.0.b05 released Slika kako će to izgledati u trojci: ![]() Što je novo: Code:
OCCT PT 3.0.0.beta ! What's new ? 5 Tests * CPU OCCT : The classical OCCT CPU tests. The modes "CPU, RAM, and Mix" have been renamed to match more closely their roles to "Low, Medium and Large data sets". * Linpack : The very same test that Intel Burn Test, based on an Intel library, that will make your CPU hotter than never before. * GPU 3D : OCCT GPU, a home-made 3d program that will make your GPU hotter than anything else (even furmark), and sports an error-checking mode just as ATITool. * GPU Memtest : A GPU memory memtest based on CUDA. Very useful as well, but in practice, it is better at detecting manufacturing errors, and not overclocking errors. * Power Supply : This test is actually Linpack combined with OCCT GPU. It aims at loading your power supply, and results shows that it uses 20% more power than Crysis and 25% than 3dmark BEWARE, THIS TEST IS REALLY HARD ON YOUR POWER SUPPLY, IT COULD MELT IT EASILY ! DO NOT USE IT IF YOU HAVE A "NO NAME" POWER SUPPLY ! GUI * Brand new GUI, with alot of options added * Help panel : just move your mouse * Modularity : you can hide/show the Monitoring/Sysinfo/Help parts Graphs * Graphs have been revamped - they'll show the test configuration in the titles (Resolution for the GPU 3D test, etc...) * Another line has been added showing the CPU Usage on CPU tests and Power Supply, and the FPS on the 3d test ! Monitoring * Engine was updated, should support more cpus * Added GPU temperature monitoring and autodetection * The CPU Usage displayed is now instantaneous (just as the task manager) instead of the average since the starts of the test - more meaningful, especially since the graphs shows the CPU usage in time. And many, many things i am probably forgetting. KNOWN LIMITATIONS * The linpack test has a 64 bits mode, but no detection of a 64 bits CPU and OS is actually don. it'll be added later on. * The GPU MemTest test is supporting only one Graphic card * There's currently no way of launching the 3d test in fullscreen mode. I know this causes some issues on ATI and SLI systems. It'll be resolved later on * Translations aren't up to date at all ! Code:
Features : * New Design ! (Thanks LOE) * The Linpack test (and thus the Power Supply test) should be compatible with AMD and Intel CPUs * You can now choose the 64 bits version of Linpack for the Power Supply test. Known bugs : * Assigning a custom temperatures makes the voltage line disappear. Stop and restart OCCT to get around that * Sometimes OCCT detects a wrong # of CPUs. Again, restart OCCT and it should be fine. Direct link
"Everything with a heartbeat can knock you down" Zadnje izmijenjeno od: Vuco. 23.11.2008. u 19:27. Razlog: Sredio DL link |
#176 |
Postovi: 11,642
Vuco se baca u extremne vode ![]() ![]() |
#177 |
Postovi: 9,505
#178 |
Postovi: 18,872
Oho, OCCT postaje moćna igračka... ![]()
#179 |
Postovi: 9,505
Znam da je beta, ali može li netko probati OCCT: GPU test ? Mislim, meni se niš ne dešava ![]() Prvo idle-a minuti, onda piše starting i to je to. A brijem da bi mi se trebalo pojaviti onaj donut kao u Furmarku ili slično ![]()
#180 | |
Vodenjak :)
Lokacija: Križevci
Postovi: 667
Temperature ostaju iste. Ništa jestivog i dlakavog se ne vrti |
